View Full Version : Tech / Misc
- Any shops out there
- wiring help
- steering wheel shake at idle with soid mounts
- Car won't car because of immobilizer
- Bearing sizes
- Lean Idle and Stumbling
- EK awd rear trailinig arms
- Car expense template for Excel
- LS bottom end - main cap diameter?? impossible oil clearance!!
- B16a2 timing belt sprocket question
- Question about Greddy sandwich plate m12 port?
- In desparate need of carb gasket repair kit for Honda Civic - December 1987
- electrical malfunction?
- Civic Starts then Stalls
- hondabond ultra flange 2 question-urgent
- 1996 civic ek fuel gauge weird problem
- Assistance Required: OBD1 CEL 21,41,&16 - HELP...
- RPM UP AND DOWN AT IDLE PLEASE HELP
- passenger side axle keeps popping out
- b18c how to remove timing belt cover
- Honda-specific degree wheels?
- exhaust ek sedan
- Engine stumbles at low rpms (2k-2.5k)
- Under-hood fuse box diagram for 2003 Honda Accord LX
- DA to DC compatibility
- 2005 Accord interior fuses ( locations 5&6) keep popping after power applied.
- immobilizer reprogramming
- Post 2 of 2
- seatbelts
- power door issue
- Broken VTec pressure switch
- Heater problem
- Timing belt tension, z6 need some help
- vtec control solenoid code on non vtec engine
- Scratching/rattling sound at 3K+ rpm (vid)
- b20 swap wont crank by key
- 2001 prelude head gasket
- Surging idle. I'm stumped
- Low idle when car warms up
- Bad 3 bar map sensor?
- can a wrong ECU cause limp mode?
- dead cylinder HELP!!!!
- MR 552424 UC-T30 fuel pump
- What kind of motor is this? B16? B18? Or?
- PCV Black Box - Broke :(
- Where to find bigger valves for my z6?
- Washers for head bolts? B18B1.
- Proper break in procedure?
- Crankshaft Question?
- b18b1 coolant leak
- Power steering pump battle
- CEL CODE 6 PROBLEMS
- 96 civic random bogging
- Vtec pressure switch - not bypassed
- OEM Undersize Bearings
- gst misfire help!
- Plastic intake manifold & backfire
- 2006 Honda Pilot EX power steering pulley removal
- Help/stranded
- upgraded mounts for stock motor
- Weird vtec issue
- Arias 84mm piston on stock b20z2 rods
- b18b1-rewired harness and now alternator smoking when battery is hooked up
- 2 extra bolts after timing belt change
- another to maneuver
- Civic VX and the dreaded throttle lag - solved!
- Oil seeping into manifold
- VTI radiator vs D series
- Crank sensor
- Limp mode? Help please Don't know much about Hondas
- eg sedan motor mounts
- 92-95 civic hatch taillights (hardware)
- Acura integra 90 ls starter relay problems
- What is the combustion chamber size on D17a1 (plm head)
- 92-95 Speedometer Frequency -> Speed specification.
- What rebuild kit do i use for d16a6?
- Degreeing stock cams, how much lift?
- 95 CX gas needle pin broke, replace?
- H22 oil pressure sensor torque setting?
- are we the only ones with obd2 port?
- Heard a loud pop near driver side axles
- what did you do to your car today? (technical posts only)
- 0-20 weight oil, drop in oil filters, are all new cars like this..
- I need parts numbers for pistons, please help.
- Honda N600 - Spark plug leads
- Anyone have an obd2a strut tower plug pinout for civic?
- Ef hatch has trouble starting and wants to stall
- d16y8 issue
- Rod Bolt stretch ARP 2000 bolt question
- Cam gear vs Ignition timing
- B16 RPMs bouncing up and down rapidly and car jerks
- What complications from an oil pump o-ring leak?
- 04 civic stuck on vent
- stubborn distributor leak on gsr
- Transmission Help
- JDM LHD doors on a RHD DC2..?
- is it ok not to run block o-ring?? coolant leak
- B18c O2 sensor plug came off of engine harness!!
- dropped a bolt into my tanabe muffler.
- Bypassing heater core ? Quick question on thermostat housing !
- Can someone tell me if this park has to be connected
- Thermostat Ground questions
- need help on a b18b1 in crx please help.
- strange overheating problem on my b16b
- 92 civic HB dx no fuel prime
- F22b1 swap in a 91 civic wagon?
- element rack&pinion
- B16a wiring problems
- 96 Accord EX Coupe Coefficient of Drag
- F23 Motor
- ls crank in gsr block what rod bearings?
- Honda City Vario Ignition Key getting hot
- I need to get this car out of my shop
- How do I identify a 4 cyl engine?
- 2000 civic si EM1 unknown engin part.
- Manual
- is my b18c usdm or jdm?
- leaking oil from below distributor. '00 civic ex
- 02 Honda Accord Starting Problems
- B18c O2 sensor plug on wiring harness came out! Help!
- Need help identifying camshafts
- 1992 CX running at 3 cylinders
- Distributer for JDM Motor
- Need Help Interpretation Compression Test
- Is VTEC or VTC ever activated on a Daily Driver?
- please help identify this plug
- Integra vacuum issues... Please HELP!!!
- need help b20b4 swap
- Ferrea Valves with stock valve guides?
- rusty headers
- low idle no power
- B series obd2 injector order
- CRX Burning an alarmingly large volume of Oil
- Exhaust option
- Crazy Idle
- B18A engine swap in 1988 Civic DX Hatch ECU Wiring issues
- Distributor Help B-series
- engine swap
- dc2 w/ b18c no power to fuel pump, wont run.
- 1987 Civic Sedan (EW2) Idle Issues
- 98 civic boost gauge question
- 91 Civic Questions
- how do i test an engine for rod knock damage?
- Vtec Switch??? That's not right...
- where to buy a canister spout
- new bearings with new rods?
- Heater system electrical problem causing battery to die????
- Installing Positive Battery Cable
- Tilton clutch master cylinder OK on stock clutch ?
- Timing Belt Wedge Retainer
- HondaBond 4 or HT for oil pan gasket?
- Possible ignition switch?! Please help!
- Straight Pipe b18c1
- main relay not getting power sometimes
- Engine Cuts Out, Where to Start..
- MM code changing on its own
- wierd.... please help
- Is this normal?
- VTEC Disengagement Failure
- Question about ls vtec
- 91 civic hb vs 91 civic sedan compatability
- Failed Smog: HC(PPM) and NO(PPM)
- I need B16a complete parts list
- Car won't start! 1995 Acura integra gsr.
- problems with b184c
- NEED SERIOUS HELP!!!
- need help
- 99 hx Temperature gauge goes from normal to cold with heat on
- NEED HELP ASAP!!!!
- MT Shift Rod and Oil Seal
- engine balancing tolerances(new parts tolerances)
- Retrieve engine codes from 99 civic with obd-1 ecu
- What kinda camshafts are these?
- idle problem
- Mitchell On Demand Data Disc NEEDED!
- Knocked hole in headers
- Signs of a bad steering column?
- Please help get my Honda snowblower started!
- Unknown Header
- H22a5 rebuild!
- 95' Civic EX with B18C1 engine swap coolant issues
- ITR SWAP PROBLEM
- CRV shifter box, is it similar to the prelude?
- 2015 Odyssey LX; Power Tailgate & Sliding Doors
- Active Exhaust System?
- Help! b20b vtec Compression Height?
- B16A2 BUILD
- Does Seafoam actually work? PROOF!
- 2011 Fit Sport - Power Steering light on but steering normally
- Acura CL parts compatibility with EK chassis
- Help identifying plugs.
- B serie Thermostat housing question
- d15b help please
- Help me!!!!!! my motors Hydro locked!!!!
- obd1 questions
- power stering bracket bolt
- HELP ! White smoke, motor stuttering, smell fumes/gas
- need help!!!!!!
- Jdm d15 ac bracket
- 1994 Del Sol low idle when warm
- B18c5 engine ignition trouble
- Smell Burning Oil (Candle Wax) in fresh air intake.
- H23a swap wtf is happening!?!? hate cars
- B16A2 HITTING VTEC LATE
- jdm motor swap please help
- engine information needed
- b20vtec Thinner Head Gasket?
- Need some help with d16y7 swap!
- What OE-replacement radiator brand does everyone like these days?
- Randomly loses power while accelerating- 1997 Honda Civic CX d16y7
- for real D series experts only
- 95 civic ex with JDM b18b
- 93 civic lx b18a1 motor mount problems?
- Vtec not engaging in my b16a swap da9!! help pleade
- B18a1 with ctr pistons
- Looking for longer fuelhose (OE-fit).
- Honda CRV Revving in Neutral
- b20 swap
- bogs and misfires only when warmed up
- Vtec won't kick in ... yo
- Steering wheel spinning out of place while driving
- b20v over heating
- B16 block OIL GALLEY PLUGS,
- Difference between cylinder heads
- 96 accord compatibility
- B18B1 Crank journal measurements just shy of Minimum spec
- rpm not working
- oem,gates,greddy toda timing belts strength
- whats bad about blox style FPR?
- Clutch pedal sticking
- Suggested Break-in Period?
- Rebuidling b20b4 bottom end
- 2000 Civic SI cigarette lighter fuse?
- 99-00 keyless into 93 si
- S2000 seats not locking when reclining , any ideas ?
- Raining Floods and Low cars don't mix
- Never seen this before
- Rattling noise, notchy shifting, then car died while driving
- bottom end assembly ballancing
- Weirdest problem on a ek9
- S2K Dash Cluster
- cylinder bore variation ?
- Racing seat question
- Honda Civic 2007 si
- Boosted EG idle and smoke issues
- 55psi oem fuel pressure regulator?
- different header affect tune?
- help installed halo headlights n fried alt.
- stock d16z6 hondata issue
