- G-Tech Pro vs. Nology PDA-Dyno
- Gear Oil??
- anti-theft idea
- Fitting Miata wheels on a Civic..
- D16A6 cam in D16Y7, different cam gear?
- itr cams in ls/vetc
- what else would i need??
- DFW local headwork anyone know?
- What has broken on your car at a race?
- HID installation
- will gsr cams give me hp
- aproximatly...how much is it to blueprint an engine??
- What type of a suspension would you go with
- i have a exhaust ? that i need the answer to ASAP
- Do I need to worry about flat spots in my tires...
- where can i buy a cf splitter like this?
- Wierd noise!
- catalytic converter FYI
- Help with braided clutch line please!
- What size is the male fitting on the hard clutchline?
- Cable tranny in Hydro car...
- Rebuilding D16Y8 and need some serious info guys!!!!!!!!!!!!
- GSR and LS main caps?
- Msd BTM install on a civic
- what am i supposed to do?
- P72 vs Pr3 head ?
- Can U help no power out of VTEC
- What generation b16 swap is best for a 92 hatch?
- Help Diagnosing Sound
- would a valve adj make a differece ?? noticeable??
- in need of the truth.....
- Seat wight
- Looking for a Machine Shop in West TN area or close states
- ZC parts 4 sale!!!
- crx engine question
- adjustable shocks?
- Which would be better??
- When should I replace Honda CRX (1990 yearmade) timing belt tensioner?
- What wins Races ft lb tq or Hp?
- Replacing Radiator Support
- little Rubber .......*Warning, lame post*
- prevent fouling plugs after oiling cylinders
- Vibration in pedal and steering wheel...warped rotors?
- CTR Cams
- Snap on tools/valvespring install questions
- Squeaking Noise over speed bumps
- Will 2000 integra Skunk2 coilovers fit 2002 civic si?
- Supercharged B20
- White smoke! help diagnose prob..
- Question on V_AFC unit? (vtO,vtI)
- ecu chipping
- 2000 Honda Civic Vacuum Line Diagram
- Will shift linkage from a 99 b16 si work in a 92 cx h/b
- Restore engine restorer and lubricant
- timing - what happens if you retard it past tdc?
- LsVtec Problems Help ASAP???????
- rebuilding and nitrous.....???
- B18 long block vs. short block ...
- Do you need the map sensor controller with the JRSC on GSR???
- Please help, i'm too PISS off with mine car it's keep boucing at idle
- NEED help!!! desperate!! Type R dies while driving, #3 spark plug wire popped oFF from distributor
- Cleanup of head bolt threads in block...
- Car lost responsiveness...
- what are...Hyperion Coilovers?
- How much does the ITR weigh in?
- Tech Question
- which swaybar for a integra brake swap on EK?
- best chip?
- vtec????
- ls/vtec
- helping a freind out
- removing a/c.. howto?
- need help difference between b18a and b18b
- Field vtec controller settings
- gas problems
- Dart (aftermarket) B-series Block...
- CTR N1 Crank Pulley
- need wiring diagram for fields SFC vtec controller
- LS block and B16A crank???
- h22 swap into a 96 civic
- 90 - 93 Teg floors same dimensions as 94+?
- Alignment question....do I need another one?
- JDM 36 mm axles. Need the intermediate shaft as well?
- **help with timing belt tensioner...b16a**--SOLUTION!!
- which is which?(ecu)
- will this work?
- HELP needed in NE Indiana*SUNDAY-11/24 ! ! ! ! ! !
- Skunk 2 b18c manifold help
- Can KYBs GR2 (silvers) handle a 2'' drop with a smooth ride?
- question about lsd
- Canadian SiR gauge cluster install (help)
- cel code 9
- LS pistons/B16 rods?
- oxygen sensor faulty will it affect the VTEC?
- shift kit?
- best drag racing suspension
- Tachs???
- Reving and acceleration problems.
- how to tell if its a gsr tranny visually.....help! buying tranny tom.!
- What size injectors can you run with the stock ecu?
- 89 CRX engine questions.
- what do I need to make DSM 440cc's work?
- exchanging a h22a1 auto tranny for a f22 manual tranny.
- skunk2 intake manifold?
- Broken reverse
- Help! It's getting cold and heat is not working...
- b18c intake manifold
- Difference in axles
- shot peen?
- flywheel bolts backed out.....
- where is the knock sensor on a jdm B16a
- Toda Spec b valve lash spec's? cant find them
- Installing new calipers...
- wierd idleing problem with integra...
- 1.5l block/ 1.6l head????
- Car wont reverse?
- will nos cause smoke to come from exhaust
- honda ecu programmer??
- no pressure
- Aftermarket pistons (PLEASE PARTICIPATE)
- anyone help me on my header
- Eprom size question
- Buying a block this weekend..What to look over??
- Rewire from scratch???
- what engines will fit in 1975 to 80 civics
- spark test
- trans / clutch (?) problem
- powersteering
- motor problem HELP 911!
- weird noise when I turn Left??
- i need step by step directions of how to wire up my 95dx for vtec.
- cost of used engines in Japan?
- Crank differences between D series motors?
- Weight!
- hybrid question
- What next?
- Best tires for most street yet a little bit of strip?
- excuse me....
- fuel tank pressure sensor
- Cam Dynos?
- jdm r final drive in jdm gsr tranny?
- what size perma fan for fluidyne radiator?
- headgasket/cometic????
- secO2 sensor groundin/bypass question
- h22 in a civic 99-00, its posible w a/c ???
- check engine light on when V-tec engages
- 94 japan b16a tranny ques
- Gas mileage
- Wheel offsets?
- heat cycled tires
- Electrical system's voltage is fluctuating?
- B17a sensors question?
- ok to replace the clutch disc only?
- VTEC and Coolant Temp
- Painting wheels..what temp paint to use?
- Question about the H22
- O-ringing vs step decking a block?
- ground control question
- Propane Injection
- compression ? y8 head w/ y7 bottom end ?
- where to buy Helms Manual?
- DOT5 Silicone brake fluid...
- Eibach suspension
- i need some help...car isnt starting
- How much do 92-93 accord injectors flow?
- I wanna know about installing a Type R engine into a EG civic
- Tearing apart Tranny
- Making tool, are B crank pully same as H
- coolant path question
- Finally hit the dyno see what you think
- Do i have to replace the clutch ??? help me please
- Is this a common problem w/ JRSC?
- thoughs on----------------TODA timing belt=20% stronger
- My civic needs help?!?!!
- who's got engine work done by Dan Paramore Racing in Cali?
- B18c Lsd
- 1st gear on shifter for Import
- B&M fuel pressure regulator
- Power to MANUAL Window conversion ?'s
- Gear ratios
- How to get a hybrid to pass a smog check in SoCal?
- Car won't start after cam install!! HELP!!!
- MAD engine mounts?
- An exhaust: which section is which?!?
- knock sensor question??
- Good B18A Setup???
- Question About a Setup
- compression tester
- GSR making funny noise please help out!!!!!
- JRSC on built GSR
- obd1 obd2?
- ECU wire identifier (3rd gen) Please help
- All B series flywheels the same??
- EF Wiring Gurus HELP!!!
- JDM 4-1 Header vs Spoon 4-2-1 Header! What would you guys recommend.
- failed emissions. need help
- valve train
- What is the best SS?
- Acura parts for cheap?
- Ignition timing is working in reverse. How is this possible?
- vehicle speed sensor is not working properly....
- z6 manifold Q's
- help!
- DX to ZC conversion
- 90 CIVIC DX/B16a repinning dist
- My Accord... ita needsa surgery! Somebodya pleasea help me!
- what coil overs
- 94 cx hatch, swapping in a d16z6, need wiring info please
- Differences between OBDI and OBDII
- Suspension questions
- Hondata Upgrade
- 3rd gen Prelude DIY intake?
- do injectors take signal from ignitor?
- Mugen or Type R Front strut tower bar?
- Standard or Oversized Pistons? Which will u recommend?
- Skunk2 cam specs
- Any one else seen this?
- Help please gears grinding?
- secondary o2 sensor
- Fuel pressure gauge adapter needed...
- B16 timing cover (lower) on a GSR ?
- It was just a question....didnt want to start a friggin controversy
- Why my CRX runs in cold slightly like a diesel car???
- itr pistons usdm versus jdm.
- AEM FPR or B&M Commandflo Fuel Pressure Optimizer?
- where did the lsvtec idea originate?
- Installing Spoon(rear) lower arm bar.
- Car won't start. Electrical or starter?
- Intake air temp sensor question
- car is bogging and stuttering...
- Compression test on stock b20vtec
- How much would it cost to...
- Removing blockguard???
- 4 door GSR tranny??
- Fuel gurus...need help how to read fuel pressure??
- spark plug problem! oil on the electrode side!
- recommended VTEC crossover point?
- sap got all over my car!!!
- splicing wires = bad???
- hondata gurus...
- Fuel adjustment?
- CTR .25 oversized pistons...worth it?
- can an LS block be bored out to 84mm (B20 bore)
- worst case of getting pulled over!
- MUGEN Tools???
- Does Honda make "Rebuild Kits" ??
- why didnt it start?
- Installing alignment kits??
- will a 91 civic dx shiftlinkage work for a 92 civic dx
- 2ndary runners on gsr....fluctuating idle? 2 problems.
