View Full Version : Tech / Misc
- b20z intake
- any modification to intstall obx lsd??
- B18b head, rocker problem
- Rev Limiter
- rewiring a harness, or change?
- Tuners in Hawaii???
- Is the civic si engine harness the same of the integra type r engine harness
- Outta curiousity...
- burnt valves?92 DA
- Arp headbolts installing..confuse.
- Skunk2 retainer installation
- Help Needed on B-series Head set-up, What valves with 3 angle valve job?
- anybody know a good tranny rebuilding book??
- Filter on Valve Cover?
- d16y7 w/ p05 ecu and turbo?
- Just Purchased a 1996 Honda Civic
- Weird Cold Starting Problem
- Infamous Idle Problems
- Zex 59300 Cam ... Quiet ?
- S2000 swap w/ k-tranny in an eg?
- Hondata Intake Manifold Gasket
- whats that black box behind the block???
- need your opion
- How to adjust Valve seat/clearnace??
- need advice on engine swap
- Mixed opinions on OEM valves
- good reading for understanding honda engines
- Cam Gears
- Coolant leak
- **Only 1 EK Hasport mount OK? Thoughts/advice?
- biggest possible bore on a d15?
- i need many of ur gusy feedbacks on camshafts
- flywheel ring gear
- What Plug Wires are these?
- B-Series Alternator Wiring Question????
- knocking?
- Zexs control box mounting in del sol
- resinator quetions!!
- tranny rebuild ?.... replace only syncros? or full gearset?
- D16Z6 Head/Block - with d16a6 rods, pistons
- My velocity stack
- Immobilizer/ignition problem on Prelude.. after clutch job,no spark..
- timing adjustment, with a milled head and stock cam gears (b18c1)
- p30 ECU - knock sensor error
- Thermostat problems?
- Installing used o.e.m valves?
- Is ABS good or bad? for daily driven
- greddy bov type s question?
- Putting obd0 motor in my EG, help please
- o2 sensor
- Which throttle body gasket? LS or SIR
- LS Vtec understanding/questions
- Tranny Problem - Hard to downshift into 3rd
- what would u recommend for an old engine?
- Help on wiring up a fan toggle switch?
- Turbo/Engine questions
- tranny pop out
- Rear disc conversion????
- positive crankcase pressure problem?
- awd b18b1 turbo 85 crx needs wiring help
- Car not starting....
- obd2a to obd1 conversion
- tranny question
- obd2 vs obd1 and mods
- Hood wont close!!!!!! with my b18a1 swap?????????/
- Oil Light and Temperature is above High! HELP!
- Removing rod caps with ARP bolts
- EMERGENCY~~~~~- buying b18a1....seller is waiting on answer he is right here....
- How do you all unfreeze the pistons..
- wiring ?
- performance tuning using uberdata
- solid cel need uberdata help
- piston rings.
- Walbro 255lph and B&M FRP a bad combination?
- reading a compression test
- Part Number Engine Harness...
- Electric fuel pressure install question
- exhaust gasket paper
- Engine break-in question.
- Paintwork - apologies for wrong section
- Buddy Club VTEC controler
- AEM Electronics Forum Temporarily Unavailable - 1 month celebration Hurra !! .
- i'm trying to build an all motor beast...
- timming help
- Irritating Sputter
- Vtec not engaging? Needin help!
- ls/vtec wiring harness
- MY B16a1 2nd gen swap switching over
- Porting Victor X Manifold to fit BDL 70mm Throttle Body?
- Another LSD help thread. Is this factory CTR LSD?
- DOWNTIME: oil pump failure
- jdm style body kits
- anybody bypass the IAC (idle air control)??
- d15 block/d16 head
- found shell
- What clutch fits?
- Apexi Vafc2 install help
- Ok i need help with a fuel issue.
- autometer fuel pressure gauge
- size of tps bolts?
- rev limiter/speed cut
- Fuel Cut-off, Hondata s200?
- Will a obx lsd fit a cable transmission without modification
- Fuel Rail washers... are they crush-type washers?
- Losing coolant
- Hondata S200 vs S300
- 91 dx hatch need info for 1.6 si motor swap wiring
- Ls/vtec swap problems!
- Help identify LSD
- Which Exhaust manifold for H22A (N/A spec) should i choose?
- re-build help
- Help D16y6 to B16b Swap
- b20 jrsc
- Electrical Issues
- Electrical experts, I need your help! Inquire within.
- removing oil pump from b18a block
- 00 si b16 valves making noise
- ported ls head vs vtec head
- Looking for opinions on B series clutch/flywheel
- Question about VAFC
- type r crankshaft in a b16?
- sterno heater in air box?
- replaced distributor internals now car wont start.
- Pulley Tool
- car bogs
- e-brake locked up
- JDM headlights ?
- Skunk2 Cam gears = noise
- Valve ?
- b16a + d15b specs
- Water Temp Gauge - Where Does Probe Go? Hose or Rad?
- overheated?
- Chipped ecu and hondata
- vtec wiring/ engine smoking
- What Causes Cluch M/C leak??
- AXEL SEAL!!HELP
- Clutch pedal pressure problem - urgent need help asap
- information
- Cylinder 1 Misfire - Code 71
- ITR vs LS/vtec
- HOW TO: Installing 94+ tranny internals and factory LSD into a 92-93 YS1 cable clutch case
- Fluctuating idle + cooling issues
- Civic CVCC 2door Hatchback ?!?!?!?!
- DRL's WANTED on 2005 Civic
- Cranky Civic 1,8 Vti after changing ...
- Throttle Body to Intake Manifold Bolts/Studs
- Purchasing GSR block, dissassembled girdle????!?!?!
- another ckf Q
- need help with problem
- Car bogs when vtec engages
- Skunk2 ProSeries Throttle Body!!
- 2006 Civic Si and RSX type S engine parts
- Timming belt help!!!.. asap
- skunk 2 intake manifold
- please help me my car doesnt start
- ITR throttle body on d16a6
- Forgot to add oil :-(
- uber data
- Civic wont start??I have no ideal!!
- whats the diff between the B16 Gen 1 and Gen 2??
- what causes this?....dyno sheet inside
- Would it be possible to do an Auto to manual swap in a 1st gen CR-V with an Integra transmission?
- 5th gear pull vs 4th gear, only expert tuners wanted
- TYPE-S ECU QUESTION
- iacv?
- B-series transmission question
- HELP.....high and rough idle @ cold starts....I NEED HELP
- Turbo exhaust manifold heat barrier
- Blox IM
- need help with a B18b block
- OBD2 secondary 02 fix
- 96-00 civic ex and dx lower control arms the same?
- tranny help for a 87' 3gen civic
- Putting back piston problem.
- TIMING WITH MILLED HEAD YES OR NO???
- Aftermarket H.T leads
- code 41 help (thanks guys) b16b with p28 hondata
- Auto Repair/Tuning - education
- Car protection
- I need Help selecting a piston
- Heavy Fluid
- Towing car w/ traction bars?
- Does secondary 02 sensor code send the ECU into limp mode?
- why do the valves look like this?
- Cleaning out Gas Tank?? Anybody done this??
- LS ECUs.... whats the difference between LS ECUs???
- Transmission Seal
- steady idle BUT instantly stalls! help pls
- What the heck's going on with the Honda Jerks?
- A good shop?
- better flowing exhaust = better mpg???
- I have a general electrictronics question...
- taking apart b16 dizzy
- Anyone heard of "Level 10 performance transmission systems" transmission rebuilds
- Gear Speed-Tranny Rebuild Question
- Rebuild tranny or buy a used one w/lsd
- All you pro engine builders and tuners, where did you learn your skills?
- Need help! Will auto B16 tranny bolt up to my LS?? mods needed???
- Extrude Honing IM
- idle control valve on D16Y8
- d15b7 to d16y8 Swap
- Putting Gsr head onto B16 short block questions. easy
- valve guides
- Piston ring question.
- pingin or tickin noises
- Temp gauge goes to hot in seconds
- Is 20w-50 too thick for a B16B?
- engine list help please(searched)
- B20B4 Block B18C1 Head, need suggestions for Pistons/Rods for Boosting...
- Engine dies on start up
- Need help in choosing correct rod bearing.
- 91 honds civic
- Good Shops in Jersey/Philly area?
- 95 stock civic cx 1.5 exhaust manifold question.
- BITCH AXLES
- Lock actuator
- Quick question about installing a ITR girdle on an LS bottom end??
- Cleaning engine/removing paint...beadblasting, etc?
- Science books about IC engines
- TURBOEDIT - How Do You Start? Beginner From The Beginning!!! HELP
- Install Water Pump/ Install Oil Pump
- Valve Drop? Blown?
- High-Pitched Sound When Reving (Video)
- H22 build question
- h22a4 aem ems
- Sleeves in H22- kinda confused
- spark plug wire brain teaser...
- urgent help required!!
- RSX Engine Removal
- h22 swap question (not your typical 'what axles' bs)
- stainless an fuel lines, what size to get?
- can low vacuum pressure cause me to run rich? [installed cam]
- Valves, springs, and retainers
- conrod lenght?
- Ben Strader new book (what do you guys think of it?)
- D16 Question
- Reuse headbolts?
- engine balance problem
- Rebuilding stock axles
- Tranny ?'s
- brake line questions.... what size are the stock hard lines? and where can i find the fittings for t
- trottle body question
- p28 question
- First clutch/flywheel install - PICS OF DAMAGE - WHAT HAPPENN??
- Need Help...Greddy Shiftknob Civic/Teg Pitch-Will it fit 1st gen eclipse?Help...
- Can't get any spark!!
- used K24 short block.. ??
- Code 9 CYP sensor
- Honing a cylinder .20" over /.5mm???
- after taken tranmission out and put it in it doesnt go in gear
