View Full Version : Tech / Misc
- Adjusting valves after installing cams. do i really have to?
- 2000 ITR cams, are they different?
- spring rates...400/600?!?
- Opening a B series G/box. (Y1)
- how much oil does a d16z6 tranny hold
- Why does the CEL disappear when I wrap tin foil around the O2 sensor
- first generation b6 tranny
- coilover install
- anyone know hp gains by raising compression???
- where to get a spoon tranny fixed?!
- Tenzo-R Coilovers?
- AEM FPR
- Shed some light on valve springs to use or inter change
- Gear Ratios
- Need answer to about suspension application
- 87 honda civic d15a2 Low vacuum question
- B18a intake manifold on a B16a-Will it work?
- vtec?
- Got new tires - now steering feels too easy?
- need a part # for aem replacement rotors
- Anyone with an STR manifold on an H22 PLEASE read.
- Can my front disks from my 97hatch replace the drums in the back???
- Need help w/parts for rear disc/rotor swap into '94 Civic VX
- Greddy Evo. or Apex N1 exhaust...
- Stiff clutch pedal..
- Anyone pass SMOG with JDM engine?????
- Manually Tunin the Vafc by yourself Vafc people please help
- B16a NON-Platinum Spark Plugs Wanted, any help?
- B16A, B18C1 timing belt difference?
- downpipe question!!!!!!!!!!!!!!!!! for DRAG GEN 3 for GSR
- Infamous Civic LCA Problem
- platinum plugs - one of all four
- High Octane Gas
- O.T. HELP!!!! RATS!!!!
- Highest compression on pump gas in a hot climate.
- ecu question
- Brake Q
- suspension question
- will a dc 4-1 b16 header clear the oil pan ona b18??
- knocking/running like sh*t!!! help!!!
- Atlanta H-T Gathering May 25th
- where to get a sheet metal intake manifold made
- Changing from auto to manual transmission
- Restarting problem
- My Tranny is binding up.
- distributor question
- Calipers upgrade on 4th gen civic: which?
- How does REDLINE in a DOHC VTEC work?
- Do wheel dimension/weight affect dyno runs?
- Brake booster broken or not need help
- Wheel Hop
- gsr turbo help
- any good tuner shop in chicago area??
- Hondata Help! Kinda long, bear with me... I Posted on the hondata forum but I guess everyone is scar
- Best shop for tuning in Central Ohio??
- help....oil in intake manifold and all over spark plugs
- Bizare brake problem Please help!!!
- wideband O2 sensors, what are they?
- Yokohama Paradas and Parada 2
- how to install ex manifold on dx civic (97)
- H22A/Civic axle ?'s
- Could my head gasket be shot
- CRX HF rear drums...
- head problems
- Spark plug heat ranges???
- how often do we change the.......?
- Sudden partial electrical failure
- non-reground cams for b20
- LsVtec oil pressure problem
- Someone tell me, What is the GREEN wire FOR?!? O2 sensor related.
- LS Hydro Tranny upgrade?
- D16Y8 Intake manifold on Y7 head questions
- busings and clamper kit or is it caliper kit
- D16A6 ECU
- Who do I need to speak with on starting a FAQ/How-to section on Honda-Tech?
- Check Engine light
- si A/C mounting brackets needed for swap into EX 6th gen?
- Intake Bypass solenoid ?
- Losing Oil Pressure and Oil
- Spoon Tranny vs Type R Tranny
- WHAT CAN I EXPECT FROM THIS SETUP?
- F22 head swap??
- engine coughing, no clue why
- why a knock at cold idle>?
- Clutch install
- heat wrap smoking?
- b18 head - b16 block possible??
- D series injectors same as B series?
- "shave the block"
- JDM B16 in EF9 doesn't fit! HELP!!!
- Best Place to Buy Koni Struts
- I have a DX Auto hatchback can I....
- Tire poll
- can you fit a 195/50-15 on a 15x7in wheel?
- Help!! driving w/ a bent valve!!!!!!!
- laws in VA??
- IACV...age old idle turbulance...problem solved?
- Vavles Ticking..what do you think
- Good shop in Bergen, NJ for gas pump repair
- speedometer is not working...
- jrsc b20vtec?
- quick quesetion....CR for ctr cams w/ pisonts
- compression and leakdown test numbers?
- someone please post instructons on rear R sway bar install
- is there a upper pillow ball mount for koni?
- Anyone have experience with a PR3 chipped w/ Mugen program?
- Venom 400 or JET V-Force????
- stupid question about Spoon head gasket.
- DC shift adapter = cracked console
- Won't start right after shutting motor off
- hardly any brake
- EVO vs Thermal R&D
- Lightened Flywheel questions
- Clutch... what parts make up a clutch assembly?
- Engine braking...
- timing belt losing teeth after 10k miles
- vavle sounds?
- moon roof not closing?
- Do '99-'00 Civic SI's have the anti-theft immobilizer?
- 2000 EX and SI exhaust compatibility
- Type R valves
- Using bronze valve guides in an h22a
- RC injector install questions
- Opinions on the Powercore bseries header???
- Type R intake
- Ok, call me an idiot.
- 88crx dx --> d16y8 = spark but no fuel ( help)
- !!! recomended ECU for this setup...i'm thinking Hondata 3
- A/C: On or Off?
- vafc vtec controller problems
- Fuel pressure (and yes i did a search)
- Using b16a3 pistons in my spare b18c1. Pro's/Con's/How to? thoughts appreciated
- Problems with vtec head (i think)
- 99 si front & rear sway bars?
- anyone running a welded diff or a spool?
- Gearing ???
- RED Suspension
- what spark plugs should i use??
- Blitz Power meter ???????
- problem if vafc vtec controller
- Piston Clearance
- Best CAI kit?
- starting my bottom end......
- Has anyone used ARP studs on their B17/B16 crank mains?
- Transmissions and swaps, help clear up some confusion please!
- Please, i need serious help with my car.
- Ls/Vtec Internal ?'s
- Intermittent Studder
- Endyn ???????????
- OBDII to OBDI, what about the tranny computer??
- !!!!!Loose and wobbly hub and rotor!!! HELPPPPP!!!
- 96-up EK Suspension components and swappable parts.....
- spark plug gap?
- Need to know if an ecu will work
- What are symptoms of a leaking head gasket?
- What's the best way to clean your engine bay?
- Check Engine Light On
- Stock Torque Ratings on B16, 18B, 18C1, 18C5, 20Z, and the H22A???
- N/A, hi compression question for piston choice
- Edelbrock Throttlebody
- Atmospheric Pressure sensor Location
- Piston/Rod/Machine Shop Questions
- Is $100 too much to pay for installing springs?
- spoon cams! help on specs
- Toda Cam Gear setting question
- 95 GSR has trouble starting when parked overnight on an incline
- Dyno Testing North Central Florida?
- question on wire harnesses
- Civic Si wont rev high any more
- Wet N2O + B16a w/MODS = :thumbup: or :thumbdown: ?
- CEL
- Kevlar versus Organic Clutches
- Looking for ways to smooth out a bumpy ride
- Crower cam timing! Need input ASAP
- What size slicks for GSR Civic?
- just got my new ground controls...
- how to pass emissions?
- losing oil, how to determine if its rings or valve guides
- wtf??????????? please read
- h22a4 bottom end is apart... pics!
- Stripped some stud holes...need some help
- fuel leakage
- HELP with fuel injectors
- 96+ problems with rest fuel pressure?? (car cranks slowly after shut off sometimes)
- Cheap B16a Tweaks
- where can i get hondata tuned? im in ohio.
- Reset check engine light?
- Shocks and Springs..
- Cutting Springs..
- my car chokes when i accelerate sometimes!! help!
- tire balancing "on-car"
- need suspension advise....
- gs-r throttle body
- Tensioner Bolt removable??
- Just installed Crower 63402's....
- help!!!!!!!!!car is runing lean
- ENGINE Light
- Chipped, or not to be chipped
- Fitment of Skunk2 CO's from 99si onto 91crxsi
- bearings identification
- Head bolts
- exhaust dilemma....opinions
- What size is stock LS head gasket?
- Opinions on RPS clutches..
- Strut Tower bars, and a little Mugen bashing
- Idle RPM Problem
- AF guage
- Help engine problem
- What is the mini-me?
- Oil pressure help!
- CX bottom EX head need info
- Help!!! can't get rid of error code
- SOME WEIRD SHIT ABOUT MY EG...
- 95 SOHC V-TEC in a 91 SI Hatch
- swap probs, please help. accord peeps and super techs
- getting crank pulley off when motor out of car?
- Engine Care.. Need advice...
- wideband O2 gauge vs. EGT gauge
- Short shifter
- skunk2 cams markings?
- AUTO TO 5SPD???
- who has toda b's in a b16??
- Rod Bearings?
- P72 OBDI ????
- sounds like heatsheild rattle but i have no heat sheild
- GSR DOHC CAM GEAR ADJUSTMENT
- Both fans always on
- Can you turn a tranny over by hand?
- PowerFC
- thread and sleeve coilovers
- Bronze valve guides
- Crower Stroker kit? What rod/stroke ratio?
- ** engine reving. ** problem help
- how to install rpm tachometer
- Code 15 help
- need assist about ITR intake arm
- Best tranny fluid for a factory LSD equipped gsr tranny?
- D16Y8 Crank Help!!!!!
- How do i hook up a air/fuel gauge
- 1987 CRX Issues: Where to get 1987 HF drum brakes for rear And Solutions for CRVTEC Shift Linkage in
- Start running Synthetic in B16a @ ~45k or stick with non-Synthetic?
- Changing fuel/oil/sparks in the B16a today, need advise plz
- swap wont start iam stumped.
- toda b specs?
- What else to buy with Skunk2 Intake Manifold?
- Question on suspension
- using a glasspack as resonator ????
- Vehicle Speed Sensor on a 95 civic EX... will one from a b-series tranny work?
- Type-R valvetrain in a ls head?
- O2 sensor
