View Full Version : Tech / Misc
- heads and camshafts
- tokico springs
- Help car wont start!!
- snapped the alternator belt today, what size belt do i need? (details inside)
- Little Help for a VW guy: Throttle posiyion switch
- troubleshooting injectors
- I Need a P28 With P73 Specs!
- msd rpm activation switch questions
- rear lca bushing
- sy1 tranny problem
- any suggestions on a hi-flow catalytic converter??
- pcv valve broke
- Why is my b18a1 smoking?
- B16a Timing Belt
- Car hesitates and dies sporadically, need some help diagnosing the problem!
- nitrous detonation!
- How hard is it to????
- TPS question
- Drift/Grip Car Choices...which would you pick?
- Help Massive Loss of Power.. any and all help appreciated
- uberdata h22 turbo...anyone have maps to share or somethign to take a look at?
- Hydraulic problem
- need help choosing best cam for minime
- vafc-ii with pr3 ecu
- h22 head on b20 block?
- which tranny for a b20vtec...stock b20 or other?
- b16 engine ticking
- 94 Civic Hatch exhaust HELP NEEDED!!!!!!
- Bolt Stuck In LCA, HELP!!!
- question about LSD and torque steer.
- Need help hooking up my buddy's B16A. Suspension and Turbo.
- Experienced honda tech people please! Idle Problem!@! i am on the edge of going insane!
- any body shop guys here?
- quick help needed!
- Suspension ????
- Anyone know the flow rate of the injectors off of the new K24 (2002+ CRV)?
- a few questions about B series trannys special 94 LS tranny HELP ME OUT
- Best Head for a B16 block???
- Coolant pressure
- O2 Sensor Failure: How common is this?
- ignition problem but only when backing up
- cable or hydro tranny?
- Clutch fluid leak from tranny! help please..
- problem?
- Bleeding A Hydro Clutch
- Lowered past 1.5", how do I save my kyb agx's?
- Help decipher problem plzzz.. Tranny problem???
- Bronze shavings???????
- Wheel Balancer and/or Tire Changer
- HELP!! Engine surges while at idle!!! Please help
- Usual cause of steering slack?
- VTEC Solenoid help please!!!
- Msd Pills?
- head problem
- What size wire to use for a simple fuel pump kill switch
- quick qestion about cv boot and rotors
- distributor ate the rotor screw, destroyed ICM HELP!!! please read!
- y1: is it limited slip?
- Spark Plug Wires
- Air Conditioning on '90 CRX. R12-R134 Conversion HELP
- who makes the *?LIGHEST?* B-series cam gears
- 96 automatic transmission into a 90 accord
- Civic VX D15 Turbo
- Cylinder Sleeving
- Head Question!
- how was your experience with camp1320?
- best size tires for 3" or 31/2"rims (skinnys)on a 97 civich/b
- Quick Time Electric Cutout Package Single 2.5'' ?
- How to adjust coilover springs
- someone help!!!!!!!!
- intake cam @tdc
- Locking out the distributor. How to?
- hydro tranny?
- engine swap
- f22 crank h22 block
- N/a Engine for now Turbo for later....Need Help building and deciding....
- Need help finding b16 Turbo spark plugs..
- Is this a good price for Iluminas
- Spark Plugs fried
- chp
- h22a4 wiring diagram
- uberdata questions?
- ECU switch, is it harmful?
- What can I do to make my AGX's last longer?
- Intake Manifold comparison (d series)
- h22 swap complete....with problems
- What Radiator for H22 in EG1???
- Head gasket changed - results
- For the love of god, i HATE my damn car
- B18c5 Chiping an ecu
- cant get my tranny oil fill bolt out!!! please help
- D16Y8 manifold swap D16Z6 motor, gasket?
- throttle body gaskets
- Fast engine swap/change help!!
- How to fix a coliover thread?
- Socketing a JDM p30 for Uberdata
- VW Golf help...
- torque steer?
- sy1 axle seal
- what is my final drive gearing
- Crank pulley vibrating!
- do new flywheels need to be resurfaced???
- Suspension grease questions ..would like help quick!!
- Can the CKP in the distributor be used to trigger an MSD?
- Sulfur smell - trying to pinpoint the sourse. 6:53 PM 4/15/2004 Reply Edit
- Ignition Timing affect radio???? (searched to no avail)
- OBD1 code 4 CKP sensor, LS Vtec, Greddy Turbo kit, need some advise.
- Check Engine Light is on
- Clutch Problems
- Tranny zipping sound??
- DeCaRbOnIzInG HoNdA MoToRs
- Timing 180 degrees off???
- Mugen Valve Cover?
- fuel injectors (remove/install) G3
- k20a head question
- pushing piston back in when replacing pads
- Clutch question?
- How much of a power loss will be shown with an LSD when a car gets dyno'd?
- anybody have pics of valve guides installed?
- Voltage reading @ ECM for ignitor wire?
- 95 civic ex
- can gsr calipers fit on a 99 civic dx???
- SMSP header...
- Sage Racing Final Drives or others
- Honda diagnostic tools on eBay!!!
- aftermarket starters
- PoorMan's-R swap now VTEC bogs!!
- Oil light ...help
- request: how about a faq on how to rebuild axles?
- how to change engine from 1.5 to 1.6v-tec
- What is "liquid gasket"?
- Size diff in vtec solenoid??
- Comptech Rear Sway/Tie Bar Combo fit the EG chassis???
- WTF is going on .... Air being pushed out the valve cover
- Do b16a2's come with oil coolers?
- What kind of bearings do you use ? ACL or OEM honda
- Clutch Damper, do you need it with a heavy duty clutch?
- whats the purpose of the fia control silinoid?
- something interesting at this site
- NEED SKUNK2 STAGE 2 LOBE SPECs PLEASE HELP
- D15B help
- people with oil pressure guages and vtec
- how u take off a windshield?
- 6 puck clutch>good or what?
- 6 puck clutch: tell me about it please.
- IS there a difference in ABS and NON ABS MC and BB
- CARBING FRONT STRUT BAR & ITR ANTI SWAY
- question on stock ITR oil cooler
- B16 problems no fuel to cylinder
- Are these the upgraded ARP eagle GSR rods?
- Overheating problems on D15B. Thermostat?!? Other!??! please help
- Timing Belt Help (Searched)
- Raising Rev Limit
- Why Does Sand/Sugar Ruin An Engine? How much?
- How similar are power steering and manual steering racks ?
- vtec/vafc question
- LSD Techs Needed!!!!!!
- "Massaging" the strut tower?
- hard to start car
- wiring harness
- Snap ring came off the axle while it was in the tranny.... HELP!
- Integra Tranny Swap Auto > Manual
- p29 in d15 mini me
- Is this a possible spun bearing?
- HEAD WORK Welding the head for more HP... Comments on new Dart Head?
- Best Tranny for B18C1......LS or GSR???
- SoCal People, want to end car theft?..all info inside.
- stock lugs with rotas.
- Specs
- AEM FPR owners!!!
- vafc install help!
- factory torque specs for valve cover?
- jdm dc 4-1 and dc sports 4-1
- PLEASE Help
- CKF Sensor (Crankshaft Speed Fluctuation)! HELP?
- D15B7 vs. D15B2.........What's the difference????
- Anyone have any experience w/ Jerry Built of LA?
- 50-50 mix : 87oct. + 91oct. = 93octane??
- need to rebuild
- SAFC II Tuning Problems!!!
- i need help with my flywheel/clutch
- Can't get cams at TDC...
- B20 bottom half with B16A head + Skunk Stage 2 Cm shatfts
- b18c valve adjustment... tdc=? go by cams or crank
- off topic: why cant i post anything?
- wiring question
- Rebuilding tranny, how hard is it to replace syncros?
- Hesitation/Miss at low Rpm, WOT...
- ecu problem
- v-tech
- ?!vtec head?!
- Maintenance on ZC engine in 91 Crx si
- terrible throttle response (stock b16a), and engine health
- steering vibrates on and off help
- Ignition cylinder / tumbler help
- b17 crank compared to b16. pictures please
- yet another no inj. pulse after swap...this sumbitch makin me mad
- Skunk2 Camber Kit
- b16a block: how to identify if its 1st or 2nd gen
- Wiring secondary HO2S to my dx. wiring gurus please help.
- Is this normal for a 6 puck clutch?
- Exhaust flow reduces at higher rpms??
- ls block with b16 rods and ls pistons= low compression?
- broken snap ring
- Problem with my B16
- ***86 accord dx***
- JAZMA MUFFLERS
- Need to replace my fuel rail... options?
- D16Z6 need help
- K20 in a 90 civic 4dr???
- what can i expect with this mini-me turbo steup?
- my proposed turbo motor... opinions wanted...
- SMSP Header Owners
- Transmission issue.....
- Plastic Connectors for Harnesses
- need some info..please (cam gears)
- question about aftermarket lug nuts....
- What cams for B20Z more HP ???
- D Series ARP main studs
- GM Synchromesh question??
- Stock cam specs for a B20A5 (90 Prelude)
- is it ok for me to switchto synthetic oil?
- AEM EMS Feedback
- help pls... greddy header question
- *****NEED SWAP HELP*****
- will B21 cable tranny fit any other car?
- fuel pumps?
- MUGEN CHIP IN P13 HOW DO YOU INSTALL JUST SALDER THE NEW ONE IN....
- ARP MOLLY LUBE, where do i use it?
- B16 & B18 tranny case differences
- Can overfilling your oil cause a "check engine" light?
- 96 jdm itr cams: good for a b16a or not?
- need help tryed everything?
- Suggestions for Swaybar set for 1996 Accord dx 4cyl sedan?
- getting tien s springs: what are the cheapest shocks/struts that will hold up?
- d16y7 O2 sensor vs. b18b O2 sensor
- Results of Leakdown test : what to do now??
- need help asap. idle too low:(
- Donut Gasket for 2.5" Collector - substitutes?
- Michigan Dyno?
- Need you help, I f'd up
- ECU problem... Please help !!
- Threw a CEL 21 after installing CTR cams.
- NEW JG CAM
- B18B AUTO TO B18C MANUAL CONVERSION
- HELP!!!! bad idle surge in my swapped hatch!
- hideaway lights gone bonkers
- 00/01 ITR cams in B17A.. wierd noise..?
- 5 Lug CoNversion ?
- ***putting my b16 head together i got Q's***
