90-93 integra....AXLES KEEP BREAKING
Old Nov 28, 2003 | 08:49 PM
slixxracing's Avatar
Default 90-93 integra....AXLES KEEP BREAKING
HELP anyone!!!!!! Here's the problem. I just keep breaking my damn axles. It's all stock, juss lowered sitting on some 16" rims and a b16 moto swap. All else is stock.
1. What do you think the problem could be? Crossmembers (front, rear, middle)????
2. How do I change/remove the rack and pinion to replace the rear crossmember bar?
3. Could frame be bent?? But how can it, never got in an accident
Any help or replies is greatly appreciated..
thanks
Old Nov 28, 2003 | 11:00 PM
Kwuaymaikrup's Avatar
Default Re: 90-93 integra....AXLES KEEP BREAKING (slixxracing)
Well I would look into the swap. Maybe it isn't sitting properly in the bay. Did you have this problem before the swap? Before lowered? Properly installed? Hope this gives you an idea or 2.
-Ryan
Old Nov 28, 2003 | 11:14 PM
untitled's Avatar
Default Re: 90-93 integra....AXLES KEEP BREAKING (Kwuaymaikrup)
motor isnt sitting in the right place
Old Nov 28, 2003 | 11:36 PM
99blackcivicSi's Avatar
Default Re: 90-93 integra....AXLES KEEP BREAKING (Vetter)
motor isn't sitting properly. Did you use a Hydro or cable tranny? that could cause the motor to sit too far to the left if you had to make a conversion (non was made for that car)
also could be you are TOO LOW and the axles are not straight enough and your putting to much pressure on teh CV joints
Old Nov 29, 2003 | 08:04 AM
Default Re: 90-93 integra....AXLES KEEP BREAKING (99blackcivicSi)
I am using a cable tranny and i had this b16 motor in the car for about 3-4 years without no axles problem. Everything drove fine. It just recently occured. As for swap it's done right thats for sure, cause if I never has this incident in the future w/ this b16 swap the axles would of broke on me first hand off.
Old Nov 29, 2003 | 10:23 AM
obd2gsr's Avatar
maybe your motor mount is broken somewhere.
Old Nov 29, 2003 | 04:11 PM
Default Re: 90-93 integra....AXLES KEEP BREAKING (obd2gsr)
all mounts are good, frame not bent, motor sits in correct, axles seems to line up fine. I recently replaced the tranny, half shaft, clutch, whole driver side suspensions, from top to bottom....
Old Nov 29, 2003 | 05:24 PM
Kendall's Avatar
Get some axles with the lifetime warranty from Pep-Boys and every time they break, take them back and get a new set. Not really solving the problem, but making it less financially troublesome.
Old Nov 29, 2003 | 07:41 PM
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">Get some axles with the lifetime warranty from Pep-Boys and every time they break, take them back and get a new set. Not really solving the problem, but making it less financially troublesome.</TD></TR></TABLE>
Thats a good idea, but I've already tried that w/ 2 different local shops. But than they they caught onto it. HeHe..Also I dont think it is worth it to keep taking the axles out back and forth every 1-2 days just cause it broke. No luck there now it's just time to move forward and find out what the damn problem is. Gotta face it sometimes.
But I think I fixed it today. Me and my buddies was working on it like crazy and I think we got it. I drove it around the block a few times and everything drove fine just that I need to bleed the brakes from letting it sit so long.
Old Nov 29, 2003 | 10:17 PM
eastbay92cx's Avatar
Default Re: (slixxracing)
Do the axles break somewhat at random or only when you launch the car / shift hard? If they break when you cause them stress then it could be the quality of the replacements you're using, but with the way you make it sound like you've broken so many axles, it definately seems like the motor is not sitting right or something else is loose / broken / crooked. Oh well I hope you got it.
Old Nov 30, 2003 | 12:46 AM
simple4012's Avatar
New User
Default Re: (eastbay92cx)
what kind of clutch is it?
Old Nov 30, 2003 | 12:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slixxracing &raquo;</TD></TR><TR><TD CLASS="quote">
But I think I fixed it today. Me and my buddies was working on it like crazy and I think we got it. </TD></TR></TABLE>
What the hell does that mean? What did you do to it? I was also wondering where the axles were breaking and if they break in the same spot all the time?
-Ryan
Old Nov 30, 2003 | 09:36 AM
IQ's Avatar
IQ
define 'breaking'... or are you just tearing the boots? I noticed you just lowered your car.... this is one of the down falls.
Old Nov 30, 2003 | 02:16 PM
vtekstorm's Avatar
Default Re: (IQ)
how low did you lower the car cuz rite there i think that is where your problem is. dropping it to low will cause twice the amount of stress on the cv joints just on the way the car is resting.cuz ive heard of ppl breaking axle scuz of there car being to low. try that hope that works out for you
Old Nov 30, 2003 | 07:56 PM
Default Re: (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">
-Ryan</TD></TR></TABLE>
Fix meaning..maybe fixed and wont break no more. I changed the front, rear, and middle crossmembers and rack & pinion. The axles was breaking inside the inner cv boot by the half shaft.
Old Nov 30, 2003 | 07:57 PM
Default Re: (simple4012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple4012 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of clutch is it?</TD></TR></TABLE>
It's a stock clutch
Old Nov 30, 2003 | 07:58 PM
Default Re: (IQ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IQ &raquo;</TD></TR><TR><TD CLASS="quote">define 'breaking'... or are you just tearing the boots? I noticed you just lowered your car.... this is one of the down falls.</TD></TR></TABLE>
Breaking the bearing into little pieces. Yes im also tearing the boots too. I just havent lowered the car, it's been lowered for about 6-7 years now.
Old Nov 30, 2003 | 08:01 PM
Default Re: (vtekstorm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekstorm &raquo;</TD></TR><TR><TD CLASS="quote">how low did you lower the car cuz rite there i think that is where your problem is. dropping it to low will cause twice the amount of stress on the cv joints just on the way the car is resting.cuz ive heard of ppl breaking axle scuz of there car being to low. try that hope that works out for you </TD></TR></TABLE>
The car is lowered on some 16" rims w/ 40 series tires right to the top of the tires only. I dont know if thats consider low to you guys but to me it's not that low. And thats for all your help on the inputs guys... Greatly appreciated, but problem has been fixed and headaches are gone. Wheww!!!!! What a releve, now I dont have to sell it no more.
Joynerhd
Transmission & Drivetrain
Sep 27, 2015 10:33 AM
Dirttrack1975
Jul 12, 2015 10:02 PM
dropt
Jul 25, 2004 01:28 PM
turkdog
Nov 24, 2003 07:36 PM
90-CRXSi
13
Aug 7, 2002 08:49 AM
