View Full Version : Tech / Misc
- distributorless
- need help
- built vtec engine wont rev past 7k
- bad to disable the eld load detector?
- 1992 Accord Power Window Electrical Issue
- Antenna!!!
- Could a faulty ECT sensor cause the car not to start?
- gorilla lock nuts key
- b16a starters the same
- possible main relay problems, help
- '95 Civic overheating.
- fuel ratio for 1996 honda cr250??
- Spoon Wheel Question?
- Remove my A/C?
- electrical gremlins.... spark issues
- obd2b to obd1
- Using hx harness for swap?
- Switching to the dark side?
- how to clean '90 Civic DX EGR valve & port
- What can you clean a AEM filter with?
- i need BAR connect
- K20 1700-2100rpm misfire?
- 96 spec JDM typer TPS voltage
- Question About Wiring For Air Horn Install
- idle surge
- cant find the problem..pissed..B17
- Chattering sound coming from the engine??
- Gsr swap em1 friend misses third rips alt belt comp off car, idle funny,lil smoke
- HELP!!
- Integra having trouble starting...please help
- not sure what happend?
- Automotive Repair Reference Center.. Manuals
- Supertrapp muffler
- B16 Camshaft Identification?
- Problem after upgrading fuel system
- bolt fragment flew into valvetrain/cylinder!?!
- who can help me with my vtec controller ????
- b16 timing
- What rings to use when boring a B18C1 from 81mm to 82?
- Engine missing during race problem
- heater/ac doesnt work
- engine starts but then dies, need help
- 92 civic sir, speedo intermittently works + CEL
- built d16y8 not starting
- Help! Distributor frankstein!
- stalling on decel
- Junkyard finds... What to get
- Voltage drops and misfire.... Need help!!!!
- Figuring out engine harness plugs.. *HELP*
- msd problems...want to go back to stock
- help i dont know whats wrong!
- 2002 Honda Civic sputtering and loud exhaust problem
- good sanding/polishing tool to work the combustion chambers??
- eg ek civic strut question
- where to buy a good rebuild kit?
- installing motor swap through bottom with jack?
- im new here!!!!
- help
- Honda s2000, 2001 loose of power when vtec engages
- Leaking head gasket replacement requires special bolts?
- distributor help
- Top Speed ?
- Cel help
- help head swap problem
- how to unstick stuck injectors
- cams question? my motor seems stuck. HELP!!!!!!!!!!!
- Is this an air pocket?
- NEED HELP CAR STARTS FOR 5 SEC then turns off
- motor bogging due to engine cleaning???
- Cluster = NO Lite ?
- T-Bracket clarification please!!!
- A good cam question.
- 5 lug knuckles
- code 67 ( p0420 )
- can someone help me out !!!!!!!!
- tools needed for rebuild where to buy online
- Is a NEW tensioner spring necessary when doing timing belt change?
- ignition coil
- stock compression numbers on a b16a2?
- S2000 cluster in EK hatch with H2B???
- What will cause the radiator fuild to disappear
- engine wont get spark. need help fast!!
- Trouble Shooting Misfire problem
- Identify this ECU - P76
- H2B clutch problem
- need some advice to progress
- MOMO horn retainer for Quick release
- code 9 on my 89 si w/ Ls swap
- head resurfacing
- cleaning carbon off the valves?
- 91 accord a/c conversion into 2000 civic
- HELP! my car is choking every time i hit vtec
- vtec problems
- Code 21, Vtec solenoid issues.
- 2000 civic charging problem
- JDM H22a Internals into USDM H22a1 help
- Camshafts turn roughly
- JE GSR Pistion on LS rod?
- Vibrant's Adjustable Timing Belt Tensioner?
- help replacing fog bulb on JDM front DC
- y8 head question
- gsr block, ls crank combo
- water temp sensor light still on.
- H22 Starting Problems
- Compression Results, New Rings!
- I just picked up a free eg and want to work on it.
- installed a new ac fan... ac stil not running...
- Having injector issues!!
- oddessey PC 680 battery questions
- header gasket issues
- Dizziness + Burning eyes while driving!!!!!
- vtec, rpm issues
- clutch average life? ( personal experience)
- smog cali
- Need Some Help Here || D15B7 Auto having issues starting!!
- What is a gsr short block and gsr long block
- Remove plugs from the main wire harness ?
- timing offset in Skunk2 cam gear
- *issue with my gsr block*
- civic horn issue, help
- I Need the Honda's B Series Cylinder Head Codes
- how to wire up vtec in an obd1 ecu
- dynolicious
- b series vtec cams in non vtec b18a ls????
- R12a (hydrocarbon refrigerant, propane) illegal for R12, ok for R134a?
- Does open headers add HP?
- NEED HELP PLEASE!!!
- build is now running.. but with problems.
- Engine builders please read!
- 97 civic HB ecu in limp mode and code 16
- pro2 cams
- injector connectors..
- Question about part under the hood
- Don't understand what happened..
- 89 crx momo monte carlo steering wheel fitment help
- low/high impedance
- How to indentify a B17 tranny?
- integra wont start
- little help
- help with CELL code 7
- F22b2 Piston and wrist pin ?
- wire OBD2 DLC connector into JDM car?
- need carfax please
- CRX starts then dies after 6 seconds
- scat rod specs.
- What kind of Injectors are These?
- HELP Park lights flashing \flickering
- QUICK QUESTIONS GSR BLOCK AND LS CRANK
- B&K weight difference
- piston to wall clearance question?
- clutch master cylinder question??
- S2000 cluster with k20z1 transmission? civic/integra
- TIMING PLEASE HELP!!! B18Ls/vtec
- Why are the insides of steel oil pans painted?
- b16a OIL COOLER HOSES???
- 95 gsr runs, doesnt start, code 9
- DIY: retrofit 12'' slim fan in OEM radiator shroud... (for half size radiator)
- delete
- Problem with H22a not starting
- missing pin on ecu harness
- Help!.. Fuel rail and injectors on b20.
- FOR GUYS RUNNING 450-600WHP
- stem seals. intake ok all round?
- sohc motor question
- help replacing cooling fan assembly
- Multiple CELL CODEs after replace O2 sensor WB
- coolant leaking help please
- cant get horn to sound, only a click from the relay
- Do i need to chip my p72 to run better on a pr3-4 b 16 head on a b18c1 gsr block!?
- ls motor problem
- wiring diagram?
- 2000 Honda Civic resistor replacement
- gsr swap help [bay area]
- plugged cat. code on obd2.
- Reusing a water pump?
- loads up easy
- Carfax request??
- what type of thread sealent for fuel pressure gauge?
- need help!! idle problem after manifold install
- Scratched cylinder wall??
- Alternator work when jumped, battery wont charge.
- Weird clicking noise underneath dashboard when car is on...?
- Low rpm vibration only,its gear based, wtf help
- Unknown B series Camshafts, Toda?
- ***Need Help Failed Smog 2003 Accord V6
- need help asap! starter question
- Eagle Rods with 5/16" bolts
- Vtec problems
- will integra catalytic converter on a civic?
- Benen Fuel Rail Install question...
- ECU Fuse - Keeps blowing
- rattling noise around 2k-3k rpms
- HELP solid cell
- recommendations on rod bearings?
- Best Place in Japan To get Stuff?
- does displacement affect smog?
- Fuel drain plug leaking
- Steering Rack Replacement - Help
- headgasket symptons
- Female needs advice! Alignment and Trouble
- Stock b20 head gasket on 84.5mm bore?!?
- H22 Knock Sensor
- motor mount nuts and other such
- Car starts, runs, dies, won't start again immediately
- K Motor Forum
- help crank pulley bolt BrOke
- fresh motor
- d16y7 to y8 mini me swap!
- CAM Bolt broken inside of HEAD!!!!!
- Yet another problem,no interior lights.
- b series cam classification
- Weird Dyno run?!
- LS/VTEC overheating
- Help!! PLX Wideband install..
- Scam or not?
- i need help instaling ek9 power folding mirrors
- Car running richer after intake?
- ignition module HELP!
- Question about chipping
- Oil Pressure Gauge Intall.
- getting motor swap out of freight truck?
- Prestone Super Flush, any users?
- Burning oil while breaking in new piston rings??
- 1986 civic si - not starting
- Weird grinding, rubbing, clunking sounds - front end
- 94 accord lx idles smooth above idle #1 skips
- Oil Analysis: JDM ITR engine, Motul X-Lite 0w30, 9,756mi
- VTEC NOT POPPING! HELP
- bent valves ?
- How to install adjustable cam gear. WTF!!!!
- I NEED HELP INSTALING MY EK9 POWER FOLDIND MIRRORS
- GSR CRX Power Loss/Stutter in vtec
- h22 in ek
- My H22a cylinders 3-4 are not firing
- b16a2 clanking sound? HELP
- HELP to fix CHECK ENGINE LIGHT CODES!!!!
- new heat-shield experiment
- 84mm b20 head gasket question??????????
- It wasn't the head gasket
- b18a swap code6(ECT) and code14(IACV) HELP
- TPS Calibration
- b16 or b18c1 head?
- HOT AIR BLOWS INTO MY CAR WHILE DRIVING
- Removing pins from connector
- how can i tell if vtec is popping!?
- b16a water pump? b18c5 water pump? same?
- what can i do to clean out a gas tank
- Is anyone using these seats?
- timing belt slipping of gears!?
- ignition ?
