View Full Version : Tech / Misc
- toyota 1990 celica will not go over 60 mphs its with out shaken BAD very puzzleing?
- Clutch Application for JDM b16 tranny?
- header install on DA went wrong!!!!
- Knocking Noise on Cold Start
- ImportBuilders...Reliable?
- CRX WIT LS MOTOR WAT DOES IT RUN 1/4
- Fuel Experts Help Me Out!!!
- If you've done a rear disc swap on your EK, I need your help!
- Weird sound when turning
- Cable vs hydraulic clutch transmissions?
- help ! I got no VTEC...
- What can cause oil squirters to break off?
- Difference b/tween ACT Heavy Duty and Extreme PP
- I need help rc 310 and nitrous ?
- does anybody have any feedback
- CAN I SAVE MONEY BY GETTING A DIFFERNET TRANNY WITH LSD FOR MY H22a IN MY HATCH ...or aftermarket on
- weird
- CEL code 13 with DSM 450's and AFC...help
- I'm not sure what ecu is this......
- need a cable y1 tranny rebuilt
- Is anybody still selling the h22 balancing shaft removal kit
- Camber Kit on EG with Sportlines?
- wiring safc-II. which type sensor?
- cleaning the head!
- help on halfshaft install 99 LS
- Blown resonator, what replacement should i order?
- Cant get my halfshaft to bolt up??? i need help, pics
- really stupid question but does anyone have a pic of the halfshaft bolting onto a b16 or ls motor 94
- Leakdown test -> what is an acceptable figure?
- My clutch slips periodically....what is the cause?
- Port and Polishing IM
- where can i get a wiring diagram for emanage? ASAP
- P30 under valve cover?
- ((((is there a .30 over piston))))
- AEM Big brakes,16in rims +40 offset.Will they fit?
- Cat issues
- Boost and 4.73 final drive
- Is OBD1 intake manifold better then OBD2?
- Computer Chips/etc. for 96 Accord EX VTEC?
- Pivot Tach problems!!!!!
- how to polish intake mani
- Sandwich Oil Adapter safe?
- Anti-Theft Question
- Wiring ?
- is this definitely a head gasket???
- question suspension tech
- ElectroCharger ??!! Anyone heard of this??
- Civic ex rev limiting too early (~4.5k)
- here's a good question for you guys
- the site for verifying vtec cams
- fuel is shutting off early.....please help
- gsr header on b16
- I need mounts!! WTF Hasport doesn't make them???
- Anyone heard of an electonic control exhaust switch?
- valve adjustment screw stuck. help
- Axles binding and clicking because of suspension being lowered?
- New head gasket - break in period?
- my fuel is shutting off early? help please
- uber data and wideband tune
- Are all odb2 bare blocks the same?
- Camshaft Holders?
- Suspension Question?
- Can a clogged MAF/TPS be cleaned?
- getting a new clutch got some questions ....please help
- Fixed my understeering civic..
- zc / d16a8 wont start.... i need help!
- buying honda bearings.
- help check engine light constantly blinks......
- Going 84mm B18C1 head question
- B16 bore spacing.
- Q on Dyno...
- removeing LS cylinder head...help
- strong fuel smell in engine oil
- Question on fuel cut-off
- what springs
- Pros & cons of a Type R tranny on a LS engine
- 1987 prelude idling problems
- number one cylinder not igniting
- help! obd0 to obd1 conversion in a 2g crx
- Quick distributor question!!
- B16a in 89Si and having an ECU 22??? Vtec :(
- VAFC- has my check engine light on permanently...Misfiring problem
- Brake problem, HELP!!!
- Rear upper tower brace which ones the strongest and fuctional one?
- b16a2 head sensors
- SUSPENSION?
- 4x100 to 4x114.3 Lug Conversion question!!
- ?????????vtec pressure switch Q's???????????
- Where to Buy a Short Block
- need help, engine oil pressure problem(long)
- VTEC Engagement, when is your's??
- HELP CAR IS NOT GENERATING POWER PLEASE READ
- compression testing! need info
- B16 cable tranny problems
- Need help identifying a connector
- ACT plate with exedy organic clutch
- Cable Reel Testing....
- need help!!!!
- Will VX rims clear gsr REAR brakes?
- wheel rotational mass vs. power(searched)
- WHICH HARNESS DO I USE
- Can someone give me the address to TrackMasters? I mis-placed it!
- Need help. Rebuilding Mugen MR-5 Rims.. Dunno if right place to post.. sorry if not..
- help with ecu?????????
- Injector Problem!
- valve ticking (adjusted 200miles ago)
- VAFC... What is VTEC Unmatch Fuel Correction ?
- wiring help
- motor problem
- d and b series speedo sensors the same???
- I have a 98 Lude that was supposed to have a very big build done to it. The shop that screwed me wi
- Swapping out D15B1 Checlist confirm
- ZC TPS
- Weak starter signal, car starts sometimes then it doesnt...
- will a B20 OEM headgasket fit on my 85 mm sleeved(AEBS) B18C1 block & B16A head ?
- Car doesn't start, need some insight..
- Racing Windsheild?
- T25 on a ZC running 20psi....?
- JDM b16a block, what are my head options?
- obd2 to 1 wtf with the coil??
- rear disk break conversion ?
- wiring vtec up
- please explain this to me...vaccum lines
- 89 CRX Si Clutch + Engine Rumming?
- has anyone ever heard of flashoptions.com?
- Measured resistance to flow on stock intake system of B20A5.
- Car wont start after Turbo Timer!!!!! ICM???
- EX header and cat on HX????
- how to mount engine harness and hide most the wires??
- ZC DOHC = D16a9??????help
- looking to get an exhaust resonator...input please
- Battery dies when car is not driven for a week? tried everything.
- how to tell if your starter has gone bad (aside from the obvious...)
- Idle problem
- Grounding Distribution Manifold?
- ECU Help - USDM B18C5 in an EK w/ a CTR ECU. Need help - - -
- 4 wire o2 wiring?
- what color is what ???
- Knock sensor connectors Where to find it?
- Making Engine Guide - post pics & codes
- IACV wiring
- Tach jumping at idle
- 4-2-1 or 4-1 exhaust manifold?
- can anyone give me obdII help/suggestions??
- Crank Question Easy
- timing
- Help, pulsating around 4 grand
- 99 si tranny grind @ high rpms
- NEED HELP ON INSTALL ...MUGEN CHIP IN P13 thanks...
- Relationship between emissions and lobe displacement angles?
- ARP rod bolt torques spec on LS motor
- ecu or tps ?
- ZEX nos/Throttle position sensor??? ?
- supercharger/turbocharger
- wiring obd2 distributor to obd2b harness? is it possible?
- comp valve springs
- slider or breaker bar?
- resonator & glasspack whats the difference
- Skunk2 obd1 manifold on obd2 si
- Look @ my Alignment Numbers Plz.
- Pumped up B, AFC, stock fuel pressure ?
- smallest crank that fits in a D16 or D15?
- Autometer ShiftLight Problems
- TEC II and B16
- JDM or USDM Pistons?
- Sr20 question
- can autos be fast
- best timing gun?
- Clutch master cylinders, how does this work?
- Starting Problems after DIY valve adjustment.
- help answer some civic head swapping questions.
- Is Honda factory brake line 3/16"(4.7mm)?
- Making own Exhaust ?
- using "coilover" springs from another application
- Heads up on Ingalls Style, Ingalls Type, and Ingalls Knock-off camber kits
- Engine Noise
- Weird Idle Help
- Identify this sensor?
- URGENT! Help me ID the tranny with the gear ratios I counted out.
- head bolts......
- Wiring up the 2.2, what is this?
- What does pin # C01 (PO2H) do?
- p30 ecu
- y8 timing belt and z6 timing belt
- 91 civic 1.3l problems- idling and water from exhaust?
- Spark Plugs for LS/VTEC
- Need some help with this reoccurring problem
- tranny swap
- epromer 6 ... grrr
- in your hands......
- Clay testing
- Running stock Civic Si Plugs Denso pk20pr-L13 ok in a b16b??
- engin took a crap
- Lsvtec conversion questions?
- d15b with d16a1 rods and pistons.
- Question: Crank Position Sensor.
- ecu break in
- Latency Time (MS) - ???
- DIY Carbon Fiber
- Electric Pump Question
- got issues with z6.........HELP!!! PLEEEEEAAASSEEE!
- Is Coolant Temp Sensor related to Vtec Engagement?
- b&m Command flo
- 2 way vs 1.5 way LSDs questions HELP
- PLEASE NEED HELP OR DIAGRAM HOW TO INSTALL MY MUGEN CHIP IN MY P 13 PRELUDE ECU ..THANKS
- Uberdata project under-way p28 y7
- Car pulls right.Please help
- will changing valve spring affect your valve seating?
- h22 vtec ???
- CR question with a twist....
- Is there a way to bypass the ICM?
- lan
- external oil pumps??
- compression test... cyl. 4 bad... HELP
- Torque spec for 3/8" ARP rod bolts?
- can anyone identify these rod bearings?
- taking head off....
- VTEC Enagement Problem
- Im lookin for a 96 ex wiring harnesss
- non honda problem, Gas smell but no leak.
- am i F*CKED? experienced experts only
- 00 Gsr brakes.?>
- race fuel question.?
- Possible fuel issues with JG Intake manifold and TB
- I need help finding the right half shaft!!
- Civic stays cool at idle, but oerheats while driving...
- O2 Sensor Problem (LONG)
- B20
- need help..h22a motor!
- AEM fuel rail + Edelbrock victor X = AEM fpr doesn't fit?
- Speedometer Adjusting?
- vss question
- Need some help...first upgrades??
- VAFC problems: Do my sensor checks look right?
- Motor Mount Inserts, Motor jumping around inside the engine bay.
- cams??
- suspension dilemma- please help
- Removing the EGR consequences
- should i buy a b18b1 ls motor/ tranny swap
- Overheating on a track (pics)
- About coilovers hardness settings
- fuel system problem
- removing the head
- reusing head bolts and head gasket surface questions
- maintenance sched. - mileage vs. months?
- B20Z Oil pump ??
- Doing a transmission swap for a D15B HELP!!!!!
- please identify these cams
- will a F22A1 throttle body fit onto a D16Z6 intake manifold?
- Braking Shake???
