View Full Version : Tech / Misc
- RS*R Help?
- Vote your favorite suspension / braking swap
- Back firing
- hole on the firewall after a/c removal
- fuel pressure ???? what to run!!!
- Car died: help
- what do u think??
- B16A3 ECU Wiring Diagram
- alternator problems, again
- jun3 cams w/ ls-vtec?
- Valve adjustment for ZC
- Control and trailing arms?
- Whats the difference between a D16y7 and D16y8?
- what should i do or what do i need before i swap in gsr egine into 5th gen hatch?
- Turn Signal
- 2001 Prelude Sh Oil question Help Fast
- A practical Braking solution for a street/roadracing 92 hatch?
- having problems with the car please help
- Limp mode, need help!
- is this a true dyno sheet.. i thought 5250 it crosses
- what car would you get??please read
- Valve adjustment spec
- Help installing ac on CRx
- What heads can I use in a 95 civic??? DOHC VTEC heads
- New Guy in the Forum
- Need Help w/ my swap.
- Mobil 1- 10w30- burning oil
- need help, car is kinda hesitating
- lighter flywheel
- Question about a seized motor...
- RPMs REV
- Best Compression for going all motor on a B series motor?
- Water Pump upgrade...do you need too???
- Please help diagnose my problem...
- Eibach Road Springs for 92-00 civics
- bubbling coolant overflow tank
- driving without cat
- Fuel injector differences - Rates, type, and performance.
- Dialing out Overlap on Cams
- koni yellows
- Head work
- Fuel pressure and emissions test
- How low is your car?
- What's the proper way to reset you ECU?
- Wiring Diagram For 99 SiR
- engine codes for jdm h22
- Need help installing Skunk2 camber kit! NO instructions!
- Camber Kits, who uses what, and did you install them yourself?
- Any tuners in the Ohio area?
- Resurface the head... Questions!
- PR3 pistons in combo b16 head and b1b8c block?
- rpm cuts off at 3500.....
- How much should i retard timing with 12.5:1 CR?
- Can anyone vouch for Rick Solis?
- How to take TPS off D15.
- cat bad already?
- _AEM Big rotor brake upgrade for civic Si 2000
- *PLEASE Help me with Brakes*
- Need some help with a NON HONDA CAR
- Holley aftermarket computer engine management system?
- Serious gear whine only when foot is off the gas in 1st or 2nd.
- Pin-outs on P30 ECU
- Anatomy of the Honda ECU (or What makes your Honda ECU work so well)
- skunk 2 rear lower tie bar install?
- clutch noise?
- quality shop in va?
- low compression numbers, won't start.
- KYB AGX shocks with Eibach Pro-kits?
- Computer in the car
- question about dual lug pattern wheels
- ITR head on b16a?
- Bolt "stuck"- Rear Control Arm "link"
- ITR DC header install...major probs
- Installed Skunk manifold...Throwing 3 codes..pleasehelp..
- Help: car is shaking like crazy.
- CAI proven to reduce QTR mile times?
- whell clerance
- Head bolt question in 3g Ludes
- I need B16 head stud torque specs
- b18C vs b16a
- Extensive retarding ignition timing = Coolant Loss !!???!?
- how much horsepower?
- ~~~ANYONE WITH ANY KNOWLEDGE OF RYANE MOTORSPORTS STUFF???~~~
- CEL code 1 and 10..help!!
- b20 pistons in a b16a?
- Any differenc between GSR power brake booster and 92 Civic Si power brake booster?
- ES Rear trailing arm bushing installation question
- EE vtec design help?
- Radiator fan not coming on....car not overheating though
- help....code 14 electronic air control
- ticking after valve adjustment
- Car wont start after valve cover removal
- Question about wheel centering rings
- Coil Over Springs?
- 5 lug bearing help!
- Rear drum to disk brake swap for 91 civic
- sleeving my block
- Need HeLP with RadiatoR fans
- Need opinions on engine set-ups
- APR head studs question!!!!
- Can anyone ID these rear calipers?
- MSD SCI question
- does lowering stress the cv joints?
- Oil around vtec selenoid
- how to calculate Compression ratio?
- settings for struts/shocks?
- Hole in Block...need opinions on what to do..
- <<<need tranny help quick>>>
- Ok Need Help with Tranny Problem, "fluids"
- something about a camber kit and an alignment...
- suspension upper pillow ball mount question.
- MSD problem
- 1st to 2nd gear crunch.
- timing belt failure
- How to tell a GSR head????
- PCV Valve necessary???????
- Piston taper???
- Best Locking lugnuts
- TPS re-instal
- gsr vs type r ...not just a which is better but question about both
- Would running the dyno on 17s vs. 14" steelies affect whp numbers??
- sensors on back of block
- 91 Civic Front Sway Bar
- What is this?
- Questions about swaping a automatic to manual tranny
- has anyone actually tried to put a 225/40/16 street on a 7" wide rim?
- Golden Eagle MFG.
- Wiring in power windows and door lock
- Honda Si Idling problem
- help: i cant stop my motor from idling wrong
- HOW TO GET RID OF ANNOYING BREAK SQUEEK??
- Has this ever happened before?
- '90 & '91 Civic Si transmission, Are Si and DX 5sp axels the same?
- o2 sensor placement on 1st gen b16 88-91
- open and closed loop.. explain please
- Skunk2 catback or Apexi N1?
- engine runs HOT, swapped thermostat, still HOT ?????????? aaaargh!
- ctr cams in a b16
- My CRX Won't Turn Over....
- skunk2 vs. ground control
- Put in new clutch help!
- GSR crank& rods?
- Spring rate for 1998 Civic LX Sedan AutoX car
- B17A 92 gsr valve adjustment help
- prelude injectors in B series motor
- --HAVING A IDLE PROBLEM--HELPPPPPP!!!!!!!!!!!!!!!!!!!
- yo katman..i need yo help on this..
- Shift Light
- check engine light
- rear suspensions for strip
- Need help reading ECU codes ASAP please...
- fast insight
- Tanabe: Corrosion Hole in Piping!! Help!!
- racing oil pan for D16
- Failed Smog what to do now
- Bent valves....head damage
- ecu programs?
- d-series and b-series bolts same?
- all the LS/VTEC and B20/VTEC guys
- Where to hell can i get some KG/MM spring
- 00 civic si IAT size
- need tips for swap
- liquid gasket
- Blown motor update
- Hey with wire harness
- Weight of trannies?
- Wilwood & wheel clearance problems
- Honda valve adjustment tool
- Deep Thoughts on block girdles
- dirty oil, best way to clean.
- CV boot ripped...advice please
- Eng Block Choices --> JDM HC vs. USDM & JE's
- IACV question
- Integra LS Cam Gear Setting
- Clutch starting to die..
- ITR/CTR cams question
- Running Rich
- Help: Stand alone fuel mgmt
- Radiator Problems
- JDM tranny question
- suspension in EG
- GSR Exedy Clutch Install
- Torque specs
- slop in camber kit.....
- I THINK I MY RINGS ARE BAD BUT NOT TOO SURE?????
- DIY anit-reversion chambers.
- For those w/ carburation? A few ?????
- ACT or Centerforce???
- retainer and coil bind?
- Grinding noise, or slinky noise on my rear wheels..
- How do you replace ignition key stumblars??
- Broken flywheel bolt
- gsr fuel reg.??
- ticking noise??
- Tokico nonadjustable handling package??
- clutch problem
- Engine mecha
- WTF, cels after header install
- idle problem
- Cold Start..
- tach in ek???????????
- Matrix 24 point adjustable coilovers
- Check engine light
- does anyone have a bosch universal replacement 02 sensor?
- How to repin obd 1 ecu plugs???
- ECU pinouts
- exhaust
- 12.5:1 CR too much for pump gas?
- Who makes good aftermarket valve guides for H22a?
- Vibrating after new axle install?
- Can't shift into third gear! help!
- Oil cooler and pressure gauge...sending unit options?
- Equation for 8000 RPM
- question about removing a/c, how much weight reduced?
- RACE GAS ???
- The Honda PGM-Fi system
- better braking?
- HELP QUICK
- 15x6.5 35 mm offset
- O2 eliminator
- Breaking in a motor... But why ?
- Does anyone know anyting about swapping a 99 sohc vtec in a 89 dx hatchback
- help me choose an a/f guage.
- Brake pad Q's for 94 civic ex coupe w/o abs
- non OBD inline resistor packs
- headers?
- O2 sensor compatability?
- Ideal cable tranny set up
- Overheating question_____Appreciate your opinion___I hate dealerships
- 92-95 SOHC vtec indicator light
- Hyperblinkers, How-to, turn signals
- Removing main caps ?
- Clutch or Transmission died wich one ?
- LSVTEC, knock sensor, and a CEL.
- OT turn steering wheel and (jeep)
- b20 pistons
- Speed sensor?????
- Skunk2 Camber Kit inquiry
- 96 Civic Suspension Question?
- no spark from my b16???
- GSR in a Del Sol
- B18c in del sol
- Engine jolts, check engine light flashed PLEASE HELP!
- Need Help...Tranny Grinds
- does aftermarket ignition system increase hp
- where do I buy gaskets for a.market exhaust?
- What is the normal idle on a B16A2?
- Lower Tie Bar
- 3g Prelude motor tech needed bad!
- Installation of KYB AGX shocks on a 97 Civic
