ECU HELP.... 98 INTEGRA LS....
Old Nov 30, 2003 | 01:09 PM
stockLS's Avatar
Default ECU HELP.... 98 INTEGRA LS....
ok, a friend of mine did a b-20 swap in his 98 civic ex and is using manual trans non -vtec ecu from a single cam motor... my question is... can i use the same ecu in my 98 teg? im going from auto to manual trans. and i am in need of an ecu! but the only "yard" around here wants 200$ for a 94 ls ecu.. t.i.a and any help is appreciated!
Old Nov 30, 2003 | 01:49 PM
Kendall's Avatar
I've never messed with single cam ECU's (or LS motors for that matter) but I don't see why not.
Old Nov 30, 2003 | 04:15 PM
stockLS's Avatar
Default Re: (dc231)
anyone else?
Old Nov 30, 2003 | 04:25 PM
Kendall's Avatar
If it's the same OBD system it should work, all the OBD-II systems use multi-point fuel injection, so you don't have to worry about that, and you don't have VTEC to worry about, so all that's left is to turn the motor and fire the spark.
Old Nov 30, 2003 | 04:28 PM
Kendall's Avatar
Also, you don't have separate control parameters for each cam so the engine operates electronically just like a single cam and if they're aren't separate control parameters for each cam, then how is the ECU going to know the difference. I believe it will work, I don't know how well it will be tuned, but I do believe it will work.
Old Dec 1, 2003 | 04:42 AM
stockLS's Avatar
Default Re: (dc231)
thanks.... anyone else have anything to add to this!
Old Dec 1, 2003 | 12:32 PM
stockLS's Avatar
Default Re: (stockLS)
bump
Old Dec 2, 2003 | 12:27 PM
stockLS's Avatar
bump for the last time anyone please???
HONDCIVIC99
Apr 23, 2011 07:42 PM
candyblueta
Engine Management and Tuning
Jan 8, 2009 07:34 PM
cas95
Dec 12, 2006 02:06 PM
eghatch4sale
Jun 22, 2006 01:00 PM
