View Full Version : Tech / Misc
- front main seal pushing itself out.....4 seals.....
- Where do i check to see if im getting power to my distributor????
- OBX question
- noob question? Dont even know what to search...
- Bearing removal?
- Hondata .... chromed ecu ???
- Oil pan gasket?
- Where to buy wiring stuff.
- B20B and tranny possibilites HELP!
- JDM ITR 5 Lug 36->32mm Hub
- Dealer wont sell me parts from TSB... service bulletin
- Ecu for Ls-t application??????/
- I need somebody to helpme with my <p05,p06> ecu
- dizzys
- Engine is having breathing problems. Oil in PCV valve/hose and some blow by
- Measuring crankshaft endplay
- High pitched noise while driving or idle
- Cost of rolling road components? vs complete rolling road?
- Y21 Trans Problem.
- 93 civic dx (d15) hesitation....
- sitting engine question(s) please look ASAP
- a engine that is impossible to blow! no matter what!
- lsd tranny good or bad?
- Help with hondata shift limiter
- PLEASE HELP !! car idle after start up prblem
- need help with my b16 .no water goes into my motor.
- GSR tranny Problem. HELP ME PLEASE!
- Negative effects of stroking?
- whats the cubic inches of a b18 bored out to 2.0?
- High Idel..b16..idels just past 2300
- differences in h22a1 and h22a2
- engine came today, what to do B4 install?
- abs, vss and non workin vtec
- No top end! Whats goin on here?
- O2 shorting question
- an-r
- D16Z6 LOST MOTION ASSEMBLY QUESTION
- What cams do I have?
- CA-san jose-$ 30 to anyone that wants to replace my clutch cable.have parts. thanks
- 1992 honda prelude 2.3 si oxygen sensor wiring diagram
- breaking in clutch/flywheel
- how loose is TOO loose on main/rod bearings
- misfiring/bogging while driving? @ 6k
- B18C-R blew up...time for a rebuild..
- clutch help
- TPS
- Springs and retainers vs. Cams
- stupid question, but is an oil filter really necessary>?
- Can someone please explain the advantages of fitting billet aftermarket LCA's?
- [B]HELP[/B] d16y8 distributor obd2 rewire to obd1
- gsr tranny question
- Competition Clutch
- Broken timing belt, I need help setting timing on Skunk2 cam gears??!?!?
- b20vtec turbo setup, shed some ideas and suggestions this way.
- anyone heard of Competition Clutch?
- Another "Got Spark and Fuel, But Car Won't Start" Thread... With a Twist.
- V-Tec Head
- B series tranny question
- pleas healp!!!!
- O2 Sensor Woes...
- pistons pr4-p72
- OEM mufflers that = 2.2" or bigger ID?
- Differences between 94 and 98 Auto Integra transmissions
- Check engine light on, checked code, not sure what the code means!
- Help choose parts ...
- blown headgasket?
- adjuct the free length?
- Valve lash help on b16a head
- gsr a/f too rich?
- programmers
- Clutch gave out tonight, any ideas why?
- ECU?
- What exhaust the n1 or mega power?? lemme know
- i search it didnt help or i couldnt find
- question on buildin an egine
- b16/b18 toda sports injection kit
- B16a and GSR.. What parts are interchangable?
- D16Z6 block, Y8 crank - possible issues?
- obd0 conversion
- NRG quick release question
- Race header...worth the hassle????
- the IACV - it's job, how it works, what it does when you introduce other modifications...?
- Has this ever happened to anyone? please help
- horn on CTR steering wheel?!
- worst night!! please need help
- legend brake swap???
- Way to have a constant vacuum w/out engine in?
- help with pulley
- gsr tranny vs b16 tranny
- Dyno
- Catch can intall wrong harmfull?
- O2 sensor location on b18c1?
- poormans type r
- poormans type r question
- Gas Tank Overflow?
- Help me With Check Valves
- turbo tuning
- VSS question?
- Sporadic Tach, motors cutting out
- Rod question
- Newbie, EK,EG,CX,DX,EX,Si ?????
- bolt ons?
- ls head gasket replacement
- PLEASE help about the s2K coil plugs
- Need help finishing my B18C in EG swap
- Aftermarket Throttle Body from Holly!
- Need some help...
- fuel pump question
- any differnce between a p30 and itr head?
- Engine code from VAFC 2 (problem, help)
- chech eng light
- i have a dart block and want to use a baffled oil pan for rr/ ax.....
- Clutch Problems and Replacement Help
- brake lockup??
- Honda OEM AXLE question!!!!!!
- can't get into gear after new clutch replacement. help if you can. thanks
- Clutch pedal goes soft under wot?
- how do i hook up a map sensor for 89 crx si?
- Where to find cheap LSD
- heavy vibration while driving
- Darton Sleeves
- LC-1 terminator plug?
- a little guru help
- Help with misfiring
- B18B1 & OBD0 B16 Head???
- speedo sensor Q
- fuel pump not working !!
- Temp/thermo problems
- b18b doesnt want to idle
- What Does Stamp "V4D" On Tranny Mean???
- Axle question please help?>???? DID SEARCH
- Funky Dyno Graph, please take a look
- oil in dizzy cap?
- Tranny housing trouble
- help for dsm engine, dsm forum had no advice there, so thought I ask the wise ones
- diff question, d16 boxes
- help car boggin out at hight rpm
- Wikipedia Definition: CURB WEIGHT (includes gas)
- b18c head + b18b block
- snapped my first shaft! question?..
- No vtec, how do i test parts
- ITR TRANNY QUESTION!!! 4.785...HELP NEED TO KNOW!!!!!!!!!!!!HT HLEP ME OUT
- Is my ignition coil ok? - odd behavior
- IACV question?
- Is this a oem honda lsd?
- b18b torque specifications same as b18a.
- OBD Harness
- anyone have h22 in eg hatch??
- obd2 to obd1 conversion question and more
- H22 problem
- can i use a 96+ manual ex IAC VALVE For the TYpe R
- Ebay aluminum Radiator any good?
- OBD0-OBD1 Harness Build
- Difference between Sprung and UnSprung clutches?
- WTF is wrong with my motor? Paypal $10 to anyone who solves the problem!
- tranny snap ring
- 8000 differnt EXPERT opinions on what kind of head i have.
- Squeaking noise coming from motor. alt belt or timing belt??? HELP!!!!!!!!!
- what depth of scratches can be polished out of a crank?
- HELP!! H22 Reads Low Oil Pressure
- Miss or stumble on acceleration??
- what to do about the idle air control sensor on my h22
- How to tell if it its a spun bearing or valve lash
- clutch adjustment
- Japan Spec Civic type R crank pulley
- IAC Valve for b18cR which ones i can USE?
- electric cut-out
- h23 tranny on h22 with flywheel and boost?
- Ek interior panels??
- Starter Problem!! Starter wont engage flywheel!! Yes Ive searched too.
- y7 to y8 tranny question
- ITR pistons on GSR rods/crank fit,right??
- Looking for Chrome/Hondata tuners in San Diego
- how do u degree aftermarket cams?
- Local Tuner Needed
- would this hurt a motor
- AC Delco synchromesh = GM synchromesh?
- Removing/breakign threadlock on H22 oil pump casing?
- Engine Build...Which pistons??
- prelude injectors?????
- Anybody Identify this Flywheel
- Compression check #'s? K20Z1
- cannot separate engine from tranny TRIED EVERYTHING
- tranny making noise when in nuetral
- Header heat wrap
- Questions on wiring connector types?
- Does anybody know these cams
- Question on serial numbers?
- When to CRV ATF and Differential Fluid Change?
- compression check....manually?
- Pic Request: Good Synchro vs. Bad Synchro
- would closing the gap on spark plugs help with unburnt fuel?
- p28 with B18...efficient?
- which cars have vtec?
- Is this head an anchor?
- torque specs for my ebay stage1 clutch and plate w/ oem flywheel ?
- DA torque specs for clutch replacement same as EF clutch torque specs ?
- need rom chip p28
- K-series oil fliter on B-series engine = more oil pressure???
- Coolant and emissions lines PLEASE LOOK
- tell me whats wrong with my vtec......
- JDM Prelude Headlight Wiring
- ???y1 tranny help????
- i think i mixed up my main caps
- DSM injectors, 450/390/350? How can you tell?
- what rods to use
- Head Gasket Size
- RC Injectors
- prelude overheating and has trouble starting
- Correct me if I'm wrong.....
- Oil Pressure Issue...HELP A MAN OUT
- tuning shop in orange county
- Do you think you know how the O2 sensor would react if...?
- NEED HELP QUICK
- Cant get into 4th at all help
- a little help please.
- head gasket?
- Fuse Box Help - Honda Electrical Guys In Here Please (pics)
- d16z6 OEM bearings from Majestic
- clutch cable question.
- hard to shift into gears - opinions/help welcomed
- B18c1 bottom with Ls Crank
- what tranny fluid should i use?
- tranny shifter stuck, then fine again?
- DIY $5 - Fiberglass muffler, will this work?
- Skunk pro stg1 cams
- LS/Vtec calibrations? for s300?
- Larger bore size...
- flywheel bolt!!!
- help on piston install
- greddy emanage ?'s
- tranny whining very loud on decel at high speeds
- having tranny or clutch problems? someone help
- Tranny rebuild, need part
- S2000 Cluster Orange to Blue - Colour Change
- Rebuilt motor... white smoke from engine bay, not from exhaust?
- taller (longer) Final Drive options?
- Urgent LSVTEC Dowel Pin Problem...
- 1/2" Head studs, what dowels to use?
- feels like clutch isnt catching...
- help me pass smog
- NRG Damper ::->Thoughts<-::
- b16a2/b18c1
- What thread sealant do I use for oil lines?
- pic request.... rhd clutch master cylinder/clutch pedal assembly
- camplate bolt wont come out. stripped bolt? help!
- Will Arais SPIRAL clips work in SRP pistons?
- 92 stock Civic VX tranny question-bearings
- replacing rings/ do i need to get new pistons?
- does this really work???
