View Full Version : Tech / Misc
- Intermittent stumble then dies.
- Noob obd0 to obd1 question
- 98 GSR fXXked idle
- H22 swap wont start!! Need help with ECU.
- Need help. Car smoking
- Skunk2 Owes Me A F$%#in New Motor
- Do I need to replace the secondary oxygen sensor too?
- oops: Timing belt adjuster nut washer
- Anyone here reprogram PW0 or PR3 to run with only 1 o2 sensor?
- JDM EG6 Caliper fit a USDM EG Hatch?
- *** Unable to Time a b18b with a Timing Light... White mark too far ***
- Help!!! Hydrolocked!
- smelling oil Burning oil?
- Smoke????
- wider tires for eg
- Turbonators?
- Lowering Springs.... whats best?!?!
- Need help, Broke bolt changing oil pan.
- converting OBD0 to OBD1 for Hondata - checklist
- Dry Ice intake??
- Anyone dynoed the B20z intake manifold (w/ top chamber) ?
- Need a little help with OBD1 engine into CRX *pics*
- Vtec engagement question
- spoon/mugen fan switch = ect sensor
- B18b vs Smog
- plz help!!!
- help with fuel pump
- belt tensioner
- AEM OR FJO WIDEBAND
- quick help! front brake problem need help asap.
- Oil problems with DC2
- Best suspension for me??
- need help with ac in my 94 civic?
- 2000 gsr ecu question
- Weird Noise When Clutch Is Pushed In
- ??MAHLE RACING PISTONS??
- Innovative M-300 Wideband group buy
- d16 sohc non vtech
- v-tec kick in
- What is a p30 ac bracket from?
- Valve Cover Stud
- Can't set revs with Hondata button
- WTF is going on? I need some serious help! Pics inside!
- help! how to tell if ecu is auto or manual?
- exhaust problem
- question about distributors
- Bad Stuttering and Bogging!!
- 450cc DSM Injectors in Non Boosted B18 ?
- Ls/vtec build questions
- Blue smoke
- Anyone got a write up on how to install a crank pulley on a B18C?
- Does Civic springs fits on integra?
- Venom 400 performance control module
- B20z plug wires
- Proper cool down
- B18C1 (GSR) vs B18C5 (Type R)
- Pinking (pinging) under BOOST with my B18B
- engine swap: does obd matter besides smog reasons?
- Did I hook this universal o2 sensor up right? ASAP answers please
- Knock sensor.. pr3, B16a, (obd0?) What is the proper test for the knock sensor?
- small light fuse problem!!! no lights!!! HELP!!!
- Fuel Rail Nut
- what parts could possibly be made of carbon fiber?
- need some info on crank pulleys/bolts
- weirdest idle/throttle issue... Never seen or heard of before. Help me!!!!
- f22 vs. h23 vs. h22
- ********HELP THE NOOBS**********
- inline fuel pump theory
- 1997 Honda Prelude SH CLUTCH
- The new trend of nitrogen filled tyres
- My Dad and I got into a disagreement
- ek hatch obd2-1 harness runing on chip p28 throwing heater o2 code wtf?
- Bilstein shocks with sleeve coil overs ?
- how to use plastigauge???
- anyone know what car this dizzy is off of?
- B20b/LS
- uberdata on crower 404's
- If anyone knows anything about role cages please help me
- NEED HELP ASAP
- pain in the ass radio
- Engine builders: bearing clearance ???'s
- y1 lsd locked up?
- Knock sensor question?
- my car smokes???
- High Heat Flexible Hose For Exhaust Needed. What can I use????
- Where to start with uberdata
- not getting any fuel
- obd0 to obd1 swap must adjust timing
- Hondata Question on Injector settings and uego setup
- AFR Fluctuation / at idle? (wideband readings)
- machine shop in so cal
- fuse/main relay/fuel relay problem
- replacing ignition rotor without screw= safe?
- Weird sound from Cylinder head? Help me out
- d16z6 built with boost ?'s
- ls vtec question help
- 86 Civic Idling To Fast
- rod question
- 1st gen b16 head "valve seals"
- d16z6 block passing smog in a 00hatch
- cracked block theory when sleeved? pics.... story.
- upper control arm bolts, remove when lowering?
- obd0-obd1 conversion help!
- 02 sensor size
- B17 To B16 Swap (What ECU?)
- Head Gasket
- Tuning with Hondata
- Bitch pin removal...I have a great tip here!
- Thermostat Housing Question
- Engine Code, Chassis Break down: All Honda 73-03
- need torque specs for b16
- Strut Bar Question........
- breaking the axle nut with tranny in P.
- Proportioning vavle, 4040 vs 3040
- Say bars on a '97 civic HB
- Couple of ECU questions, regarding OBD1 GSR in a 99 Acura 1.6 EL
- LSD wheel hop?
- what can i do to carbonize my engine
- help me build a b16a the right way
- Hex help!
- Remove camshafts then reinstalled and didn't use assembly lube... Would it cause bad idle?
- Anyone heard of those rims?
- B16/ ITR head diffs
- obd 2 to obd 1
- Oil Pressure Question **EMERGENCY**
- flashing light on digital 7??
- What CR for Skunk2 Stage3 cams
- Fuel Pressure Bad Problem
- Y7 Block with a Z6 head
- car keeps dying
- arp sent wrong head studs?
- Hard much downtime to stroke b16b?
- Good shop in the Temecula So. Cal area to dyno tune a VTEC controller.
- stumped about an 86 accord...help plz
- shift linkage pin removal
- "S" light blinking!??
- Loosing oil pressure in corners, any ideas?
- Recommend me a cat!
- **TRANNY QUESTIONS S4C 99-00 CIVIC** HELP
- Help with compression (this motor building stuff is crazy!)
- 92-95 civic SI Brakes & Suspension on a 91 CRX HF
- crank pulley question.
- instruction on using a Heli coil
- Injector clip removal
- crvtec head stud question *****need help ASAP*****
- ABS REMOVE FOR TURBO SET UP?
- Need help with EGT gauge!!
- What Throttle Body Combo did you use ?
- Is my P30 socketed???? LOOK help !!
- why is my motor stalling? fuel-related? need help
- so my vtec stopped working please help
- gsr ecu with ls motor any benifits?
- has anyone purchase the cf spoon replica mirros from www.jdmshit.com?
- Do Ground Wires Work?
- Info on replacing Brake MC on an Accord.... (searched)
- flywheel bolts
- Steering Wheel Vibration
- few questions about oil and boggin
- A Question about Oil.....
- after vtec kicks in, it starts cutting off an on again. CEL code 22??
- Dust boots for Koni/GC
- Having to take a dump
- Great site For DIY
- Laptop Stand
- lsvtec? car starts to bog when i hits 5000 rpm
- inline fuel filter pics/tech
- inj not workin......fried????
- This didnt happen before
- wierd stuff with pressure plate need help!!!!!
- Car will tach out by itself when you start it. Any Ideas????
- How much do the shops charge to align bored or align honed??
- JE pistons specs
- F20B?
- gsr 240cc injectors with 84.5mm engine?
- Injectors not firing.
- question about b16 tranny gears?
- Delta Camshaft "Hook-Up"
- Question to people that have personaly soldered/chiped their ECU's (hondata related)
- LS-VTEC ROD KNOCK?
- please help quick! y8 Oil pan on y7 block
- Machine Shop in DFW?
- How to wire knock sensor in b18a block.
- whats the average cost per hour of Dyno time???
- do you think it will last?
- timing-distributor question
- what throttle body should i use?
- lucas 440cc injector seals
- differences in dynos
- vafc tuning without dyno...need help plz
- apexi gauges install location
- Black Smoke( searched)
- pistons with offset pins - advantages?
- before i look into a h22 swap... simple question.
- lsvtec question..??
- How Hot?
- zc transmision
- causes of low oil pressure?
- does this sound like a fuel filter problem to you guys?
- my car makes a loud rattling noise when accelratin or reving when warmed up
- Crank Position Sensor... Code 4... Did search, different issues!
- what happen to all the tranny ratio sites?!
- immoblizer to PCM signal error problems after VAFCII
- compression test #
- Why the weight difference in Intake and Exhaust valve springs?
- is the knock pin (D3) supposed to be grounded?
- oil leaking on ground?(non honda)
- AEM EMS Problem
- 2004 SOHC Honda Accord Vtec
- N1 know when vtec kicks in on a p28?
- HELP!! crx w/ zc problems (may be timing)
- Adjusting Idle
- anyone have a chart of stock injector sizes??
- need help with emissions
- need to lift engine of stand
- Is 5 Lug Conversion Worth the $$$
- What are the differences between dynos?
- rings and bearings?
- car starts bogging at high rpms??
- back firing // spitting flames? whynot!?
- 15psi Tuning on OBDO System. Possible? Which Company?
- VTECH Question
- NEW MOTOR - Hondata base tune - Car starts and dies right away. CEL 22 HELP!!!
- How do you tell what year a head was made?
- My Trusty Tach (Search Found No Answer)
- clutch questions
- Timing Belt Cover b20 vtec ?
- Getting confused over B16 swaps
- #3 and #4 cylindars having trouble on new rebuild
- bouncing idle until warmed up... ideas anyone?
- who's has access to a NMR machine?
- H23/VTEC DYNO
- Whats parts are needed?
- Block differences between D series engines?
- 2001 Type R Springs on a 96 Civic hatch
- Tearing head apart B-series?
- Dyno Tuning/Baseline
- New engine... won't start now. Will pay if someone tells me whats wrong. NO JOKE!
- Another one of those bad idle threads plus vtec, lma, bogging HELP *lots of searching*
- AEM CAI & hydrolock
- Good clutch replacement.
- Is there something wrong with the new honda calipers?
- injector wiring problem
- ecu chip question
- fuel injection question... who can help ?
- Help.....
- Dual Valve Springs
- jdm b16 going in a ek96cx.need help
- 5w-30 or 10w-30 for a 142k
- Spark plug wire popped out from distributor cap and ever since that, car is lagging??
- disabling abs ?
