View Full Version : Tech / Misc
- Engine rebuild How To?
- Would This Be Necessary? How To Install
- B16a2 sounds like diesel
- Best ECU for ODB0 -> ODB1 conversion
- gear set question
- HELP! car wont start
- b16a idles high
- ALOT of Carbon bulid up in the exhaust ports?
- Question about posting in Classified?
- What will make your car stall at idle
- body seam sealer?
- Help for next mod on my S2000
- Question about "O2" sensor wired to SiR catalytic converter
- Cold Start "thump"
- nitride coating in the NE
- How much do GSR Injectors Flow?
- rear strut
- check engine light came on
- help me out on my hesitation problem!!please
- Quick PR3 Question: Engine Code #3 - What Is It?
- Need opinions on pricing for injectors and hondata
- crx/b16a wiring for ONE o2 sensor
- Which plug is which on ECU? Trying to wire Vafc
- what plugs
- 92-95 civic hatch gastank fit 00 civic hatch
- clutch slave cylinder
- prelude injectors for b20z???
- loud bang and then...... (cable b16 tranny problems continue)
- sohc d series question
- from what car is the td68u distributor?
- CEL Jumper Q:
- Where to get Probe I beam rods with upgraded ARP 2000 bolts?
- Do you adjust ft-lbs when using extension with torque wrench
- finished a b16 swap..just a few more ????
- exactly how do you know if you bent your valves?
- need help on suspension
- Buying Valve Adjustment tools... Can someone verify my list? Snap-On
- My head is off right now, what should I do?
- 79 CIVIC DRAG CAR
- Radiator question.
- do i have a blown headgasket or what??
- can anyone help me install a cam gear in santa clara or san jose
- Install AEBS Intake Manifold on a B16
- ls/vtec in a 90 integra
- mobile 1 or clean drive?
- doing a tear down of b20/vtec....
- stage 3 cams ?
- what else should i replace while changing headgasket
- Do I have everything for my hondata s200?
- I Searched... But I need more answers to Wiring questions!!! please help!!
- A way to convert JDM VSS driven Clusters to read MPH.......FYI
- wierd overheating problem
- Adj cam gear for ZC 1.6 twin cam ???
- HGR catalytic converter
- Max Cam Gear setting on LS/Vtec?
- off topic sorry
- honda s2000 oil filter
- idle control
- Axis Touring cup rims
- HELP ME!!! i'm goin' nuts! Which plug is which on ECU?
- auto tranny slipping? EZ question
- ~~~ scratches in sleeves after rebuild / break in.... who's fault? ~~~
- What are the risk in buying used cams?
- after valve adjustment I still hear noise
- B18B Transmission problem
- how low with konis?
- 4-2-1 vs. 4-1
- a transmission page -- please let me know what you think (mistabone??)
- Install hight on skunk2 valve springs???
- P07????
- Honda with 2 Intake Cams?
- Just got my intercooler piping welded - how do you clean up the welds on the inside?
- Help! one of my valves broke!
- Parking brake lines (obsenities at bolt) EK
- filtermag...?
- Initial motor break in period
- Weird Clutch Noise...HELP
- obd2 im confused
- arp lug studs
- polyurethane motor mounts
- best/easiest way to get a twisted off bolt out of the head?
- HELP!!how 2 rebuild tanabe muffler
- Using Integra Solenoids with B18 88-91 Civic Swap
- Weird Vtec hesitaion?
- Tach problem after hondata install
- comptech icebox in crx?
- ignition question please help
- Hid questions for Professionals
- injector plugs. which side is ground wire?
- Tein H-Tech's
- running on two cylinders.......help.
- does anyone know how to install the Autometer pro-shift light?
- which coil-overs?????
- torque spec for d17 crank pulley.
- Need Help car won't stay running!!!!!!!! (please)
- I need help with exhaust bolts
- Nitrous on h22. HELP!!!
- failed inspection
- CTR N1 pulley
- aem cam gear question..
- piston to valve clearance question.....
- Car will not start!! Info Inside Auto-Manual Troubles....
- APEX V-AFC HELP BASIC TUNNING
- Hook Ups!!!
- Need high quality pics of B16A IM
- H22 Oil Pump O-Ring
- Tranny grinding.. Quick fixes??
- Inner A-arm bushing gone again!!WTF
- Differences between engine series?
- How to change oil pan gasket
- vtec engagement screwed up
- Help, ITR four lug brake conversion experts (ok, anyone)
- Camber problems after GSR disk brakes UPGRADE? HELP!!!
- two questions.. new to hondas.. please help
- Need Techinal Help on a civic
- vtec vs non-vtec
- High RPM missfire
- Koni converted to full coilover?
- Gauge Question?
- Crank Pulley Bolt woes, please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- B16 Head Swap
- oil pan gasket help
- royal purple purple ice, and water wetter...worth it?
- Question about CA smog...
- motor swap questions
- 96-00 full coilovers on 92-95? CAN IT BE DONE????
- car is bucking around 2g
- D15 vs D16 Bottom End Differences
- h22 in a crx chassis?
- Integra rear disc brake ??
- would it fit?
- LSvtec wiring harness question... YES I SEARCHED
- Can someone help me figure out what these mean?
- SRR lca problem for DC2 !! HELP !!
- 10 bucks if u solve my prob.
- Do the GSR Moroso oil pan and oil pic up fits to a b20 bottom end?
- Safe to remove exhaust manifold heatshield?
- what kind of engine is this?? B18a/b or b20
- fuel flow rates?
- odd heater problem any ideas or thoughts? need help tired of freezing in buggy!!!!
- PCV Valve???
- STR block saver???
- Fouled plugs?
- d-series rods'n'bearings
- anyone know vtec???
- Honda Dealership Tech computer system
- My D16Z6 started to "cluck" tonight....please help me.
- no thermostat vs. lower temp thermo vs oem-type themos
- CRX suspension?
- jdm type r motor question
- differences between ceramic or carbon disk clutch?
- want to vtec my 91 legend ls can it be done
- B16A wiring info???
- I need SOME HELP ON B18c5
- Engine turning slow?
- IAC valve
- wheel is not centered in wheel well
- Possible synchro problems... please help!
- EG Si in trouble....need help fast!
- Question : How to tell what b series tranny you have
- TPS problem... (Yes I searched)
- bilstein struts
- crank plugs needed after rebuild?
- question about JDM ITR 4-1 header install
- B20A5 is knocking (again!)...
- Oil pump mod to get a bit more oil pressure
- Built Transmission or Built Motor
- cam gear weight
- Enjo, or Raxles?
- Throwing "Knock Sensor" code...just rebuilt engine, help!...
- morCEL, but no codes
- Cold morning starts.............
- hondata s200 v. aem ems
- Heating problem with jdm b16
- a timing belt question (valve related)
- hondata im gasket ?
- J's racing SEV Orga Ion system
- Bottle neck effect
- Fujitsubo 4-2-1 header....yay or nay?
- hot tank GE block??
- Building motor in a BICYCLE
- Cam timing question (milled)
- b16a head
- Dizzy?
- jdm ITR cams valve train in b16 need help!!!!!!!!
- Flywheel comparison help
- TPS, how do you know when its bad?
- AN-R header question
- Automatic Wire Harness...Reverse Light Wiring
- weird overheating
- Problem: 97 teg with jdm ITR cluster, someone help
- Did I ruin my bearing? Check it out pics and small story inside.
- camshafts
- bellhousing access hole??? where? ASAP
- O2 sensors
- 00 b16 head and obd1 gsr wiring harness?
- Vtec engagement problem
- upper front ball joint
- timing belt problem...
- Can't separate lower ball joint!! Any suggestions?
- 1st Gen JDM B16A
- Reverse LS/Vtec
- oh no! broken vtec solenoid bolt in head!
- What is firing order on f22?
- Is there a technical difference between a "spoiler" and a "wing"?
- how to distinguish civics/integras knuckles...
- thing about progress suspenion...any opinions?
- No spark after AFC removed.
- Need a True Definition of DISPLACEMENT
- wiring prob. ANY IDEAS?
- Do Msd ignitions really help?
- gauge question
- 86 accord pgm-fi light intermittant
- Idle problems...still
- Mobil1 oil filter???
- part number ctr piston rings?
- Replacing indicator Console?
- 99si Wiring Harness help
- ES motor mount inserts, will rough idle go away if I hold the revs up?
- LS Block question
- Hot Tanking vs. other methods.
- Cams Setup Question - Please help
- Help with y-1 tranny probs!
- obd2a to obd2b adapter? help! ! ASAP
- Crankshaft marks???
- b18 cam seal part #
- oem motor mounts sufficient enought for 200 whp b20z/vtec??
- Could use some help please
- pr3-3 & pr3-2 head stamp. what are the differences? specs?
- no injector pulse
- tell me what's wrong with this honda......
- Vibration after h22 swap.
- 97 d16y8, 95 b18c,same knock sensor???
- have you opened up a vafc?
- B16 Timing Belt on LS??
- RS Type Vtec Controller
- Where to buy VERY large sockets for cheap ??
- anybody with energy suspension motor mounts ?
- clutch ?
- HID HELP
- code sixteen (fuel injectors)
- Another View on Intake porting.....again think outside the box... LONG y0!
- PLEASE HELP!!!!!!
- RC 550 Saturated injector manifold o-rings.
- Breaking in your engine... think outside the box... VERY VERY LONG...
- help-code 7
- Auto b16a Cams
- how does the K24A4's i-vtec engine like? same strong as old DOHC VTEC?
- HX wheels question
- wouldn't start, at first.. low fuel?
