02 Sensor and Air/Fuel Gauge hookup GOT A?????
Old Nov 26, 2003 | 09:10 AM
riddickone's Avatar
Default 02 Sensor and Air/Fuel Gauge hookup GOT A?????
is it better to wire the air/fuel gauge to the ECU or o2 Sensor what will give the most accurate reading, thanks guys
Old Nov 26, 2003 | 09:16 AM
AzG35's Avatar
Default Re: 02 Sensor and Air/Fuel Gauge hookup GOT A????? (riddickone)
If you are using an Autometer or something similar for A/F it won't be accurate at all. It won't matter where you put the wire, the signal will be the same. If you want the most accurate reading, get a wideband.
Old Nov 26, 2003 | 09:19 AM
riddickone's Avatar
Default Re: 02 Sensor and Air/Fuel Gauge hookup GOT A????? (AzSi22)
Well if I cant afford a wideband , where should i wire it to. thanks
Old Nov 26, 2003 | 09:22 AM
VTECVillain's Avatar
Just wire it close to the ECU so you'll have less of a distance to route the wire.
Old Nov 26, 2003 | 09:32 AM
riddickone's Avatar
Default Re: 02 Sensor and Air/Fuel Gauge hookup GOT A????? (VTECVillain)
But any chance do you know what wire it is on where can I find ecu pinouts diagrams thanks
Old Nov 26, 2003 | 09:51 AM
AzG35's Avatar
Check out this PDF, you need adobe reader to see it. It has the O2 layout for Honda's and other vehicles.
http://www.apexi-usa.com/produ...r.pdf
Old Nov 26, 2003 | 10:24 AM
riddickone's Avatar
Thanks alot
krysted9354
Jan 24, 2009 06:23 PM
Crab Man
May 18, 2007 06:43 PM
vtecb20coupe
Oct 6, 2004 05:02 PM
gelok
Nov 12, 2003 02:12 PM
FOrSfEd
20
May 31, 2002 09:49 PM
