View Full Version : Tech / Misc
- Griffin Aluminum Radiators? Quality?
- ZC swap won't start.
- SPC Camber Kit Questions 88 CRX Si
- where to connect a multimeter to act as a tachometer?
- Removing Axle end nut, on 92 civic DX...
- it it AT ALL safe to drive with your oil cap off?
- what would cause my missfire/popping sound?
- Tint?
- tranny mount question in 94-01 teg????
- Front anti-sway bar
- Turbo intake IC piping using AEM???
- vafc II tps
- Autometer oil pressure guage
- Which stock brakes to go with?
- Good Deal?
- DX With 4-1 Header and Hi Flow Cat, will it work?
- Inspection (catless) in North Carolina or Philly?
- BRIGHT CORNER WITH 1157 BULB
- OBX cam gear?
- up to 1800cc...
- ef suspension options for track
- ITR ECU on a B16a?
- oil pressure ZC engine CRX (1600cc)
- Low idle??? HELP
- my car is hesitating (not all the time though) HELP
- dart block?
- integra brakes
- h22a skunk 2 im released???
- B20 VTEC drivability
- Effects of Lowering car
- why my 5" autometer tacho not synchronize with my stock tacho?help...
- anybody using this wideband o2 converter for the autometer air/fuel gauge
- ONLINE MANUALS FOR OVER 23,000 VEHICLES FREE! by publishers of chilton
- do i need OBD2 to OBD1 ECU Adapter Harness?
- Think I broke something, Strange noises.
- Distributor question...
- distributor question..
- car is going to sit for a while....what to do.
- NEED HELP: CEL code 6
- Tein Type Flex rebuild...
- Did I damage the master cylinder?
- ECU socket?
- Brake booster on a Full Drag Car?
- Anyone using Fast Brakes, brake kits.
- Loud humming from passenger side? Need help!
- ls/vtec compression
- Comptech or Suspension Techniques Swaybar
- need help
- which one
- Need help with a struggling b16a
- High Coolant Temperature Warning Light Install ------>
- 4x114.3 15x6.5 +45 offset wheels?????
- jUST got my newly assembled motor..d16..have some ques.
- 2003 si front seats into EK hatch???
- b16 not starting PLEASE HELP!!!!
- Need answers regarding B20Vtec in a DA integra
- timing belt about to fall off??? any reasons why?
- abs code- rear wheel lock and high pressure leakage...whats the deal?
- Need Help on wiring - 5" AUTOMETER Tachometer in B16A
- z6er's, Let's hear it..
- Installed new ECU, vtec is glithy....
- 2nd gen prelude question..........
- Prelude Manual Transmission
- GOT ME!!!!!!
- ITR Tech Question
- Engine Codes
- engine code 41 and 26
- 345cc prelude injectors in an EF?
- k20 block difference between rsx s and si civic
- All 90-93 LS trannies the same?
- how would a 'Venom' intake manifold work better on a 90-93 integra rather that a skunk2 or a JG?
- installing a fuel pump kill switch
- D16Z6 in a 4G Prelude
- Wheel bolt pattern and size chart
- CAR WONT START! HELP
- Can anyone give me the basics for tuning????
- need help w VAFC-II
- H22a Cylinder Coating?
- Idle problems on my JDM B16A
- can someone help name this plug?
- nos and exhaust?
- sparco mugello
- anyone know if 2dr and 4dr integra mirrors are the same
- OT: Tire studs for winter
- Help making a JDM ITR Cluster work in a '00 Integra GSR
- helpp....cel stays on when checking codes
- What is the best block guard to use?
- mounts for 98-EK?? please help
- Rear Disc Conversion for Civic
- ACT PP Post Installation Issue
- After swap, Electrical Charging problems....please help...!
- Where to buy fuel filter banjo fitting bolt for fuel pressure gauge???? Help!!!
- carbed set up and ignition tuning/control
- what is this light? pic inside
- a knocking sound
- hydro b16 tranny questions
- 99 SI swap help..
- Wilwood Rotor Parts
- "best" valves?
- a6 parts in a z6 block
- HELP!!!!! My putters after driving for 15 minutes
- Uneven brake pad wear...is the driver the cause or something else?
- what steering racks fit 99/00 SI's?
- Wiring help! URGENT!
- Replacing synchros
- golden eagle blocks??
- idle is starting to get crappy.
- Formula/Algorithm for turbo timer RPM/MPH based?
- Nos Wet & Dry
- Question: Cable Tranny to Hydrolic?
- Question about exhaust !!! Help!!!
- question about installing headstuds...
- Where to buy b18c water pump and timing belt tensioner
- need help replacing damaged coolant hose! please help!
- O2 sensor compatability for Air/Fuel Ration Gauge
- What obd1 ecu will work for me...slightly odd situation...???
- exhaust screwed up after snow storm...WTF??
- *what else is needed for bare block
- n20 and big cams...possable
- quick ls girdle install ?
- Valves loud and metal shavings in vtec solenoid filter
- question about intake filter
- LSD for Y21 & Y2
- stock gas mileage for integra LS?
- BIG suspension/driveline problem (pictures inside)
- 98-01 JDM 4.78 final drive question.
- P/S delete on 99-00 ek coupe?
- Z10 and Moroso oil pans
- IAT question!
- Replacing Suspension Bushings
- Hondata Questions
- apexi vafc, pressure monitor...
- some 87 CRX si questions
- what kind of ECU is this?!
- d16y8 swap complete...need help
- size of crv master cylinder
- how does an 97 ex 5 speed engine harness differ from a 97 ex automatic engine harness??
- ST or Eibach REAR sway bar setup for a 90-93 DA integra??
- replacing syncros?
- my swap story.....so far....
- CRV 5 lug?
- 92-95 Si Cluster vs. 92-95 DX cluster... does the speedo look the same?
- The chime for when exit car with lights on
- FD in my B18C-R
- Anyone know where the mirror relay is?
- Whats best for 94 Accord EX sedan
- knuckle compatibility for 00 civic si
- How could I tell how many Stage Vtec there are in My JDM D15B....And Which Is best performance Jdm D
- racing crank pulley fro d16a6
- hondata on JUN ecu
- VA/DC/MD industrial supply shop.
- Rear Camber Washer Correction Disaster! -can someone help
- quik valve ?
- Spedometer is Still not working.
- torque specs?
- Ca + smog + B16 = ???
- Removing powdercoat?
- Best Shocks/Struts for Neuspeed Race Springs
- my car wont start!
- coilovers?
- myth: turbo doesnt work well with v-tec systems...
- ITR Tranny/Block brace bolt question
- Air Compressor?
- EFI PMS piggyback any good?
- who and where is a great shop to get tuning done in socal
- Valve stem seals
- headgasket b20vtec(itr head)
- D16Z6 BUILD-UP HELP?
- Balancing butterflies on ITB's
- Trying to find weight split F&R
- Fuel pump problem
- 150,000 on vtec?
- Needed: Correct Toda Spec A Cam Sheet
- need help with a honda part # for b series tensioner
- caliper bolt stripped
- Converting a 99 JDM B18C-R to OBD-1 - what injectors?
- ----Nitrous Help please!!
- Ignition Timing Questions ?
- IM tech: resonance chambers ?
- IAT Sensor
- Holley fuel pressure regulator
- weight on konig harpoons
- quick distributor cap question
- 2 Cats better than one!? (Smog)
- anyone have a good.....?
- WTB: del sol hood
- B17 crank identification
- Wheel Bearing
- jdm 4.7 final drive in 92-up cable tranny( ys1,y1)
- Installing jdm civic 92-95 rear interior
- I'm in CA, and buying a car out of state! What to expect, smog???
- Spoon Cams Specs
- Alternator Plus question - (search useless)
- force to remove camshaft sprocket oil seal
- need help please
- Is a GSR differential same as B16 differential?
- Is this why my vtec doesn't work? how do I fix this??
- which is best ecu for hondata
- need help, '91 si w/ b16a and bolt-ons
- This lil shock thing?
- Some port and polish picture from the autoshop
- Manley Parts
- Port and Polish with Skunk2 valve train.
- Question on LS/Vtec
- Welding the Diff?!?!
- wiring harness problem please help
- QUICK tire question...
- 95 accord starts up too quick
- no heat?
- Still no start (need help)
- Hardwiring question?
- ls/vtec knock check light
- 92 Accord steering pulling to left HELP
- LS Tranny vs GSR tranny Results
- cold air ,warm air
- size of K-series Vs. B-series
- springs for a daily driver
- CEL Code 70
- wheel well fuel cell
- Help! Need info on Super Silencer
- Few problems in desperate need of fixing...GSR Swapped 95 Hatch
- Test Pipe Q's
- my brand new battery losing charge....
- ITR LSD bearing?
- distributor broke.!? help
- block still safe without sleeving?
- Portflow inner w/stock GSR outer valve springs???
- flow rate of water pumps?
- Anybody know anything about effects of mixed brake fluid?
- Slid into a curb
- dc upper header with stock crv down pipe?
- b16a2 install on 92 civic si
- Floated valves?
- Wheel Stud removal
- Im getting rid of my 90 Eclipse turbo and moving to a 93 civic
- need help please!!!!
- Having some problems with TB stuff... Please HELP!
- trade my stock b18c5 11:1 for a b20 12:1
- Need help on choosing the right engine to put in my 91CRX?
- Good compression for LS/VTEC?
- What springs???
- Aem CAIs? Turned into shortrams in a jiffy?
- my civic has me stumped. wont start (obd1 EF)
- HOW TO REMOVE AND INSTALL ROTORS???
- Need help wiring o2 sensor!!!!.... not what you think.......
- Looking for a GOOD machine shop around Cincinnati
- posted in the prelude forum but no help cant get my car to idle corectly
- will ITR injectors work w/ non OBD ecu?
- Rear sway bar
- tech quest: 2000 EX exhaust manifold fit onto 95 sohc vtec engine?
