View Full Version : Tech / Misc
- Ok to use Intake Manifold nuts to hold Exhaust Manifold?
- Coating?!
- kyb agx's matched with 1000 lbs springs?
- install: jdm dc2 door visor
- D16Y7... where is the OIL DIPSTICK supposed to go...??? Im serious!
- ASE certified?
- Can Z rated tires be patched or plugged and still be safe?
- installing fuel pressure gauge
- cel after installing vafc "please help"
- cable a1 tranny??
- Timing belt question.
- New member having problems !!!!!!!!!!
- revving to 9k
- GSR Vtec problem
- cel
- Flashing Check Engine
- cam installation
- knife edged crank.
- H22 in 96 civic coupe
- Question about heater that won't blow hot air????
- who has the es muffler?
- Compression Cause a Problem???
- Will 5zigen fireball catback exhaust made for a civic DX fit my 99 civic si???
- f22 pistons.
- help! i need link to FIELDS Vtec controller wiring
- Eratic Idle - Ideas?
- fuel pump question
- identifying cams???
- ignition timing
- TPS sensor 1990 CRX
- Please Help!! o2 sensor problem??
- vehow much hp?
- Gauges????
- low oil pressure light?
- is there a High compression Head gasket for a B20?
- rear brake conversion prob
- ring gear for CTR LSD
- Compression Ratio
- post cat o,2 sensor
- squeaky stearing?
- hid and projector??
- Balancing rods
- best exhaust?
- Heard of Direct power system? look and tell me what u think
- quick question on Nitrous
- CEL 22 & 43...HELP!!
- TE37 wheel weight?
- portflow inners, which end up???
- Ground wire size
- Main battery fuse keeps blowing?
- speedometer cable (buy inner or outer)
- HELP: will a 1999 JDM itr suspension bolt onto an 1999 honda civic coupe?
- Any disadvantage to using a "cherry bomb" muffler?
- swapping out for a jdm b18c5
- Shaking steering wheel!!!!
- venom chip
- Peeps who have cracked sleeves on the B20 got a Q for ya
- SAFC - Throttle voltage?
- can't do anything
- car smoking help?
- axle
- How do I know if the distributor is sparking on exhaust instead of compression?
- R-1 Ground Wire install???
- b16 won't start
- If you wanna learn about how engines work.. check this out
- Buffing tail lights ?
- AEM alternator pulley
- Identify this unknown intake manifold!!!
- Shipping a Tranny?
- Victor X people, what did you do about your IACV?
- Stock LS/VTEC redline?
- CARSOUND cat...witch size should i go with?
- tie rod bushings out?
- Suspension
- bogging and misfire in B16A. help...
- B16a wont fire up after valve job/milling. Help please!
- 96 se exhaust
- LS/VTEC VAFC settings?
- Shifter Bushing Install Question
- Exhaust Q: Mandrel bend vs Machine Bend?...is it worth it?
- h22 type s valve specs?
- Ground Wire Kit?
- 94-01 GSR intake manifolds all the same?
- ITR gears in a GSR Tranny
- D16Z6 with B16A1 pistons
- 5 lug conversion????
- question about greddy evo exhaust
- Looking for a OBDO to OBD1 Harness
- All Motor Pros I Need Input
- Bogus Dyno #'s?
- rpm problems...HELP!!
- water temp gauge install??
- P13 vs P72, info requested
- easy way to make your own vtec timer, take a look.
- oversized throttle body?
- 1987 crX Si B17 Swap
- Just traded trannies... no reverse
- OBDII --> OBDI, which O2 sensor do I keep
- H22a Swap
- what about this combo..
- what is this??
- egr blocking plate
- ZC block with SOHC Vtec head
- Need a new engine (JDM)
- which is better...
- Stupid question..... Si owners...
- WHY oversized???
- Polyurethane Suspension Bushings
- ****East Cost Honda-Tech Meet****
- Custom exhaust pics...
- anyone else build thier own test pipe? if so look inside please.....
- leakdown test results- help!
- Information required regarding A/F mixture when crank starting.
- Question about spoon progressive springs
- iacv problems
- got oil on clutch disc, what should i do?
- Cam Gear degreeing....Help
- Cross-threaded bolt...help!
- correct fuel pressure
- exospeedAMcrx please read......slicks and rims
- what size flare nut:fuel filter
- b18a need your input!
- Tips and tools needed for painting interior of car...
- Bike engine w/haltech EFI... I am at my wit's end
- ECU pinouts
- My car died on me.
- New Clutch
- D15Z1 to D16Z6 Question
- LSD Dx tranny ?
- ls or itr rods
- Turbo Install - need help with oil pressure sensor and O2 sensor...
- B16 Compression Test
- power stearing boot removal and instalation
- Throttle body size?
- Anyone hear of an HX transmission? Gear ratios?
- Cam gear ?
- How to built a custom *shift light*
- ECU's?
- Air fuel gauge issue
- Compression ratio calculator - D16A6
- should i remove my honda civic vti cat?
- What tool do i need for fuel filter?
- First Import car, questions about max HP....
- code 8, tdc
- Hesitation and some other
- car is overheating!!!!!!
- Good non-cold air intakes.
- evap
- leaking gear oil from tranny
- check engine light 90 wtf?? this is a first..for me
- Is it better to engage VTEC at a higher RPM or lower?
- crank pully tool
- GSR Tranny Casing Removal *HELP*!
- Whats a good suspension to put on a civic 93(gsr motor)
- Autometer water temp guage install
- intake question...
- LSD for SOHC????????
- TDC Piston Question
- ls/vtec+N20=rod piston ideas?
- Please answer this for me?!!
- ls turbo vs. ls/vtec turbo
- head milled to much !!!!!!!!!!!!!!!!!!1
- Engine trouble, need some help.
- Help
- What do you think of this setup, i need opinions.
- *****NEED Pin Number and Location for a B16 ECU ASAP*****
- URGENT HELP on cam bolt specs for B16.
- Who has a hondata and lives in CA?
- how to convert obd-0 to obd-1?
- do koni adjustables need to be broken in?
- Dead car..what to check next?
- ACT Clutches??
- Camshaft lubricant
- B16A1 Timing belt help
- b16a1 plugs?
- HELP: i hate my car (kinda long)
- Accessory terminal in the fuse block
- Wiring in new sensors on B18A LS/Vtec swap
- Minimum , ideal M&H slick pressure..???
- b18 parts
- i wanted to know if i could combine a LS block with b16a1 internals and heads and everything from th
- Where to get a block sleeved?
- SOHC Tuning, help w/ ideas.
- How can i run on my crapped out carsound?
- air fuel guage not working
- steering pulling left to right????????
- b18c5 or build gsr??
- Camshafts and Cam Gears... Power gains !?
- bent shell
- Please HELP!!!
- 4 wire o2 needed for EF LS/Vtec with ODB1?
- koni yellow shocks
- Throwing code = richer fuel mixture = killing o2 sensors?
- Jun Cams
- oil gauges
- Hydro vs Cable What's the difference and which is better???
- 1992 SOHC Vtec
- tranny question?
- Benefits of a test pipe on a 1999 Si???
- lifting a wheel while driving bad?---in an lsd equipped car?
- pros and cons to an 8lb flywheel for daily driver
- Possiblities?
- Mini - Me swap for a D16y7
- code 12 and i dont have a EGR valve!?
- Installation of Integra Type-R intake manifold on B16...(LINK)
- Low 14s with b16a1
- vtec controller problems
- Problem checking CEL codes.. HELP!
- Wierd prob with ignition help please!!!
- ctr 5 lug conversion??
- which temp thermostat should I be getting?
- Cam duration?
- help with b18 swap into eg...
- Cooling Fan not working?
- Tokiko Blue shocks. What's the highest spring rate that they can handle?
- Sizzle???
- What's the oil pressure on a DOHC ZC?
- Who makes ES Tuning mufflers?
- About Anit-Roll kit
- 1st gen CRX with D16 VTEC (is it possible)
- SARD adjustable muffler?
- Suspension bottoming out and hitting frame, HELP!!!
- Apexi WorldSport Catback Exhaust
- should my new tires fit alright?
- 00 Civic Si 52 codes?
- Is there a way... arp rod bolts
- i have the best honda
- dynamic compression questions
- LS-Vtec oil lines tought.
- ---------->Brake Lines<-----------
- '00 Accord procedure for MIL
- What's the highest compression i can run on 94 octane...
- What's up with those Strutted rollerwave pistons!!!
- Best Gears for all motor?.....
- anyone ever had their cracked ceramic coated header welded?
- ZC Seems to be rich. White condensate smoke!
- b16a w/ skunk stage 2 cams = what hp
- What is this?
- Type R Springs, Retainers and clips
- Adjusting -2 camber with washers?
- Cam Question....
- Air coming out of intake?
- Belt tensioner adjustment....
- A stroked D16...Is this a possibility?
- Single cam after market axles??
- stainless welding with mig welder ?? HELP !!!
- compression numbers....
- anyone have their powerslots warp on them?
- civic Master Cylinder Q's>>>
- does greddy still make evo 4 92-95 hatch????
