View Full Version : Tech / Misc
- Apexi S-AFC or V-AFC??
- NE1 make cable tranny to hydro conversion besides hasport?
- Throttle body question
- Harness Question
- Does someone know about the TANDEM CONTROL VALVE?
- turbo bracket for d16a6
- Specs on 86 CRX Si?
- Odyssey brakes
- How to tighten oil filter screw? The screw that threads into the back of the block?
- Removing valve stem seal on a b16a1
- Technical Swap Question... Please Read...
- changing cv joints?
- Has anyone used this Exhaust trick?
- VAFC and PR3 ecu - pls confirm pin outs
- axel question
- GSR Brake Conversion Question
- Just installed a clutch and have a problem
- Rod Stroke Ratio! R/S
- GS-R Tranny shift points
- all motor guys what kind oil
- crvtec oil pressure? is my pressure correct?
- HELP!! Can't get crank pulley off!!!
- dc2 gauge cluster question? how to related
- building a b16a1
- FMU For Turbo WHere does it go Please Help
- Can i make my own stainless stell brake lines????????
- ticking sound coming from fuel injectors
- Should hone/Re-ring or overbore/Hone?
- D16y7 to D16y8???
- vtec soleniod question
- Sounds from header?
- buying a used crank what to look for?
- Nitrous and high compression motor
- Trouble replacing rear pads..
- Best bore for a b17
- Intake Q
- NOT GETTING ANY FUEL!!!!!! HELP!!!!!!!!!
- Piston Install...
- How come this clutch doesn't fit my CRX SI?
- lower strut bolt??
- VAFC Inquiry
- b16b tranny fluid?
- OT: Trying to help my friend w/Tacoma transmission problems, need advice
- I need some OBD1 and nonOBD wiring PRO's
- Axle Question for 89 Crx w/ hydro conv.
- stroker kits
- ? about CTR psitons in a b16
- Valve Stem Seal Replacement, Valve Spring/Retainer Removal?
- Alternative fuels for all-motor applications
- JB weld work for b-pipe exhaust crack?
- stock b16a2 with only CAI/IM/H in a '97 four door.. is 2.5" exh too big?
- b16 axels
- !!!!!!HELP!!!!!!!!!!!!!!!!!!!O2 sensor stuffed!!will safc still work??!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Ground Control install
- Parts required for lsd install
- will b18c1 with jdm ITR pistons 11.3:1 pass emissions?
- What intake for my car?
- HELP!!! cant get timing belt on?
- Car won't start!
- cams for cheap need them
- Engine sleeves.....pics
- ENGINE light!! Help me?!
- 1st Gen B16 LSD... fit YS1 cable ?
- Your opinion would be greatly appreciated!
- fuel injector help
- ITR motor in a '99 si
- question for all u nitrous guys
- changing fuel lines in the engine bay??? what sizes to get need help
- type r or aftermarket?
- -> Tanny gave out I think... can someone help me???
- diesel engine oil on a gasoline engine..good idea?
- hondata?
- Brake help
- How hard will it be to....
- IB "Dominator" Head Package,Any Reviews?
- anyone done the EG JDM climate control (92-95)?wtb
- carsound cat pass smog?
- Jet Performance ECU Upgrade...
- Tranny Swap Questions.
- apexi filter
- Head Gasket Question
- who makes complete bullet proof blocks
- Need help, my header got push in!!
- Alternator Question
- idle problem please help.......
- compression b20 w/ itr head
- sohc buildup suggestions?
- Honda / Acura computer question
- need valve guides asap..anyone know where to get some???
- guys i need help!!!!!!!!! motor still hitting hood under torque!!!!!!!!!
- What's involved in swapping out a crank?
- WRX compression
- tranny question
- just did ls/vtec/turbo and can't idle
- this is stumping me my tach or my rev limit?
- any cheap place for valve stem seals?
- trans codes
- ls vtec over heating problem please help
- NGK plug differences? V-Power (silver box) or side-electrode one (yellow box)??
- timing off by half a tooth...
- idle surging
- Not honda, but tech related (nissan question)
- je 12.5 compression on ab20 with a b16
- HELP: Will all D series clutchs work for a 93 Civic?
- compression test psi at diffrent compressions
- Stuck Spark Plugs
- k 20 ???????????????/
- why aren't cutouts prevalent in the import industry
- b18c5crx
- my steering/tire/suspension problems
- cylinder head damage, plz help
- IACV...control first gear idle???
- Do you need an intermediate shaft
- 90 Accord engine swap info
- CTR Pistons in B18c5
- vtach on a non vtech head
- -Scored cam cap-
- Using excel to calculate tq from hp and mph?
- Code 91 need help
- B series oil pans
- H22a throttle body modification
- nitrous and compression
- #43 code on a delsol b16a3 with ausdm p30 ecu
- B16 cams VS B18c
- does brand of upper strut bar matter?
- Tokico blue ride quality???
- GReddy EGT Gauge...
- skunk 2 coilovers or nuespeed race springs ....which is better????
- B nd D series clutch differences...
- auto sohc vtec
- Direct port nitruos questions...
- HID question
- Type R outer valve springs
- JUN cams dyno Vid
- JDM B18c (Gs-R) compatibility ...with ITR manifold ..B16 ..or Skunk2 manifold...
- headlights auto off
- Dyno results...need some ??? answered
- changing tps
- Head gaskit replacement???
- Copper (?) particles in oil during oil change?
- 84mm or 84.5mm
- Serious: GSR-83mm bore... fuel system options ?
- thinking about getting lower deg thermostat
- will this honda piece fit a momo shuttle steering wheel?
- whats the difference between H22A1 and H22A4
- you opinion... will it work?
- do they have BFG geforce kd's for 14 inch no hubbies
- Brakes: Fluid leaking, but where and why?
- mounts
- LSVTEC problem...
- sleeving a b18c1 to 2.0?
- What would a fully port/polished b18b head flow?
- help with ball joint
- instrument cluster fuse keeps blowing????
- Question about cam install, no vtec?
- obd1 vs. obd0
- does the Ls and GSR share the same distributor?
- Brake swap questions (following swap)
- Lean problem
- any advise from b20/ls users
- Question about crank pulleys
- Oil Pressure Sensor
- 2nd Gen B16 setups....
- Push Button ignition
- B-series cable tranny rebuild questions
- Opinions on JG cam gears
- Does anyone make a 4-2-1 header with a 2.5" collector for a B-series motor?
- are Toyota Camry 5 lug steel wheels compatible with Integra Type R's?
- does the knock sensor give out voltage at idle?
- Mold in the Air Vents??
- O2 Sensor wiring question
- Specs of JDM ITR cat??
- Suspension Options - Koni, Eibach, GC, Tein
- Anyone has any expierence or know anyone using NEX coilovers?
- Clean new injectors?
- sensor on the JRSC
- Very First B16A2 Tech Series Installment!! Valve Lash Adjustment!!!
- Nitto NT450 vs Falken Azenis?
- What all is included in an ECU and harness assembly?
- Throw out bearing / pilot bearing cost
- BFG geforce tires at tirerack.com
- ECU question...
- h22a in 95 civic
- OBD1-nonOBD convertor
- how many ohms should the EGR valve have?
- What parts from a 92 GS-R will fit on a 97 coupe?
- Distributors: which one to run for my set-up?,
- Hyper Ground wires?
- Cap and Rotor?
- H & R Cup Kit
- Would a B&M FPR& FP gauge be of any use to me if I have a hondata?
- h22a eg civic *power steering*HELP!!
- What are the proper bottom end bearing to get for a ZC?
- guys with 2L or engine gurus in general...check this out about intake manifolds
- swap problem
- will tps on 91 crx work on tb on b16a1
- B16A1 intake manifold on B18A?
- How much for this problem?
- LS/VTEC Set-ups (please help)
- JG sleeves for block? Has anybody heard or know About them?
- Thermal Exhaust now or Hytech later????
- Wheel Bearing???
- NEED HELP, LSD Tranny oil.........
- Idle Problem... NEED HELP ASAP!!!!!!!!!!!!!!!!!!!
- HX-EX Conversion
- B16A1 or B16A2-(Cable or Hydraulic)What do you prefer?
- Rear Main Seal question
- How do you get your wheels tucked under the fender?
- Valve lash specs for skunk stage 1's
- Valves spring too stiff?????
- Connecting rod Bearing/Bushing Question
- Best tire size for 15x7 rim?
- help w/ fuel pressure gauge
- Thinking about doing a small tech series for B16A2's, testing interest.
- tuning goal...what do you think...
- *Electrical Probs* Front Turn indicator.........
- will 92 cx tranny be okay for d16y7
- O2 Sensor Problem (I searched)
- can you identify these? B18C 5th gen civic
- cam adj. can i just rotate the cam?
- Greddy Profec b help?!?
- LS head on B16 block.... can you do it?
- Suspension Trouble?!?!?!?!?!?!?!?!?!?!
- will a itr cai work on a b16a in a 91 crx si
- how much whp with this?
- can find the vss
- How to make car beep when lights are left on?
- ShiftLight Problem? Premature lightculation.
- Check this out : 1.4 L SOHC N/A - 13.9sec
- Exhuast Help. . . . . .
- Wire order...
- oil change
- ARP rod bolts???
- How much power of a obd0 LS N/A...
- Internet Address for B Series Compression Calculation?
- Will this work?
- 2,000 miles on rebuilt d16a6...smoking, coolant loss?
- Reuse ls/vtec head on a vtec bottom end? how?
- Fuel Filter Bolt thread size?
- h22 + LS tranny = me is stupid
- Do those exhaust repair kits really work?
- automatic b16a1 able to do 8200rpm like the mT?????
- Will 2nd gen B16 distributor work on 1st gen B16?
- what type of ecu?
- GSR Motor in a 98 Civic EX now has Check Engine Light code P0171?
- HELP! removing valve springs.. anyone know how?
- small Hamp or RSX oil filter users ... need your input ...
- headgasket q.
- exhuast.???help
- B18C1 throwing CEL #3 [need help]
