View Full Version : Tech / Misc
- Main relay problem?
- vtec vtec vtec
- Whats this???
- igniter help
- What page in the helms manual ?
- good/bad idea to run car without header for a few minutes to check for excess fuel/coolant?
- h22 sleeving
- need help keyless door handle on 92 hatch problem
- car starts but dies
- a/c compressor "blowing out" refrigerant. a/c gurus!!! help me please
- endyne vs cusco crank case vent
- Modding stock dizzy cap for external coil
- Quick knock sensor ??????
- Main relay troubles
- HELP! obd2 dx distributor harness too 99 gsr dissy harness.
- 91 Accord LX A/T 120k
- Ignition Timing is jumping 20 degress
- Vehicle Speed Sensor
- trouble torquing down main bolts
- eg cargo cover
- Attempted Hot Wiring Gone Bad - PLEASE HELP!!!
- Comp Cams Rev Kits: How high?
- OBX cams screwed my engine
- Fields or VAFC
- GSR dies when unplugging iacv ?
- valvetrain with skunk2 pro1 cams
- My Car (D16Z2)
- nitrous switches??? electrical
- dc-1 p76 ecu pinout
- Swapped out Mugen ECU for OBD1 p28 and lost power
- idle wierd CEL
- Turn open differential w/ finger??
- Motor bogs on Full Throttle on ITR
- can't get lower control arm onto lower ball joint after swap PLZZ HELP!!
- exhaust help!
- throttle body sticking?
- 310cc Pintle Injectors?
- Ford 68MM T-body upgrade.......
- crower and b16
- help us plan my cuz's build
- Help me understand my new Dial Bore Gauge
- power fc on d16y8?
- Need Help: Bad hesitation problem 94 CX w/ b16a
- Head question
- Vtec wiring ?'
- Fields vtec, air/fuel controller?
- CRX HF alternator fire problem
- Piston Clearance Problem and Question for ls/vtec.
- Gator Stage 3 axles....CV joints clicking and they are new? :/
- HELP! Head Gasket Sludge.
- Taking Tranny Off: Have to take out both axles?
- 00 JRSC SI keeps stalling out
- white smoke underneath car?
- Spark when cranking only
- Radio Bezel
- d15 in 99 civic odb1 harness differ?
- Mitsubishi fuel pump on a honda?
- timing belt cover
- Need help badly plzzz.. engine swap wiring question. plz help a poor lad
- need help asap... 96cx to 00si
- gotta F22A...wanna build it...where's the power going to come from exactly?...
- Will an OBD 1 B16 dizzy work on a OBD1 B18C?
- so is the myth right: always let engine warm up before driving...
- First Post: I'm an idiot. HELP.....ME....Please!!!
- bending clutch hardline?
- fuel rail question?
- Siphoning Gas? '94 Civic
- GSR differential ring gear torque specs...
- How big a problem am I facing?
- Fuel Rail problem need help ASAP
- obd0 wiring diagram
- Rubber Fuel Line
- HELP! engine wont start, emanage fry somting?
- OUCH!!! Dizzy Shock. Any Ideas?
- Front main seal, where are you guys getting them from
- how do i know if this p06 in converted?
- ITR, LS/VTEC
- Anyone have any info on PID controllers?
- o2 simulator in a 6th gen Accord
- 1992 b18a into 89 crx-si problems!!!!!
- No brakes while turning steering wheel
- b16a in a us crx si
- Motorcycle exhaust on a civic???
- eagle rods installation
- ACL bearings for B16 and B18
- Stud Problem
- Speed Pro Electronics
- rebuilding a motor?
- J32A6 swap ideas
- ARP Stud Lubricant Application
- safe to take off valve cover?...
- ls block
- a friends DIY ITB issue
- exhaust flexi joint made out of special material?
- Stud Hole Cleaning
- Brass Fitting impossible to find?
- Just got a valve adjustment, now rich at idle
- VSA Light is on...Acura TL
- anybody know where i can find this ?
- cold air or short ram??
- Distributor King Rotor... what OEM rotor fits?
- Bearing Clearances ACL's on an LS/VTEC Block... Mains
- S2000 Cluster Mod.
- wich clutch cable use???
- WHAT CLUTCH DO I USE?
- ID this K type intake mani....
- Has anyone ever used RXP Gas Kicker?
- Tachometer and Speedometer
- My A/C compressor is smoking !!
- PLEASE HELP obd0 2 obd1 conversion
- Need Help Diagnosing a Problem
- Built ls/vtec how high can i rev it?
- need answer asap. my crankshaft pulley is right on tdc but my camshaft gears are a little off??????
- Horsepower and Torque on dyno graphs
- which belt?
- Cap and rotor for external coil
- E-85 fuel ! 85% ethanol !
- Bought a crap tranny. Worth rebuilding it myself???
- RTV question - is this ok?
- Uberdata P06 ECU = no AC?
- Anyone have any info on this set up?
- Vtec rocker arm question.
- o2 sensor wire colors identification
- Cracked Transmission Housing
- gas mileage/fuel pressure HUGE problem...
- dc jdm 4-1 header or OEM ITR JDM header
- (help) How do I install a clutch
- Pesky fuel leak
- radiator cap?
- NepTune question-
- Drove Through Water, Engine Running rich..... this sucks
- d16 vtec head on d17 block?
- Auto B18B weaker than JDM B18B?
- ELD questions?
- old o2 sensor
- which spark plugs go into which slot of distributor.....
- Engine bottom-end rebuilding in Bay Area?
- 3540 Prop Valve
- AC fan question - can it be replaced with something smaller?
- NATURAL GAS PISTONS
- i need to no what size f22a1 injecters r???asap
- 96 JDM B16 into 99 Ex. OBD2a JDM Distributor wirring -> OBD2b US harness
- Rough IDLE ITR cams in a B16...........
- TDC position timing (error code 8)
- zc cams
- what is the difference between a 90-91 b18a clutch and a 92+ b18 clutch?
- ac on ls block
- K series in ek coupe..need help
- oil filter relocation kit ?
- Confused on what to run with 8psi--fuel pump,regulator??
- Steering Rack Leak, Change seal On Car?
- clutch master cylinder bleeding...need a couple details
- help help help (4rm DSM injector's to stock b16)
- Head polishing...tips or suggestions
- question abt integra Ls..~
- uberdata how to datalogg
- OBD II Code P0132 - O2 Sensor
- issue with 90-91 integra clutch
- About the Secondary O2 Sensor
- chiping my pr3 for lsvtec
- fuel pump going nuts...
- perfect built block for boost
- sleeves or stock block
- No luck with clutch bleeding. Need Guidance!!!
- how much will bottom end hold...
- CODE 21 and CODE 22
- what size are the 12pt bolts holding the flywheel on a b16a?
- Need Help on Gsr Fuel Injection?
- Idle is messing up
- Has anyone heard of anyone having any success with "Force".
- SOHC TIMING: Dropping Head Onto Block -> Initial Timing. HELP D16A6
- WTF....
- What kind of headers???
- Action Clutch
- ZC tune up question?
- hard topic to search for...faint bubbling/clicking sound while excelerating...
- engine no start, but, loud ticking from glove department
- Apexi AVCR2 Questions help
- front main seal install (little spring is being a b**ch)
- WTF Ideling after converting to obd1
- 97' Civic Check Engine Light
- question about exhaust size?
- tranny problems
- auto to manual...
- parts for zc bottom end?
- Brighter Headlights...(Not Sylvania)
- SRS lite will not go off after seat was out???
- 1988 CARBED ACCORD MODS????
- ECU and wiring issues
- What ECU pin-out goes to the CEL? (OBD1)
- JDM GSR vs ITR (jdm/usdm) CAMS
- Turbonetics turbo problem
- Tranny Whining
- how do u know when u backfire?
- Cams and rockers scraped?
- Fresh block, coolant leak. Pics...Help please...
- Problem starting after rebuild of my ITR motor
- Where to get cam caps...
- Removing Caked on Headgasket. How Do you Do It?
- help stripped rear bracket bolt
- fuel pump help
- timing belt
- little black vent under car anyone know what it does?
- Help Vtec Sputters
- GSR mains in LS block, with align bore
- HONDATA or GREDDY E-MANAGE?????
- andanother v tec problem
- BEST COMPANY TO GET RHD CLIPS FROM???
- Boredom Strikes Again
- tranny swap
- sedan window visors install (help)
- P28 or P72 for HONDATA w/ Boost
- How to calculate....
- tech question...need advice/shortcut...
- 2.0Lvtex
- I need help!!!
- almost done changing radiator. HELP AT THE END, bleeding/air pocket/fan problem
- Keeps Blowing horn/brake underhood fuse
- Gasoline stabilizer + 2 yr old gas
- HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
- no fuel tank pressure
- Flowbench-building!
- Running Rich..Help!
- which oil burns the least?
- What are the advantages/disadvantages of non VTEC heads? (P8R head)
- I got an AC question.
- check engine light(obd2) WHAT
- Help me fine tune my engine build plans! 2.0L ITB turbo DIS water injection!
- How to take apart an Autometer gauge?
- tps issue during the damn heatwave...
- MSD ignition distributer cap type r
- Fuel Pressure Regulator Ratio, stock vs. Aeromotive
- b16a block with gsr head what timing belt will work ?
- tranny/hasport mout ?
- Problems with clutch pedal pressure after replacing clutch, help!!!!!!
- Replaced Head Gasket, and Still have a leak
- how do you bypassed the coolant lines at the tb and iac
- Towing while the engine is out
- Clutch and Timing belt replacement?
- injector spray
- How did they make the window do this??
- brake booster/ master cylinder clearance issues..... can I dent it a bit without harm?
- OBD2B OBD2A to OBD1 Question?
- battery relocation - fuse or circuit breaker rating
- Free Garmin eTrex or Magellan GPS!
- shock tower plugs?
- Radiator/ A/C fan trouble.
- engine removal questions
- vafc install problems
- automatic tranny does not go from second to third, slips back in to 1st of second
