View Full Version : Tech / Misc
- Strange ignition problem - civic
- FIC 2150 Voltage offset
- Idle issues
- Car died while driving
- What to expect from Hasport 94A inserts?
- Bore cylinders or just deglaze?
- F/I fuse keeps blowing
- 95 civic wit b16a3
- Transmission Question
- Bearing equation issuse need help!
- 2007 Honda Pilot Horn not working (clock spring already replaced)
- what causes these scuffs on my cyl walls
- h22a camshaft issue
- store brand vs manufacturer fluids
- intermittent no start 01 CLS
- Low oil pressure and possible main bearing wear
- first time honda builder with a few questions...
- bleeding brakes sequence???
- Post your biggest freshwater fish!
- Nitrous bottle problem - what the hell with the pressure
- measuring metal content of oil
- Can anyone name these plugs/wires on obd0 harness?
- car boggjng need help
- H22a Piston
- wire tuck 1988 civic hatch
- valve adjustment still noisy
- 7th gen civic front control arm bushing seperated, fix with pl?
- MSD distributor cap without coil?
- compression #s? b20 vtec
- 2001 Honda Accord electrical issue
- Omni power rpm gauge replacements....
- brake abs master cyclinder
- Evap canister leak AND what feels like...
- Red recaro fabric
- Issues with Starting Up 98 Civic DX Coupe
- small displacement AWD Honda JDM with MT???
- K24 valvetrain noise after adjustment...
- What alternator is this
- Quick ? on a HG Kit
- Xmas Present for honda friend?
- Mis fire Problem/stall Need Help????
- connector
- Distributor - Inner Seal Replacement
- Best place for parts.
- H22 No Spark on CYL. 1. 2. & 3...Please Help!!!!
- 93 civic b20/vtec setup.. check engine light problem.
- What to use to clean head and block
- Newbie
- Can any one recommend Seats for a 1988 HB?
- cluster swap
- * How-To * B Series Engine Serial Number ID
- Car wont rev past 4k in any gear or nuetral
- NEED IDEAS NO POWER !!!
- Ministock Frankenstein: B18C block with B18A1 head
- d15b2 to d16a6 swap
- Dissappointing low HP B series 95mm.. crank to rod ratio??:(
- need help identifying.
- aftermarket tow hooks are awesome!!!
- Paint to thinner ratio
- Rev Limiter on 96 Accord
- B16b owners
- EK coupe windshield related leak!
- B18b won't start! I'm desperate..
- Eg Dizzy Kill Switch Install Looking For Ign 12v In Engine Harness
- solid cel, no fuel pump no ecu but the car cranks over
- Recommend a TPMS tool
- need help with no start condition
- 1996 Accord No start No fuel out of injectors
- HElp! please. Replaced so much, but car still hard to start after sitting.
- What seats are these?
- B16a2 correct ecu?
- Injecor facts
- input on brake booster deletes
- Ignition timing issue, B20B with B18a1 components.
- Need Some help an advice on my 94 Hatch.
- which Throttle Body size is better for an all motor 98 JDM B18c ITR motor
- Integra starting issues help
- help me diagnose these leakdown test results
- Is it possible? Adding 2-step to stk. 88 obd0 2PFI 1.5 ED3
- Power Door Lock problems!
- An Honest mechanic or dishonest?
- Does "JDM" actually mean anything?
- eg6 si fuse box?
- Help
- Wheel Suggestion for under $850
- Broken plug: Need info
- STERO PROBLEM
- Faulty IAT sensor?
- B20 ecu
- s2000 clutch issue
- Possible ignition switch problem?
- 1998 Civic LX Intermittent NO-Start
- HOW TO: Diagnosing Stuck Clutch Pedal
- Pre-tune checklist! please chime in guys.
- b18c1 sensor help
- Exhaust- Difference?
- cam caps question
- 92 EG SI AWD conversion!! need help!!
- 91 ef with sohc v swap wont start
- 90 Integra mis fire
- Mounting a Weldon DB2015-A
- 03 Pilot Power Steering pump removal
- B18C in DA won't rev past 4500?
- EG Hood latch bolts & nuts
- high rpm fluctuation
- could my throttle body by my idle issue?
- Help
- Any experience modifying/making shift levers?
- What do you do for a living?
- k24a please help
- Does this sound right?
- why is oil shooting out of my h23a1 valve cover breather?
- 2" to 2.25" Cat to Exhaust
- Need Help Identifying a CATBACK / EXHAUST
- rs r header....
- parts for sale/catchcan
- November 13th and 14th planned blackout! What do you think?
- 1993 integra wont start on downhill driveway! help.
- Accord 97 V6 starts and turns off
- Single or Dual Bend Short Shifter for a 5'5" me
- 1999 Honda Civic Ex HELP with: compression test
- Civic - Firewall HeatShield
- Won't start, crank, beep...No power
- Part name / 92-95 civic
- Unplugged cable
- confused about my RC SL4-440 injectors
- good parts to pick up at junkyard
- Connected battery and fan turned on???
- 400-450 hp 1/4 time
- motor drop in
- P28 Ecu question...
- why does 1989 bumper leave a gap?
- 2000 honda odessey trans problem
- 1993 HPrelude Manual Shift Box Issue
- Good silicone gel or lubricant for rubber seals
- Guess that valve Ferrea Comp Plus or 6000
- fixing a steering wheel
- Fuel pressure tester kit
- b16 head with unknown cam caps
- D15Z1 VX piston options???
- Gear ratios
- B16 swap 97 civic cx p0453 code
- Legit check on this recaro please
- Exhaust
- Part Numbers
- Throttle body not reaching WOT
- Idle oil pressure issues...
- Has anyone experienced this wideband issue?
- SRS - Simple questions
- Idle air valve control (iacv) issue
- City light for ctr headlights
- converting to coil on plug setup
- Mixing metals in distributor cap & rotor
- how to make my own b series wire tuck harness?
- B20 swap into 93 civic lx
- Bolt Wiggles in the Thread
- Column light and ash tray wiring.
- transmission issues...
- help.... I need the harness side connector for the 5 wire o2 on a Civic VX
- Need help! integra bog down!!
- guys running no fitv
- Help?
- good cylinder bore gauge on a budget?
- TPS issues. NEED HELP!!!
- How to make my 1997 hatch all digital?
- Thickness of crankshaft OEM bearings
- emissions question: obd2a ls vs obd2a gsr ecu
- Minus transmission
- Heater Blower inop - have searched
- ap1 s2000 flywheel removal
- HELP ASAP!!!
- 92 accord check engine light
- I thought I fixed the problem! Clutch problems
- Using a Universal Joint Drive
- b18b1 Distributor Swap ??? How To ??
- Help with transmission identification!
- Buddy Club Spec II
- 92-95 civic air intake on 91 hatch
- OBD0 to OBD1 purge solenoid
- need help. no start issue
- Coolant temp and gauge issue?
- 2004 Honda Civic - Squealing Sounds at a cold start up
- B18C1 timing problem with Intake/Exhaust Cams
- Engine water temp spikes (almost overheating, but not quite)
- 1996 EX Auto Wagon Random dies
- Sensor problems
- looking for b18 spark plug cover
- Clutch problems but new clutch?
- Does anyone else try and fix their own parts?
- honda civic overheating
- Backfire? After letting off the throttle and shifts.
- Code 43 help B20 swap 1991 Civic - been through the flowchart
- 91 civic hatch fuel pump/wiring problems
- 94 prelude BB1 vtec not engaging ?
- 96 Accord LX, Cooling System issues
- oil light help!
- Cam ideas for 2002 accord 4 cyl
- b18a1 into eg hatchback, help please.
- AEM or Motec?
- OBD2a harness to OBD2b motor, crank sensor different?
- 1994 Accord LX 2.2 liters Cylinder # 1 Misfire after it reaches operating temperature
- Tore Down Block, found thick grey grit behind this front water plug
- civic eg misfire
- El cluster in civic
- How should i start?
- F22b
- please help 93 honda del sol
- 93 civic sedan lx 1.5l starting issues
- Running a chipped ecu from RyWire
- p12 ecu with a6 cam on an a4
- Integra running super rich?
- 95 Civix DX Temp Gauge
- help me please fault code 8
- 97 del sol wont idle when cold
- skunk2 pro series 70mm TB idle problem
- Trying to figure out warranty/service history for 2000 Insight...
- 2005 Acura TL with "code" on radio and dead battery that won't charge
- 96 Accord with a stolen stereo
- AP2 gauge cluster swap, problems with temp gauge,1997 honda civic hatchback d16y7 p2e
- CP Pistons stock wrist pins number
- b16a compression?
- Well... I have some issues.
- coolent plug question
- Head gasket?
- 3M vs Welding
- Short Ram Intake
- Anyone Ever Heard Of This?
- H22a1 94 Accord throwing CEL Code 22
- Door Panel
- crank preperation
- Idle problem.
- Oil/Sludge all over engine...
- b7 or a6 block with a z6 head
- Radiator Fan problem 92 honda civic
- Head gasket valves or rings
- D15B OEM Part Numbers
- Smog help... High Hc level
- 93 hatch. Car won't start at random times
- 98 Civic sputtered and stalled. Won't start!
- How to calibrate throttle position sensors with HDS tool?
- Mugen Steering Wheel, real or fake?
- Coilovers
- Pilot Ignition Switch Repair
- DMV - title question
- LSVTEC COMPRESSION TEST #'s HELP
- 96 Integra GS-R bogging and hesitation
- Can cleaning the carbon resolve the knock sound problem while acceleration?
- swapped from obd1 to obd2
- New problem H22a swap. Wont stay running. Fuel issue?
- Blow of valve like noise
