View Full Version : Tech / Misc
- cut out at 5500 rpm
- PRETTY Please Help?
- DIY front toe adjustment - 360° of tie rod rotation = X degrees of toe adjustment
- do turbos and vtec flow good together
- Timing Belt slipping over? Help!!!
- is it ok to ride on the bumpstops?
- How do you check the CEL Code on 2000 V6 Accord?
- 22mm Progress sway bar or ITR sway bar?
- Toyo Proxe T1-S life expectancy. . .205-45-16
- spark plug wires
- Apparent problem with GM/Texaco Dexcool & Silicone Seals
- Tuning without Dyno help
- good bay area clutch shops?
- where is the temp sensor?
- Is my clutch gone?
- Any how-to's out there for eg brake swaps?
- 403's vs OEM cams at 7500 RPM.. thoughts?
- Hitachi ignitor better than NEC...?
- Where to buy gasket for generic header...
- 6th gen coupe w/5 lug question
- EMERGENCY!! need help with OBD2a to OBD1 harness ASAP 12:47 AM 5/26/2002
- ecu code
- Is it safe the run with the IAC valve sensor disconected?
- Swapping Odometer?
- tach wont go past 6500 rpm???!!!!!!
- What F#$% is a difference between a B18A block, B18B and B18C
- My baby is sick :-(
- question...
- gains from b16a head on gsr block?
- wheel weight and mpg
- ECU No Light
- 2-way, and 3-way catalyctic converters
- Pullys
- AHHH! Tire rub on one side? Help!
- fuel pump how to install
- What Cool "N/A"Hybrids can One make w/ the rare b17a , I have one in my grasp!!!
- type r fuel pressure..
- a different kind of ignition question....
- Do shocks take time to settle?
- SRS light on
- need help to tune a N/A GSR w/ the VAFC....
- Idle Questions...
- help i broke a lug nut and stud off!!!!!
- Need help in NC .... ?
- wiring to the alternator?
- install on neuspeed race springs and koni yellows
- HELP!!! Why is 1 chamber Black/covered with Carbon Deposits and other 3 light gray with little C De
- Good head gasket to raise compression.
- b16-b18 flow charts?
- VAFC trouble
- What are these?
- Stock rods/pistons. Handle high rpms?
- Brake upgrade. Any suggestions?
- brake swap question on a 90 crx hf
- Oil pan gasket
- differances between D15 and D16 blocks??
- Skunk2 Stage2 on stock valvetrain.
- Torque specs for Kosei K1 valve stems?
- the b18c has pms every other day, wtf is goin on?
- Power loss on dyno due to check engine light?
- Floaties in Brake Fluid
- Fuel injection question
- is a knock sensor needed for a b16 w/chipped p28?
- Light source for gauges.
- Need some help with a problem, please.
- plastigauge ?'s
- Car wont start!
- low beams wont work
- aem pulleys on SI civic??????
- What gage steel for 2.5" exhaust tubing?
- HELP turn signals are NOT WORKING!
- Brake Upgrade for 94 Coupe??
- GSR rods in LS block
- bleeding clutch
- B20/VTEC head gasket trouble:
- H&R Race springs on 95 ex coupe...22mm rear sway...problems????
- Aces! another crazy idle thread!
- Startup problem, please help
- Re: Did I F-up my car?
- Rear Brakes on Integra
- Collector Diameters in CRVTEC?
- Going to install Pistons and rings. Bore and Hone needed?
- Tranny making noises
- Suspension Techniques Front Sway Bar
- not your "everyday" VAFC question
- Just installed AEM EMS on '97 Integra GSR, few issues
- whats the whole point of a test pipe?
- gsr throttle body
- Comptech Rear Swaybar/Tiebar combo in an EG hatch
- What is the best engine I could Swap for a 94 civic dx?
- 5g trailing arms on a 6g civic
- Differences between a Gen 1 B16 Head and a Gen 2 B16 head?
- STR Fuel Rail
- Valve Cover Problem------------------------------->
- i have access to CNC milling centers
- Which size Toda oil pump gear for my GSR
- DSM 450cc injectors pieces/parts needed
- '91 B18A Block, '97 B20B head
- Weid tranny noise, need help
- Need an answer quick!!!
- which dash harness to use for non-OBD to OBD-1 conversion.....
- b16 complete guides?
- 00 type r harness can i use on a 92 hatch with a b16
- whats the difference between bov and wastegate??
- ground and TPS wire on 91 B16?
- LS harness onto ITR ECU.
- advice on b16a tb/tps
- how much should a 92-95 distributer
- o2 sensor
- Integra Greddy cat back on 00 Si?
- Can you really get alway with those cheap camber kits?
- Electrical oil guage Install HELP
- Mixing DOT 3 and DOT 4 fluid
- bore & stroke
- drag race suspension set ups
- oil pressure guage help!!
- head flowing websites
- Can you hookup an MSD o2 sensor to the stock ECU?
- malfunction indicator light
- Exhaust Silencer
- Gaskets and seals question, need help guys.
- Question about suspension
- stock cat vs. high flow
- Are prop valves REALLY necessary??
- will the apex vafc work with other cars...
- Good INSPECTION .... EMmisson PLACE IN ...... Charlotte,NC
- Vacuum leak or internal problems?
- valve compressor tool
- Is it safe to bypass the IAC valve?
- Looking for a good so-cal machine shop
- this is what you should run
- Plug gaps for a ZC
- Help bleeding brakes.
- Question about Titanium Ti brake pads.
- v-afc wiring
- Si exhaust
- gsr build
- ctr/itr cams with hondata?
- Will a ls stock fuel regulator fit a gsr?
- Vtec Kick - Got Torque (dyno sheet)
- CV Boot, Driveaxle busted due to rotors installation?
- Suspension Bushing Kit
- what does this mean
- Mechanical Oil Pressure Gauge HELP.
- Block heights...
- Average cost of throw out bearing?
- offset questions!
- Airflow for a 65mm t/b into a stock GSR intake manifold
- HONDA CTR Piston code for honda part numbers
- tire hitting something?
- Help alternator solenoid fuse keeps blowing after B16 swap
- specs for h23 jg 1001 grind cam
- tranny apart!!Trying to put it back together???
- bore vs strokeso
- b16 block w/gsr head???
- head gasket...
- rev limit kicking in early
- can i plug my sohc ecu on my dohc ls/vtec?
- Ok, here's the deal on my H22. Update on "Fresh built H22" thread.
- af gauge wire??? install? help?
- Exhaust wrap disscusion
- Are B16 bearings the same as B18C bearings
- floating valves?
- HELP - the rim that ran away!! :(
- Piston Rings and Locks
- o2 sensor on 88 si
- 1st gen b16a in 92-95/ type r distributor
- Honda civic greddy turbo, Running Too LEAN!!
- Custom Test Pipes
- Oil Viscosity question
- vis spring rates
- Burning Oil!
- What year was VTEC introduced to the USDM...?
- need pic of VTEC soliniod, and some others ?'s...
- Car wanders under braking.
- compression ratio on stock internals?
- Mag size
- compression readings
- b series valve stem seal install
- AVOID PACIFIC HONDA in North Vancouver, BC
- Is the ignitor built into the coil or distributer or is it a separate part?
- Is there a JDM B16a2
- What a good civic engine tech page?
- Best clutch for my set up??
- Is anyone from COLUMBUS OHIO?
- What a great Swaping site?
- What motor swap is a good deal for a 94 honda dx sohc?
- need some help............
- Pushing rods out of pistons
- Clutch Kits... stages?
- catalyst replacment pipe
- 2 BAR or 3 BAR MAP sensor?
- Coilover Question???
- 92 si hb funky tach
- 91 JDM B16 vacuum problems...we think.
- NOS on the 98 obd2 cx motor
- Why am i burning so much oil???
- Fuel Cut Strategy of the ECU - Any thoughts?
- clutch problems - is it the slave clylinder?
- AEM short ram on a d16z
- Intake Mani gasket
- Orderin my CTR Intake Cam... OK to use stock Exhaust Cam?
- Newbie questions for you all...
- chance of warpage on block and head?
- Just bought a JG throttle body, need comments!
- Where to buy Volk centercap??
- will this work on hondas?? valve spring compressor question.
- Header Help
- VAFC or P28 Chipped Ecu
- 95 Ls swap into 95 CX hatch What kinda problems or NONE???
- oil in spark plugs
- 2.25 cat back????god or no good
- idle problem...need help
- Replacing alternator
- throw out bearing?
- So pissed off...
- exhaust valve coatings
- Rod/Stroke Ratio Info
- prelude injectors...
- Oil loss, white and blue smoke, coolant loss, and black spark plugs. What should I replace?
- Single Belt Crank Pulley.
- pistons
- someone experienced ignition timing on F20A SOHC Prelude engine?
- Honda number on gsr timing belt?
- air filtersssssss
- New piston rings, what do I do?
- what is that thing called..? HELP
- Apexi WS discontinued....???
- strange vibration
- 94 del sol clutch any sug.
- B20Z swap in a Civic EX 96 - Problems!!
- how to modify jdm 4-1
- Possible motor mount issues...
- Need some expierienced help figuring out an ignition problem! PLEASE
- Blown head gasket or fried piston rings, how can you tell?
- What's the worst that could happen? Do I need a new motor?
- Cusco cam gears?
- Zdyne Help
- Does anyone know how to set a Fields vtec controller?
- could it be a short?
- Why are my sparkplug tips Black?
- Question about wheels/suspension...
- ecu Help!
- Help Please! I can't figure my problem out
- what makes more power?
- backpressure and backfiring
- Cam Install
- Reasons I keep breaking my clutch?
- ls bore?
- Engine Paint Help!!
