View Full Version : Tech / Misc
- Hondata cpr + AEM twin fire
- Alternator Outputs
- Anyone know what this is???
- aftermarket srtearing wheel
- LS/VTEC pass smog in California
- 2004 honda accord wierd issue
- What JDM ECU is for the factory Vtec ZC?
- Billet engine mounts
- master cylinder trouble..
- 1987 turns won't start.
- gsr turns on then shuts off
- cam caps question H22
- Does adding water to battery make a difference?
- compression tester??
- Military TMO?
- Bolts for trailing arms and spindles HELP
- BENT RIM & DYNO
- Head Swap Questions
- Disable Canister sensor on S300?
- How 2 Swap A 99 Gs-r into a 95 Ls Teggy?
- 2012 hinda accord exl v6 need new programmed full function key
- h22a turbo
- fuel rail
- Few questions about my b20z re/build & auto
- 92 vx check engine and brake light issues
- Bug-in-oil-tank for an Odyssey... Need advice
- 1994 Civic not starting / cranking
- AEM question???
- B18c Type R... fuel clerificaion...
- New CA smog testing procedures....
- F22 B2 engine help
- Can the IACV cause a lean CEL?
- Vtec Solenoid Issue
- honda civic si 2000 heater not workin
- 2000 ek JDM B18c swap
- H22 Eg swap questions?
- WTB:jdm eg 6 parts
- Weird Idle on 1993 Honda Accord.
- CODE 9, STILL!!
- Adjustable Fuel Pressure Regulator?
- new member help
- Door Harness Problem
- OBD1 ECU
- Civic cluster gauge problems
- Should i be worried? mix matched vins (CHP)
- itr tranny gone bad! need help!!!
- B20 VTEC Overheated
- So my clutch is dying?
- Still some carbon build up after hot tanking
- wiper wiring
- steering and tire wear problem
- Rev (rpm) sticking
- HELP!!!!!! car wont rev past 3500rpm b18b1 ef hatch
- Sudden Rough Idle/Stall - 2008 Odyssey
- bearing question
- TPS ISSUSE?
- b16a2 cams vs b18c1 cams SEARCHED!!
- locked motor?
- 8-valve engine on a 16-valve ECU
- What do i need to pass Ref station
- d16y8 sluggish after rebuild
- 2006 Honda Accord V6 sold in USA vs sold in Mexico
- 97 ex head FIA leak help!!
- Tail lights not working.
- Fake Competiton Clutch?
- 1995 auto to 5 speed question please help?
- Made in USA Honda Accord vs made in Mexico
- Clutch pedal getting stuck to floor
- CDM SRS questions
- PR4 versus P75 Intake Manifold
- looking for a new exhaust??
- differential broke
- Car won't start did compression test!!! Help
- skunk2 tuner stage 1 fake cams
- Jdm B18c5 pistons in Usdm b18c1
- 1990 acura integra engine keeps flooding
- Can fuel injectors go out of balance?
- Kuhneutson valve replacement
- Stumped.... Code 9
- Exhaust port passage
- 1997 b20 civic passing emission question
- Knocking noise in engine
- Apexi EL gauge help
- Looking for part number / application for this gas cap
- Could this possibly be an Input Shaft bearing issue?!??!
- Re-using a clutch? How much material should be on the disk? 4 puck LSD
- Need Radio Codes for 2004 Honda Pilot
- Spark plug heat ranges
- WISECO RING Placement
- my first eg project im 17
- blowing black smoke
- where to find this seal for throttle body
- do valve stem seals affect performance?
- MAPerformance customer service and product review
- first eg build im 17
- Idle problem in my itr swap
- Exhaust Backfire? Maybe blocked by cat.
- low compression
- ls vtec idel trouble
- JDM OBD0 PR3 Intake Manifold help...
- Digital Guard Dawg vs Advanced Keys
- Helicoil crankshaft bolt hole....also thread size?
- Where do I order special sized acl race bearings?
- f22b2 head swap
- What wire harness for 90 Civic DX hatchback?
- rough b16 idle
- HELP!! engine codes
- Engine stalls when letting clutch out in every gear except 3rd
- NAME BRAND AIR INTAKES vs KNOCKOFF INTAKES! FAQ!
- Car stumbles in low rpm Help Please
- My D16Z6 won't start when hot
- uvel vtec
- B16A2 - Engine won't start
- H22 problems
- H22 head on f22b block
- 3in exhaust question?
- Help window problem
- brakes problem
- Element a/c problem
- Looking for ballpark cost to pull unibody
- Window problem please help
- Need help identifying a camshaft
- Car shuts off when braking or large rpm drop
- D16y7 z6 vtec head mini me swap help!!!!
- Power window wiring harnesses for 88 CRX SI
- B series rocker/valve cover material?
- Engine swap
- Wilwood brake master to stiff?
- oil catch can behind block
- Need ignition/fuel system B18c
- Fixable? Or new regulator?
- Instrument panel 1995 AccordLX F22B2
- D15b7 bogging/won't start.
- 91 CRX fuel pump doesn't prime and CEL stays lit, no clicks
- No heat in 99 Civic
- Request smog help
- O2 sensor testing
- Possible spun rod
- why so many b20 swaps??
- OBD0 D and B series distributor the same?
- OBDI B18C - 02 sensor connectors - Helms anyone?
- Integra Type R fuel gauge problem
- Fuel pump relay problem
- Most DURABLE High Heat Paint
- Fuel Fittings. Earls, Russel, Aeromotive.
- How to fix power locks and dash lights?
- EG with b20 aircon issues
- HELP! Trying to BAR a 99 spec ITR in a 93 eg hatch
- 1995 Civic VX - GSR swap - early fuel cut
- Car suspected
- how do you remove old dried honda bond?
- dumb question, quick answer piston help
- Y8 head swap help
- PGM-fi delete
- Firewall tower connector IDENTIFICATION
- Can't find fuel pump fuse 1990 civic
- DNR performance???
- Help get my car all together- Timing and Vacuum Leaks
- H22 misfire/idle issue
- FPR install help
- honda ignitions
- Scratches behind water pump
- Serial number off of engine block
- 1996 ek civic wont start electrical issue Help!!
- Cheap gauge-type sandwich plate to feed vtec head?
- d16z6 swap problems
- no heat blowing
- 94 civic si d16z6 no start
- 1995 Del Sol Si D16zc 1.6, Cranking but not Starting
- Just discovered my seatbelt wont lock
- 98 civic dx runs rough timing issue
- can & should I
- Getting tricky with my ecu (obd-1) another vtec thread
- 93 civic ignition lock assembly changed but no power or start
- d16 not starting...Video inside
- B Series Camshaft..pls identify
- How do I pass emissions test in Texas?
- EG8...Any DIY how to install power door lock?
- Nedd some tunning Advice for B16a
- b20 with p75 ecu lean idle
- Windshield Wipers disconected help. 90 Civic DX
- Educate me on junction connectors
- need quick answer about cel code
- Here we go AGAIN with
- The palace has dropped
- Just as the whole topless
- Intermittent starter delay
- b20vtec leaking oil... new head gasket
- B18 rebuild questions.
- ECU Pin question
- Bar'd
- installing coilovers
- a/c issue?
- Roaming idle help
- for the love of god.. someone point me to a REAL 88-89 crx si cluster diagram
- 89 crx z6/y8
- Problems starting and rough idle
- Dizzy question
- coil overs
- Brand new engine harness Wrapping
- Good Belt for ATI Damper?
- Running out of possible cures for this car
- Deciphering leakdown test results
- 98 civic lx 4 door
- DIY: COP with T1 cam trigger, RSX coils, and AEM EMS v1
- Wheel bearing direction
- NEED A QUICK ANSWER ABOUT VACUUM LINE ON REAR RADIATOR HOSE!!
- i hit a speed bump,and started to leak tranny oil
- Good compression,bad leak test. Sitting, cold, dry motor.
- b18 swap no start
- j32 to 94 acura integra
- gsr ignition timing issues.. very strange
- Strange Starting problem, please help me guys.
- instrament cluster lights
- built motor dd lasting?
- Gagauges not working, obd2 to obd1 posssibly???
- JDM importer in Philadelphia,PA
- The mystery of the dry and empty oil filter
- will a crushed header pipe cause significant hp losss on a stock exhaust h22?
- CKF sensor wire locations, what wire goes where?
- B18C1 REBUILD ISSUE
- wire issure or ecu issue?? help please
- Civic 2008 ac problem
- Strange Sound/Blinking Red Light
- PINEAPPLE RACING PR4-6 CYLINDER HEAD
- Does this look sleeved?
- tough/dry leather backseats
- Machine Shop Bill
- Power cuts out when turning over, after clutch change. Please help
- Civic 99 EX - OBD 3-pin Conn capabilities?
- "secret circuit" box under my hood?
- Whats my gsr swap worth? Condering K-swap
- need help code 7 throttle angle position
- Obd1 Accord and Civic wiring similar?
- Average cost of putting life back into a shell?
- 97 prelude h22 vs. 95 tegy b18
- High fuel pressure
- NEED HELP W/ PISTON RINGS??
- Name this exhaust
- D16 pistons
- Can anyone idenitiful this steering wheel?
- Valve spring compressor; DOHC!
- h22a7 crank regrind
- Which engine mount is this from?
- Need some experience help
- Motor Mount Replacement
- sunroof visor??
- EG6 SIR breaks need info
- Best Rings for boosted b18c1
- RSX Type S injectors in B series LSvtec?
