View Full Version : Tech / Misc
- 4*100 stud pattern steel wheels question
- B16A you can resleeve to get 1.9 right ?
- Oil Pan Gasket Leaking
- How hard is it to...
- looking for Import "market" facts??
- what are the results of detonation???
- TPS Sensor Problem --- Please Help!!
- egine swap question?
- what is done in a rebuilt engine???
- something is wrong with my breaks?? PLEASE HELP!!!!!!
- Headers & firing order
- na screamer?????b20vtec
- car doesnt start up need help
- how do you replace a lug bolt?
- Tips on a custom 2.25" exhaust????
- White "goop" in valvetrain?????
- Engine Additives...PROLONG...comments??
- engine swap
- PORTING AND POLISHING????
- HP and Torque
- hard shifting gears? PLEASE HELP!!!!!
- JDM H22A manual
- Is the B16a1 crank pulley the same as a B18A1 crank pulley?
- B20 crank in b18b
- How do you store a engine???
- Abused engine....
- LS/VTEC ECU QUESTION
- What's the difference?
- resurface rotors before or after new pads?
- boiling brake fluid, pic?
- Newbie questions regarding motor probs...
- computer question
- DON'T BUY FROM SCOTT@PARTSHAGGLER.COM
- Sorry about this, but.. Newbie question
- no cams
- 5 Rules for taking advice
- Need 4th gen Prelude VTEC axel ASAP!
- Connecting power steering hoses
- Honda factory LSD question...
- all motor questions
- Flywheel for B18C
- I am looking for a rim repair shop in Florida or the East coast, Please help me out.
- what high CR pistons to get for x-mas?? any sugg?
- coolant in throttle body
- obd1 injectors w/ non obd ecu
- rotor resurfacing with new pads
- Control arm for a 96 Del Sol?
- Intake Sensor
- Kansas City Dyno???
- forged internals????
- WTB:book on all specs of rebuiding the following..... please help
- head rebuild
- Are crank pulleys worth it???
- Carbon Fiber Hoods
- My power mirrors wont work, whats wrong??
- In car engine rebuild
- ATTN Hondata
- Intake air shield... how to make one?
- Automatic gerabox winding noise.
- F22B1 Vtec. Increasing compression ratio:
- replacing main berings
- dohc non vtec cams?
- 95 b18b into a crx.. HELP
- Larger valves...possibilites?
- whereTB: nuts bolts screws besides honda
- Top power for a civic
- best ecu program???
- Why did my Maintenance Required light turn on.
- ECU Codes
- Valves and all...
- would this give me a 200-220hp 91 ls
- new rebuild-how many miles avg for rings to seat good.
- 370 rc injectors??
- How much power would this give me?
- why do Honda cranks rotate in the opposite direction?
- sway bars does 4dr fit on 2dr integra
- Anyone have some OBDII GSR wiring diagrams?
- spring question?
- Vtec
- Throw Out Bearing?
- Explain this one.....
- extension to remove valve springs
- serious compression problems! PLEASE HELP!
- What is my compression..........
- 91 teg, what should my first mod be? im 100% and need help please
- b18c1, really odd as far as performance goes, need help!
- ls vtec head studs
- Skunk2 Front Camber Kit Install
- B18c1 in a 89 si hatch...
- S1 tranny questions
- neuspeed race+tokico blues=enough dampining?
- i need a new Gasket (valve cover) help..
- brake drag
- ac compressor installation~
- obd1 cat have 1 o2 sensor?
- Problems with JUN flywheel eating my starter!
- Machine shop may have messed uo my head. Please look.
- WARNING!!!!!!! DO NOT DEAL WITH.....
- Tranny leak
- How hard is it to install...
- PHAT IGNITION WIRES
- wheel hoppin
- Throttle Bodies
- Quick HP question....
- A/c install in EG coupe...
- What could cause a cylinder not to fire?
- home compression test
- Oil Leak?
- ghetto exhaust!
- Running to lean?
- 1000-1500 rpm "choking"
- windshield replacement
- Injector problem.
- RC Injectors are longer than stock?
- Need links for PC based OBD/OBD2 scan software..
- wheel centric hub/spacers? what are they?
- Pistons
- Idle question...
- Ping!
- antenna switch
- plug wires?
- valve noise, new valve springs?
- Why does a lower temperature thermostat make an engine run cooler?
- suspension help needed
- Idle too high...
- Mant Req Light
- ECU CODE HELP
- quick question
- Quick Question ASAP, Please!!
- LS head differences from B20 head?
- Knowing ignition timing with aluminum flywheel, SOL?
- Do Integras have a built in skid control system like ESP?
- Exhaust Manifolds
- exhaust
- lsd? (limited slip)
- HOW TO- Remove oem LCA bushings and replace with polyurethane / urethane bushings
- Front Sway Bars what do they do?
- NEED SOME HELP!!!!! Come on guys, let me know!!
- MSD distributor cap for 94-97 Integra..will it fit 98+?
- where is the vss fuse?
- VIN NUMBER!!!!!!
- H22A and a civic hatch (need help)
- speed sensor fuse blows out
- How does it sound, look, feel when you over rev and blow your motor?
- Wanting to put JDM FD and GS-R 5th in a 99 Si
- NA tuners help here for 97 GSR
- Ok Valve adjustment??
- Symptoms of a bad axle?
- How to remove broken spark plug?
- Engine Swap Information/Literature/Website?
- H22A Help
- high mileage valve spring question
- Will 215/40/17 tire fit on a 17 inch 7.5 inch rim?
- Skunk2 coils and Tokico shock
- Feild V-Tech Controller
- head bolts Q's for a b18c5
- need help adjusting tie rod
- has anyone bought an ecu chip from "eg6ajk"?n/m
- does anyone know the 4 digit part # for BKR7E-N-11? n/m
- ticking sound when turning
- Do not buf from jspec engines!!!!!!
- Who makes a decent throttle body for an LS Teg?
- Let get some RPM talk going!
- Suspension question...
- How does a clutch get "glazed"?
- Z rated Vs. V rated ?
- ECU Code
- Anyone using a CLUTCHNET CLUTCH?
- apexi s-afc
- A Pocket Logger Users Perspective
- a question about rebuilding my crx dx motor
- Best place for port and polish for my B18c
- spoon oil pump,
- 96 Civic suspension on 94 Teg
- taking out AC does that mean i cant use the heater??
- How to cut fuel?
- how do i take off the back panel to replace my drivers seatbelt?
- Fuel pump
- Is dynomax any good?
- losing oil?
- B16A into my 93 civic ex coupe
- i found oil in my intake....help..
- AEM Fuel Regulator Question
- JE 11.5 CR do i need n e thing else to be safe?
- cluster swap on a 01 Accord
- Suspension questions
- Are Round body or Oval body mufflers quieter?
- Autotechnic products
- straight pipe question
- test pipe = check engine light
- Rod/Stroke D16's
- Quick question on coolant flow
- GSR ecu on H22
- NA people give me the verdict on ur GSR setup!!
- fuse location when relocating the battery to the trunk
- Tuning???
- Distrubitor
- No High Cam
- increasing Displacment
- Any exhaust guru, please help:
- b16 oil pump on b18b
- Greddy A/F gauge
- When a skunk 2 manifold is NOT enough?
- Front suspension fork!
- strut bar combo for aggresive handling?
- tranny, clutch, wha?!?!
- who is a good shop to rbuild heads
- apex or greddy exhaust?
- are you able to extrapolate from this graph... ?
- damn smoke wont stop on LS turbo HATCH
- Anyone have experience with the Z10 Radius bars?
- Steering Rack?
- When is a MSD type ignition necessary?
- Map sensor problem
- Anyone know what a Code 1399 is?
- Portwork and Rods.
- timing question...need help asap
- Help...$220 +$75 labour for a new seatbelt winding/locking peice
- 99 GSR Tranny question???
- question on GSR head and B16 parts mixed
- Throttle position sensor gasket
- Suspension Techniques Sways? Good or Bad?
- Lean to Rich?
- what does this mean?
- detonation
- rough idle please HELP!!!
- Coming to a stop
- gadgetseller a/f gauge
- my oil has traces of gasoline smells on it .....
- accord auto to manual conversion (5TH gen V6)
- what can i do to make a 91 rs do 200whp NA?
- why cant you just cut and re-thread the shifter?
- good ways to clean engine bay?
- Burning Oil
- abs light came on... one last try....
- Whats a seatbelt replacment cost?
- ECU pinouts
- Tranny questions
- eibach??grand slams?
- Opinions on roller rocker set-ups....
- What's the collector?
- emissions help
- Exhaust pipe broke from flange
- VTEC lag
- Exhaust leak
- Do I need the MSD distributor too??!
- Falling in and out of vtec
- Final Drive Questions
- B20 potential
- A little help with research paper?
