View Full Version : Tech / Misc
- P28 Mini-me ECU HELP!!
- gsr crankshaft??
- need help on obd2b-obd1 conversion using uberdata
- engine wont start, seems like it want to but just wont... i need help!!!
- vacuum problems??
- Lowering springs for my ef
- vtec harness
- immobilizer wiring diagrams???
- Where is the thermostat located??
- wtf...my car is blowing white smoke everywhere..help
- Are there any other ways to check this????????? help
- Those with skunk2 camber kits tell me if Im good.
- Searched no luck, Fender rolling necessary or just inside plastic
- OBD0 Oxygen Sensor Question
- making a bseries mutt???
- CKP (Code 4) Problem after setting timing
- gas tank
- Diagnosis Needed: Broken ring?
- short shifter swap. help
- depinning distributor
- AEM 8 or 4-Channel, Twin-Cap Digital C2DI Ignition Module
- What do the subframe dampeners do??
- Map Sensor Hell
- ELD and Fuel Injectors (searched)
- NEED MAJOR HELP!!
- Eagle stroker 2.2L in a B20 ???
- race fuel help
- Why put ATF in your motor?
- Question about K20A heads, and Type R block.
- Spun Rod Bearing?
- gsr front swaybar in eg
- ls and gsr rod bearings the same?
- Electrical Question, need help A.S.A.P.
- obd 2.1 jdm gsr vtec oil solenoid?!?!
- ******CAM SPROKET BUSTED*******
- gsr timing problem
- o2 sensor wiring help
- HAS ANYONE TAKEN A.S.E'S ......M1,M2,M3 LOOKING FOR SOME TIPS
- 90 teg w/ B16 cable to hydro conversion Questions
- Found sleeve cracks - HELP!
- 1990 CRX Si Suspension
- What lowering springs for 90-93 integra?
- rinsed engine with water, now hesitate to start....
- h22 timing belt tensioner
- 4.7 FD in b16 tranny?
- wrist pin lock installation ?
- Anyone ever get work done or buy anything from these guys?
- After Market Bearings?
- B18c5 swap Need help!!!!!????
- O2 sensor?
- l/s vtec instructions
- rebuilt motor breather/exhaust smoke..
- Suspension noise
- ? about 95 gsr head
- Cam timing off...problem?
- AFC vs. Uberdata
- Simple injector question....not too tech...
- Lower my car
- 2000 ITR Tranny Issue
- creaking/suddering rf corner
- Synchros
- Any way to figure out which piston/rod goes in which cylinder?
- Camber kit
- Will a 88-91 civic rad fit in a 92-95 civic? I'm willing to fabricate to make fit...
- Suspension bushings
- Tranny Problem....I think!
- advice on tech for nhra
- vtec?
- oil pumps and pans
- distributer
- throttle cable problem
- Head lamp issue.
- ecu/ecm question
- obd2b-obd1
- how long are gs-r head studs, and how long are b16 head studs..??
- Is it ok to use heavier weight oil in a GSR transmission with LSD?
- clicking noise, which axle is bad?
- spark plug wires question
- performance headers for b-16
- annoying b18c5
- B18 manifold on a B16
- engine idleing very low
- Engine Idling high....
- d16 heads
- underdrive pulley on daily driver
- ecu question pleeeease help
- Strange noise from drivers rear
- Cleaning O2 sensor??
- Brake Rotors stuck
- oil n air fuel ratio gauge.Help!!
- how do you test the ohm on an injector???
- Bought Prelude---NO CLUE for maintence
- B16 Bottom end..... Please help....
- What kind of fuel pump is this?
- CEL 92 EVAP purge
- The Best Oil? Did some Research...
- Engine Dampener used for rear mount?
- D15B Vtec
- Start Button Help
- need help!!! what are the purpose of these?
- Stage 2 axles
- How to wire NTK O2 sensor
- tech question about injectors
- open headers or apexi n1 catback exhaust??
- Type S Flywheel(Pic Inside)
- can you tell what head this is?
- GSR EG SWAP?
- Purge control solenoid (pcs) wiring for crx. w/obd1 b18c
- LS/vtec Breack in (new used parts)
- Rod Ratio
- engine swap
- part number for act bearing??
- clogged cat????
- OIL PASSAGE IN B-SERIES VTECH HEADS. WICH ONES HAVE IT AND WHICH ONES DON'T?
- Pickle Fork Good or Bad ? ?
- catch can ??'s pcv not working
- Car will not start!!!!!
- t3/t4 hybrid turbo
- h22 and b series trans mating info?
- automatic radiator?
- need to find 4 wires on a p28
- anyone ever had this prob?
- whats wrong with my clutch?
- Just converted my power steering to manual. I've got questions
- Vibration after re-packing cv boot?
- Suspension Problems?
- How many wheels are spinning?
- DEAD CYLINDER.... PLEASE HELP
- Teal 1991 CRX Si
- California BAR Certification. JDM k20R. Any luck?
- Changed my brakes and rotors and my wheel still shakes
- transmission problems
- new to this not sure what will work
- DISAPPOINTED with 1/4 times!!
- RPM from Launch
- Aftermath after taking the old turbo setup off-- Have some questions
- Greddy Gauge Help....
- Need help with fuel pressure (96 stock gsr except intake and block is 84.5mm)
- midshalf bracket same on an integra 94 and si 99
- Turbo H23AI
- Goten Springs, need feedback.
- info on b17
- leaking rear main seal
- automatic conversion to 5spd
- GSR distributor fried or what?
- 92 h23a1 motorswap into 92 accord?
- obd1 jdm p72 with vafc on b16a3 usdm problem....help its been a year of this prob...
- power range of gsr cams or b16 cams in OBD1 B16 head
- V-Tec Report
- Y7 to Y8 MiniMe swap problems
- dyno plot, aem file for ITR (hi comp, 84.5mm)
- ARP head studs
- injectors and ls swap info
- Sensor help.
- Major stumble...can't figure it out.
- obd1 dizzy to obd2?
- Convert ECU from Auto to 5spd
- si driver side bracket bolts.
- compression test sillyness-
- help! spring question
- Need torque spec for the tranny housing
- bisimoto's setups?
- rear disc conversion question!
- Power Steering, elimination
- What D-series alternators are compatible with mine?
- Follow up, a thanks...and a new question
- Endlinks difference
- Anybody know about A/T Upgrades
- sp. procedure for brake flush after PROP. VALVE swap?
- What is the skinniest tire a 15x6 wheel will accept safely
- FI E/M
- code 13 barometric pressure switch
- Myth Buster: Light Flywheel
- rpm question rev limiter acting weird?
- d16y8 head, 0BD1, which distributor???
- Recently purchased 95 Accord EX coupe SOHC VTEC
- Shifter fork ques.
- filling drilled holes? DIY
- HELP! motor issues....
- HELP PLEASE
- B20/vtec ----- Which axels????
- MPH B Series Transmission Calculator
- Blusprinting and Balancing
- Is it possible??
- Compression test
- putting on a grill for body kit?
- Calibrating Speedometer with larger tires??
- Hesitant VTEC problem after buildup on B16A, no CEL's... What tha dilly?
- anyone who thinks they are honda smart answer this .
- H22A in eg, HELP!!!
- VTEC controller instructions....Please!!!
- gsr pistions on ls rods
- engine swapping and turbocharging
- AEM EMS question with 3bar map sensor
- Service Limit for Flywheel?
- which camshaft for d16z6
- how do I test a 5 wire wide band o2 with a volt meter\tester ?
- Clutch straight to the floor. Turbo GSR. HELP
- Cams Without Cam Gears - HELP
- Clutch break in
- need HELP AutoMeter Tach
- Better times at night or in the day?
- INFO On Gauge Cluster [motor swap]
- need info on honda/acura
- d16y7 to d16y8 intake mani conversion
- seized up tranny
- Bottom End build up...few ?'s
- Aftermarket Brake Calipers
- Has anyone ever heard of the Mugen CAI?
- GROUND WIRES
- core fill to bottom of water pump inlet?
- aftermarket decal wont light up
- Honda Oxygen Sensors
- What exactly is VTEC?
- Upper Ball Joint 6th Gen
- can/how i use a b20 dizzy on ls swap?
- Quick question on rod stretch specs on gsr rods/bolts
- Low Pressure Switch or Air Condition Compressor???
- Cleaning rods/pistons?
- 2003 Accord Broken Rear Stabilizer Link Ques.
- TEIN SS on CRX
- torque loss
- 94 civic mini-me conversion???????????? help please
- v-tech queston.
- need to order a 3rd gear syncroset and shift fork. where to order onilne for cheap?
- still looking for BKR6E-N11 for your 1G B16
- How soon should a motor be started after build?
- cleanig internals?
- Will this setup run on 93 octane?
- NJ question- Sardis Speed Shop? Anyone know what happened to Sardis Campodonico?
- will rear comptech sway bar for a DC2 fit on a 95 civic coupe?
- Hello and VTEC-E dropped in a 92 Civic DX
- Question about injectors?
- Different problems, are they related?
- quick trouble-shoot: vibration
- battery issue?
- No V-TEC
- hondata tunning in DC MD VA AREA.
- OBD what for h22a?
- Crankshaft.Bearings???Sizes? Need help please.
- brakes are starting to worry me
- HELP Gas cap problem or CEL after Fill ups????
- vtec controller dyno setting question
- ckf sensor interchangable?
- Vtec engine swap to NonVtec & Harness questions??
- Whats your brand?
- B16B compression check results
- Brass T fitting broke off in block!!
- B18c engine build
- Are these real Crower 402 cams?
