View Full Version : Tech / Misc
- Bumper selection help
- catback cel
- PLEASE HELP! Fuse keeps blowing!
- best place to measure oil pressure with remote filter
- Low RPMs when a/c engages. 92 Prelude jdm H22, p13 ecu
- 2000 sir rear disc conversion help!
- using a northstar timesert
- help me identifying this noise ,, m tired of it ,,,
- acura el 98
- k series fly buy wire to b18c
- Mechanic removed thermostat
- hondata s300 sTrim
- bad wheel bearing?
- itr power problems.
- Air Fuel Ratio Gauge Wiring
- how the hellllllllllll
- b16
- ac problems
- H22 no tach
- Overheated Engine-2000 Honda Accord
- greddy sp2 or mugen twin loop?
- DIY - Color Change your Clock
- Dizzy problem limp help!
- My 2009 SI WONT RUN .. Help!!
- It's getting hot in here...
- Door lock problem...
- blown head gasket can you repair if out of spec
- AC cutting power
- E10 92 OCTANE OR NON ETHANOL 92 OCTANE FOR MY GSR
- Locking vtec with Air.
- 09 si won't start without starting fluid
- Oil: Redline Vs. MPT
- Integra with D15B VTEC
- 1993 civic lx
- My T Bracket Wont align in a EJ1
- Turbo EK shudders when throttle is snapped
- oil filter dimensions
- Crank, no start, freshly built engine
- need help!!
- small crack on header affect wideband?
- Need help with my speedometer
- central locking controle box
- Turbo ek idles low, CEL comes on o2, no power, tried everything
- Parts identification
- I'm Back! Car won't start now!
- need help jdm h23
- CEL pops on but can't check it
- ticking noise? rod knock?
- High Compression + oil pan leak
- Cel code 20 and 41 after gearbox change
- 2002 Acura El Suddenly wont start
- wiring question
- honda b16 distributor
- Summit Racing discount code, anyone have one there not using?
- Valve clearance questions
- Broken harness connector help
- Looking for easiest way to drop B series with hoist?
- Help with my 1990 civic.
- Head Gasket
- please identify this part !
- What is this noise coming from my engine? 00' Accord 2.3 EX
- Vtec block with GE sandwich plate for oil feed?
- PLEASE SOME BODY ANSWER! when figuring out corrct bearing
- engine fault codes, need info
- How low can you get your idle with the adjustment screw all the way in?
- Black Smoke and Spitting Liquid
- Cruise Control Wiring Help-Aftermarket Steering Wheel, Relocated Horn Button
- Eg sedan NO LIGHTS
- Car no start honda civic 01
- I can't find my b16a timing marks
- 92 EG w/B18C cluster issue
- b18b1 swap into del so
- toda rep header where did they all go?
- 93 prelude si ignition problem
- Dont understand how to tighten timing belt
- Car shakes on takeoff... PLEASE HELP
- 91 crx with stock ecu and d16y8 motor
- D15b 3 stage vtec
- 89 Civic LX no spark, new coil/igniter/main relay
- 89 civic si hatch with b18a1 no spark/no fuel prime
- 2 door roll cage fits on a 4 door 99 civic??
- B20b vtec right fuel pressure?
- Honda Logo GA3 Cluster wiring
- RDX Injectors
- '88 civic EF D15B ?LIMP MODE?
- whats this wire integra headlight plug
- Removing rounded bolt
- Some guidance please.
- Help im confused as f*** what dizzy do i use? Obd0 to obd1 swap
- my intake manifold!
- 1998 civic ex not charging Alternator
- D15B7 distributor help
- Purchasing an 06-08 Honda Odyssey EX-L, what recent maintenance should I check for?
- 1990 integra not getting enough power to distributor when i crank on it
- Best Swap For '92 CB7 ???
- Help Identity Sound.. Video inside.
- Broke an IM sensor- help identify please?
- HELP 97 hatch with b16a2 swap ecu problems
- will i be able to bolt a obd1 auto trans on a 0bd2 block and head?
- Scratched cam, scratched rocker arms. Not reusable?
- Stripped tranny thread block side. Can I retap?
- crank but not starting
- Deleting factory 94 gsr oil cooler
- Help identifying an issue I'm currently having
- Needs work
- Speedometer, Odometer and Cluster Lights not working
- swap help
- Parking brake light won't go off after changing drums.
- can running rich after timing belt adjustment
- Need info
- Stuck at Work
- Anybody have EXPERIENCE fitting a DC Teg A/C in an EH hatch?
- 95 accord won't start
- Gas Tank vent line, options?
- are oem honda bearings marked with letters now?
- VSS 96 Prelude vtec problem
- Compression Ratio calculator app for iphone/ipad
- Is this limp mode?
- Itr throttle cable length
- Honda Primo Windshield Banner?
- LMA lost motion assembly questions!!
- california/WA based OEM parts stores?
- Best sub 250$ headers for b16 em1?
- P8R heads
- electeical issue lexus gs
- Head millage with Z6 head gasket to D15B7
- d16y8
- Brown fluid leaking, close to engine mount
- RDX 410 Injectors and S300
- car won't start, help please...
- Shave a distributor.How???
- Turn key to on Position and Nothing. No crank Cel battery oill light ETc.
- Back From the Dead - With Some a/f Issues
- How to gap Iridium spark plugs? (NGK 6884)
- Skunk2 Vtec spool valve Gasket fix
- shock sensor wont let my car start
- Car wont turn
- Strange Idle after the valves clearences have been adjusted
- B16a2 white valves
- NEED YOU HELP WITH MY 09 SI👀👀
- beginnings of a spun bearing?
- California Smog Test & Aftermarket Exhaust/Intake?
- 99 GSR Idle and Misfire Problem
- very simple terminology question (electrical testing)
- odb 2 Bluetooth adapter ..can it work on a non odb2 car?
- honda civic ex 1996 dying problem
- JDM B18c noise video in description
- Gas tank fix, and other stuff..
- help with tuck harness install
- No power on A/C fuse 35
- 95 integra wint crank
- AC Part identification: Can't find on Honda Microfiche
- Generic Fuel pump replacement question...
- Overheating problem on fresh turbo build
- starter shorting out??? help please!
- Ignition problem???
- Need a new muffler trouble finding inlet d size
- 97 Gsr idling problem
- idle issues hswap 94 prelude
- wierd valve lash clearance issue, cam binding
- auto to manual swap, accord chassis prelude transmission question
- Power steering
- About to buy a 97 accord
- what size to bore the cylinders to?
- Hose clamps on rad hoses
- Weird intermittent cel
- ur pully belt size
- Engine loses power
- run a vin for me?
- 044 fuel pump wire help
- Hard to shift from 5th to 6th
- springs/retainers moron tool -.-
- ecu pin out
- 84-87 Civic Hatch FG/CF ZC hoods
- Cam rail difference?
- B18c rattle sound! WTfork!!!
- How to use socket for sparkplugs.
- Can someone help me identify this radiator?
- Bank 1 o2 sensor replacement.
- Car Randomly dies and misfires
- DIY. how much time you spend on actual work?
- Video of Honda Terminal Pin Kits & Tools With Part Numbers
- what chemical to clean/remove rust?
- poll MSD happy or had issues?
- Help my car died!! 1990 integra GS b18a1
- How do I remove crank bolt without pulley installed
- Exahust
- B-Series Starter not fitting
- RHD db8 rear window problem
- main relay brand/quality diffrence?
- 3500 rev limit
- OEM parts direct?
- b18b surging under light throttle
- XADO-engine treatment
- Werid noise coming from tranny
- hondata s300 + PLX sm-afr
- Brake master cylinder outlets plugged up, how much free play should I have?
- b18b timing belt re-install
- need help with ac
- green key light
- Fuel/spark/air/timed but no start
- AC... Clutch or Compressor?
- 06+ Civic si not getting enough fuel to run?👀👀😁
- What is the correct method to bleed all air from cooling system?
- 2009 honda civic si turns over but won't run.
- oil additives to condition seals, your opinion?
- b18a1 injectors replacements?
- Spal Fan Relay
- 1999 CR-V power locks
- Headlight harness tuck/blower removal
- Gm iat calibration help
- Blinker problem
- ac clutch stuck
- p72 Lma question
- Honda Accord mobile charger
- 98 DX Losing Coolant & oil please help!
- OBD 0/1 to 2 Conversion?
- Quick question on eg dash harness
- crank/main journal size chart?
- Gsr Head/valvetrain noise
- a/c install a bit confusing
- Looking for some simple information...
- richewerks 5150
- Car wont move in gear..
- unknown electrical problem?? help!!
- b16a1 fluctuating idle 200 rpm . HELP
- No start no crank..
- how to disassemble pins (HELP)
- Need help with wiring for a 97 honda civic ex coupe
- "Oil" in radiator resivoir
- Civic wont start what could it be?
- Rear lights turn on after park
- 90 integra won't start
- felpro cam seals leaking how many of you had problems with them?
- Stock mounts?
- 2003 Honda Pilot Water Leak
- eBay IAC valve
- RECARO Automotive Seating continues business uninterrupted
- XHORSE MVCI help?
- Quick timing question
- Hondata 4 port boost controller
- 92 civic si Cel always on and no start
- Honda FR-V blocked EGR intake
- Long Warm Up normal?
- STRANGEST CEL PROBLEM EVER!!!!
- 2002 Civic AC question
- Denso or Mitsuba? (1992 Accord F22A1)
- D16y8 oil smell?
- fuel issues like usual
