View Full Version : Tech / Misc
- Autometer Monster Tach goes crazy over ~4K rpm
- d16z6 in a crx...
- Emissions Problem..... Need some advice.....
- HONDATA program for B16A obd i need a program of someone that has cams in there car
- Silly Civic EX... (automatic tranny)
- TYPE-R springs and retainers and CAT cams race cams that have alot of lift?
- torqueing flywheel and clutch
- What is normal oil temperature? *tryed a search*
- Obd-1 Pr3 wiring
- opinion on kyokugen lugnuts
- my clutch is gone!!
- hp??
- '92 Integra Suspension Torque Specs
- Need carrier bearings for Quaife for J1 tranny...
- Detailed compression test results..please look
- inpust shaft bearing question ?
- installing cams, valve springs and retainers - need to take off the head??
- B16 header on B18 motor?
- squealing noise
- help with transaxle removal please
- Hondata GSR P72 Question
- Altanator/Battery Problem
- oil pan=same for gsr and type r?
- rich or lean and skunk2 ecu??
- what are those mufflers????
- PCV Valve, how it works?
- Need clearing up on BackPressure theory
- Accord type r steering wheel question
- Stroke/Metallurgy/redline
- give me a diagnosis
- opinions on gude?
- Throttle Position sensor
- Problems with AFC...
- Manual tensioner bolt?
- VAFC Problem HELP!!
- Letter marking on the itr cams and gsr cams oil hole
- Analyze this compression test please
- Bottom end work on B18C
- ECU Pins for map sensor and sensor ground
- How to identify itr cams vs gsr cams
- List of possibilities for burning oil
- jdm itr tranny
- Can compression test number be off due to very hot weather?
- what tires for 7.5" rim?
- B20 ECU? Does it not fit on the wiring harness or what? (why get an LS ECU on a B20?)
- CTR cams question
- Skunk2 ECU help
- Mysterious CAI whistle and more hp before wot.
- Asking for Honda warranty advice
- Power steering pump and AC Compressor help!?!
- comptech sway bar and N1's
- What should i do??
- Question on high revving
- are gsr and b16 timing the same?
- JDM/USDM Exhaust System
- keeping a cylinder head for future use
- Is P73-2 head ITR or B16A?
- Shock/Strut Ground Control help...
- spark plugs, suggestions/help anyone?
- tuning questions, please help
- Will Itr Cams drop in stock gsr valve train
- My e-brake doesn't work!
- importbuilders.com crated motors?
- Final Drive Question
- JDM distributor/wiring help!
- worn lower balljoints
- i need a little more b20 advice
- Do the shocks/coils of a ITR fits on a GSR?
- Bad Wheel Bearings? Help Diagnose...
- Toda Flywheel question???
- 98 dx hatch cat coverter question
- engine lift wont lift...
- h22 eg swap..fuel pump ???
- CEL with 2000 gsr testpipe
- What causes a high NO reading?
- My engine is blown.. what do i do???
- please help my 2000 integy a/c doesnt work anymore
- Civic Jitters?
- b16 or ZC
- b16a compression
- Exhaust Question ? ? ?
- How to adjust alternator to replace belt on 92 d16z6 engine...?
- Difference between the ITR head and B16
- Question about underdrive pulleys
- Port and Polish???????? questions!!!
- Brake issue. Wheels whinning and dining all the way down the road. Need Help ASAP
- engine feels like its quitting
- Compression Calculator?
- *#$king nokya bulbs!!!
- gc/konis or teins?
- are there any numbers on the engine that tell what yr. it's from.
- Does anyone make an intake like this(see pic)?
- Just rebuilt the head of my teg, is there a break in period???
- Installing an LS 5th. gear in a B16 tranny..how difficult?
- NGK BKR7E's, what's the Bosch equivalent?
- Skipping IACV?
- CTR pullies? are they different than my b16A2?
- Race Engine Break In Period???
- Recommended spark plugs for high comp CRVTEC?
- what to do about rust on new engine parts
- bogging car
- RE-pressurizing my AC?
- NEED help!!!!!! CAr running like poop!!!
- How long does it take to install reverse indiglo gauges????
- Catalitic converter
- comptec intake?
- Putting in a bump stop so the clutch pedal can't go all the way down
- water wetter ????????
- Y8 + Z6
- Spring Rates for Integra Ground Control Limited Edition?
- mass air flow sensor ?'s
- How to bypass the VTEC oil pressure switch?
- TEIN NA Suspension?
- I need advice and quick!
- how to use plastigage?
- SI sway same as GSR?
- Please help>online parts catalog
- best motor setup?
- GSR muffler
- Clutch Pushrod Adjustment?
- Some sort of electrical problem I think...
- b16 w/ gsr internals.., is it possible?
- 96 Honda Civic Idles up and down
- O2 sensor....which wrench size?
- Wanted: Help on DIY Programmable ECU project
- b20 vtec c.r.
- Please help 2001 GSR starting problems
- CTR cam(s) for a SC'ed Si
- Swapping Parts Question ??
- Shifter problem, hlep!!!!!
- JunIII's with stock cam gears?
- modifying KYB's to fit ground controls on an integra??
- Why am I running lean...
- Nos kit on b18c
- What is need to make CrvTec OR lsVTEC Reliable?
- Blue Smoke-STUMPED-ATF cleaning related?
- Drivers side motor mount
- Steering Wheel Vibration - Please Help!!!
- ITBs Question
- bent valves? heads off, now what???
- help will these wheels fit my car!!!
- is it ok to turbo my b16a with skunk2stage 2 cams?
- Anyone is using Unorthodox Alt and P/S pulleys with a stock crank pulley?
- D16Z6 Head gasket question...
- bypass oil pressure switch
- Hondata Stage2
- VAFC setting
- Websites for tearing down a block to send to Golden Eagle???
- misfiring (I think)
- Putting stock header back to mate to aftermarket exhaust.... need bolt sizing for teg
- Hole Shot?
- how to check REAL MILEAGE on a bseries car
- mini me problems
- Header wrap
- What drivetrain loss ratio do you use?
- 89 Accord Cooling Problem
- HELP with intsall...vtec head on my dx engine
- Cheap Engine mods
- Point of B16B?
- 93 civic dx swap d16z6
- distinguishing different camshafts...how?
- ECU Questions..
- Old School help
- question about b16 to GSR swap
- H22A1 dry sump questions
- Milled Head Compression Increase
- Help getting springs and retainers out
- Anybody have any engines for sale
- installing a fields Vtec controller
- How does V-Tech mack your car faster
- neon plug wires
- injector size
- Oil Cooler
- Oil cooler sandwich adapter
- Fields SFC Controller and problems with MAP?
- I'm screwed!! NEED HELP!!!
- bumpy skunks
- O2 Sim
- need help about zex
- GSR intake with butterflies removed?
- ask long as it works right?...
- Distributors
- Wheel align needed?
- Is the HP JSpec Canister Exhaust Good?
- sohc vtec in a 89 civic
- Tranny problems
- turbo b16 vs. turbo b20vtec
- JDM FD in B16(Si) Tranny?
- PVC makes a good cold air induction
- Torque Wrench... Is it needed to re-install the valve cover???
- Higher Octane Gasoline?
- speedo cable broke at VSS
- CEL#63??
- Ignition Timing adjustment?
- Honda Acura Manuals
- New spiral exhaust?
- NGK-R bkr6e-11 and bkr7e-11 honda part #
- spring ???
- Shorted Wire problem.. any Electrician or Experienced Techie here?
- civic fuel lines
- ARGHH! Need help/advice on Broken Upper Ball Joint
- maximum bore on GE sleeved/o-ringed b18c block? 84mm?
- 99 SI lags @ initial take off...
- Washing out rings, can someone describe that?
- will this fit?
- Zc motor swap
- what to do?
- noise from the timing belt side of the motor...
- Can't get into 4th sometimes?
- B20B or B16A? Please Help Me Decide.....
- Are highway miles better or worst?
- radio wont show "CODE"
- cam question
- anyone have problems with skunk2 spec 2 cams and valvetrain????
- All motor b18b1
- are DX and SI starters compatible?
- $&*&*^ Idle sucks!!! Cannot adjust lower. No Codes.
- B18A vs B18B
- code 22
- Just installed fastbrakes 'SpecR' 11" rotors and ITR calipers on my 99 GSR.....
- Alignment w/ new tires?
- Fuel Pressure..
- AARRGGHH!! - Car wont start, no crank nor turning over
- Mini Me on 90 HB STD............PLEASEEEEE READDDDDDD
- my engine oil is coming out black and watery!! help!
- technical shock suspension question
- gauges does not work....
- tranny problem, please help
- tranny problems
- How to: modify your stock EG6 civic seats into supportive buckets!
- intercoolers and turbo
- What's the best engine assembly lube?
- oil pressure gauge readings
- crank oil seal replacement
- How to precisely check timing with a digital light?
- What do you think of dynomax super turbo muffler?
- Rebuild Or Buy a New Engine?.......Advice Needed!
- 1.5 liter 95 honda hatch back
- norm for temp gauge?
- Sporatic bog with B16A1 CRX...
- what size O-ring?
- any tips for finding a vaccum leak???
- My civic is loud as hell for no reason????
- Help!!!! I think my motor is F*cked....need tech help
- oil burning question...Urgent...
- cutting bumpstop w/ shocks & springs installed
- Best VTEC engagement?
- ABS removal from a gsr. know what i need, how hard is it to do?
- Creaking Noise when I'm in reverse...
- HELP... Noid Light Testers...
