View Full Version : Tech / Misc
- my e brake doesn't hold
- Driving without my knock sensor wierd ????????
- decisions..............
- Sparco Recaro question
- Can someone tell me where the KNOCK SENSOR on a jdm b18c1 is located ?
- 93 vs 91 octane: how much difference on the dyno?
- Whats with this octane stuff???
- GSR Diff in LS Case?? It wont fit, correct?????
- Need help wiring summit racing air fuel gauge
- Skunk2 D Series Intake Manifold Sellers and Owners,I need this measurement.....
- Where should o2 sensor go on obd1 ecu car?
- Engine dampers????????
- help with springs
- When did vin tags start coming with trannies?
- *****4-wire o2, how do I wire it?******
- What holds your idle at neutral?
- Where to get these magical radiator hoses?
- idle surge???
- OT: How do you install shocks in a ranger
- Water pump?
- B18B INFO
- Replacing my K20A3 (Si) w/ a K24 (CR-V)...
- ITR sway bar application
- b16 and d16 rod bearings the same?
- HONDA PASSPORT CV AXLE
- I got two IACV and they need ID's I think they are both odb1 but I could be wrong
- Squeeky Sound
- ALMOST lost it on the freeway earlier!!!!
- where to get TWM individual throttle bodies or similar items??
- Installing head
- battery problems...
- Replaced ignition rotor, now problems
- Car smokes at 6.5K rpm and higher. Help.
- distributor differnces?
- Crv Trailing Arms?
- Steering wheel is jerking left and right especially at low speeds???
- Clutch ware
- How to use a V-AFC?
- Fuel Injector Help
- anyone done this with a B18c1 swap???
- stuck between a rock and a hard place...
- Quick Radiator question...
- Greddy AF gauge showing lean
- Vtec spool solenoid code in gsr'd eg
- ============>USDM b16a2 EG h/b owners<=============
- d series timing belt
- Problems with car
- header clearance issue
- tach help
- acura vigor, fwd or rwd???
- Electronic Load Detector
- Upgrade fuel pump power wire
- stock fuel pressure in D16Z6
- Check out my Blown up Diff!!!!
- Recaro seat rails
- B engine series
- valve train noise
- 95 gsr throwing codes 21 and 48?? please help me
- Air temp sensor on a B18c motor swap?
- i have this stupid question about Intercoolers...
- pipe/tube beader tool - need one, can't find one
- Clearance for CTR Cams
- Need help B18C JDM Type R in 00 Si
- Using Alarm as a means of a Turbo Timer
- cv boot clamps....aka "oetiker" clamps. where to find?
- Cam timing questions
- Stroker kits
- Did I fill my radiator right?
- can some1 ID this PART for me?
- RPM wire on 6th gen accord
- SRR cam gears?
- need opinon's?
- knocking noise?
- HP vs Torque?
- no more hyper blinker please!!!!
- Twin loop type muffler(mugen style)
- Do used Cams need any kind of break in?
- AC help
- DIY Request: Knock sensor install
- HELP!!! brake problem!
- excessive engine vibration from AC?
- How would you replace a TDC censor?
- what are symptoms of bad motor mounts?
- ZC Help please.
- Cold air helps high compression?
- camshaft installation
- wanting to make 4th gen accord faster
- Anyone know of a place that will CNC Machine parts?
- Will a B16 oil pan fit on a B18 motor?
- Please Help! D series probs (noise/valve/timing)
- NeEd Help??
- What are some signs of a timing belt jumping a tooth or bad water pump?
- Clutch problem
- vtec wiring
- how hard is obd0 to obd1
- CODE 75 ON MY HONDA CIVIC WITH 1.8 INTGRA LS ..FLOODING AND BLACK SMOKE
- putting in a new ecu chip(help)
- DC Sports header for B16A1 question
- distributer problem...HELP PLEASE
- Temp gauge doesnt work after swap
- itr engine in gsr
- golden eagle cam gear torque?
- Oil pressure fluctuation
- Has anyone converted 98 harness to 95 harness ecu plugs only
- engine hp, wheel hp, etc..
- which is better?
- Crank Pulley question?
- dx auto to zc manual...... help!
- wtf is this thing on my B18A?
- Skunk2 D-series intake manifold pics...
- So I broke a chunk of the IM off today.... what can I fix it with?
- Blowing....FI E/M fuse...
- I be Stroking, That's what I be Doin
- obdII distributor on a obdI engine?
- What is the best Lube/grease for new bushings for suspension components?
- $%*&@! stupid clutch year changes
- eprom burning ecu chipping
- Clutch questions(did some search.....)
- ecu question
- 185-60-14 Pirelli P7000 Questions/Comments
- are these symptoms related??
- Engine Swap Regulations
- Got a Wideband, so how do I tune?
- D series injectors will not get enough "power" on a B series swap?
- Need a new ecu what would you do?
- Smog info
- DA6 Integra Help. Car revs to rev limiter by itself when started.
- Acura / Honda replacement battery
- Which would you choose(not a newb topic)?
- H22 spun Bearing rebuild or replace
- Adjusting 90 CRX drums
- Swapping out Skunk2 Stage II Cams for Stage I's
- How to check Tranny when it's out of car (without tearing it a part)?
- how do you install a skunk2 lower tie bar??
- headgasket problem
- D16ZC = What Years?
- this ain't tech but...................
- JDM H22 Distributor Direct Replacement
- MORE BRAKE PROBLEM
- Water Temp gauge only comes up 1/4 of the way. Why?
- My solution to the IAT sensor ( Check it out )
- what's a cel 68?
- gas pedal won't go down all the way
- need confirmation: shift linkage
- fuel rail w/injectors removed and the car runs!
- is performing a valve adjustment worthwhile to learn?
- A'PEXi S-AFC wiring
- Which MTF to use w/ my Quaiffe LSD?
- help on o2 sensor wiring
- Ordered a new distrib. and have some questions
- car wont pull...
- 94-01 teggy springs = 92-95 civic springs????
- My car is really hesitant (90 DX HATCH)
- Air/Fuel Question?
- Engine Code?
- changing ecu chip from chipped p28 need help please ? what tool i need ?
- upper cylinder cleanear
- LS/VTEC ppl, maybe you can help.
- zc dohc mains
- torque mount problem(help)
- in need of a few torque specs
- will B16A A/C bracket fit a B20B block?
- engine weights
- Cable tranny case the same as Hydro??
- ctr vs pr3
- Oil Coolers...anyone using them?
- ecu damaged? or, ?
- Strange Tach Problems...
- y1 tranny grind
- best way to clean valve cover?
- Lugnuts question
- Need TRQ specs for headbolts for 93 Civic if ya got em handy....
- Radiator fan not activating
- OS CTR piston/cylinder bore...
- 75K MILE SERVICE. What to do..
- Is there a difference between B18A 91 and B18B 95 on the bottom end of the engine
- ECU Programs?
- caliper slide pins removal help
- Crank pulley bolt removal w/o impact gun?
- Car history
- JDM ITR steering wheel?
- Will 270cc injectors suffice with my setup?
- brake fluid/ebrake light
- Question for those running Skunk2 Stage 2 Cams on a B16
- code p0133
- Specs for Spoon 4-2-1 header (2 piece, older version) ?
- Fuel System Vacum
- Cam Gear Settings for CTR Cams...
- alignment homemade rack
- When removing axles, do I NEED to drain tranny fluid?
- Symptoms of blown hub bearings?
- axles for lsd?
- I still have a code 6 after replacing the ECT sensor WTF!?!?!?
- Car Won't Start....
- I need NEW axles
- Problem installing stock suspension
- Will An Older Motor Pass Emissions in my 97?
- Cruise control not working
- How hard is it to fix a jumped tooth on a GSR? And someother questions. PLEASE HELP!!!
- Factory water oil cooler from b16/18c blocks made to work with b18b blocks? HELP PLEASE!
- has anybody used ebay "spoon" or "mugen" ecu chips?
- How do I wire my OBD2 plug to a OBD1 distributor?~SEARCHED
- OBD1 motor in a OBD2 car which O2 sensor plug?
- Hole on oil pan=blown engine?
- ENDLESS MONEY PIT? whats wrong with your DAILY DRIVER?
- are you looking for a how to?
- How to do i get more torque?
- Turbo Si dyno numbers?
- fump pump/fuel regulator problem
- problem with rpm's not going higher then 3500
- Problems with stumbling and hesitation
- Timing question
- Help please: clutch pedal unusually hard
- Still have a bucking/hesitation problem at startup, cant trace it
- Aftermarket radiator fan flow direction?
- what are the key differences in the usdm and jdm itr intake manifold
- FS GSR CYLINDER HEAD
- Problem with setting ignition timing on LS/VTEC and MSD
- suspension problem
- checking engine codes on a obd1, hondata, crx
- Motor rebuild, balancing question.
- Progress Full Coilover kit
- headgasket quickie
- clicking noise when braking
- should i change over to synthetic oil?
- ZC head bolt/stud question?...
- b16 or gsr cams?
- major tune up
- My honda-tech write up on the " Front mount intake " and the flame most have to offer
- bolt stuck in head
- BOLT STUCK IN B16 HEAD
- Help on B18B build up?
- Stock pistons reusable after being pressed off rods?
- purge unit HELP
- code 10 help please...
- alternator fuse
- How much HP / boost can stock bolts handle??
- How did you make your city light holes on your 96-98 headlamps?
- 4 wire o2, grey, white, white, and black
- Welding Stainless
- A-T-S clutch type LSD: possible to remove discs and make less agressive?
- help: heater box removal...
- Just somthin to look at....
- Coolant temp sensor issues????????
- cam plug install
- Will LS ARP head bolts work on a GSR?
- HELP
- who would win pls answer
- is this normal? (kyb-agx shock related)
- How much HP are stock LS injectors good for?
