View Full Version : Tech / Misc
- OEM Connecting rods... difference in weight?
- Low Oil/engine smoke? need advice
- emergency O2 question
- Do these target values look safe/good? (hondata)
- Would i gain hp?
- Warming up a car - a myth?
- anything else I should do while installing a LSD in y1 cable?
- B18 Turbo - going over 6k and battery light comes on???
- big brake kit
- cryo treating the crank and cams?
- Oil Pump difference?
- rebuilding gsr block
- TB
- RC 1200CC injector install, need rc clip?
- Gs-R rebuild and break in questions
- Main bearing troubles, please help!
- what kind of cams are these?
- Ls vtec gsr head leak
- Automatic Transmission problem..need some advice
- gm 3 bar map......what car?
- b-series tranny question
- When to expect new rings to seat ? Low compression with new cp's.
- SRP (JE) piston rings work for oem itr pistons?
- NorCal EFI 101
- d15b8 Vs d15b7
- ecu guru help
- Bright Fog Lights?
- b18/b20 oil pan the SAME?
- p72 or p28
- Need advice, 1cm scratch on cylinder wall; Hone entire cylinder?
- Power folding mirror wiring diagram??????? somone posted cant find
- placement of the TWO 02 sensors?
- Hondata Install With Chip Still Inside??
- B18C ARP headstud dimensions
- headlight dim...ground???
- stock injectors, why good enough for NA but not for turbo?
- b16a1 and y8/z6 injector differences?
- Stupid Radiator/Coolant question
- My Bare USDM YS1 GSR Cable Tranny 1992-1993: Begin Rebuild For Boost
- Is this Clutch/Pressure plate F'd?
- Hookin up TPS to billet throttle body??
- Anyone been to Dyno spot racing in San Jose?
- autozone headgasket
- OBD1 VTEC-E distributor same as OBD1 SOHC VTEC distributor?
- is there a tool to change valve springs/ ret. without removing the head
- Header Stud STRIPPED! Heli-coil? Re-thread?
- what axles to use in a k20 swap?
- Retuning Apexi vafc
- Differences between 1st gen and 2nd gen B16 heads
- ECU question
- Help Please.. Code 15
- Disabled o2 sensor uber ?
- Fuel rail promblem
- 4.785 Final Drive upgrade for B16A Y1 tranny
- best combination of parts from 3 engines
- OBD0 to OBD1??
- Aftermarket Knock Sensor Not accurate
- tps question please read
- need syncro part number??
- Still having problem with RSX fuel system
- car wont start crank...
- perfect chip for p72
- Just bought some Muteki lugnuts... and I don't know what to torque them to...
- H23 DA Integra
- question about 99b16 into automatic eg
- fuel pump location for 91 CRX HF
- People with aftermarket steering wheel and airbag resistor.
- code 41 on b16!
- LS rod question
- What is B16 oil pan made of?
- how to transfer data from comp to ecu?
- ATTENTION ALL VENOM VCN-1000 USERS!!
- Oil around valve cover bolt & near dizzy side of head...
- ls ecu chipped ???
- zeitronix datalogging help
- Accel 300+ ignition questions
- my tranny has a p80 stamp..what does it mean?? (already searched)
- totaled pistons or what? please help!
- What size resister to fake O2 heater?
- D16Z6 Fuel filter torque?
- redline at 3500-4000
- to weld or not to weld
- b16a belt tensioner
- Flange fitment, will it fit?
- What you know about: F1 RACING CLUTCH ?
- No reverse in my tranny what should i do?
- hondata or venom chip?
- Innovate LM1 or PLX R-500
- Torque specs and seals (gsr)
- should vtec engage if the car is parked and the motor is reving??
- LOOKING FOR WIRING SET UP(92-00 civic and 94-00 integra)
- Measuring Cylinder Head Height
- anybody has a b16,gsr , lsvtec for sale
- what is a good fuel pressure reading?
- Clutch issue
- can someone help me find a thread
- 2nd gen in 98 dx hatch help
- rear engine mount bracket stress
- d16z6 block, d16a6 tranny, what clutch?
- all i want is a smaller steering wheel! is that too much to ask?!
- Installing Skunk 2 intake manifold on a 2000 si?
- Light white smoke at idle and ALOT when reved.. D15B7
- Sticky Throttle
- black assembled
- Tranny Fluid Mixture for this summer. Check out my mixture!!!
- high flow cats...
- Gas milage problem
- how to wire a apexi S-AFC II to a p72
- skunk 2 ecu program
- Hondata Q&A D16z6
- Shaking problem when touching the brakes
- ECU Issue - Gooped up Chip - Hondata Related
- Odd Problem at the Gas Station
- does tuning change when adding or taking out a/c
- HELP! Bogging/hesitation...possible misfire?
- How to easily remove passenger airbag (96-00 civic)
- Taking piston off of rod? help
- Help with aftermarket clutch pedal assembly…..
- camp1320
- How can I test this injector (electric problem?)?
- Diff between 00 SIR and 00 SI head ??
- Gas Meter
- OEM gsr flywheel vs. evolution flywheel
- Engine bogs/missfire? Problem Drives Me Bonkers
- getting cel but no code
- Intake Manifold for low and mid range?
- rpm switch as vtec controller?
- LS VTEC HEADGASKET
- Anyone have a basemap for GSR 1000cc injectors?
- One last kink to be worked out, SO CLOSE!
- jdm obd1 p72 ecu?
- Valve Clearances
- Cyl. Bore Measurements Results
- OEM Valve Spring rates 93 - 95 D16z6
- pro topline re-ring kit
- Isnt there an alternative to using a JDM style 2.5" exhaust flange?
- battery off switch
- Timing Belt Gear
- engine building parts selection...
- SOHC Cam Gears
- Blox Intake Mani on GSR
- Engine Crane Rental
- Hesitation and bogging???
- car won't start, please help!
- my tps sensor clip smashed in
- b16a quest.
- Installing Pr3/pw0 in 90-91 teg
- Input on brake pads
- autometer gauges
- opinion on valvetrain
- AFC I vs. AFC II
- AC doesnt blow cold = no freon
- DOHC D16 head on D15 block
- Downsides to running very retarded timing ?
- symptoms: deposits on spark plug + burning oils = bad piston rings?
- Would no FITV cause hunting/jumping idle on s200 system?
- Question about 2.4 Inlet muffler with 2.5 Inch Pipe
- Help, what's wrong with my TRUCK?
- Unidentified port LEAKING on my proportioning valve HELP!
- 90 integra MAJOR SHAKING/VIBRATION
- Any tips on removing the crank key?
- Palmlog for hondata
- kaaz lsd rebuild- instructions for different lock up amounts?
- LSD--need HELP!!!
- quick question...all b-series throttle body's interchangeable?
- Underdrive crank pulley in LS/VTEC
- Can the Jackson Racing Thermostat be used for N/A ?
- THROW OUT BEARING
- two gas tanks
- HElp: Cooling hose?? which one?
- What do you suggest?
- b-map sensor vs. h-map sensor
- o2 sensor code clarification.
- Another DAMN starter problem... 90-93 DA9/6s
- injectors clips shaved..... soldering okay?
- need help on replacing my break pads
- cam gears
- What would cause thermo not to open! HELP PLEASE!
- Broken Hood Latch
- plx m300 into 00 integra
- oil pressure...10psi at 600 rpm's and 40 psi at 3k rpms, normal?
- Hondata s200 (extreme newbie)
- Used a head gasket for 30min. and disassembled- Do I really need a new one???
- how certain are you that your engine...?
- first gen b16a
- v-tec controller??
- Hey can you guys help me with some wires
- blowin blue smoke between shifts!!!!!help??
- coolant in oil but good compresstion
- Is this possible?
- Compensator arm, need an answer
- CAN'T GET LOWER BALL JOINT OFF!!
- engine specs
- 00 civic wont start (stumped)
- So. Cal dynos....
- Shifter causing tranny problems?
- TDC sensor
- WHEN I PRESS THE GAS ENGINE BOGS OUT?
- open header ? good when tuned?
- b16 (pr2-3) firing order of distributor
- HELP CAR WONT START
- Anyone know of a good Muffler shop in Clarksville, TN?
- msd ignition install question
- Good Used or Remanufactured Crankshafts?
- Need AEM EMS info (searched)
- stroked b16 has anyone kept the oil squirters
- Tranny Gurus please help....not wanting to shift into 3rd,4th or 5th...B series
- bought s200b, have uberdata socketed p72, what do i do? haha
- crank was rotated wrong!!!!!!!!!
- TQ on Main/Rod Bolts D16A6, Eagle Rods, ARP 2000 bolts
- RSX is hydrolocking itself with fuel! (injectors are staying open) any ideas?
- Need map sensor help.
- Door lock solinoid
- Can b16a1 tranny parts be used in an LS b18a1 "S1" tranny?
- WHATS THE BEST WAY TO GET A VERY STUCK STUD OUT OF A MANIFOLD?
- p28 ecu/EGR code
- P2T ECU and 01 GSR ?'s
- Questions for VAFC2 Install on B18A1
- b16a timing belt
- my first honda swap runs ...now i need help
- Fastline Performance Shifter Review for EM1
- How should I smooth out scarred cams.
- obdo to obd1
- head work
- Tighten Timing belt Question!
- obd0 dizzy
- Alternator Problem.
- Checking Engine Out of car?
- ZC fault codes
- taking apart Comptech Icebox intake
- Autozone Double Silicone Wire set
- stock b20z2 AFR question
- Overheating for over a year. Please help. Details inside...
- New exedy clutch doesn't fully engage/slips
- Can someone tell me what this plug is?
- Temperature rising, Oil Pressure dropping, More smoke at WOT
- Dropping motor from under the car
- >>> HELP <<< Reverse doesnt work.
- timing belt problem
- knock sensor/vtec question
- HELP?
- Need help! answers on why my motor does not start?
- thicker injector seals
- Worth the hassle?
- Timing Belt Ques??????
- question on itbs
- Autronic w/ Accord Coil-On-Plug... Non Honda guy needs info and help
- hondata timing / Distributor
- hondata
- ECU
