View Full Version : Tech / Misc
- Hammer-driven Impact driver same as impact wrench?
- Anyone have any expierence with Nippon Piston Rings?
- 4th gear broke
- Is there an expected mileage for my Head gasket to go at?
- dyno tuning a relativley stock jdm b16... power to be found???
- RS Machine
- Zdyne wiring document help
- Sealant for fuel feed line... AN fitting?
- Problems with Datalogging!! Damnit! 56k be patient
- '92 DX P&P D15B7 or Z6 Mini-Me?
- b16 tranny y1 and/or s1/j1
- Skunk2 S2 Black Valves any good?
- Nice Surprise
- ECU lookup
- newb engine question
- fuel pump issue
- skunk2 any shorter than blox?
- cranks... but wont fire
- tachometer installed but doesnt turn on
- vtec ?
- CEL 41 - Primary Heated O2 Sensor
- Do u need to remove the axles from hub to remove engine?
- S-AFCII or vafc
- h22 head on f20b block
- k20a IN A TEGGY
- >----B16 repair...HELP-----<
- oil pressure sending unit - to cluster only or to ecu?
- Help with Sleeving
- anyone chip ecus around los angeles
- Complete LS Swap Pricing
- endyn
- b16 sir ii main girdel
- retarding cams
- stripped starter bolts
- countershaft and mainshaft??
- VTEC Rockers
- whats the best ecu chip for my set up?
- k series closed deck?
- b16DA9 sputering after spark plug install???HELPP
- VTEC killer cams
- want to build up a transmission
- proper way to break in
- GSR Throttle Body Question
- Failed the nox test Need direction
- turbo pistons for a turbocharge b18c1
- Direct Port?
- compresstion test results-180
- uberdata, getting started
- Header question
- Golden eagle dowels / ls vtec
- motor swap needs wire diagrams
- My GSR runs like a RED HEADED STEP CHILD
- GSR runs like a red headed step child
- How do you make a manual fan control?
- skunk2 chipped p72 question
- REAL High-flow cat
- Need help, lsd problem
- temp sending unit part # crossover?
- where to find some OEM Honda Rods?
- HELP!!!! car wont start!!!
- Greddy A/F Gauge ??
- Arp toque spec?
- CEL #1 won't go away !
- ignition problems
- D16A6 Timing belt fit other D series?
- B18C GSR Head with IM
- Engine Swap Info
- VTEC Problem
- LSVTEC running random CEL +bled clutch still kinda soft. HELP
- is knock to high?
- Safc values
- cel video
- Automatic transmission lock ?
- Cleaning bare block.
- Is this Smart :) or Dumb :( Idea?? Switching ECUs?
- Auto to Manual conversion questions... need help
- PCV valve hose size ???
- annybody know where 2 find some ignition inf. i need 2 write a essay
- What ECU is this...Auto or 5 speed?
- arp bolt stretch???
- Pistons, valves, and spark plugs looks funny... can somebody chime in!!!!!
- Magnaflow Mufflers
- SOHC OBX/quaiffe LSD, if you have one please help
- engine harness question
- Problem with reading ecu codes
- bad engine leak - whats causing it?? pic incl.
- Is there such a thing as upgraded rod bearings ??
- Should I upgrade my LS/VTEC stock rods ???
- gsr/ls pistons
- B20vtec owners I'd like for you to post your 1/4 and set-ups. That involves your tranny too
- LS Turbo
- Rsx Type-s 05 Mod Time
- 99' integra GSR timing belt help
- need help on Ls/Vtec
- I was talking with my freinds about fuel pump rewiring...
- B series coolant line question...
- H22 IM stud broke off
- Estimates of how much HP my tranny will hold?
- What would you rather use hasport rear or jimfab rear?
- cam overlap
- removing vtec oil passage plug in head
- Is there anyway to determine a cars exact redline after it's been hybrid'd?
- aem ems tuning
- smoking while only in vtec and some times when first start help!!!!!!
- Not a Honda Question but PLEASE Help me out!!!
- Driving at 6K rpm's.
- toda b cam charater?
- b18c engine swaps come with clutch slave cylinder?
- need help!!!!
- check engine light with hondata s100. pls help
- will porsche injectors fit honda/acura rail?
- Tranny Identification B-series
- I NEED MORE BOOST.....
- weird looking plugs (pics inside)
- alternator for my b16 integra???
- vtec and gas pressure???
- head question
- Auto Meter Gauge???
- I HAVE A PROBLEM:((
- sputtering hesistation
- H22a standard internals power rating
- b16 head gsr block
- coolant filling up overflo tank
- obd0 pr3?
- Head work
- can someone gimmie some info on wut my better option is?
- MAIN GIRDLE BOLT QUESTION????
- itr pistons on ls rods
- brake lines...need some advice
- Deleting the use of the IACV?
- spun bearing???
- mp
- 91 si....1.6 head same as 1.5????
- breaking trannys...
- obd1 b16head on obd2 gsr block?
- Valve adjustment problem
- will a header for a f22 fit a b-series motor
- 240cc vs. DSM 450's Vs RX-7 460's (pics to compare inside)
- making a header look good again...?
- CV Joint bearings question
- HeliCoil Questions. Please Help!
- ding in crank pulley
- Help me with my timing issue on B16
- JDM D15B CAM vs D16Z6 CAM - INTERESTING INFO
- Socketting a p06 -- What DIGIKEY #'s are needed
- Who sells K series motors?
- ys1 cable...ls and b16 the difference
- ITR P73 Integra OEM Rods & Rings Part Number Request
- How to set VTEC controller APEXI V-AFC
- Radiator leak?
- Unhooked Evap Purge control solenoid
- it sputtered at 6500
- Where can i get specs on gsr cams?
- 8500 rpm, then pop, now crazy issue ???
- Help! I need Wiring Diagrams
- 96 to 99 climate control conversion (no light!!!)
- quick question...
- B18c1 SWAP INTO A EK, WHAT HARNESS DO I USE?!?!?!
- hondata s200 throwing O2sensor cel
- How to check the o2 heater circuit?
- clutchmasters ?
- ferea valvetrain rpm?
- Nos spray for the intakemainfold
- Dash clock??
- wtf, why are my distrubors going ....
- plx devices r-500 r500, ANY GOOD?
- question for anyone who has a stage 2 clutch and 8lb flywheel
- ys1 tranny..the difference
- Idle surge w/ac off
- Do-it-yourself timing belt kits: embrace or avoid?
- soggy stud
- Help..What HOOD CABLE RELEASE do I use for my jdm itr front end?
- replace o2 hondata
- i dont think my injectors are firing help (will pay for your time)
- HELP: timing question
- Would a bad main relay cause surging at part throttle?
- running rich after new header
- engine choppy at 4k
- Putting an obd1 engine in an obd2 car
- Camgear angle
- due to a mis-shift #2 cylinder has low compression, engine chugs at idle, ideas/comments?
- What would you do? I Just got quoted $4K to have my d16z6 rebuilt(stock) in maryland...
- OEM Gas Tank/ Fuel Cell
- H22A missing
- Tranny Noise (((LSD)))
- how far downstream does a o2 have to be?
- Metal shavings in tranny fluid after quaife install
- Need Help!
- how much nitrous on stock valves?
- Anyone in RI/MA help me with a b18c1 swap tomorrow?
- popping noise when car jerks
- Longer Rod = slower acc. at TDC, but...slower or quicker at BDC?
- how to tell how close the gears are
- Anyone used the Enjo Engine Mount upgrades ??
- Rubber seal on M/C shaft....
- apexi piggy back question
- nos jetting
- Piston Ring End Gap Questions
- convert p28 to activate iab's for h22
- OBD1 Integra headers?Weare O2 located?
- How To PUT CAR IN TIME?
- Balanced and Blueprint?
- no spark...no fuel....wtf!?!? help me out fellas
- Timing belt
- Pilot bearing loose in Tilton Flywheel
- VTEC solenoid.....
- pulley upgrade for a type r
- How good is this product...Convert your A/C R-12 to R-134a..From Walmart $39.99
- obd-0 to obd-1 in ef
- Crx exhaust from header back?
- car made a pop noise and shut off...anyone know why?
- largest allowable main bearing clearnance
- t-belt question
- Engine RPM Comparison, am I correct?
- Help with hooking a UEGO to a p28
- Bought a cheapy multimeter, how do I read it? (searched, HELP!!)
- altight So i fitted my new throttle body on, same map sensor..same TPS sensor. throttle body TPS pro
- What flwheel clutch combo for B18c1 with B16 tranny?
- Manual to Power Steering Conversion
- obd 0 hondata stage 3...help please!
- Question: Clutch disc center hub swapping... ?
- replacing a B-18c1 headgasket.. help
- please help: car won't start
- Help with code 3 and 41, can they be related?
- Cluster doesnt light on after installing a headunit
- Help with MPFI...I have triple checked everything
- Please help crazy shit happening...
- JDM or USDM
- How much power can a kaaz hold??
- Civic gas/elec hybrid oil change
- Honda guy working on a Ford Ranger crank pully bolt
- i have a porblem but its not with a honda!
- Interchangeable injectors
- Power windows problems.
- Reconditioning Kevlar clutch by sand blasting?
- where is the best place
- Steering Rack Installed Problems??
- turbo question
- How does this look??? Can i still use this block?????? help please
- Hydrolocked NEED HELP PLEASE.. SEARCHED ALREADY
- 99-00 civic ex distributor wiring for si distributor
- OBX Turbo Manifold & Downpipe for b Series Question
- JDM dc2r front end HID wiring
- Spearate the Transmission from Block (How)
- Clunking after new pads
- OBDII Diagnostic Software for Honda - is there such a thing?
- Who is the brains of this operation?
- type r cams and valve springs
- 98 300 four trax that needs a cam chain.. WHEELER
- warped block......
