View Full Version : Tech / Misc
- \\\\\\\\ nsx gauge cluster question ////////
- 2.25 muffler on a 2.5 catback piping
- Nakayama Exhaust
- Wonky speedo
- MAP Bypass Valve question...
- which brand oil H-T??????????
- #3 High Cyl Temp/Wierd Engine Problem???
- cluster parts identification
- how to identify a b20 crank pulley
- H22 Pistons?
- grommets for fuse box
- Distributor Problem.
- **NEED HELP ON RAILS**
- JDM b20b with vtec head?? clearance question
- To Pros, which cams it is?
- b20 cylinder wall finish (also knife edge crank)
- overheating / missfire
- Clutch is slipping and not disengaging? FML!
- CEL for IAT....
- d16 crank help
- cam gear question
- Good, Bad, or Ugly Buy on a Ford Focus ZX3
- vtec pressure switch
- New OEM Block
- Is my gsr block salvageable
- VSS problem...vtec not working and speedo reading high.
- Compression test on a b20vtec?
- B18C1 Swap - No fuel/spark
- a/c light wont turn on in arizona T_T
- ABS DELETE
- Can an ECU be converted from auto to manual?
- anybody know for what engine these skunk2 cam gears are for?
- car wont start
- Harbor Freight OBDII scan tool?
- Cleaning Pistons
- DC2 Steering Wheel/Cruise Button Relocating
- Y8 coolant bleed valve?
- b18c1 no butterflys.....obd1 b16 ecu???
- b16 pistons in gsr
- h22 swap wiring
- Speedo Conversion
- 93 integra needs catylatic converter replacment
- Cleaning AEM DRYFLOW filter...
- vtec help
- dohc cams stuck, wont rotake with engine
- Burning oil?
- brake lights not wrkin
- is this a real JDM d15b cam?
- help me to pass inspection!!!
- obd1-obd2 question please help !!!
- using stock breather box
- Car making wierd sound when warm.
- Car sputtering/bogging around 3k rpm
- aftermarket oil pan
- H22 Ef - vtec not working
- .....what is OEM fan cfm ?
- h22 EF - rad fan not working
- car dying at stop lights when unless revved
- supertech valves or brian crower ss valves?
- motor swap for a prelude i need help please!!
- deal with raceaxis....
- H22A IAB VACUUM BOX ISSUES. PLEASE HELP!!
- Hey guys i have a question about CAMS
- d16 rods in b18
- installing ITR LSD in 00 b16a2 tranny
- Social networking site for car owners - MyPhatRide.com
- Exhaust setup ??????????
- turbo help!!
- Megan Header Welded Tag?
- Mystery Flywheel: Who made it?
- Color Changing LEDs
- intake problems
- EK4 Temp/Fuel gauge out - NEED HELP
- how much torque clutch to flywheel?
- camber question
- How to remove Evap Nipple from Throttle Body?
- Prestone 50/50
- oil light after rebuilding motor..
- failed emissions can u help me?
- Help!!!!
- Main Relay issue
- Fuel Pump help asap
- Car Won't Start... And I'm Stumped.
- Timing issue
- Runnin Hot issues
- Can someone identify the series tires used on these rota's?
- Subaru Brembo Calipers on Civic???
- very good cam write up
- How to Install Integra Center Console onto Civic
- replacing interior carpet
- B20b longblock dilema
- oil leak INSIDE distributor
- B Series Oil pans. Which ones fit and hold the most oil
- B7 blocc TB tensioner
- How Do You Prevent Exhaust Manifold From Turning Colors?
- D15b Swap
- Shift lock problem (2002 Acura MDX)
- Relocating Battery Concept??
- Cometic Ls-vtec gasket?
- honda cam degree wheel/kit where to buy?
- A reputable custom window decal supplier??
- NY: Honda Antifreeze/Coolant Type2
- disadvantages/advantages of open headers
- Block machining questions.
- best place to buy oem bearings?
- help please! car won't start
- lost motion assembly
- Weird Noise Coming From Cam Gears
- slave cylinder problems???
- Need help!!
- sucked some water last night.. any ideas?
- Jdm swaps illegal in ca?
- piston n rod issue... *NEED HELP*
- street tune????
- alternator help
- integra alternator help
- need a good basemap d16z6 zc pistons
- need help
- installed afc neo now got cel 22
- Cable Ls case with cable B16 internals?
- turn signals and speedometer
- are there any shops in or around PA that sell lips?
- Ls tranny with gsr final...
- LMA's?
- d16a6, crank pully rubbing timing cover, Cause?
- dial test indicator
- Need thread on how to remove my b16 head. searched already
- Nippon Rings in GSR Rebuild?
- jdm spoon knock off or 96 ITR header?
- AC compressor not getting power...Need Help!
- AC and leak question!
- Muffler question
- '91 Civic starting problems *please help*
- Vtec Controller Question
- ZC Timing
- stock valve material
- sohc in a integra
- Check engine light Help code 43
- EVAP Smog Questions B17A Engine
- cel help asap
- Oxygen sensor elemination?
- Noise, TO bearing hmmm, can't pin it
- fuel line without banjo/an fittings
- inside of a stock honda muffler
- ARP rod bolt questions (b20b)
- Confused about ACL D series main and rod bearings
- injector seal on IM
- smog issues... failed miserably
- HELP I'm doing an obd1 swap in an obd2 automatic car ....
- Suggestions on how to reupholster door panels
- shaving and panting inside of car
- Who likes shift knobs?
- HELP!!! E85 gasoline car owners HELP!!!
- QTP Electronic Cutout Controller issues...
- JDM B16a SIRII
- octane boosters?
- postive ignition coil
- matching IM to 68mm TB
- car wont start
- OBX Diff problems
- 0BD1 Pistons in OBD2 motor?????
- Sqeek From Dash 2009 Civic Si
- edelbrock intake manifold question
- which pistons do u prefer....
- Steering wheel swap question.
- timing belt lose ?
- 93 EG w/LS Swap Oil Light!!
- Google with a twist, funny stuff
- LSV Timing
- guages
- question about h22 head gasket..please help
- Can I mix my green oem coolant with the new blue Type 2 coolant.
- ***Honda Gurus!!! I need HELP PLEASE!!***
- OEM fan vs aftermarket fans
- Anyone heard of..
- need help code 23?
- Stalls at idle...
- Timing off? low compression/won't start but everything looks OK
- D16y7 head on a d15b ef
- Radiator fitment on k20a help!!!!
- JDM tranny which one do I have b16 gsr or ls
- Please help with my 1700 rpm idle problem..
- Problem Starting up
- Camshaft question.
- NEED HELP SWAPPINH JDM H22A into CB7!!
- need help..how do you go about checking for faulty wiring on a altenator
- p06 ecu with ls swap??
- What is mean by VTi written on Honda Cars?
- ac compressor
- stock b20
- auto to manual conversion help
- good mechanic in NJ area?
- Valve Guide or Valve Seal Help???
- Timing Belt loosens and then tightens again
- New battery and altenator but its not charging why?
- I need axle help. Already searched.
- Will an oil filter leak if over-tightened by hand?
- Type R sway bars ?
- I'm new
- can I check continuity across contact points on dizzy cap
- Brand new duralast axles, pieces of crap? Vibration when accelerating
- purge control solenoid 95 civic dx single cam
- Idle surge! hint(searched) going nuts plz help!
- Oil pressure gauge setup
- Want Custom Avatar..
- 5Zigen Twin mode clutch system??
- Hesitation when lots of throttle given
- Where does this metal clip go to along with hose?
- secondary o2 sensor
- Engine information
- How to clean coolant passages and cylinders
- How long does timing stay retarded after knock detect ?
- PLEASE HELP!!! 03 V6 Coupe 6spd won't idle!
- Water pump?
- Clifford Alarm
- Where would you go to buy new Spark Plug wires?
- Innovate LM1 VS Motec PLM
- cardone axles?
- whole gauge cluster doesnt work...help!!
- definitions please
- Car wont start? Need some help!
- Engine bracket stud removal
- leak down test help
- hasport mount issue
- Fuel pump delay...
- headgasket shopping
- Ls/vtec b20/vtec notching piston valve relief
- Quick question. Plz read
- B-Series Head Help
- valve adjustment question...
- 95 honda civic ?
- d16z6 into a 2000 Civic ...searched
- 1.....O2A - Oxygen sensor #1 stupid but quick question
- Car won't start, but battery is good.
- water temperature
- 2000 Civic EX - Code 1399 & P0302
- MSD help
- nitrous bottle question?
- intake help!!!
- Total Seal Rings??
- b series parts swap? bolts and small stuff
- gsr tb on b16 manifold?
- Speedo Problem in 94 Del Sol
- please help... please have pity
- help!? head gasket or not!?
- OBD2b to OBD1 distributor conversion harness
- Memphis, Tennessee
- what is the langauge on here?
- New Swap WONT START!! HELP PLZ....
- question about plug wire placement...read
