View Full Version : Tech / Misc
- IACV ? HELP PLEASE
- Clutch help needed
- Looking for good muffler
- code p1259 (22) VTEC system malfunction???
- compression and cams
- y7/y8 Intake manifold
- clutch problem
- my timing keeeps skipping
- CRX EDM SiR alternator vs DA integra alternator
- Suggestions on Heat Barrier/Shield
- Pay Omage to HT
- clutch kit, flywheel choice???
- question here!
- valve damage! belt broke!
- LS motor specs
- vtec not working and 5000 rpm rev limit???
- Need help!!!
- b17 ctr pistons and skunk2 cams
- obd1 - obd2
- NEW CAMS CAUSING AN IDLE PROBLEM
- HELP !! with S-AFC .. . everything is wired and working fine but pressure and throttle signal dont r
- CODE 8 PLZ HELP
- Y1 Tranny HELP!!!!!
- Safe to wax Carbon fiber hood?
- V Tech Engines
- alternator question
- evap purge solenoid
- AXLE ? PLEASE HELP
- hondabond or high temp gasket maker?
- looking for S300 tuner on the eastcoast
- How much does a D16Y8 weigh?
- customize throttle body on a 1998 civc coupe
- Which 3/8 studs are in B Eagle rods?
- Timing belt/Water pump maintenance
- Cam Gears?
- Should I modified my head?
- should i tune my car if i have I/H/E/TB/IM
- VTEC Controller question
- window visor question
- you know how to tune ecu's?? quick question...
- ***ecu tuners or gurus tune in..***
- Just installed Exedy Clutch and Fidanza Flywheel
- engines revs up & down at stop light
- Some mild combos, your thoughts please...
- Comptech is closing their doors!!!!!
- two "how vtec works" videos
- Timing belt - h22 or h23?
- CAR WONT START?!
- b20b block .. 84.5 or 85 mm non sleeve...?
- Removed head, do i need to do a valve adjustment and adjust the timing?
- tuning with wideband, but remove stock oxygen sensor(its bad)
- need help with ecu
- Help code 43 plus other issues...
- Race preped crank VS stock
- GM Synchromesh FM or New Honda MTF?
- Built NA B18b LS block VS Built NA 89mm stroke B18c GSR
- Finding Bearing Size B16A2
- B16a2 with JE 9:1 pistons compression at 130-125 psi???
- tuning with a wideband uego... HELP PLEASE!!
- CEL 68????? WTF!
- obd1 b18b valve cover to obd2 head
- main relay clicking crazy when i turn off car.. what's the problem?
- in need of ef sir crx front bumper.
- Deleting the ABS on a 95 GSR - The easy and cheap(er) way.
- What would you guys do with a da chassis?
- Will my ls/vtec hold 9psi?
- Higher compression on d series motor
- ITBS trottle cable
- Where to buy ACT Clutch Kit?
- Odometer stopped working
- A1 Technologies Head Studs
- Skunk2 throttle body and customer service..???
- If you know about tunings and ecu's please help here..
- oem lsd hp rating?
- blox manifold with rc injectors 310 wont fit
- Idle problem (searched 421 times)
- obd2 gsr engine into 94 civic vtec IAB wiring help (butterflies)
- Help quickly please
- Y21 JDM tranny VSS technical questions
- Any way to tell Walbro 190lph from 255lph?
- b16 swap fuel problem
- Super Quick and easy Question
- Quick question. idle screw. turn them c/w or cc/w to lower the rpm?
- D16Z6 A/C tensioner pulley problem!
- Which clutch fits YS1 Tranny???? Help please
- NEED HELP!!!!
- frame shop prices?
- Throttle body question......WTF car dies instantly.
- I Need Help With My Clutch!!!!!!!!!!
- GSR hatch dyno vid and graph.
- LS Trans??? LOOK
- clutch/release bearing issues??....maybe internal problems??..........unable to shift
- does a straight piped exhaust bennefit your power at all
- jet v-force moule?
- ITR tranny , 3rd gear grinding poping out when disengaging clutch.
- Recommendation on a torque wrench?
- Degreeing Cams - I'm confused about Skunk's method
- tranny swapping
- Apex power fc coil outputs?
- trannys and engines
- HID problem bulb or ballast?
- Clutch squealing!!!
- fuel return line leak?
- Need some help on B16a
- axle problem!!!!!this is aggrivating
- JDM YS1 tranny
- s300 car wont start
- ecu HELP!!!!!!!!!
- short question about JE 12:1 pistons (b18C)
- Trial user question
- Help request: Reassembling a TB
- Shakin' While I'm Brakin'
- oil in number two cylinder
- Crome 1.2 Technical Question
- REAR MAIN SEAL. Is it ok to get it from autozone/Advance?
- Is there a tranny removal Write-Up!!!
- HAVING A HUGE AEM EMS PROBLEM!!!!!
- I can't start my car! Wierdest problem ever!
- accord auto to 5spd questions.
- honda vx gearset and FD in an 92 integra gearbox case will it fit and work?
- 97 ITR starter issues continue
- whats a better tire size
- Bearing shells question
- itr motor's surging. irratic idle. help
- Installing ARP head studs-Help...
- Can I use a hondata s200 w/boost option on my n/a?
- Can somebody please help me out with a Part number!????
- ANY DIFFERNCE BETWEEN CLUTCHES FOR HYDRO/CABLE TRANSMISSIONS, PLEASE HELP!!!!!
- p28 help
- 68mm gude t/b problem?????
- JDM B20B, crankcase?
- MSD 6a and blaster coil
- weird idle problem
- Upper control arm bushing torque specs?
- Power on pump gas
- skunk2 stage 2 cams, which cam gears??
- Wiring Diagram or pictures of 89ZC D15 non-VTEC
- Engine running cold and heater blowing cold air
- 01 obd2b GSR into 96 civic with obd2a harnass and ecu
- p28 question
- How to Perform a Compression Test??
- Torque Spec For Fuel Rail Mounting Nuts?
- S2000 5/6th gear swap?
- hood pins
- can some one help me out
- B series ACT HD pressure plate and Throw-out bearing questions
- throttle position sensor question...
- Pistons
- v8 killer
- Trannies with worn holes???
- Dirty rear bumper on ITR
- pinging/pinking
- Starter question
- Honda Approved Fluids
- Before I go mental, please help me identify this noise!
- hondata s300 base maps
- Accord 91' Tranmission vs H22a Transmission
- quick question
- Question about idle
- AEM Fuel Rail Help
- 360 exhaust clamps: do they work?
- SEARCHED-piston-to-wall clearance
- Car still wont start.
- oil pressure gauges???
- anyone run there car without the canister under fuel filter?
- some sort of knocking on d16y8?
- Rod bearing tangs...direction?
- Question about Short Shifters
- 160 degree thermostat???? Where are they???
- Clutch install, got some questions...
- 93 civic dx auto engine swap please help or point me in the right direction
- Fuel Rail Mounting Studs
- trans case tricks?
- I cant seem to put a finger on my problem... violent engine shake when cold
- ACL Rod Bearings for a b20vtec ??
- what rods are better
- Sohc/Dohc transmission vs. SI d Series trans. (difference)
- Help after clutch install
- weird vtec changing up
- COOLANT for Turbo - Single Looped Line? One Source OK?
- prelude dash into eg6 civic jdm
- Ferrea Valve Guides Questions
- smashed my oil pan. the aftermath:
- Possible starter problem question
- ls/vtec leaks??
- OBD1 JDM H22 CODE 36
- help > is a spun rod the end of things ?
- MY D17 BLEW UP
- Ground post
- VAFCII settings...help me out?
- elctric exhaust cutout
- Coil on plug ignition
- Quick question about diameter.
- biggest cam in stock type r
- Extending AFC wires?? What wire??
- pics needed!
- jdm b18c1 ecu
- jdm integra type r final drive in jdm b16a hydro trans
- Bearings From Engine Arent Matching Bearing Chart. Please Help!!!
- Crank machining
- cant downshift...
- Oil pressure w/ rod knock
- countershaft bearing
- HELP!!!! Exhaust Prob
- INTEGRA or CRX : Which car should I put my money into?
- Clutch Click. Cable Trans.
- Question about squeaking
- STP Products......are they worth it???
- Any tuners in the northeast florida area?
- ctr cams,is valvetrain upgrade a must?..
- timing belt replacement question
- Revving higher with a b18b block?
- Codes after new headgasket. 3,4,7
- Password:JDM Thermal Shield Intake Gasket (Honda
- JDM B16 tranny or hansport C-H convertion
- Question about oil burnage
- 99 Acura Cl H22 Swap Wiring issues!!!
- Charcoal Can Removal-EK
- oil filter relocation kit question....
- Wiring problem HELP
- curious why does machine shop ask for main and girdle when honing?
- Larger and smaller diameter steering wheels?
- RC k series Injectors work on B series fuel rail?
- 92 prelude h22a problem
- loose timming belt
- piston rings
- need more power!!!
- why am i still a trial used
- skun2 pro series trouble, HELP
- apex vafc
- obd1 ecu pinout for d series non z6?
- rear 97 type R calipers
- Nissan 350z
- Problem with swapping cams and timing belt >=(
- Help! 1997 Prelude Non SH, swapping a blown H22A4 with a H22A.
- Is a twin Turbo or a regualr turbo better
- What if
- how fast does your car go?
- honda 4wds
- 4 cyls
- LC-1 not communicating with XD-16 ?!?
- 5th Gear Pop Out ARGH!!!!!
- Axles spinning in any gear
- Lightweight Fidanza Flywheel & Stage 1 Exedy clutch kit?
- Help!!! swapping out automatic ek to manual... already searched
- 92integra 93-96 prelude TCM, same?
- Buddy Club spec IV cams..??...??
- map sensor on obd0?
- obd2 b18c1 install almost finished
