View Full Version : Tech / Misc
- OT, Customer Service and a pending car swap
- Where To Find Info On JDM B20B ?
- Is 50 psi at WOT to much on a B16 with ITR cams?
- best adjustable lowering springs...
- Vtec controller help???
- Milling heads question
- Adjustable strut and adjustable coil over
- schematic (sort of) and step-by-step of tiptronic button shifters
- Cooling system help - more advice please!!
- anybody ever stip the drain plug threads in your oil pan?
- Possible Accord transmission problem
- Regular or Premium Gas - What do you think about this article?
- Speedometer and VTEC not working.....
- WTF! Tranny housing won't go back together...
- why no early oil change ?
- Your opinions on Honda OEM oil filters vs. aftermarket ones
- Fender Rolling
- resleeving????
- DO I have a bad wheel bearing?
- Dont the RPMs drive you crazy?!
- Maximum Compression for Street (Part Time) Driven LS/VTEC?
- Poll: Testpipe users
- Venom intake manifold whistling like nuts. How to stop?
- New clutch problems, help!
- Right Front wheel hopping at speed and under acceleration??? Help!
- b18 vtec head on b21 block
- Clutch Problems...HELP!
- VTEC wiring in a non-vtec car
- block guard question
- Will Accord springs fit a Prelude??
- Replace my O2 sensor?
- Anybody try this upgraded lighting wiring harness?
- OK, I am going to attempt it in one weekend, and I am going to need your help?
- compression to high or no?
- NOS Help!!???!!
- taking off front LCA
- jdm b16 pistons...Ls block
- Compression Test on motor out of the car??
- 97-UP PRELUDE TYPE S SPECS?
- Type R cams in an LS??
- Need all motor help!!! ugh i'm digusted
- MCU = ATTS? -- PLEASE HELP!
- Big job, can I do it? (springs, shocks, rotors, wheel bearings, and bushings)
- 2000 gsr if i change the head?
- Break in period on rebult motor?
- how to stroke a b16a
- serious stalling issues HELP!!!
- What wires for clutch kill switch?
- tran/diff swap for 89 civic si w/ 1.6
- B20 pistons from JE
- Oil pan gasket part #?
- CTR pistons Standard or oversize?
- radiator.com sucks
- 1rst gen B16 questions
- over heating problem help!
- Help to locate injector on ecu?
- My friend has a problem help asap
- crvtec question
- Vacuum from the Valve cover?
- B16 motor?
- Brownish orange color on spark plugs
- Comptech Icebox ??
- Need Help, Where does the Vtec Oil Pressure pin go in the ECU Clip?
- Need some Opinions..........
- headgasket thickness
- VX rod and piston and deck height specs
- Couldn't get my HID's to work!!!!!!.....
- Chipped VSS gear in differential...:(
- Type R valvespring question
- Raising Compression on a B18A
- How can you tell what year the engine is?
- B16A2 crank in a B18B motor for LS VTEC
- Cam Gear Whining
- Type R springs and Shocks on 99 EX
- Stand Alone ECU's
- Should I buy a vtec oil pump or shim my ls
- relay I think..
- Ignition poll........... Which would you use???
- clutch lost pressure today... help??
- spinoff of head gasket question
- headgasket question
- This is what happens when an engineer gets bored - button shifters!!!
- Tire Size & Brand To go With 17x7 Rims
- Stuck Tranny......
- Clutch loses grip as it gets hotter...what does this mean?
- probs after valve adjustment and plug change
- Which Pistons should I go with in my b16?
- What all should I replace on the B16a when I get it?
- allmotor problems!!
- Spark Plug Wires w/ MSD Ignition
- problems following distributer installation
- is it difficult to change out the distributor??
- How long does a B16A usually last
- Learning how to work on trannys
- need help with field sfc-vtec wiring !
- ???axles???
- roll cage/bar?
- GS-R OEM Springs
- Set rings on axle and intermediate shaft...
- spark plug questions
- Transmission ?
- Can a LS crank fit into a b16 block?
- OT: Help with MR2( car wont idle)
- Loose Wirin Plug
- Valvetrain noise
- Whats the difference between corrected and uncorrected hp at a dyno?
- SRS Light question
- boring out a 1.6L DOHC???
- ITR flywheel
- if i get a turbnetics turbo or a garrett turbo...what else would i need to get it functioning in my
- new chip inside of cars?
- Frank Lin in Sport Compact Car
- Whats the best overall high performance all-season tire out there for the money?
- are there recommended rim size for specific cars?
- Valvetrain, what should i go with?
- Moroso Valve Cover
- will 94-2001 integra LCA fit on a 92 Civic CX?
- JDM P73 vs P30 pistons in B17a?
- sway bar question
- Need Tire advice...
- flow rate?
- HELP MY DAMN CAR
- heat range for compression ratio of 11.5 and..,
- CYP Sensor
- Question brake and brake pad wear!!
- Are Honda rods shot-peened from the factory or not?
- I need spoon stuff, where can I get it cheap?
- Engine Block # ?
- Making a G2 LS fast..on a budget of both cost and reliability.
- shaved emblem clean up?
- Part number
- breaking up when I step on the gas.
- Differential bearings/Casing torque specs
- Is rebuilding reliable?
- How to find Trouble Codes?
- Timing Issue?
- oil pressue issue
- high boost zc
- Zip tie brake lines after coilover install
- Problem with abs, power mirror, and A/C lighting on 5th gen lude
- need help deciding on trans
- servicing injectors
- ABS problem...
- Field's SFC-??????
- To straight pipe or not to straight pipe
- what can i do to my integra ls??
- Alignment Specs: Caster Problems?
- table of gear ratios
- Help Trouble Codes on ZC
- GSR Rev Limit = ?
- I guess this would be considered a modification, but can you help?
- roller rockers?
- Broken Lug Studs on a GS-R
- oem sway bar questions
- Oil burning
- got 6th gen trans question
- venom parts
- Need for speed
- Help! Engine Code on a ZC...
- SOHC question
- squeeking steering wheel, 91 civic dx
- sleeving, and boring a B series
- Shock Question...
- ITR and CTR cam Q's
- flywheel install
- B16A CAMS AND RPM'S QUESTION
- suspension trouble please help !!!!!
- Engine replace..Do I have to pull tranny too
- nitto tires! question???
- spoon cams ? and ctr ?
- Honda Civic Diagrams?
- Ring gear holder-Flywheel
- JDM Oil pump
- ECU wire Diagram for 01 accord 4cyl???
- Question about ITR Springs on my Civic COupe
- Raising compression
- Can a busted outer cv boot cause...
- spoon parts question
- Upgraded headlight wiring harness and higher wattage bulbs
- good dampers for apc coilovers???????????
- Sway Bar Question
- cant get the axle out..PLEASE help
- ABS light (ABS not functioning)
- need help please on auto to manual swap
- Adjustable fuel pressure regulator vs. Electronic Air Fuel Controller?
- Are Beck/Arnley Clutch Master Cylinders any good?
- Fuel Rail Studs?????
- Yet another ignorant question
- Ignorant question from an ignorant member.
- how to tune with vafc?
- prelude injectors???
- valve cover bolts on a d16z6
- different part #'s for piston rings.., which one to get
- type r need pin for fuel pump turn on at ecu
- which cams?
- New York Machine Shop
- CRV in trouble...
- skunk2 vs itr im
- Check out this new honda site
- YS1 Grief.....
- distributer sensors: need info
- Rebuild B17a or use parts for CRVtec?
- Honda Paint?
- B20VTEC machining
- Brake upgrade question.
- Accord Front Upper Control Arms
- Injector size will too big hurt?
- A/C Refrigerant
- Type R Shock Bushings and Bumpstops fit on a GSR?
- Honda's ZC engine??????
- Vibration Damper
- CTR Intake Cam Identification?
- Suspension Tech's Lower strut and sway combo??
- ADVANCED TIMMING
- b16 jdm vs usdm cam question
- question about rims for winter
- Anyone have a Catch Can???? How do you hook it up????
- valve clearance and valve adjustment
- My ECU
- Venom Inake Manifold?
- 2001 GSR Greddy kit
- ECU
- Blinking Oil Light
- Skunk2 intake manifold
- What is an open/closed deck?
- can i use this turbo?
- What size bolts do I need?
- Blowin fuses
- Where can i get an Intergra type R muffler?
- OEM Honda LSD v. Quaife LSD
- clutch cylinder
- Burn oil(fume) come sout of cranckase vent???
- is my clutch dying?
- Need help with wiring crx to obd1...
- Is this a real technical term?????
- where to get cams ground?
- What's involved in an engine rebuild?
- need help car running to lean
- car won't start! HELP
- DYI, instead of payin for labor
- crvtec question
- '89 Civic Hatchback Fuel Cutoff Switch
- EG/EK/WTF?
- gas tank vacuum
- Wiring question...
- coilovers! coilovers! coilovers! UGGHHH
- H22a vs. H23b
- Hydrolic bleed woes...
- vibration????
- HID ballast?
