View Full Version : Tech / Misc
- Anyone using Sachs clutch kit
- 99-00 Si or 98-01 GSR
- crank
- adjustable cam gear with mildly milled head?
- Downshifting
- thinking about how to remove my engine...whaddaya think?
- idle problem on my hybrid
- Clutch won't engage?! help!
- how to tell if a ecu is 5 speed or automatic?
- Tech: Greddy Oil Filter Relocation Kit (P/N: 12013012)
- help with building H23 for 94 Civic
- H22 auto-tranny LSD into 5speed tranny?
- ITR and 99 Civic Si SYNCHROS the SAME???
- Saturated/Peak&Hold Injectors
- Hand sanding /Polishing metal?
- ECU Code Question...
- 9.6 cr to 10.2 /10.5 cr
- intake noise
- Funky idel
- code 9
- remember SKUNKWORKS before they changed their names to SKUNK2???
- safe to bore?
- wusup im new to the game n i need some ideas for bolt ons
- those of you with raised vtec X-over
- Adding CTR intake cam w/ GSR exhaust with 11:1 CR
- Interesting tuning results
- Speaker size for Civic
- 88 CRX with 94 ex engine.
- crx wiring harness
- ls-vtec vs. type-r
- to those of you with a K&N filter.
- BRAKE help........!!!!!!!!!!
- what do you think of this engine setup LS VTEC
- H22 timing belt tensioner
- CHECK ENGINE LIGHT!!!!!!! code 23
- Next step for my hybrid. ECU??
- Any difference between the 2nd and 3rd gen b16a?
- Radiator fan switch?
- should i be worried.....missed shift!!!
- moonroof fuse
- SOHC guru's Unite!!! and help my ass
- OT, but major problem...
- 92 accord trany on the fritz
- dyno questions with brand new engines
- This REALLY sucks! The seal on the oil filter split!
- need help!!!!!!!! ek-22 swap
- A6/Y8 mini-me (what kind of ecu/management help!!)
- compression test
- b&m fuel gauge (help)
- I think my fuel pump's gone....need advice
- obd 2 to 1 harness?
- my car won't turn over and it's not the battery, *Please Help*
- Forged pistons..... make more noise than OEM?
- intake sound?
- How to Replace an ABS Sensor
- Noise comming from springs?
- serpentine belt
- reading duration and lift
- I got a B18b automatic engine...
- Gsr ecu work on a 99ls?
- cheapest place to buy JE piston
- jun 3 cams valves clearance
- air/fuel gauge vs. egt gauge
- Quick Exhaust Q-???
- Exhaust way to loud. What can I do?
- PLEASE HELP! clunking noise from car
- 92-95 shocks on 97 civic
- Where is the TPS wire on 97 GSR Ecu?
- h22a probs?
- Can I use B16A pistons in my B18A?
- what do u guys think of this tranny
- OBD2 a or b? ....what years?
- How often should a PCV valve be changed on a 97 GSR????
- Do you give jumpstarts?
- Throttle body and intake manifold question
- when installing the h22 in an ek how big do i need to cut the holes for my shifter assembly?
- Swap? or not to Swap?
- throttle body assembly problem.
- how will the gear ratios be
- What does the PCV valve do?
- Where are Helms manuals sold? i can't seem to locate any at my local auto parts stores
- No air from the a/c
- Spark Plug Wires
- cams.....to itr or not to itr......in a gsr
- what are some carb legal mods that i can do to my car?
- JUN 3 to Crower 403 and...
- b16a w/ ITR intakemani/throttle body questions
- Timing issues
- Rebuilding oil pumps...
- All Motor All Day
- B18b with 100 wet shot safe ???
- Internet Source For ITR Factory Manual Chapter(s)?
- Why is my car idling erraticly?
- ima rookie wut kinda headers spark plugs n wires+ clutch for my civic
- ignition timing question
- leaning out safc for better mileage with a/f gauge
- autometer a/f gauge?
- 93 coupe suspension setup ?'s
- Name This Wheel?
- Tranny Gears Question.
- What to look for with an engine swap?????
- buying a b16a2 block, not sure if its a b16a2 head thou
- Who sells 1\8" BSPT to 1\8"NPT Adapters?
- do pulleys really?
- Required Clearance between rod and pin (floating assembly)
- my head is getting noisy?? valve adj?
- Are these car ramps gunna raise my car high enough to do turbo install?
- Squeeling noise...
- Dyno Day in Southern California, April 5th 2003
- Raising Rev Limit on B16A2,Tech Questions
- whats th difference?
- on average how long does it usually take to pull a motor?
- d16 build up
- where exactly does the...
- EK Rear disc brake conversion
- Broken C.V. boot. Performance ones?
- air filter... how big is too big?
- b16 throttle body
- Couldn't figure it out myself. . .
- Syncro?
- should i get a gurlde?
- One final b16head/b18block thread!
- Can i drive with only the top piece of two piece header????????? please help
- jun 3 cams
- i need ecu pinout for a 2001 civic like stat
- LS crank in a B18c block..
- Throttlebody from type-S Prelude.
- good clutch ?
- Oil and fuel in spark plug tube?
- 96 ITR tranny: What are the stats on this transmission?
- is it safe to drive with out thermostate?
- what trans fluid for itr trans
- Where to find heat range colder plugs
- 96-98 Dx head to possible ex or b16a head?
- What ECU for CX block with CRX Si topend?
- how much worse is the gear ratios on a y1 than a j1
- Skank2 stage 2 clearance
- Toyo Proxe FZ4?
- Skunk2 stage 2 cams blew my motor....
- should i resleeve or bore out and use a blockgaurd???
- tips on driving stick?
- Compression Test???
- CTR pistons in a B-16A
- Which Intake Manifold and Throttle body?
- LS + Hondata + nitrous =??? Need dome info
- Newbie Question
- symptons of bad fuel filter/fuel pump?
- Proper step for Clutchmasters stage 3
- More tranny problems!!!!
- Metal Divider on throttle body...
- Hose from valve cover to intake piping...?
- ** -- Can I use a V-AFC on a NON-VTEC engine -- ** ?
- Breaking in brand new CRVTec swap!
- car shutters in first gear....clutch?
- welding different metals?
- Installing Cusco LSD into B16A1 gearbox. Advice Needed!
- Hondata question
- 92-95 jdm cluster install????
- RS*R rear muffler section inlet/outlet diameter
- Questions about 63403 crower cams
- When should i worry about valve to piston clearance?
- Step by Step for LS/vtec.....easy/hard..?
- wut kinda clutch for a honda civic vtec 95
- what coilovers for my EK?
- h22a or b18c
- where is the vtec on obd2?
- blown d16z6......need help fast
- Maintenance that is 10X easier with the motor out of the car???
- DC 4-1 B16 header on b20/vtec?
- tuning hondata...how?
- Anyone have CTR cams on an Si???
- where can i buy ls/vtec oil line kit ???homedepot????
- advance distrutor (timing)...increase fuel pressure and more HP?
- 92 Civic DX Feeler Gauge/Valve Adjustment specs
- b16a block= b18c1/b18c5 block?
- are all b series piston rings the same?
- No power to Coil! Help please
- poor mans gsr?
- dyno charts on b20s
- Very strange coolant leak!
- Quick help please :)
- how much work does it take to replace piston rings
- please help!!!!!!!!!
- H22 Swap into Ef hatch
- bore and it's effect on CR
- How do I........
- valvetrain components
- Oil pressure?
- answer!!!!!
- Has ne1 here blew there motor usinf skunk2 stage 2 cams?
- Oil, mixing synthetic and petroleum base
- custom exhaust(rp)
- Which header .....
- integra brake issues!!!
- ef-1's cams and valvetrain?
- Angel Eyes anyone??
- Please help with header install?? What do i do?
- D16a6 feedline gas bolt to d16y8 fuel rail?
- How to identify a ITR tranny
- Opinions of this ECU please :)
- FAILED emissions test.. need help
- where to find 85-87mm bore pistons for GSR engine?
- First Gen Apexi RSM problem....help needed!!
- what intermidiate shaft to use
- Apexi N1 Exhaust!
- newbie - intake question
- which tranny is better with a all motor b20 vtec setup
- Service Connector
- Newbie Help.
- Steering Wheel Frustrations (Volanti Wheel + 89 Accord = ERRR)
- b16a2 trans on a b16a1 motor, will this work
- clutch problems help..
- fields or vafc?
- five speed swap...neverending hydraulic leaks that i can't seem to get rid of!
- Tranny gear ratios - What's 'final drive'?
- Hella HID...Are they good?
- distributor problems...
- cam timing off? fire out the throttle body!
- Type R, GSR, & B16 fuel rails???
- b16a and b20a originals??
- Can you calculate my new compression ratio after getting my head milled?
- Cleaning my engine??????? Steam cleaning by acura??? help
- B16 in a CRX, trouble, please help
- i would like to know a good place to find engine specs for preludes
- could i do high compression on a turbo????
- 99 civic ex/si ECU (are they the same)
- PR3 pistons in B18A block?
- tranny problem
- H22 distributor for a 5G hatch...
- wierd stuff on my motor b16a sir1 obdo
- whats the max speed in each gear
- y1 lsd on a j1
- was this a good tranny deal
- some one please list tranny codes
- are 95 ex/si rotors BIGGER? and gas tank removal.
- Does anyone have EF h22 swap pics
- Has anyone used HCP'S(HELLA CRAPPY PLACE) wiring
- Intake Problem Need Help Plz
- AEM Fuel Fpr!?!
- lightened flywheel = stalling
- need help installing msd blaster coil on h22a4
- reliable engine builders
- Okay to TIG weld a block in the car?
- engine codes....
- >>>Need your help, confusing starter & timing Q (GS-R)<<<
- noise from my b16a
- minnesota ship i cna get my rods ground for CTR pistons
- Code #43 and other shit. Need some help.
- VX- rated 55/48mpg factory...im not seeing nearly that HELP!
- great story
