View Full Version : Tech / Misc
- ef to si probs
- 96 d16 block on 93 d15 head...problems?
- suspension advice
- Timing belt question
- Sparks from high speed Braking
- Bench bleed required to swap mc/booster as complete unit?
- How do I relocate the battery?
- what is vtecH?
- Q: Acura Service Bulletins Online?
- Code 14
- 96+ LS/CRV spark plug wires work on B16?
- Valve Springs???
- Very simple, what spark plugs?
- 91 1500 cc motor tired
- 91 civic engine swap
- abs light staying on????????
- what would cause an ignition coil to fry?
- Anyone know where to get a rear toe kit?
- Braking distanse and thread mark
- civic/teg spring question?
- axle question?????????
- Would I need aftermarket shocks?
- Rod shoots through block!!!
- How to start a car that's been sitting for 2 yrs?
- steering ratio modification?
- OT: lexan windows and NHRA & IDRC classes
- water/alcohol injection
- OBD-II ECU Modification
- ctr pistons in b16a2
- Will an LS 5th gear from hydro tranny fit into a cable tranny?
- Exhaust temp, oil pressure gauge..
- high idle on startup?
- Can someone explain what "1.75" means when refering to rod/stroke raito?
- need help please read,motor gone?
- My wont my R start right away?
- Custom strut/tie bars!?!
- BMW Valvetronic!?! SCC Article for this month.
- To: RLrye95 and any others with an LS.
- Roller rockers
- Motor Mount Inserts any good?
- tell me what you guys think??
- Koni yellow question
- Greddy oil catch can question (yes... again... I promise this is a new question)
- NPT fitting in rear of block?
- Best fuel pump for me???
- What is the minimum octane for a JDM GSR engine?
- VTEC's function
- Walbro in-tank fuel pump
- endyn vs. je
- Mechanical or Electrical. gauges???
- Adjustable butterfly throttle on exhaust..info please
- Auto to Manual Clutch Pedal
- B20 VTEC
- why do people buy two wheels at a time, AND put them in the back?
- Can someone explain what I just saw?
- Dual Stage NOS system on a B18C1 Civic
- Opinions on the Jackson Racing high-flow cat.
- 87 Accord Batt/Alt question
- Torque specs
- any one took the whole timing belt cover off the your engine
- Brake pad for the street/autoX...Hawk HPS vs. HP+
- -3an oil line too small for VTEC?
- ECU?
- does weight affect speed of fi cars just as bas as in n/a cars?
- All motor LS, what's next
- Got fuel and spark, car wont start
- push button ignition..
- oil pressure gauge
- b seriers blocks
- free play in clutch
- ITR gears in GSR
- quick suspension Q
- JDM ITR final drive in cable tranny
- BRAKE warning light on intermitently
- Venom400? Is it worth it?
- Tubular Lower Control Arms?
- Autometer Oil Pressure Gauge??
- What kind of HP gains from removing PS and AC?
- Quick-shifter
- Valve spring removal
- VTEC cams?
- MANUAL TRANS FLUID
- need help "monster tack" install
- Re-use headgasket if torqued but never used?
- Tuning Toda B Spec's....
- Help me build an all motor SOHC, please!!!
- help please
- Wiring Question
- selecting main berings
- Help Needed ! ............ can these be done...........
- 95 teg LS B18B - #1 cylender is dead...need some help
- Help with VSS issue (relates to B16)... Please
- civic slow after warm up
- what shocks? springs?
- which ecu for 00 si
- custom polishing on wheels...
- LS Cylinder Head Tech
- HELP! Please, Valves are ticking loud as f*!k after adjustments.
- ecu questions
- DOCH VTEC Del Sol Radiator????
- need some advise on my hoopty
- Difference between Cross drilled and slotted rotors
- CEL's
- Ground cable to the Valve cover
- Oil pressure gauge install
- flywheels
- tow points for jack stands?
- b17 head?
- Think you are the master tech? What is the anwser to this question?
- H22 power
- Opinions on Eibach Sportlines??
- Found oil where it doesn't belong
- oil tube
- removing cam gears without impact wrench
- valve clearance
- Looking for a hi flo fuel filter
- ITR springs on an SI
- Anybody have dyno for LS/Vtec?
- CTR pistons in a B18C1?
- b16 rod and ls rods
- EGT temps relative to A/F ratio
- Exhaust Gas Temperature
- How hard is it to resleeve...........
- BAER Big Brakes on EG6
- question about hydraulic jacks
- The special tools from Helm's manual.
- eg big brakes - need some info
- D block bore? How big can I go, since i have to keep the EGR system.
- should i 'steal' parts for my car
- Persuade me to go turbo or na.
- Is a valve adjustment required immediately after cams installation?
- Web sites for plastiguaging....
- raising the CR on a b18a
- what size is the locknut for valve adjustment?
- Black caked on crap in exhaust ports
- REV Valvetrain??
- learning sources
- Suspension: Rear Strut Bar
- hp ratings
- K & N
- What exactly is backfire?
- Import torque converter makers
- Any differance between the JDM SiR 89-91 and SiRII 92-93 heads?
- electrical water temp gauge, where to put sender??
- Koni yellows & what springs?
- toda camshafts = v-tec killers
- what are the specs for the CTR intake cam
- Maybe a Simple Question but Plugs are weird
- Engine Swap Problems
- Boge chock??? anyone got that or heard about that???
- Emmisions failure, smelly exhaust, check engine code. You be the judge??!?
- A website for OEM Honda Parts?
- PLEASE HELP: What is the website/Phone number for Pro Drive?
- Toda vs. Spoon Sports?
- Which catback for 2.5" header collector.
- Trans pop's out of 2nd gear
- Opinnions on 5W20
- finally got sum loot to spend
- PLEASE GOD!!!..does anybody know how to install an APEXI ITC?!?!? or at least have english instructi
- whats better a 98 gsr ecu or a 2000 type r ecu
- Gotta B20 and have a major reving problem..?
- Gotta B20 got a rev problem..?
- How to maintain a leaking radiator?
- Questions about the radiator fan?
- Re-grind cams?
- Is this normal?
- A little vacuum help
- Help me out with a distributor question.
- Besides the D16A1, what H motors use a 40T cam gear(s)?
- AEM vs. Unorthodox
- Front brake swap
- h22a fit in?
- piston question plz read
- $1900 for complete LS swap into a 91 crx HF...good?
- Engine will not Crank
- Code 20
- CEL light?
- GReddy oil catch tank
- Are 98+ GSR shocks the same as LS's?
- what does a p13 do that a p72 doesnt?
- emgine vins?
- What is "PS"?
- Stupid problem....
- Bent Radiator support
- Throttle Body
- Please answer my susp. qustion before I go crazy.
- prelude rotors on an eg
- car starts, then shuts off WTF!
- Brake problem...please help
- leaking manifold = loss in torque? help!
- How do I mic the crank?
- how high can i rev? wit bone stock ls motor?
- Random Starting problem, changed a few things, and still have no clue, help!?!?
- broken freakin axels
- Running Problems
- Bronze Valve Guides Vs OEM Guides
- Spring rates, How do you find out what they are?
- Heat sink on oil pan
- Anybody hear of "hard spots" in brake pads?
- Check Engine Light Help Please
- Cost of ITR piston install
- Easiest way to raise redline 1000 RPM on an LS?
- Car won't start...?
- TIG or MIG weld's???
- Question: Right side Vs Left side for tire rotation?
- My Clutch Gone???
- New Axles: Does that include a CV boot/joint?
- b16 in 91 civic- having problems.. any input would be great
- edelbrock/jg intake manifold?
- Exhaust build quality...Apexi or....
- Sqweaking clutch...
- suspension question....
- This "Tornado Fuel Saver." Is it BS?
- Car grinds into third gear.
- think my passenger window is f#ct?
- would pcv valve constitute massive oil loss?
- CC'ing Combustion Chambers - b16a head VS. b20b
- max rpm for stock sleeves?
- question about ghetto rear camber kit
- Headgasket
- 95 GS-R TRanny
- How to find VE(volumetric Efficiency)?
- Bosch Platnium +4 ok to use instead of Zex plugs?
- b17 crankshaft in a b18(non-vtec)..
- Flywheel ?
- Z10 Oil Pump
- Best place to purchase Helms manuals???
- Oil cooler fitting size
- which ecu do i need? help!
- Brakes caught on fire! =( Help!
- Water Leaking.. Need help find what's wrong
- Will EF Struts fit on EG?
- help with factory LSD install on b18c tranny
- serial number on block
- My oil is dissappearing...but im not sure how....experts please help!
- will the size of your rims affect your dyno numbers
- camber question
- How tight? Front strut bar
- "HELP" is this a big problem!
- Springs...stiffer, but keeping the stock height.
- Shock time....?
- aftermarket rods
- b18a to b16a swap couple Q's
- engine troubles
- Lower Tie Bars???
- del Sol seats in a Integra?
- coilovers question with stock shocks.......
- HELP with TPS sensor
- looking for an easy way jack up my car
- Is this the same as harder bushings?
