Vtec is not engaging. yes another thread about vtec not working:(
Old Nov 27, 2003 | 08:18 AM
POE's Avatar
POE
Default Vtec is not engaging. yes another thread about vtec not working:(
The head I used to do the Mini me swap (D16z6 head) was sitting in the car for about 7 months without running, well my vtec worked in my car for about 2 months, then it started throwing code 21 vtec not working. Well i check all my wires and made sure they were plug in, what else could i do to check it? Someone said maybe that the soleniod can mabye become clogged and that needs to be taken out and cleaned, is that mabye a factor sence my car head was sitting unused for 7 months?
Old Nov 27, 2003 | 01:06 PM
Phantomboostin's Avatar
Default Re: Vtec is not engaging. yes another thread about vtec not working:( (Vtecin94dx)
check your oil level.
Old Nov 27, 2003 | 01:35 PM
Jimmy's Avatar
Global Moderator
Default Re: Vtec is not engaging. yes another thread about vtec not working:( (Phantom CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phantom CRX &raquo;</TD></TR><TR><TD CLASS="quote">check your oil level. </TD></TR></TABLE>
Ahh nvm beat me to it.
Old Nov 27, 2003 | 03:03 PM
POE's Avatar
POE
I checked out the oil level and it seems to be fine, what else could be the causes?
Old Nov 28, 2003 | 01:14 AM
mh's Avatar
mh
the solenoid filter may be clogged. you can use a ohm-meter to find out if it's the filter. i'm not sure about the limits. think it migth be something like 7-14Ohm. that's between one of the solenoid plug pins and earth.
Old Nov 28, 2003 | 09:00 AM
Jimmy's Avatar
Global Moderator
Default Re: Vtec is not engaging. yes another thread about vtec not working:( (mh)
Yes another thread where someone didnt search.
Like said before check your oil pressure and oil level.
Old Nov 28, 2003 | 10:34 AM
dohcnotec's Avatar
Default Re: Vtec is not engaging. yes another thread about vtec not working:( (USDMDC2)
did you take that little oil diffuser pin out of the top/middle of your block before putting the head on?
Old Nov 28, 2003 | 11:23 AM
POE's Avatar
POE
the oil jet? if so yes i remembered to take it out. anybody have a pic of where the solenoid is and how to take it off to get to the filter?
Old Nov 28, 2003 | 02:15 PM
slvrcivic97's Avatar
Default Re: (Vtecin94dx)
The solenoid is the round cylinder thing on your IM side of your valve cover.
Old Nov 29, 2003 | 10:42 AM
POE's Avatar
POE
ohh ok what all do i need to take off to get it off?
Old Dec 1, 2003 | 10:15 AM
POE's Avatar
POE
ok so i was going through checkin all the wires to see if they got cut and, i took my battery out to look where it goes threw the firewall and i see a little nic in the wire. What happend was one of the wires that i installed for vtec had gotten smashed under the battery and was being grounded off, so i moved it and WAMMO vtec is workin yo, Im so happy i was gettin ready to take the solenoid out and clean it if i couldnt find anything wrong with the wires, thanx for the info H T
jdm.boi408
Nov 26, 2010 09:53 AM
idea_jdm
10
Feb 5, 2006 05:09 PM
B18cHatch06
Aug 30, 2005 05:09 PM
My Db2 AinT JDM
May 18, 2004 09:24 PM
POE
Dec 1, 2003 12:15 PM
