View Full Version : Tech / Misc
- hard break in? what do you think.
- hondata question
- B16 HELP!
- Question about ECU's
- What would cause the power steering to go?
- DA Brakes loosing pressure
- Secondary O2 sensor trick
- Tech Edge Datalogging rpm signal
- Transmission Swap question
- Urethane... window weld...DIY motor mounts
- Adjusting Fuel Ratio (VAFC2)
- byebye tranny
- d16a6 Tranny Rebuild...
- Which tuning program? Hondata, Crome, etc.
- TRANSMISSION - REVERSE IDLER GEAR BOLT WONT GO IN
- what's the difference between a JDM d15b and d16y8 head???...more q's inside
- D16Z6 oil pressure issues...oil pump??
- Blox Manifold
- GROSS POLLUTER... now what???
- type R or skunk2s or stock cams in my GSR?
- B16a connecting rods
- type R head
- 91 obd0 obd1 alternator
- Main Bearings and Crankshaft
- b16a crx wiring
- are DOHC and SOHC vtec solenoids the same?
- Weird grinding noise coming from tranny.. HELP!
- Crank Angle sensor
- How do I change steering column 96 civic h/b?
- what size rods will I need?
- GRRRRRRRRRRRRRRR Type R valve spring placement
- My Flex-a-lite Electric Fan Keep Blowing Fuses!
- MSD Ignition Questions
- LSVTEC- How to drop compression? Headgasket Q
- alt light comes on after 4k
- d16z6 head mixup
- YONAKA MOUNTS WHAT AXLES?
- 98 ls motor into a 98 civic coupe questions
- p30 ecu problems?
- one issue to another
- F and H series main sizes?
- Harness
- vafc
- Whats wrong with my tranny?
- b18?
- tach help...pictures???
- 4 wire o2 hook up,diff color wires???help??
- Code 21 (VTEC Solenoid) clicking on, instead of VTEC engaging
- will this sway bar fit my EJ9?
- Buddy club cams
- Just had my tranny rebuilt. PROBLEM HELP!!
- Diagnose Clutch problem..... ( VIDEO )
- Failed emissions. THC is too high. Searched a TON. Retard or advance timing??
- Motor build tolerances
- I made a hole
- arp headbolts or stock..? d16z6
- GSR crank timing belt sprocket/gear same as LS?
- Question about ARP Rod Bolts, Line Bore, and ACL Bearing Combo
- Apex'i Exhaust Control Vavle Do they work and how easy is installs?!?!?
- Part 1) Measuring HP in Japan
- bogs at WOT
- need some help with a problem
- which head studs
- anyone got the ecu pinout for AUTOMATIC 98+ integra?
- how much nos on a ls/vtec is safe ??? N20 ?
- Comp. ratio 4 my ls/vtec
- E3 spark plugs????
- lightened flywheel with stock clutch( did Search)
- Wideband question
- Need Help CEL 20 (Electrical Load Detector)
- b series vtec cams
- need help removing broken bolt
- need your thoughts on this situation
- Ariel Atom Tranimssion?
- motor wont crank, but runs after a push start???? please help
- What year and model is cylinder head code is PR4-6???
- no oil pressure
- New oil catch can routing.. Is this ok?
- Acura Legend info
- Lower compression pistons for FI.....is this possible?
- Honda Part Number Request? - 2000 Si VSS
- valve lash therum
- NEED HELP RE: B18b freeze plug
- at around what speed does a 91 jdm b16 s1 tranny 3rd gear top out at, at 8000rpm???
- Should I get a car with ls/vtec?
- so i put new valve springs in and..
- Timing Gurus, ? on Flame travel, TDC, dwell time, etc
- Z-10 gridle from my ls/vtec?
- tuning suggestions
- Bearing Clearances
- ecu wit obd1 conversion harness.
- brake master cylinder ques.
- Where to get oem electrical plugs and pins?
- SOHC, Whats the differance?
- I need d16y8 pin-outs.
- Can I eliminate my fuel cutoff (speed limiter)?
- Just a quick question or two reguarding timink mark on the crank pulley.
- Need help with ECU codes - Thanks
- trembling when accelerating..help..
- Throttle Position Sensor Wiring
- jrsc idle issues
- *** Need adaptor plate so b16/b18c intake manifold will fit on b18a/b motor
- WHEN does the new Accord ECU look for knock input?
- car wont start...
- Question about OEM Honda rings...
- Combustion Chamber Sizes
- need help wiring my o2 sensor!!
- obd2 dizzy in obd0 car running obd1 distributor code 4 problem solved
- need some help for my tachometer project
- Smoke coming from engine bay after VTEC ?
- gsr throttle body on skunk2 im
- Fixing broken oem ITR injector
- Rethreading a short shifter?
- help tranny experts
- oil catch can
- issues on cable clutch *help wanted*
- Usefull or Useless?
- EGR lift sensor
- Will any B series half shaft work on GSR?
- Braided steel lines, permanent fix for radiator hoses?
- 98 jdm itr tranny
- stroker h22
- !!B18a Rebuild Help!!
- How to get the pins correct for my O2 Sensor Wire?
- MDX..................quick help please
- OBD II vs OBD I P72 ecu
- Displacement Calculation 95 mm stroker 84 mm bore
- My street/drag build?
- reverse wiring on resistor box
- B16A2 oil pump faulty already?
- B18/ls head vs B20 head question
- ## KM/H to MPH Guage Cluster ##
- HID lighting
- DC5 Type R Header in Base RSX
- can you swap guts between cable and hydro b16 tranny?
- engine stutter
- ARP ROD BOLTS Torque Specs
- Are all b series starters 90-01 the same?
- thread size on aem fuel rail?
- Car payment Calculator?
- Problem with Tach
- need a chip writter d15b vtec...!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
- sporadic vtec engagement
- Strange temperature gauge
- what will lower hydrocarbon and carbon monoxide levels?
- ?? Planning to rebuild OE Denso alternator. OK to use generic brush set ??
- I dont know where to post this but i need a quick response
- Clutch pedal not depressing in the morning sometimes?!?
- strong smell of gas after hard corner
- Stock 95 VX failed emissions, Please help #'s inside....
- Binding axles?
- EF, DX to SI intake manifold swap questions?
- spiral spring on power window?
- lsvtec problem help..
- B16 INTAKE MANIFOLD GSR HEAD
- Mix ARP and OEM studs?
- Can you use z6 Distributor on a y8 head.....?
- what would u do??
- Will a B18C1 swapped EK hatch pass smog in CA LEGALLY?
- EF intake manifold swap
- act and exedy clutch question
- PLEASE HELP bought a 91 crx today and it has some engine problems
- ONLINE HONDA PARTS CATALOGUE
- Need info for my engine build....
- B16 block GSR Head
- Auto Loan?
- Will a Vtec head fit a D15?
- How does the ECU determine when the vehicle is "cold" for cold start ups?
- Intake Temp Sensor.. Help please
- Car won't start up unless you pump the gas pedal. 87 Integra LS, PGMFI
- Car won't heat up in Wisconsin.
- LMAs Exchange
- vtec won't engage. searched. tried lots of things. please help
- New Headers overheating, dead battery, muffler problems
- Hesitation problem remain unsolved...
- Rod bolt stretch gauge increment question
- pistons and rods for b20 vtec engine
- skunk2 stage2 vs skunk2 skage3 vs toda spec c vs toda vtec killer cams
- Finished swapping blocks....Motor won't stay alive... Help!
- So I get this "P28" that does not look like one....
- Compression Ratios from LS to LSVTEC
- tuning
- Unbiased Dyno Testing of Synthetic Oils
- insurance and swap question
- help losing oil badly
- vtec problem....check out pics
- What do you think of this Port Job? Give me input ASAP.
- idle problems with f22
- PR3 and jdm GSR motor
- d16z6 crank question
- Help please my car wont start
- VAFC wiring question
- gsr head dowel pins
- anyone need a A.T.I dampner?
- need specs
- Anyone have Hondata's EPROM?
- Help: Changing Distributor Plugs from 2 Plug to 1 Plug
- '92 GSR will not crank after this...HELP HELP
- how can i check my valves to see if they are bend and also check the valve seal?
- new orings for rc injectors
- Which ECU would be better P30 or P28
- Exhaust leak=Bogging?????
- **********H22 IN AN INTEGRA WITH A/C?**********
- Re: Abnormal Spark plug wear (erosion)
- I need 2nd, 3rd, maybe even 9th opinions on this rod.
- STUMPED...Vtec
- aftermarket block gridle
- Converter
- Diffuser plate
- Varsol for hot tanking the head ?
- HOW DO YOU SWITCH FROM TRIAL USER TO FULL ON THIS SITE
- Stripped T30 Torx Bolt - Need Help
- check engine light flashing?
- OBDIIa - OBD1 Conversion without harness...?
- odd problem
- Ignite my engine!!
- NO SPARK$!@#%^%&* HELP
- What cam is this?
- new piston rings? or something else
- clutchmasters
- HELP Apexi RSM
- Transmission Type
- Help me with Radiator issues...
- difficulty removing rod studs?
- help with fuel pump
- defi fuel pressure guage sensor took a shit?
- What are the chances of warped head?
- Acura Legend, 2.5-2.7?
- Willem EPROM Programmer Woes --- PLEASE HELP!
- 2005 civic Exhaust Pipes
- Extendin the o2 sensor?
- Thermostats, the colder the numer, the hotter your heater?
- Smoking B16a
- auto tranny: popping gear into N at a stoplight?
- car smokes/burns/spits oil after new valve job - bad rings?
- car not reading temperature
- D15B2 Transmission Linkage With a D16Z6 in a 95 Civic
- need help on d15b2
- Swaping my motor
- port&polish vs. polish head theory
- head on d16y8 block
- iridium plugs
- LSD question? please help!!!! THANKS!
- GSR rods and Crank in an LS Block?
- Wireing Question?
- How to Convert Hondata Stage 2 programming to S100 spec?
- distributor question
- electronic cutout w/ stock muffler?
- ITB confusion
- obd 1 block in obd-2 car
