View Full Version : Tech / Misc
- better for a turbo?
- 1990 civic/crx si jdm DOHC ZC engine swap
- throttle body coolant bypass
- 1998 Civic EX Poor Gas Mileage
- Which throttle body?
- Simple SRS Switch
- Intermediate shaft question???
- First turbo build-Need Suggestions/opinions
- 1990 Civic Hatchback Parasitic Draw
- Turbo LS RPM breaking up
- Idle Air Control Valve / supposed to have constant signal??
- CEL code 10 (IAT) How do I wire direct?
- Please help identify this skunk2 exhaust
- IACV problem / questions 2001 GSR b18c1
- ID these bolt sizes/What am I missing?
- engine light... vtec related. HELP
- Wiring harness differences?
- b16/b20 build
- 2007 3.5 honda in dune buggy
- Is there a fitting to convert a stock fuel rail?
- b series M factory stage 2 axle with hubs
- Honda Regular Oil on Track
- Need help identifying this part
- Is this a Omnipower Throttle Body??
- Hasport Engine mount Problem
- vibration when accelerating
- Just picked up a 95 ls/vtec with Clutch or Differential issues
- PLM-A01s are back (July 2012)
- map sensor signal wire
- 97 civic car wants to idle high and hits like a rev limit?
- ANYBODY INSTALL DARTON MID SLEEVES??
- 03 Accord Ex. AC barely works, and only passenger side
- Replugged spark plug lead and now car struggles to start
- OBD2 D15B into 99 ex. Cant find answers anywhere!!
- need help and advice...
- Low oil pressure at idle in a k20a2 engine
- Stolen : Nissan 300ZX TT.
- Mysterious oil leak
- are the sensors located in the same area on 90 b16s and 98?
- 2001 GSR Bran new SpArK PLUGS, Covered in Oil.. Causes?? Remedies?
- pedal sets?
- Where can i get a yonaka muffler
- Anyone used Carboagez.com for service manuals?
- anyone built a 5 speed shift plate?
- Looking to be mechanic's apprentice (Orlando, FL)
- climate control wiring
- Honda EDIX Crusie control
- Using Gsr head Built for LSVtec on GSR Block
- 2001 GSR What SPARK plugs am I supposed to USE????!!!!!
- Decreasing Exhaust pipe diameter - How bad is it?
- Anyone possibly know about my motor? K20a
- OBD1 ECU to OBD2 Alternator
- Need wiring help in San Fernando valley
- Having problems with my 95 civic coupe
- Toolset
- draining oil and checking it
- GSR Idle problems!
- Integra ABS modulator failure?
- Map sensor wiring? wiring help.
- b18c overheating, already searched a lot
- Wiring trouble
- engine swap
- o2 sensor
- help can this gsr throttle body fit ls?
- Won't start - fuel pump primes - check engine doesn't light up
- Read my spark plug...
- Catalytic converter issue/questions
- synchronize fuel gauge after cluster swap?
- ef mini me overheating
- Where to buy h22a1 main caps
- temp gauge is reading way higher then it should be
- Car won't start and seems to have a ghost in the system
- can someone help me please
- so i got a b20b swap and looking for parts for it
- Seat rail ridiculousness...
- swapping engine vin plates
- Combustion Contraption : contact info
- Can N1 mufflers go bad?
- Narrowband O2 sensor outputs
- A/C still not blowing cold...
- Will this work? D series radiator-a/c with B18c swap..
- Consequences of running 15w-40 in a stock Civic [D16Y7]...
- rack question?
- Haven't been on in a while.
- Timing Belt Tension (w/ Video) after cam gear install
- what the hell is a zc motor?
- WHAT WHEEL IS THIS????
- civic idle problem
- 5% off For Honda Tech Members Only!
- Front end squeaking noise honda accord 95 ex ???
- a quick question on a type of relay/selonoid
- BEST TQ & MPG swap for 95 cx? HELP!!
- How to ID my Civic motor type
- Need Pro Advice. Want High Torque for dd EG, what engine. obd2+ w/s300 will be used.
- What tires are best for 16.5 gsr blades?
- Fuel tank lining and long term storage?
- afr reading lower after adding velocity stack
- 98gsr dizzy?
- 97 civic lx info
- battery light on at high rpm
- Hseries vs bseries valvetrain - differences and similarities?
- normal?running hot?
- stanced craze?
- help me identify this ticking noise
- PEAK motor oil?
- 3in vibrant bellmouth velocity stack is 2 3/4 instead
- LC-1 wideband in s300
- AEM CAM GEAR INSTALL D16Y8
- cut off mileage for used honda??
- d16 overheating
- ac wont kick on after converting to obd1
- A/C problem with my TSX
- 98 integra wierd auto tranny problems
- Measurement of tilt on Z6?
- iacv keeps going bad!!!!! (HELP).......
- Brake lights not working???
- b series trans concave/conical washer
- comptech exhaust
- hybrid diesel
- fuel cut and vtec doent engage
- 99 Civic Ex, Strange AC problem, Works only at Idle
- d16a6 + PM3 pistons, need some advice
- 60+ mph vibration.
- Recovering dead cell in lead acid battery
- EGR Cleaning / Replacement Port Plugs ??
- b16a2 intake manifold IAT rigging question?
- harness re wire
- Weird Coolant problem
- Ignition Spark Testers / Checkers (BikeMaster, Lisle, or Tool Aid) for checking coil?
- spark plugs
- Walboro fuel pump noise
- 92 EG6 RHD Window Wiper Help (pics inside)
- Grinding when clutch let out from a stop?
- glossy vinyl where to get it and what brand?
- Automatic integra with crazy electrical issues
- 98 Gsr Died
- removing h22a1 head from block
- Skunk2 D-series Pro Series Cam gears for d16y8
- built vs bought
- H series header I think?
- car stalls when warm
- Weird problem without CEL, y7/y8 minime
- Is it possible to press splined part of eg steering wheel hub into rsx wheel?
- Built shortblock sitting for a while...good to go?
- timing off a tooth?
- GSR into EK Breakdown. Wiring/Mounts
- just by looking at the stock civic injectors how can i tell which is high or low imp?
- How to stop that leaking oil pan gasket once and for all.
- 97 civc lx b18b1 swap what do i need
- fake p-73 intake manifold?
- Need torque specs for a '97 Passport: valve covers & upper intake
- 2 part question on cruise control
- 1992 Prelude Automatic Turbo
- Honda n00b with k23a1 questions
- what goes here? 2000 CX ctr side mirror content
- code 21 on when vtec should hit then goes away
- Transmission replaced but still grinding
- valve springs is there a top and a bottom
- How do I remove CTR pistons from GSR Rods
- Engine rotation
- automatic harness to manual
- How to have instrument cluster on with no exterior lights lit?
- What relays control the fuel pump on a 90 integra?
- Z6 tapping in head?? help again.....
- removing abs
- 94 hatch turbo gsr no start
- Wiring the condenser fan and radiator fan together
- Valve stem seals
- z6 vtec CEL code 22 HELP!!!!!!
- Rsx lack of power help !!!
- Major transmission issues or ?
- What front door handles from an '96 or '97 Civic fit Integra
- Decode ODB1 ECU Serial
- Help with z6 bottom y8 top swap
- Wiring
- P06, P28 injector test circuit
- Magnetize any socket/wrench $4
- injector o-ring for twm
- Oil coming from exhaust manifold bolts?
- Let's talk about bseries retainers - tool steel?
- B series bellhousing in d series tranny
- D15Z1 - Too Rich Poor Mileage
- powerband and intake length/diameter articles
- 1988 Accord DX Automatic Start Circuit help needed
- B18/20 sleeve length
- i need help figuring out why my running lights dont work!please help its my daily!
- Oil Cooler help
- PLEASE HELP ID CAMS
- Need Help With Shopping List: B16B into 99' DX HATCH
- Passenger side higher than driver side?
- front end coversion
- ?? on making your own radiator mounts
- Wire tucking question
- Diagnosing Idle and RPM issue
- Motor breaking up after 7000 rpm
- b18a1 swap help
- Help - 2000 Honda Civic Ex Sedan - Odometer Stopped + CEL Code 41 (Primary 02S)
- time sert gsr?
- h22 all motor, nos, or forced induction
- OBD2 alternator upgrade questions
- Which Valve Keepers to use???
- What can i use this ecu for (aem ems 30-1010)
- crx w/ b16a swap troubles
- What to do with other o2 sensor?
- h23 swap
- clutch problem
- cel 9 would it throw the timing off?
- B20vtec. piston/wall oil lubrication with aftermarket rods.
- Is AEM and same as K&N?
- 93 civic si wont go into gear
- alarm going off
- rod movement
- any way to clean the valves?
- Eg6 type r hatch exhaust
- Oil pump stamping
- Motor identification
- Motor won't go past 45-50 psi of oil
- EK civic wont start checked averything NEED HELP
- RPM doesn't read
- Magnetic oil drain plugs
- need help on my swap
- 1998 accord lx p0108 code map senor
- Weird misfire/ Jerking No CEL
- Wiring for an Antenna
- What can I do to beef up my 01 GSR Tranny?
- fuel pump questions
- PLM Narrow Rep: Real or Fake?
- T1R: catalytic converter
- Tools
- cylinder dent. fixable or big problem??
- t1 cam trigger kit
- type r turbo help
- CEL problem
- Knocking and Vibration. Need HELP!
- what throttle cable do i need? gsr to 92dx hatch
- 95 civic D16z6
- arp head stud question
- sound deadening and exhaust
- solid rod ends.
- *PIC* Mevotech upper balljoint came unlubed, how to you lube it properly?
- need measurement for project
- interior lighting help?
- k24 identification
- 97 Civic cx Ticking/knocking (video inside)
- Noob question: How do pistons make compression?
- Viper 350hv Alarm
- 93 honda civic pwr windows
- Universal Val Spring Compressor
- ls/vtec cooling problems plz help
- fan switch connector
