View Full Version : Tech / Misc
- Air drag holes in back bumper
- magnaflow oval muffler interior drone ?
- Front brake conversion
- Car doesn't start, No electrical power after doing power steering conversion!?
- How to calculate compression ratio
- b16 in to 95 CX hatch, retain d15 drive shafts?
- info on changing my ls into a lsvtec
- Tranny noise gone, what is this noise now?
- CP piston pin lock install
- cutting the half the head off a lug nut stud? anyone done this to replace it?
- torque-wrench settings for motor of xl250r
- Honda 0W-20 oil!!?!?!
- Windsheild replacement...
- Just bought EG with ls motor and found out it has a 95 civic ECU??
- A couple questions?
- Should i replace my valves and have my valve surface re-done ?
- what's cooler mostly water or mostly anitfreeze?
- Camber or No?
- Built engine sitting for 1 month + w/o starting... what to do ?
- LS/VTECvs.F20B
- Synchromesh Trans Fluid
- b20 / Vtec what ecu to use?
- Where to buy sodder?
- think a b18c could fit into a 4 door metro?
- gsr vtec solenoid fit on a b16 motor???
- looking for progressive suspension bushing
- IAT Mod
- need to set timing on 87 acura integra??
- emissions Q?
- h23a1 tranny have syncros?
- need help asap!!!!!!!!!!!!
- swapping p28 with p72 will it work?
- Question about hybrid piston-rod combo..
- 1 Wire o2 sensor for AFR Gauge?
- Suzuki Grand Vitara Pistons. Sohc Zc(non vtec). 125 Shot
- car wont start, help
- Apex'i PS Revolution Exhaust
- Need help on picking a good full coilover
- th my VSS Troubles
- Having trouble installing axles? Try this out!
- suggestions on brands for strutbars/swaybars
- greddy warning guages question...wiring/ map sensor question
- need a way to test the stroke of a shock absorber/damper - work out rubbing
- questions about code 21 on check engine.... no vtec
- how to install 2 step
- Crappy shift linkage = missing 4th gear?
- Misfire in all cylinders, timing light shows misses
- Code 10,16,21,22
- b16b problems
- endyne block fitting part number
- drag suspension
- Greddy Warning gauges HELP!!! Map sens question/wiring
- no front drop with prokit/koni yellows?! (rears dropped 1")
- the truth about timing?
- timing belt tension question
- Knock sensor question, built motor, Apexi Power FC
- TORQUE SPECS PLEASE......thanks need asap! im on hold
- Gsr motor won't rev past 2500 rpm
- B16A stroker "kit" ???
- ls/vtec questions
- b16 exhaust cams same as ctr cams??
- How to tell if LS OBD1 ECU has been chipped for HONDATA?
- How to neaten up wiring?????
- Calling on all members for help on this one > NEED ECU pinout for JDM Euro ATR H22 OBD2a
- HOW DO YOU ADD TORQUE?
- Si Seats
- ECU An Harness
- anyone know how to rebuild an A/C compressor?
- Pressure Loss even after complete rebuild
- B16 CRX Failed Emissions :(
- How do you reset the maintenance lite on 2000 acord?
- helpe me
- IAB wiring help please
- K24 Head same as K20 Head
- CEL confusion on a 99 CR-V (CEL and ABS light both blink)
- Gear Speed Tranny
- Teins on an 03 Civic Coupe
- Code 1362... crank position sensor
- lsvtec prob : golden eagle oil line conversion kit leaking
- SCS connector question
- high flow cat causing a cel
- cv joint will not go in!
- do i have to re-wire?? when..
- Anyone have the VAFC II instructions?
- Plug and Tap Size for LS/VTEC Conversion on B18C1 Head?
- msd ignition help please!!!!
- Grinding?
- Nosey Suspension
- q about boosting a stock motor
- CEL Misfires when cold....
- convertion of dc2 to type r japan version
- wrecked crx
- pinout for P08 ecu... badly needed
- Double stacking head gaskets
- I've the choice between .....
- Anyone got the thread to the Frame Locks Are
- Failed 3rd smog test, need some input.
- FLywheel and clutch bolt torque??'s
- Hydro tranny and cable tranny???'s
- help cam seal leak
- increased compression in stock ls?
- Honda Stats
- Stumbling Accord!
- run this part number
- Valve Spring Compressor Tool
- quaife help
- ls valve train question
- Intake for 6th gen. 4cyl Accord ... extra component?
- to obx or not???
- CRVtec
- Limp mode with new injectors
- hosed my motor..need some opinions...
- first time cranking it over and nothing......
- S4C Tranny?
- Tranny rebuild question
- First time lowering my car...............
- tire size?
- B18C1 into 96 hatch rewiring help
- what size tap do I need to chase the threads for main bolts and head bolts
- cometic
- tranny help
- what needs to be removed to replace wheel studs?
- b18c1 problems, questions?
- Type R valve springs???
- PLEASE HELP!!! Any one know how to put together ls-vtec?
- 12:1 CR - Ignition Amp rquired?
- Quick VTEC distributor question for OBD2-OBD1 conversion......
- Torque Wrench
- b20 Vtec Upgrade
- How to calcuate cc displacement?
- shocks & fitment
- Brand new B17a dumping fuel
- i have a bike
- Knock Sensor Swap
- Will it be okay if I mount 215 series tires on my 6.5 in wide rim?
- Retracting the antenna eg
- B16 gear ratios?? anyone know??
- Kamikaze Headers
- ZC tranny on SOHC
- Interesting Problems.
- 4 Wire O2 sensor conversion for dual 1 wire systems.
- which scanner to use to read codes
- Ultimate F'n madness....talkin In-SaNiTy here.
- p28 or p30 for b16a3 obd1
- Body Repair Question
- Changing Levers on a 04 Shadow 750
- car starts and runs fine, ONCE A DAY!! one start wonder, need help..
- How much pressure is in a clutch line?
- B16a with GSR cams
- I don't understand
- 4-PUCK clutchmasters clutch slipping on stock motor????
- HELP WITH VAFC2 **Already did a search**
- stripped head studs
- JDM OBD1 OBD2 Oil pumps LSVTEC Please help.
- Serious ECU/CEL problem, need knowledgeable help.
- testing compresion
- any respectable or recommended tuners in nj/ny
- ???? b18c build up
- Car makes noise and vibraetes when turning right
- itr intake manifold ? help please
- Debate:too little backpressure?
- Please tell me what's wrong with our car
- motor swap
- Knocking sounds like diesel after warm up wiesco on eagle rods Help!
- something is messed up. please help.
- Looking for a machine shop in DFW, TX. Any suggestions?
- obd1/obd2 b18c1 sensor differences?
- turbo help
- Electric water pump
- 2.5 inch exhaust flange help
- DPFI TO MPFI CONVERSION
- Fitting Help
- **Chainging Fuel Filter**
- Oil pan gasket, b-series
- ?????crower valve train???
- ignition coil install need help?
- gsr forged piston in a ls block?
- B16A - stopped, whirring noise when trying to start - any ideas?
- looking for 91 crx si 4 injector engine harness from dallas
- how to tell when dist rotor is bad?
- bad fuel pump, mainrelay, or ignition problem????HELP
- SS Vs Mild Steel exhaust
- LS/VTEC question, please read and help...
- b18c1 build
- Reference: Proportioning Valve Sizes
- type r cams
- If was planing on Installing a Turbo
- gsr pistons in ls block?
- GSR block with itr valve train and stage 2 comp Cams Should they make much noise?
- Solid aluminum dowel pin or OEM aluminum roll pin for shift linkage?
- interior light fuse Problem!!!
- VAFC
- Oil Soaked Plugs, Now My Car Won't Start
- Cam Gear Install Question
- EFI Spreadsheet for planned future mod... making up numbers...
- ??? on ZC tranny
- apexi turbo timer (pen style)
- looking for a block assembly in so cal
- Wiring help! D16Y8-> '92 Civic LX
- Difference between the 90-93 intermediate shaft and the 94-upLS Int. shaft?
- vibration still there! need help
- rc 310 injectors dont fit!!!!!!!!
- Idle surges from 900-1500
- Serious Help Needed - Oil Pressure Related
- radiator fluid getting darker
- d15b a/t ecu to d15b m/t engine
- B18C1/EG Problem - idles amazingly rough, won't rev up
- Older honda stalling in turns
- '97 civic startup shudder
- fidanza v exedy v act flywheel ?
- whats the problem with my motor
- head install big oil leak head gasket on gsr please help!!!!!!!!!!!!!!!!!!!!!
- **Changing Fuel Pump**
- ecu ?
- Low headlights - Eibach suspension - HELP ME!
- Selling MSD ignition Dis-2 ignition with boost retards
- Oil pickup and Oil pan
- OK so im buying a swap with a bad block.. need some help/ opinons
- Reversing LSVTEC head
- Oxygen sensor question?
- I wanted to post my first pic...
- OEM tach upgrade
- Idle surge from 750 to 200
- Turbo Gsr Idles a bit high.. Need Advice..
- Can some one please help me ASAP!!!
- valve adj.
- Bare Minimum Connections/Sensors/Solenoids on B16A Engine
- EAGLE RODS WONT FIT...NEED HELP!!!!!
- coilover question
- Sorry guys, I need help on ecu codes for 2000 Acord v6?
- bell housing
- 03 Accord, Wideband?
- Fully built motor problems
- engine swap what do i need
- Info on a b20 project...
- Head back on, and some problems...
- Cam Question!!, For D15B vtec
- Details on building your engines... d16y7
- what do i do?
- FRM sleeves - which pistons?
- Help....my tach is freakin out!
- Is this crank worth fixing? (56k possibly, but don't hold your breath)
- Head Swap
- New Power Excel shops in NYC
- help! dizzy? timing??
- hondata or a vafc??
- k20a2?
- EF9 Turbo not starting
- ******HI pitch scrapeing noise left front susp.********
- links about building n/a road racing engines?
