View Full Version : Tech / Misc
- b16a1 in EF hatch wont run
- Honing Cylinders
- compression with 9:1 pistons in a GSR?
- Gs-R Clutch Problem
- Broke Block mount?
- b18c5 with b16a1 rods/pistons?
- 1988 Prelude Si
- What oil should I use for my YS1 transmission?
- building crvtec advices pls
- People that have Frankenstein motors
- calling all all-motor experts
- Honda CBR 600F4i head porters
- J1 Trannsmision Outline--Putting the tranny back together...
- Stock pistons that fit B18C1 to up C/R?
- Im Screwed
- Trans leak!
- Need help with turbo
- can this be vacuum leak...please help.
- ? ? Is a 45mm offset ok on 17s ? ?
- car on a jack stand no axles are connected, at idle the speedo is at 5-10mph and the intermideate sh
- car died while at light
- can I mate this head
- C.A.R.B intake info
- Feels like my transmission jerks when I disengage clutch at low speeds.
- B18C1+B16 head
- i'm new to this b20 motor build up
- need install help
- Price for Header
- how to build up me engine when i do a mini me swap?
- LS/Vtec in an eg
- B18A help
- wiring harness
- anyone seen DR. charles new set up?
- field sfc wiring
- Please help fluctuating idle, exhuast pop.
- Camber kit help...
- timing belt no keeping tension.
- b18c type r jdm help
- car seems sluggish
- code 17 for 1987 Accord LXi?
- difference between saturated and peak and hold injectors
- Car wont start-=-Not getting fuel
- Integra GSR to Accord V6 brake conversion.
- Transmission oil overfilled
- putting in a 97-98 modified itr ecu in a 99 gsr and a 2000 gsr
- Toda Killer...HS Special Cams
- too good to be true !!!!!
- My car squeels.
- JDM integra '96-'97 w/ B20Z???
- 5 speed conversion in a EG
- When to bleed brakes?
- Books that you can reccomend ...please read
- Timing belt a tooth off???
- AEM cam gear problems
- Civic DX fuel pump vs Integra
- B20VTEC - LS tranny
- Prelude injector specs
- compression test results
- Need Reviews of Nex Coilover suspensions
- b20 blocks....... lots of power or weak?
- Friend in Trouble, need some advice
- what size bolt? cat to the header?
- thrust washer
- Tein HA's the same for Prelude/Accord???
- EX brake conversion
- Is there a way to tell difference between JDM S-1 and USDM S-1 trans?
- honda (check engine light) code 23?
- P72 or P28 for B18C1??
- What causes pop -> dim?
- what type of headers can i use?
- whats needed to put 4.78 final drive in ctr tranny
- need help.. hit a divider
- Suspension woes
- Ummm...
- head gasket
- gas milage sux
- Short shifter
- $115.00 for an sohc vtec head, good price or not?
- LS rods in a D16 turbo?
- ITR clutch and flywheel??
- ARE Nippon Thermostats of Good Quality?
- Hmmm~.... Check this out and LMK what you think.
- Fuel system HELP!! From someone who knows
- Engine sometimes won't start
- Tranny Side Mount's bolt
- mini me swap! sohc vtec head and ?
- carnk position sensor???????????
- GReddy b-pipe size?
- Catback for an 97 civic
- Gas Gauge
- Header
- need to know ASAP!!!!!!! will f22b1 engine fit in 93 accord lx?????????
- anybody have b16a1 and swap gsr cams?
- butterfly intake mani Q's
- Upgrading brakes question
- evap removal question
- Wiring help
- need modifing tips
- Sooty Spark Plugs
- Is my LCA bent
- Help!! ACL rod bearings, where to buy??!!
- Tranny Fluid Help on 87 Crx Si
- Gaz pressure on b16a2
- Help needed, regarding rust on cams
- Injectors...
- gsr cams fit b16a1
- putting in B16 pistons in my gsr. is honing necessary?
- problems w/idle after warmup -- 85 accord
- Question for skunk2 coilover owners.
- P28 and harness installation ?
- Advanced timing...Where can I get some info???
- ApexI Vtec controller question/vtec setting....please help
- Carb conversion
- Help! Turbocharging Automatics
- HELP! Cannot remove crank pulley bolt
- Online stereo stores
- Proper claying of the head techniques ,engauging vtec
- Anyone here know whats required to put a 'smaller/higher' 5th gear(LS or GSR) in a USDM or JDM ITR T
- Rev?
- Super APEXi AFC - newb question ;/
- Code 3 with vtec controller?!?!
- after ls swap, ls ecu wont prime fuel pump
- urgent! need pic of a obd2 to obd1 conversion harness
- apexi vafc /gsr
- help with model/chassis #'s
- portflow inners
- Fuel Filter Replacement
- any easier way to remove ball joint out of the knuckle ?
- adding 2 injectors
- New
- Is this a 10 second WS6-killing Civic HX?
- motor swap question on fitment
- Newbie Question AEM Tru-Power Pullies
- building new motor; suggestions very welcome
- skunk2 stage 2 cams
- intake/boost question
- RPM gauge accuracy
- Dyno of Stock R with bolt-ons (dynojet with wideband O2 sensor)
- diagram for Field Vtec Controller.
- tranny selections
- brake lights?
- Exhaust Manifold
- runnin into problems w car
- B16 S1 trany. problems please help
- how to compression test??
- Any Reputable North Central Florida Engine Rebuilders?
- Anyone running an ITR rear sway on a Civic Ex?
- abnormally high idle > HELP
- timming belt and water pump
- vtec hiss or hicups during engagament
- turbo problem need help fast!
- Help! Car ran hot and now idle is off
- Hondata intake manifold gasket
- What's the part# for the ARP b16a head studs?
- H22A7 JDM prelude motor in a 92-95 civic hatch EG
- No responce at all from my engine. HELP!!!
- Difference between B16a1 and B16a2 heads?
- stock suspension??
- Strut stiffness during 1/4?
- Brake BOostR 411
- 5 speed conversion in a 92 integra
- master cylinder question/swap concern??
- bumpstops on neuspeed race?
- How much to CTR pistons weigh?
- bump stops on neuspeed race?/
- stupid question..but can
- porting and polish!
- engine-to-tranny bolt size?
- How safe to downshift a B20-VTEC ..........
- clanking noise after H&R install
- Harley battery??
- Vtech controller question?
- titanium exhaust question
- replacing CV joints on a 90 prelude, eash or hard??
- anyone know if 94 ls alternator works w 90-93 ls
- B16a w/ B17a Crank?
- In need of some help
- Brakes n' Porportioning Valve (long)
- oil pan gasket
- Stripped nut...help
- Alternator Ques?
- idling and idling adjustment question
- plastigauge
- fuel consumption question
- RSR spring rates???
- help! wiring diagram, apex-i
- switching ECUs in a 97 delSol
- OBD2 CELs under boost
- anyone with pics of fastbrakes wilwood big break kit
- Running on 1/3 horse ?
- Fixed my brob..Car Starts..buttt..do hondas come with spare fuses?
- Ground Control adapters for Konis? removable?
- Help my poor little gsr:(
- skunk2 cam ? need answer asap!!!!
- rapid clicking of the main relay???
- Checking for Vacuum leaks:?
- re-pinning ECU
- IAC sensor
- Compression numbers on my turbo LS.
- Car Won't Start---
- Dont know if this is a problem or not???
- Best 2.5" collector header for high CR application...?
- taking out the pistons & crankshaft
- vtec is kickin in late.
- wheel studs??
- How Can I Visually Tell the Clutch is Bad???
- HELP: MSD SCI-L installation
- for those of you with coilovers
- Will '00 CRV B20Z stock injector fit '94 Integra LS B18B?
- exhaust leak. how can i tell if i got one?
- rebuild my B16 head OR . . .
- $$$$$$$$$$$$$$$$for engine swap$$$$$$$$$$$$$$$$$$$4
- Fuel Filter leaking
- Attn: People with skunk2 coilovers
- knife edging???
- power steering hose
- how do you use an engine stand?
- please confirm this stupid question
- My LS/VTEC is losing torque. HELP!!!!!
- shock installation...tokico illumina
- Is this a VTEC problem?
- gsr crank or the stock ls crank for ls vtec????
- S-03 Pole Position owners, optimal tire pressure??
- Is $380 for a set of HB Tockiko shocks/struts a good deal? Installed on a 99 civic.
- vtec prob need help bad
- I'm going to a Dyno, what should I expect?
- Hondata
- What is this thing?
- All gears having problems, happened suddenly?
- AEM EMS Group Buy
- h22 HYBRIDS out there...i need some advice
- Spring rate on Eibach prokit?
- spring rate conversion???
- Which TB to use?!
- Anything To Prepare for Spraying Nitrous? (NO2, not NOS!!!! =))
- idle problems narrowed down to TPS
- question about tps voltage...
- need help quick! Car won't start.. no crank..
- arp rod bolts question...
- How many 200 MPH hondas? details inside
- low oil pressure no vtec
- Belt replacement ...Urgent
- Crankshaft Hardening
- suspension help fast!!! please
- Calibrating Guages after indiglo install......HELP?!?
- Replacement for a FITV on a b16a1???
- ok, this is gona sound realy dumb but i need help with my plug wires
- oil pressure after new pump
- Idle Problem???
- fuel cells
