View Full Version : Tech / Misc
- H22 h23 f20b Balance shaft differences
- Questions on a ridiculous swap, but its all just sitting there
- Wire Connector caught on Fire! Suggestions?
- Help with b18c1 no crank condition swapped del sol
- URGENT! How to disable car OTHER THAN disconnecting battery or pulling fuse?
- Grounded...Engine wiring harness debacle
- NTK 24385 5 Wire Identification
- Rod knock or something else?
- 2006 crv (K24) mystery coolant leak?!
- Farenheit-81
- B20b high idle
- ECU (ECM) repair shop recommendations?
- Installing new o2 sensors
- B16 trans da halfshaft
- Separated wiring Civic EK.
- Poor MPG
- just bought figuring out what to do
- Build The Civic EK3 to boost 800HP
- D16 won't go past 5700-6300 intermittently
- P0420 DTC - O2 sensor trace
- 88-91 Honda EF/CRX - Master Kill Switch Wiring
- Oil dipstick length issues
- Spoiler fitment
- Constant code 9
- D Series block girdles
- Tps trouble
- VSS Issue at ecu
- 2016 Accord lx abs
- Heads up on b series ignition coil from jhpusa
- Non Injector Pulse, EF B18C1 Swap
- Won't start unless holding throttle. Low rpm missfire.
- ANY HELP/SUGGESTIONS APPRECIATED
- 2004 Honda Accord Need Help
- '00 EX auto swapped and conv.to 5spd D16Y8.. ECU?
- 2002 Honda Civic EX Question
- 2000 em1 starter issues
- 2005 Element need help
- Mini me misfire/compression help
- Stripped head bolt time sert
- OBD1 vtec into OBD2 non vtec harness
- Distributor question
- Battery Isolator Switch Wiring Setup
- Flusing a cooling system -which radiator?
- 98 Honda Civic LX
- PLEASE identify this sensor from 01 GSR
- Ek sedan seats
- D15b with Z6 head help! Idle surge issue
- Racespec switch panel wiring
- 1992 civic eg hatch - S2000 Clutch Bleeding Issues
- Troubleshooting. What is this "Whooshing" sound I hear?
- B16A Crank, No Start
- Civic Mb6 (B18c4 engine) not starting
- Shift light hondata s300
- B18C1 not reading pulse for ICM, anyone know next steps?
- Shift Knob Thread 2001 civc si
- Intake manifold swap help!
- B series cam trigger with power steering
- White smoke from exhaust, head gasket?
- ABS Open or shorted circuit
- Noise-vibration-harshness "NVH" app
- Need help with F22B1
- Honda GX200 Intake
- f22b1 head sensor wire snapped
- How to know window regulator's gear teeth are in correct position before placing in..
- Wire diagram for b18c swap to ecu
- 1990 acura integra
- CEL doesn't come on in key position II
- Help ID Missing Roof Rack Part
- troublshooting: D15B2 wiring harness issues
- Weird connector in trunk
- Horn Wiring-Integra Vs TL
- B16 analog temp guage
- B18a1 Idle surging after swap
- Door Lock Issue
- What component is this?
- Please help - D15B Oil pan gasket
- Cross compatibility between radiator fan motors between Civic and Accords
- 2000 Civic D16y8 - IACV p1509 Code = Blow the whole car up
- What is the name of this exhaust manifold
- jdm B16a Low voltage
- What kind of wires are these? Please help
- Cam gears that have the most degrees of adjustment
- Crank sensor CEL / Limp Mode - obd0 to obd1
- odd one but what would cause engine mount bolts to break?
- Front Wheel Bearing Direction 98 CRV
- noobie question - exhaust
- O2 sensor placement.
- Stalling issue
- Liquid/Grease on Fuel Tank Electrical Connectors
- Code 8, running rich, doors lock randomly
- B16B wiring HELP!!!
- 2003 civic clutch plate problem maybe?
- Dry Sump Oil System Questions
- Fuel Rail Disassembly Q's
- Rotting Gas Tank / Gas Line Replacement
- Checking main caps befor aligne honed
- can i use a gsr oil pan on my LS
- Blown Head Gasket Now Piston rings.
- 93 Civic LX power window and locking switch malfunction
- D16a
- Obd2 to obd1 o2 sensor location
- Tach bounces around, but consistently too high
- OBD2 to OBD1 Conversion
- Designing a Custom Electronic Brake Proportioning Control System
- Tristate Motorsport Ramhorn reviews how was your experiance
- Integra Bogs hard around 2500-3000RPM
- PLM RMG style header joint leak
- Occasional loud clutch grinding noise please
- Leak down test question
- 2nd fan not turning on
- Oil sandwich plate questions and concerns - Golden Eagle copy
- Sounds like the car is grounding out or something on startup
- Accord battery slowly dies while driving - no charging
- B16a2- 93 civic cx - won't rev past 3k
- Cam degree kit
- Not happy with my Clutch Masters fx400 stage 4
- Rectifier Diode test
- Wiring B series
- Assistance needed: Engine "bogging" at low rpms - unknown engine, details not given
- B series offset fuel pressure regulator to inline
- 00' Civic LX ECU/PCM schematic
- Capacitor leakage
- B16A2/B20Z PCV valve crankcase Ventilation discussion
- Cranks but doesn't turn over b18 turbo
- Assistance needed: Radiator hose location and how to run them. Unknown vehicle.
- Battery voltage changing, no parasitic loss on voltmeter?
- Trying to diagnose A/C problem on 05 CRV. Expansion valve or compressor?
- B16a2 now at 8.8:1. Stay with 91 octane fuel or no?
- XTD Clutch - Honest Review (~6 months usage, w/pics)
- Troubleshooting: 02 Civic EX M/T Immobilizer issues causing no start
- B Series Timing - Crank turns on its own before cams
- 1988 civic with b18a1 swap problems
- Avid racing mount bushings
- 1994 Integra GSR wont start
- 1996 civic ex passanger window issues
- 98 Civic - Interior moisture/front passenger floor wet
- ATI Dampener removal
- The thermostat ground shocks me
- Previously Unheard Sound When Shifting
- 2016 HRV AC issues
- What part is this?... called?
- 99 civic b20vtec with P2T ecu
- Issues with 98 honda accord
- J35A Engine Stand
- Plastic positive battery cap, engineer to fail !!!
- H Series swapped Ek
- H22A swap DC2 Integra
- B16A Surging idle despite normal checks of TPS, IACV, FITV, etc.
- LSV back of head HEX PLUG THREAD PITCH to -6an SIZE NEED ASAP! HELP
- Oil Viscosity and Weight discussion
- Ports for lsvtec oil catch can
- B series LS/VTEC TDC/Timing issue
- Assistance Needed: Blox gauge wiring install
- Who makes the red performance distributor for honda
- PR3-3 head / best matching block?
- Integra to eg swap
- 2004 CRV Compressor clutch no engaging
- D16z6 intermittent loss of power at high rpm
- Showa - Steering gear overhaul - drill a hole?
- 08 TL type-s auto ecu
- Need sensor name help.
- How-To: Recognize & swap-out Transponder chip 2003-2007 Accord & Civic
- Is there a date code on this Honda timing belt?
- Can you identify this oem muffler?
- 86 civic, lost power in cluster, blinkers and tail lights
- Troubleshooting: 1993 DA fuse panel #50 no start issue.
- 91 crx p28 hondata ecu no power - main relay good!
- 90 Honda Crx 5 speed(used to be auto)Cranking issues.
- unvented catch can routing b16a
- Troubleshooting: Tachometer bounces around 5k-7k. Signal issue?
- Troubleshoot: 2010 Accord immobilizer allows ignition immediately.Is this bad?
- 96 integra Wireing diagram for fuel pumpt fuel cut off switch
- Troubleshooting: H22A stock engine has low idle and inconsistent operation
- What throttle cable to use
- T1 cam trigger with stock tach
- engine over heated
- 03 civic Ex Ecu
- Honda Sensing and Adaptive Cruise Control problems
- Looking for vtec rocker arm pin!
- Not able to hear vtec crossover after oil leak fix..
- Yahoo japan auctions
- CF4 Accord/Torneo Service manual?
- Deatschwerks DW400 installation
- B20 too big / loose main bearing clearance
- 91 civic dx motor swap
- P28 D11 diode burning?
- Gsr water pipe question
- Red light in dashboard when the car is on
- Question: Is it possible to bypass the VTEC oil pressure sensor?
- B20 Running Poorly
- Why Timing Belts are So Expensive to Replace
- Assistance Needed: Problem codes with multiple ECUs.
- Honda sensing cruise
- pressure in fuel tank
- P28 auto to manual conversion help
- Advice on JDM B20 leakdown results
- 05 Accord Ex Seat Belts
- Coolant coming from oil pan drain plug
- DC/EK power steering delete - killing the slop (write-up)
- 1980 civic release bearing clip
- Using A/c Switch on non non ac equipped car for Ecu input
- Racegas fuel concentrate
- Bent valves?
- Malfunction Indicator Light or Check Engine Light... where?
- OBD2 Auto Integra Replacement Engine(B20z2) Questions???
- Engine fan issue on 95 Del Sol D15b7
- Exedy ITR vs EM1 clutch kit differences
- Code po113 IAT high voltage, i have 12 volts at pigtail instead of 5 volts?
- High flow fuel pump on stock injectors affect AFRs ?
- Fuel cut off at highway speeds?
- Seal belt issue
- VSS wireing to ecu HELP
- PCV - Vented vs Closed Catch Can - Containment Build up
- Moroso 5.5 oil pan users!
- Surging idle with new O2 sensor?
- AC Compressor Check
- 1993 Civic Si Moonroof Issue...
- How-to-install Inquiry: Camshaft / Cam gear grommets
- Throttle body water line plug question
- Trouble:07 honda Odyssey has constant ringing noise in back of vehicle
- Oil leak found between block & head gasket. where could it be from?
- 06 CR-V Troubleshooting: Stumped by coolant loss/other issues
- Is a crack in a camshaft where the Cam bolt inserts repairable?
- Distributor cap help - 96 integra distributor systems
- Check Engine Light blinks one short.. then nothing.
- D-series Engine Starter ID confusion. What is the deal with this?
- “ChaseBays” CB-BD-CM1 (H22) Sub-Harness plug
- Battery light comes on after WOT and turns off
- 2017 accord coupe power folding mirrors?
- JDM J35A Engine Into USDM 03 Honda Pilot. Injector Question.
- Smart Key - all lost- HDS 3 - how programming a new key
- BATTERY CHOICE: Best Option?
- Does anyone know the thread pitch for the Skunk2 dual bend shifter for 88-01 civic?
- ECU wire diagram for D16 ZC honda urgent!! plz thanks
- O2 sensor location issues
- I've discovered some interesting info on Honda's ELD (Electric Load Detector) system
- Suggestions needed: 06 Civic DX -switching from key start to toggle switch/push butto
- Assitance needed: Honda Parking pole Installation guidance
- Anyone had a Re-manufactured Engine put into your Honda, what was your experience ?
- H22a swap injector question
- A question about 92 - 95 throttle position sensors
- B16A PR3-1 how can I tell if it is OBD1 or OBD2?
- Problems with HandsFreeLink
- J35A4 vs J35A8. are the engines similar? Higher compression?
- What do the following Honda Part Number Identify? Honda won't tell me
- Unique Esso sticker on JDM B16a spark plug cover.
- Which Part # for O2 sensor numbers for B-series 4-wire systems
- Denso 2840 Radiator Identification
- Solid CEL months later leaky capicitors, ecu repaired now CEL 22
- Troubleshooting- 94 Accord will not run w/ new main relay and fuel pressure
