View Full Version : Tech / Misc
- ARP head studs on b18b
- 97 civic si canadian cluster problem
- automatic tranny question
- need help
- confusing engine noise
- EVAP and IAT
- How many amps of power does the fuel pump pull?
- distributor advance
- obd1 codes for converted ef
- Drag Racing Suspension Tuning question???
- Need advice about Spool , 1st long gear??
- The White Crow
- very high idle help
- water4gas - huh?
- need help with k20 motor timing
- question about a block
- where to but Honda plug pins
- what size??
- I need a 12" x 12" AC condenser
- Intake
- What motors are reverse rotation
- What is this sensor?
- gsr problem
- jasma b16a header bolt size
- 2008 Accord 2.4-liter engine hp
- Which PS Bracket for b16 head on ls block in an EG?
- d15b and a 1998 honda hatchback.
- Engine help and stuff for a noob
- fuel or ignition problem?? 92 civic w/ls motor HELP!
- Wanna know about LSDs? Here are some FAQ's with answers!
- 2002 Si cel comes on when low fuel
- eliminating ef fuel resistor box
- Loud Knock/Tapping noise under load
- da 90-93 integra axle problems????????????axel seems to short and is binding up?????
- Engine overhaul's
- Help with new ride!
- Need Mechanic around Mt.Holly, NC Area
- YS1 (B16A) Transmission Specs
- Tech question on body kits
- VIDEO: MFactory 4.9 FD in B16A2 EH3 Civic
- DC integra knuckles on a EK chassis... will it work?
- B16a2 Swap/ Wiring Problem?
- Temporary heater bypass?
- Circuit Worx drivetrain issue...
- front shake
- JDM vs USDM ECU - wiring problems
- Tranny problems. Any suggestions on what you think it is?
- hard brake lines rusted out..
- valve keepers same?
- obd1 integra ls and civic o2 sensors
- Can you use an ABS hub/bearing assembly on a NON-ABS car?
- skunk2 intake manifold evap ?
- 92 si speed sensor question
- B16 tranny case with GSR guts?
- No power to Main Relay..PLEASE HELP!
- Wave Trac Differential- Do you have one?
- Injector question
- loose cam gear bolts = valve contact?
- ive tried searching...What exactly is an LSD?
- What LSD is this?
- URGENT HELP coolant leaking under dashboard
- What injectors are these?
- h22a4 transmission swap to h23 tranmission
- Need wiring help!(have pics)
- steering wheel vibration
- Total Rebuild Tools
- H22A4 droped thrust washer!!! Rebuild, or G22 hybridize it?(H22 head+F22 block)
- how to mesure the "hardness" of the cam lobes?
- 05' Hybrid throws a rod?!? Any help is appreciated.
- Transmission guts interchangeability Hydro gsr in cable LS case
- Quaife LSD...
- weird power lost problem...
- Need help on valve springs
- Wiring OBDII port after swaping to OBDII?
- vtec problem
- 92 honda 1.5
- Please help, electrical problems
- overheating prob!!!
- swapping differential h-series vs b-series?????
- What sensors can I eliminate and still run with no check engine light?
- CRX Fuel Rail and FPR options... what is available
- p75 head on b16a2 ?
- h22 into dc chassis. need HELP!!!
- Shift Linkage Probloms?
- idle question!!!!!????????
- Car sputtering please help!
- AEM UEGO oxygen sensor interchangibility?
- B16 Transmission hard to shift.
- How to clean WIDEBAND Sensor???
- Crank Bolt Pulley Tool
- huge oil leak, gasket question...
- changing gear sets
- cam keeper threads
- Throwing many codes at different times first 15, then 13 and 5, then 15 again, and now 1. 91 dx ZC d
- Power grounds with deleted main relay (PG1 PG2)?
- LS/VTEC wont start randomly.
- vehicle speed sensor
- ls vtec oxygen sensor question
- Transmission shifts BUT NO GO.
- when u swap from obd2 to obd1 can you check for codes?
- Removable baffle inside V/C
- quick question
- help out wit gsr
- Will ELD CEL occur when using no alternator?
- chrome engine parts
- Defective O2 sensor, safe for motor on track?
- CEL code 8 quick blinks. I already searched, can't find it.
- Spoon N1 exhaust
- what to do first break in or tune
- Are timing and TDC marks on a b18c1 crankpulley the same as a b18a?
- Warning: Bad Gas EVERYWHERE
- Header and Exhaust Temperature questions.
- machine shop estimate.
- skunk2 TB problem
- Spark plug Leads
- heim joint boot
- Metal "Ringing" Normal after Short Shifter Install?
- Clutch question
- CEL 14 and 7
- HELP! im using an ecu from an automatic in a manuel?
- bad idea????
- resurfacing a light weight flywheel?
- Bolt for attaching the chain when pulling a D or B series engine
- dpfi sohc vtec?
- Need help ASAP.. built b18c1 with b16a head and crank pulley, doing valve clearance
- car sounds like a monster truck!! need help
- Help a Newb! B16 cable box LSD to fit in B18 hydraulic box
- Where'd you buy your feeler gauge?
- STOP LEAK WORKS
- no power to main relay
- What to do with my camshaft and cam gear? Help!
- finding a short
- 94 accord vtec missing
- How do you remove spark plug tube
- ///Need a transmission wizard here!!///
- Hydrogen Mod
- K20A2+Civic Si 5spd???
- Has anyone done any D-series header tests for MPG?
- Double checking valve stem seal install
- Have one bad injector. Should I buy 4 new ones? (k20a2)
- How stiff are new linkage bushings supposed to be?
- Transmission swapping?
- Highest Lift Cam D16z6
- ecu help *pics
- stage 3 clutch EG
- B16A1 NO CRANK, NO START after storing!! PLZ HELP
- starting question please help
- Wanted a gsr now i got a ls tranny what should i do??
- I NEED HELP CHOSING PISTONS & RODS 4 GRS ALL MOTOR !
- why won't auto trans shift out of 2nd?????
- B17 Crank and VTEC Indicator
- Crank pulleys
- how many of you run your tq mounts with aftermarket race mounts?
- How to do a transmission swap DIY?
- Leaking from passenger axle output on d-series trans..
- f20b + nitrous
- Vibration when downshifting
- oil catch can idea help
- Piston-Wall clearance to large?
- skunk2 stage 2 cams
- 4wd to 2wd
- manual transmission
- ECU doesn't have cel light or scan bar
- Power locks not working
- Will this compressor power an air gun well enough to remove crank pulley bolt?
- need help figuring out if i have a type r tranny of jdm gsr
- Which Radiator? ( URGENT )
- moan/grind under load during launch
- h2b problems
- harness...need help..
- Is this map too lean?
- b series oil feed
- haveing over heating problem with sleeved gsr block
- Has anyone ran into this problem?
- How much is my rebuilt b18a worth?
- Short Shifter, Pros & Cons ?
- Possible Differential/ Axle problem. Help Diagnose.
- Dynamometer
- JDM B18C...spun #3 rod bearing...need opinions on my options...
- help!! will ef springs fit on a eg? anyone?
- b16 dropped valve need help.
- b16 wont start after wire tuck. ugh.
- Will Precision Injector clips fit RC injectors?
- accord Throttle Body + K20A2 engine???
- B-Series, Cracked Fuel Injector Tip...
- h22 help
- d16y8 coil in a gsr dizzy
- h23 random missfire ideas
- help with stock motor in DA, bog problem
- b18c1 a/c
- how much are these wheel worth
- please someone explain why my car has no go balls
- code 23 and 4 need help...
- b16a oil pan plug size.
- Losing Prime in fuel system
- Wiseco head gaskets?
- Main relay not powering on, relay is good...
- quick question about k20 valve locks
- OBD0-OBD1 question
- Alternators interchangeable?
- Main studs
- poor mans type r tuning
- 98 h2b teg, no start!!!!
- Driving with an almost worn thrust bearing: Can it do any harm?
- Tranny Guru's - Question
- AM I RIGHT OR WRONG?!?!?!?!
- need suggestions about a catalytic converter!
- bearing cap bridge on b20???
- Effects of a poor ground engine ground ?
- how to get a hold of "chase" from (chasebays) besides IM
- K Sereis Cam Dowel/Pin Help!!!
- k20a2 runs rich in cylinder #4
- Attarco motors????
- brake issues. newly built car. need some good minds to help me out plz
- how to lighten fan load. read...
- If you were to give current to an alternator, would it spin?
- I need info on OEM car covers for honda's/Acura's
- B18c w/ ctr pistons... will it pass smog?
- Why are starters so weak?
- Ahhh missing bushings for B&M shifter
- HELP!!! '94 civic, crome, won't rev, VSS code, idles great.
- Torque Wrench Recommendation
- Integra Parking Light/ Turn Signal Wiring harness question. Reply quick..
- blown rings wondering if there is anything to buy some time
- few wiring and sensor questions...
- How to read check engine codes?
- B16 Tranny
- What modifications can you do to your car to improve performance, and not hurt fuel economy?
- JDMB18c1 Idle
- PLEASE HELP- Check engine light/obd port problems!!
- Help Me Solve My Tranny Problem. PLEASE!
- b series mainshaft interchangability
- Y1 Transmission, Where to get Replacement Parts?
- B-series or D-series P/S Pump
- are all b-series piston rings the same?
- this is a stupid question
- replaced head gasket now car wont start
- Help!!! My car is misfiring 3 cylinders....
- Auto Meter Auto Gage 5" Tach Help
- question of relocating battery..
- Need Help VAFC 2 stock settings for 2000 SI
- Engine building tool recommendations...
- Will Miracle X bar with optiona barsl for EG6 work on a DC2?
- power steering
- What's the deal with VTEC killer cams?
- skunk2 cams problem
- How To: Convert to Distributor-less Ignition (requires standalone)
- parts for new civic si
- 97 Prelude Won't rev past 3500 rpm...acting like a rev limiter
- LEAKS
