View Full Version : Tech / Misc
- Nice to know someone else cut up his EK for an h22 also like we did.
- Wrong engine in a car.. what now?
- Minimal gains with high flow cat and stock engine. worth it or not?
- Help: Aftermarket Intake Manifold
- Virgin Tuning
- fuel cooler
- integra 2nd gen manual transmission accessories interchangable with 3rd gen?
- Wiring Question
- gonna be swapping in a OBD 1 JDM gsr into my '90 obd 0 DA
- Need Intake Bypass Valve for my CAI?
- SAE vs. METRIC thread pitch ?
- Axle Won't lock in, quaife lsd, y1 trans, DA axle HELP!
- overheating/brown fluid in Radiator
- Can I turn my LS tranny into a GSR tranny??
- failed smog high HC no NO
- H22 Quick Question
- JDM B16 Bar questions. Help needed
- b18b long block, b16 trans weights.
- How Much for a Tune
- Ecu Resistor burned
- Help: Engine valve cover
- Transmission Synchros
- need plan of performance build on 1990 4 door honda civic !!!!!!!!!!!!!!!!
- Fule pressure regulators
- auto to 5speed conversion...help
- JDM 96+ DOHC VTEC engines do not have a vtec pressure switch on the solenoid.
- Complete DIY write up for atermarket steering wheel
- quick hondata question
- Aem fpr fitment issue on strut bar question "Can it be opened and repositioned?"
- d-series tranny of all generations
- cam install???
- S300j problems........ Car running in permanent limp mode
- need to know about my jdm b16 tranny
- iacv problem
- ignition timing, advance all the way, need input please,
- fried ecu, new ecu but car wont start
- Civic to Inegra Clutch MC fit?
- High gear shaft
- i jus picked up an transmission yest.. Can some1 help me identify (SEARCHED) pix inside
- How do you tell gsr cams from b16's?
- Help with B18B bogging!!!
- Automatic wasteland...
- help: doing an engine swap and i have a question about the mounts
- pr3-2????
- throttle body
- Loctite Flywheel and pressure plate bolts?
- H22 info
- cps help me 96hx 99si
- How to tell true SKUNK2 cams
- car wont start?!?
- need help might have vacuum leak
- changing head gasket on Honda Civic LX
- ***Another are these CTR cams thread.....help!***
- Compression on last two cylinders.... Timing belt walking...
- Help!! Real Messed Up
- resistor box problem...i think.
- 1992 Honda Civic EG HB Motor Swap Tech Help!
- difference between h-beam rods
- how to play with cam gears
- Possible short? Maybe?
- Type-R oil pump on a B18A block, will it fit????
- head gasket removal
- Need colaboration for cool intake project
- 99 TL doesn't run.... MOVES WHEN ITS IN PARK....HELP!!!
- Si(R) Head VS GSR Head on B20 Block
- how to convert obd2 distributor to obd1
- questions about a b16 head on a b18b
- Blown Fuses?
- how hot should an AC condensor get???
- O2 Sensor - How to test?
- EF9 B16 to B18a swap questions!!!!!
- Vacuum lower after 3MM headgasket install and larger TB
- Help, Exhaust sounds like wrx, loss of power...
- Oil Burning Quite Quickly
- anyone ever had this tps problem?
- Engine design advice needed for 1.8l D16
- PCV Question?
- no power in cabin, engine bay has power
- Optimum bore size for a B16A??????
- Rough starts after fueling or running a/c
- Bore size increase, any real gains?
- wierd idle
- JDM H22a S2k pro series stage2 cams,valves, springs ect.......
- Piston To Wall Clearence Confirmation
- Disable O2 heater???
- VSS
- Tranny Broke!! Help!!
- Anyone use their auto trans w/H22 swap to Gen 4 Accord?
- safe compression?
- Help!!! Piston bore!!
- NEED HELP
- Busted Axle and ABS light
- Getting ready for a 2,000 mile trip, what to change/tune-up before I go.
- need help!!!! h22 swap is slooooow
- TOE PROBLEMS ON CRX, EMERGENCY!
- Showdown: F20b vs H22 Cams
- lower front strut tie bar?
- got a problem!
- Fuel pressure at regulator 98 civic ex sohc vtech
- 92 integra overheating!!!!!!!!
- Starter Trouble (Not turning)
- World Sport II Universal turbo muffler axle clearance
- 1995 Honda Accord Lx Transmission problems!
- What year is my cable LS trans? I need a clutch!
- Removal of rust from the header
- Mystery LSD? (pics)
- trouble code 4th gen jumper? 93 h22a civic
- need help. just installed a built head.
- Changing from s200 to chrome on p28'
- a good obd1 trouble code scanner?
- Defi gauge wiring
- What type of ignition wires?
- Midnight Performance Tuning
- Idle Air Control Valve Question
- putting block on stand, what bolts?
- Looking for some books...
- 12100-PPL-A00 cillinder head code, ???????
- H-Brace: Thoughts on usefullness...
- can you turn intercooler core to a radiator ?
- Need radio help
- Question here...let me pick your brain
- Oil fitting broke block, world of hurt... drinking away my sorrow...
- need a simple wide band 02 sensor no data log
- 1995 OBDI GSR..Failed CA Smog...High HC and NO what do I need to fix
- JDM B16 tranny Linkage Question
- ecu ?
- hydro to cable transmission gear swap, why swap differential bearings?
- tuner in CT? dyno
- Code 43 question. PLease help!
- Please Help... Civic Exhaust on an H22A...
- valve stem seals installed in the right place?
- Can I use this fuel injector clip?
- Walbro fuel pumps for Honda's... How to make them work with half tank of gas?
- i got a couple of questions hopefully you could help me out here
- cyp problem on anew distibitor
- low oilpressure
- Pitching the stock ECU
- Trying to save money...Need help identifying transmission parts!! (5th gen) :P
- ECU
- over heating
- P0130!!!!
- 92 lude H23A... FACTORY CAM GEARS
- help??
- valve spring problem
- usdm gsr piston on LS rods?
- Who has a 4 puck/unsprung clutch for a daily driver?
- Bearing material *take a look*
- over heating just rebuilt
- Sealers?
- Need Help!!!!!!
- H22 Turbo (20psi)520hp - RPM Kickdown (no redline while boosting)
- fuel level gauge showing less fuel when headlights turned on.
- Stock Sleeves On A B18C1 GSR Engine
- How do you measure valve guide bore?
- My car eats 5-30 Mobil synthetic oil like I eat Burgers. Bad rings? Valves? Dunno? What oil to chang
- TPS based shiftlight
- just wondering,
- Honda LSD Power?
- wrist pin lock removal
- Should I replace the head gasket?
- Working on an engine using an engine stand
- lsd into a non-lsd...
- tranny?
- balance shaft
- HID Ballast
- torn engine mount
- Does Mugen make a catch can.?
- ECU Control and Windows Vista - Doesnt work!
- Speed limiter?
- ACL Bearings
- H22a Tranny
- obd0 b16a vaccum verification needed
- Aftermarket free-flow CAT's
- I need to replace my motor
- trans gears swap
- Ls motor questions.
- Vtec wiring Q.
- Dim Lights, flickering.
- Type r cap & rotor fit B16 dizzy?
- How correct are these pinouts?
- Vacuum Hold
- WTF sensor is this???? I NEED IT!
- DFI 6 HELP PLEASE!
- 97 Civic keeps blowing ECU fuse.
- Weird wheel bearing part number
- HELP PLEASE
- b17 tranny question???
- IDENTIFY this..plz...
- help!! valve spring right side up/ up side down?!!?
- HELP! Car Engine Shuts Off
- CEL HELP!!!!
- Trouble with my turbo "Poor Man's Type R" setup... "Subey" sound
- walbro fuel pump whining ?~?
- Oil in Intake Manifold
- Oil pressure switch with higher psi engagement (for dummy light)?
- 4.9 volts on iacv connector!!
- engine bearing difficulty??
- AC Compressor
- simple question for someone who knows already
- 81.50mm Pistons?!!
- Please help with my BIN.
- d15b swap into a 96 dx??
- PR3 ECU Help
- LSD into a NON LSD HELP!!!!!!!
- CTR cams value.....
- D15B Vtec Valve Adjustment (SEARCHED)
- New Ceramic Brake Pads Smoking - Normal?
- Need a bit of help...Name this plug!
- exhaust manifold runner size calculations
- Comparo - Mem Fab vs. Password CF Intake
- What clutch is this?
- Looking for a Driver
- is it safe to pull the subframe yourself when it's bent?
- any one ever you a fields afvc???
- Trying to find a cheap wbo2 sensor
- Oil pressure gauge...Mechanical vs. Electric
- 91 civic car not shifting into gear
- lowest oil pressure for vtec to work??
- B20a crank in b20b block snout length issues
- (need help)EJ7 auto to 5 speed
- quick question- b18a
- switching chips??
- Bad Valve Guide???
- Calling ALL vtec specialists!! JDM H23A H2B!
- non honda electrical help please
- B18C SWAP PROBLEM PLEASE HELP!!!!!
- Stick with stock flywheel or go light?
- Chipping how to
- Stalling/Idling issues... AEM content...
- CTR installation in B16A: valve adjustment necessary?
- WHAT CAN HAPPEN IF..(GE HEAD STUD QUESTION)
- Rusted cam still fixable and good to use??
- Chipping my ECU?
- How to convert D16Y7 to OBD1?
- D16Z6 Tech Help
- hi guys i need help in building a k24a2
- Hood Damper Diy?
- stupid resistor box question
- is the quaife differential suitable for track use?
- Oil leak from head.
- Mcloed 72702-15 help
- b16a obd1 engine/ecu wire harness,how?
- Vtec problems in a H22 EK
- type r pistons
- p06 auto to manual mod.
- need help, couldn't find a write up on this.
- Replaced Clutch...CAR WONT GO IN GEAR
- Need help with adding vtec to my P06
- Best freon?
- H22 transmission?
