View Full Version : Tech / Misc
- JDM ITR ECU tach signal different than USDM?
- question on locking vtec and claying for clearence
- Buddy Club Spec 3 or Spec 4 Cams?
- interchangable clutchs??
- Window keeps coming off track
- why is the part # diffrent?
- H22 crank shaft housing/girdle question about application
- clutch engagement
- cutting vavles
- need info on what all is needed to swap a lsd in s1 tranny
- Need help with Ls tranny?
- Anyone know how to tell a minor vac leak from obd2 live scanner data? Good MAP levels?
- help!!!!!!!! spark plug wire problems
- CNS in Milwaukee\Butler
- h2b block grinding
- A/C install on B16 EG
- identify these retainers?
- couple of Q's
- gsr cluster question
- Ring Gap
- no VTEC after head gasket change
- Building motor
- Anyone have a stock B16A obd0 PR3 manual ecu - BIN file?
- Mixing oils mobil 1 & VR1
- HELP: Engine removal of b20/b16
- Autometer cobalt gauge question
- Automotive Wiring Writeup or FAQ
- Displacement 84mm or 85mm
- Cleaning Injectors
- temp gauge fluctuating inupper rpm range
- What do yall think about this transmission???
- Dog box. Where can i get straight cut h/f series gears from?
- Shitty Compression Results, options?
- 90 honda accord trans problem
- no love for this thread!! someone help me out
- what is a good engine management for high horsepower turbo?
- tranny greasing
- tune my 1990 crx
- h22a manifold problem severe.
- leaking transmission
- need sleeves??
- mini me Q
- very intimidated about building/putting togethor first motor. please help H-T.
- tcm?? transmission control module??
- tcm?? transmission control moduel??
- oil pump help on a d15b7
- cable tranny internals in to a hydro case?
- swaped ecu , NOW valves are making noise~~~~
- CTR- B20 block (n/a)
- Setting timing w/ Timing Light (Gun) Help.
- jdm d15b cam upgrade????
- NEED HELP WITH 1ST TIME ENGINE BUILD
- Quaife LSD in S1 B series cable tranny--> wich parts do i need?
- Trans help (and i searched!!!)
- Before putting in new pistons... Honing <sp?> block... how much and how to check quality
- OBD2 >OBD1 questions
- tranny problem? it wont....
- Maximum TOWING
- header bolt always comes loose!
- think i damaged my F20B IACV solenoid- anyone know how to service?
- 98+ ITR transmission - Which axles? (searched, just have to be 100% sure)
- rocker arm HELP
- Anybody familiar with Mechanical Gauges????
- HELP!!! Comp. Tester stuck in head!
- electrical problem with em1
- thrust washers
- p30 ecu problem??
- Need Help Going Crazy....clutch/tranny problem. kinda long.
- Massive Oil Leak
- help on motor guys took head off want some opinions
- Untuned?? LS/VTEC compression + white smoke at high rev
- MAJOR ELECTRICAL PROBLEM
- ECU H22a SWap wiring question
- CRX Gsr swap
- Need help on wirings..
- Help with carpet on 95 honda door panel
- 0-5V Fuel Pressure Sensor to Datalog with Hondata S300
- usdm>jdm, 5-speed>auto conversion help
- JDM tranny questions....
- Steering Column retaining collar
- Removing Automatic Flywheel
- Help with gear selections and where to buy
- Built LS block leaking?
- Skunk2 Manifold w/ BDL Throttle Body
- MORE YS1 TRANNY CONFUSION
- 03 accord perf help/suggestions
- Is this ITR head salvageable?
- H2B QUESTION
- 94 Civic Head Gasket
- Head Swap
- B18c ARP Main Studs Torqued to Factory Specs?
- 1995 ex tranny vs. 1999 ex tranny
- my engine idles really high when i have the clutch engaged
- b18b rocker help
- Wiring resistors to stop the O2 CEL???
- built gsr motor smoking!!!!!!!!!!
- HELP PLEASE!!! ASAP! ENGINE LIGHT!
- LS/vtec wiring issues
- help please
- skunk2 disaster.
- Ecu tuneing
- b16a arp headstuds??
- Melted IAT sensor
- question itr motor into da
- car not starting...lil confused.
- Billet Cam Seal for F20b
- tunning at Green light honda in San Diego
- high pitch whinny noise
- IACV WIRING QUESTION????
- In need of some Y21 tranny help.
- what transmission to use b16 or gsr?
- will a radiator fan from a 96 ex fit and work plug to plug on my 93 ex?
- starting issue/ possible spark
- SURFACE RUST ON CRANK
- Fast-blinking blinkers in 94 Accord
- Tranny Help
- Blown Oem headgasket?
- CEL code 1 "Oxygen Content"
- oil filtering position
- help check engine on and car is reving weirdly
- 100% Leakdown on Cylinder 4
- Bosch O2 Crap??
- is there anyhting i can soak valves in to eat away carbon?
- Intake
- Whats the problem?
- Blown timing belt
- major oil leak, ls vtec
- Help me with ecu wiring.............pix
- how to wire horn up----type r steering wheel in eg?????
- B series S13?
- ls crank in gsr or itr block question?
- ITR mani or stock Si mani?
- any know if f22 rear tranny casing will fit on h22
- ???? B series MIDSHAFT
- Flywheel Resurfacing in OC?
- d15b motor can't rev past 4000 rpm??
- 1991 accord speedometer stop, car loses speeds and then power goes,
- rusted block?
- STOCK SI
- 93 Tranny
- Transmission Cooling???
- IAT, INTAKE AIR TEMP QUESTION?
- Transmission Problems (First and Reverse)
- transmission wont go it to gear
- 2 questions.
- will Defi Link support 4 EGT's?
- retaining horn on wheel release
- Check engine light
- GSR bottom with B16 head
- oem vs. external oil cooler.
- CEL code 8, TDC sensor on DOHC zc
- Replaced Input shaft bearing, now no reverse
- Converted p06, B16 CEL Code 10 & 21
- quick ?
- Wierd noise coming from under Intake Manifold! Help
- Question about Hemlholtz Chambers
- freshly built ls vtec, way low compression
- Major electrical issue
- car runs poorly plain and simple.....
- need help b18c4 conversion into 95 civic coupe
- tranny casing problems
- my speedo and temp guages bounce
- Little problem with clutch engaging arm(?) sitting on pressure plate, wont back off.....
- d16z6
- OBDI ? OBDII ?
- D16y7 in EG hatch smoking?
- Help reading spark plugs
- Speed Theory EK Coupe/RHD/K24 Turbo Build Thread
- Obd1 distributors, is there a difference
- ITR intake manifold OR skunk 2 intake manifold??
- which set up is a better idea.
- Cometic headgasket reuse question?
- mini me conversion questions?
- need: uberdata w/ostrich,datalogging
- Plug cover preference/necessity?
- question about a d15
- ecotec vs vtec
- gsr tranny??
- 94 civic rear disc conversion
- tranny help
- d-series crankshafts
- any problems with soldering on obd1 injector clips and leaving obd2 injector clips on as well?
- skunk2 intake manifold and stock ecu
- CAN I USE D SERIES VTEC SOLENOID ON B SERIES!?!!?
- A/C issue
- quick question OBD1 and OBD2
- Tuning
- D16z6 CEL 95 del sol
- clutch will not engage.
- Trans Q? (LSD)
- Difference: P28 vs converted P06
- OBD1 vs OBD2, difference
- tranny ?
- Competition flywheel, Yay or Nay?
- finishing swap spark and fuel problems
- b20b in 99 sir
- relay for the jdm itr headlights???????
- Reusing Spoon 2 Layer Headgasket after 3k miles?
- need help bout tunning
- Steering wheel Interchangeability list
- Cant find instructions for MSD driver for pro billet dizzy (orange & red wires)
- dont buy this axle!!!
- question bout d-series swap
- ls conecting rods??
- Too much RICE BURNER sound...!!
- Shiftpoint Gear Grind/Miss
- need somones help plzzzz on oil pressure gauge
- BLACK SMOKE
- Point me in the right direction please.
- loud popping noise - friends 06 tsx
- need help!!
- Taking my car to transmission shop
- Did you replace the TIMING BELT??
- A possible never covered oil catch can question
- IACV:: Help please.
- Fresh motor Lsvtec My Vtec is on and off
- hydro2cable converter
- help ID y80 tranny
- P28 ECU noise?
- misplaced rockers
- Gas Gauge went crazy...
- ls/vtec headgasket
- Motorheads I NEED HELP!!!!!!
- Vtec to Ecu help!!
- Searched First; Timing Gear Removal?
- ek dials in an ej
- 91 honda civic PM9-1
- B20 crand and rods in a B18C4? (Quick help!)
- whats needed to tune?
- cleaning an engine internally?
- port and polish is done.. what to put on head if its gonna sit around??
- z6/y8 question
- Type R TB
- Pounds of tourque on the flex plate?
- Rywire Subharness Install?
- Odd clutch engagement issue
- Crank balancing necessary?
- engine swap, please help im new
- diagnosing a problem..
- More pedal free play with SS braided lines?
- tranny problems?
- mystery trans. Odd gear ratios?
- problem with timing belt tonight , advice please!!!
- Blower issue. Any genuises????
- The Ultimate Honda Engine Code List
- help me diagnose my electrical problem
- ***** HELP! How do you JUMP and ecu/main relay!!!! *****
- 96 civic dx hatch swapin a 98 ex D16y8 code 65
- Relocating battery in engine bay.
- 95 gsr
