View Full Version : Tech / Misc
- HOlding power of ACT XTreme?
- drum brakes TO disk brakes ! HELP !
- Double spring Coilovers??
- intake manifold leaking coolant
- anybody ever get a P&P on a '96+ gs-r with obdii? how does P&P affect the obdii ECU?
- Getting the @#$%&** oil pan off!
- need help with engine.....
- G3 Integra ABS wheel sensor.....
- How to Install a Cusco Catch Can on a B18c1 engine.????
- Hondabond
- hondata+12:1CR+91 octane???
- Need Help - all you electronic junkies :)
- Spark Plug tips Pure Black, Please Help
- B16 swap--which clutch, ITR or ACT??
- Launching Technique
- ACT clutch?
- Mugen ecu chip, your opinions
- will del sol stock springs and shocks fit into an integra?
- Titanium Retainer Failures
- ctr motor:will it pass smog?
- RPMs are fluxuating at high rpms
- How hard is it to install a cam gear?
- p28 on a ITR yes or no
- I hate knock sensors.
- syptoms of a bad distributor
- What coilovers to get with Koni Yellows?
- ngk spark plug part #
- Fresh Built H22 Motor
- CAMBER - 97 civic w/ H&R sports, KYB AGX
- short shifters?
- Difference b/t auto ECU and Manual ECU?
- strange vibration in engine
- HONDATA or AEM EMS?? Who has what???
- spark plug tips pure white!!
- Transmission grinds only when warm
- good fuel pressure for nitrous....
- What is blueprinting?
- Erick's TB Idle Adjustment
- white smoke - ls/vtec
- IAC Valve Help!!!!!!
- A/C question... R134a vs. HFC-134a
- GM 1 BAR Map sensor, part number ?
- B20vtec question
- B18c head & b17 bottom. Possible???
- Spark plug gaps on Denso Iridiums?
- Any danger using copper/brass radiators?
- B16a stoked with a b17 crank?
- Why is my CLOCK dim? What is wrong with my clock HELP!!!!! WIRING PEOPLE!
- VAFC ques
- Z10 Radius arm for wheel hop?
- N/A hondata tuning q's
- GSR vs. CRX b16a
- master cylinder
- need some help with alignment
- Warranty Services....
- 160 mph!
- Oil pan baffles, anyone have a design or a diagram?
- obd2 to obd1
- car is making funny rattling sound just above idle...help!
- battery was dead....need help
- my car pic, sigh.
- need some help quick!!!
- T belt gear ? techs only
- Grinding 3rd when speed shifting...Tranny going bye bye???
- common question ?
- cusco (tryed search)
- fluid leaking from clutch pedal... what should i do.
- golden eagle sleeved gsr or b20 vtec??
- How to change a clutch?
- Auto Meter Volt Gauge
- compression test figures
- removal of stickers from paint
- 00 Civic EX w/Turbo vs. B16a CRX, need stats/opinions
- b series crank pulley
- AEM CAI Dyno plot on GSR...anyone have it?
- Anybody ever heard of a ITR spare tire well brace ?
- 91 legend ac lines pressure?
- pure oxygen to increase power?
- Knock Sensor replacement/removal
- Pic Request: gsr's w/ skunk2 i.m.'s
- need to replace clutch master cylinder --- help
- does anyone know a reputable mechanic in so cali
- Missing Valve
- b series questions
- re-using main and connecting rod bearings????
- Valve adjustment and oil change?
- How to break into Endless MA11 brake pads?
- Dyno plot....suggestions??
- milling your head (how much is to much)...?
- suspension question
- Milling your head, ( how much is to much)?
- ECU related peformance problim! really need help on this one
- HELP - Just got in deep sh*t
- Got some Q's on my rear sway bar installation
- intake, header, cat back
- bleeding clutch fluid
- Oil Temp vs. Oil Pressure
- Turbo Kit WHP numbers on EK, DC, etc.......post please!!!!!!!!!!!!!......
- No Spark H22
- trouble with Mini-me!!! Help
- irratic idle need help asap
- Can my stock gsr valvetrain take the pressure of both Ctr Cams??
- Cam Gear Settings
- Civic Ex 2001 no mods WHATS FIRST?
- Anyone know the bleed sequence for a Nissan Quest?
- Help! Just did a compression test
- Built ls or gsr
- nosiy belts
- Distributorless Ignition ...
- Leaky Engine Oil ? for Techs
- How many volts to activate VTEC 12volts
- WTF!! car wont start after compression test!!!
- Greddy b-series headers
- AEM Standalone
- OBX GX type strut bars?
- B16 model on US Civic? CR
- does pep boys do good tuneups?
- help guys
- Noise under car?
- Question about the IAC valve....
- What would cause a large amout of carbon build up in the combustion camber?
- flywheel holder??
- tranny prob, pls help
- Spoon headgasket or 1layer stock headgasket?
- my d16a6 losing compression any suggestions?
- 01 accord ex disc changer....
- possible problem??
- Fouled Plugs!!
- high idle in 88 dx with ls/vtec
- Having second thoughts. . .
- O2 sensors? Stick with stock or others ok?
- H22/Civic dudes, swap's done, but i have an ignition problem......should be easy for u.
- Flat spot after JDM header install...
- Wiring Questions on a 1995 GSR
- Decat or system?
- attn anyone w/ h22-ek
- broke the thread to my valve cover
- Smog Results
- Oil cooler adapter..need to know if it'll fit
- Braking Shake (not warped)
- fuel pressure wont hold!
- HELP: Driving without brakes is not fun! =(
- Wheel Bearing replacement
- B16a wiring help!
- Suspension problem!
- ITR intake manifold
- High tech
- 6th Gen. Civic Rear Disc. Conversion???
- what is better for turbo b18b or b18c1
- What is wrong with my engine in this video?
- supra problem...help! knightsport or anyone!!
- Anyone got a virgin PM7 ZC Hondata/Zdyne/whatever map?
- suspension question.....lateral g
- customer headers v6
- Need Clutch help...
- intake cam and spark timing tuning question
- odd startup staling and fuel pump noise
- technical - O2 sensors disparity
- fuel pressure regulator
- engine temp sensor
- ctr pistons in a b16
- Malpassi Fuel Pressure Reg
- assembling motor, wondering about crank pulley key(s)
- b16a ??? regarding ctr pistons
- Battery on fire!
- Aluminum Crank?????
- ECU codes? site that lists them
- best header for a 2.25 exhaust?
- aem cai whistling
- OEM Type R Cam
- Weird Engine Noise.. help!
- GSR guage cluster in a 99 civic???
- HELP busted wheel lock?
- please define lean fuel mixture.
- tokico coilovers
- GSR engine obd year
- chipping and masss air for non v tec integra
- want to convert from drums to disc
- Same? USDM and JDM wiring harness!
- cool air intake vs. ram air vs. stock
- throttle body
- What do you guys think of this header?
- BB3 changing pressure control valve to BB6īs one
- puffin smoke HELP?
- VAFC - should I bother?
- installed fpr.....got a ???
- jdm s1 vs. usdm s1
- superchip
- im having problem w/ my idle air control valve
- Throttle body question
- D-Stuff
- So what does "B18C5" mean anyways?
- Quick help on thread pitch of a couple of nuts....
- Little help?
- cyp sensor wire?
- venom nitrous problems, please help
- what do toda cam sprockets look like close up?
- b20 quick question.. please take a look & help
- Coil spring compressor
- 1stgen b16 in 90 hatch, how to do Timming.
- help me please....idle is wierd
- what do radius arms do? strong bar? floor chasis bar?
- RB26DETT in supra
- D Series Headers
- b16 wiring diagrams
- no vtec?
- Installing Defi Link system, need ignition diagram.
- building a leak down tester help
- Bad news!!
- i got a few newbie questions...
- Remus exhaust any good??
- WHen to bore and when to hone
- pacesetter exhaust
- Best ring set for High CR and possible N02?
- diagrams?
- B18C1 water temp
- Cam & spring install pics
- I gotta give it up to you honda guys
- MAP sensor problem
- the best built transmission
- how do i.....
- can i run b20...(w/ no vtec) on obd1 if i have obd0
- gsr into crx.
- *ADVICE* How and when do I need to clean the Air Filter on my AEM Intake?
- Nitrous
- (ITR ex & in cam set ) or (CTR ex& in set) or a hybrid of (ITR ex & CTR in) for a B18c1
- car hesitating to accelerate
- Need Suspension Advice for 7th Gen Civic
- VSS Speed Sensor OR Speed Pulser?
- Help, Gray Smoke!!
- who has had stock to the extreme?
- GS-R manifold question?
- hello!
- Hybrid A/C Thermo Q's
- Spoon Ventuli plate
- Frankenstein project
- prices
- Car won't start after checking timing?
- I Need Some Help
- Where can I get ClutchMasters stage3 for cheap
- Turn signal problem
- Bigger brakes?
- polish rods?
- need advice
- Apex i stuff
- catalytic converter?????
- Electrical Gremlins - Radiator Fan, Fuses
- Making a wet NOS system dry, how hard is it?
- OK, My brain is going to explode!!!!!
- Speedometer Problem..HELP ME SOMEONE!!
