View Full Version : Tech / Misc
- Quick, can NE1 help with my intake problem??
- OBD0 to OBD1 Distributor wiring question!
- honda accord no start
- Transmissuion Help Not going in Gear
- need a 90 Ls Dizzy? or does any obd1 ls dizzy work????
- code 7 question.
- b16 piston change
- Car died crx with b18c (fresh swap) now no spark!! Help!
- Headstuds?
- Quick questions/ AEM SRI install
- CEL 03 manifold absolute pressure help
- Oxygen sensor question
- check codes on obd1 crx??
- h22a intake Manifold
- trouble starting when outside temp is hot
- Air Conditioning help! Compressor not engaging!
- help....will these struts fit my 92 civic hatch dx?
- what's name of these suspension bushings? which need press to install?
- Car starts then cuts off...
- b16a2 spun rod bearing!
- Weird suspension feeling, floating over bumps
- Dunlop FM901
- Rough Idle?
- 4th Gen. Accord Automatic Transmission problem
- I hate VTEC
- When i turn my wheel...
- B16 is Stuttering badly.. Could be O2 sensor?
- NoVA- machine shops recomendations
- auto to 5spd....manual IM needed?
- Tranny Help
- 4th gear grind???
- Problem with JDM Itr HID's
- P30 is it auto or manual
- Front upper strut bar question
- Non Honda 4 wire o2 install
- Big brakes other than fastbrakes that will fit under 15's. Or custom brake setup?
- Question for anybody w/ Skunk2 stage 2 cams in GSR
- ANYONE HAVE DIAGRAM/GOOD LAYOUT ON PUTING GSR DISK BRAKES(NO ABS) ON EG CIVIC?
- reliability...
- Willem eprom burner issues with program, help here.
- brake master cylinder got empty while bleeding brakes...
- Injector problem on obd1 to obd0 swap into 92 hatch Anybody?
- SMOG help 91 civic si
- NEED HELP with AXLE (GSR ABS), driver side ASAP
- Where to get parts to rebuild a Y1 LSD cable tranny
- What king of LSD is it?
- injectors question...
- Electric Die Grinder or Dremel?
- broke a sensor...ah
- Best way to pull Axle seals ???
- car dies out???
- ps belt
- hondata chip burner?
- GSR DC 4-1 header on 92 LS?
- would having the wrong ecu cause vtec to not engage?
- would a bad cat cause black smoke when reving high rpms?
- spark plug gap b16a
- CALLING OUT H-T PROS: POWER STEERING INSTALLATION HELP
- old topic, new question: bouncing speedo
- fan mounts where to get them?
- need help figuring out Dashpot/Purge cut-off valve wiring?
- turbo pistons
- IACV Valve Question
- Strange noise on cold starts...
- Whats the difference between y1, s1, j1????
- tuning through v-afc
- a few questions about engine displacements...and bottom end components
- JDM S1 tranny parts from a USDM S1...
- Overlap, can I please get an Explanation?
- Suspension Hybrid Questions
- Hondata
- obd2 ver 1 --> obd2 ver 2 harness
- K series question.
- ITB's better than Intake manifold's
- Bearing Identification?!
- Review: JDMShit.com's P28 H22a Race Program
- (I USED SEARCH) My car will start, but it cuts itself off.
- What's the going rate for AFR tuning?
- What size bore (throttle entrance) does a stock B16 intake have?
- b16 tranny grind at low rpm...just started
- Engine swap ? For 98 EK (B18B1)
- OEM 2 belt crank pulley?
- Header coating shops in So. Cal?
- Any sensors on a b18c1 that relate to cold start..
- Falken Azenis
- B20B VTEC QUESTIONS
- Kaaz LSD
- thermal tape or thermal wrap? help please
- replacing brake master cylinder
- D Series swap question
- NEED HELP WIT SHIFT LINKAGE
- 4x114.3 to 4x 100
- break problems! need help
- PG7 what fuel pressure?
- AEM ems, Apex'i Power FC, or Hondata?
- Holy FUEL!!! HELP!!!
- D16a6 head on b15b2 ...compression?
- Weapon R header
- 92 parts on a 91 civic hb?
- going uber
- Is it possible to use the AC currently in my hatch after the motor is swapped?
- is 92-2004 civic exhaust same?
- Poly bushes - How To?!
- Installing clutch,flywheel,cams,gears,springs,retainers and valves....help?
- Clifford Intelliguard 850
- need header/exhaut help.....ASAP
- CSF aluminum single row race radiator review
- Car overheats at Idle, but not while driving, why?
- just gave my engine alittle tune up....feel a difference.
- HONDATA OR MICROTECH
- can somebody in texas install a motor for me ?
- Vtec Controller by Data Systems??
- pipe bender...
- Nubish question...why buy LSD???
- Problems starting up!!! HELP!!!
- Flywheel for my turbo application. Is stock strong enough?
- Mini me question
- ECU working only when cold?
- does ABS ring on axle come off??? (searched already)
- Can someone please tell me if a d15 intake will bolt to a d16 head????
- about my lsvtec...
- corrosion in spark plug boot
- OBD2 to OBD1 conversion questions
- PROBLEMS..
- D16 knock sensor
- Difference between 92-93 and 90-91 Integra Headers than other B series Headers
- automatic ecu with a 5spd car
- will a 99 EX ecu run my Lsvtec?
- What size bore (throttle entrance) does a stock B17 intake have?
- Sohc set up w/ pg7 ecu, what fuel pressure should I run?
- h23 Vtec build similar to b20 vtec or ls vtec build?
- top end cut out HELP HELP
- when chipping ECU, what do the capacitors in C51 and C52 do?
- strongest most reliable automatic?
- Testing vtec solenoid????
- Does anyone have jdm d15b vtec cam specs/information
- Vtec & non-Vtec Spark plug wires interchangable???
- broke timing belt. chances of bent valves?
- what ecu do i have????
- Integra wont start when hot sometimes
- Max spring rate that TEIN SS dampers can handle?
- Will OBD1 P75 LS ecu look for a Knock Sensor?
- 3rd-4th shift grind blues!! need parts for b16 jdm s1
- NO SPARK HELLLPPPP!!!! NOPI Drags in 2 weeks.
- Driveshaft question
- USDM s1 tranny vs. JDM s1 tranny...?
- need help wiring up VTEC on a Y8
- EG Brake uprade booster and master question.
- JDM F20A SOHC better or.....
- Nitrous on Crower 404's Ls?
- N/A LS OR NITROUS LS.......
- Chicago Machine Shop?
- Setting tps off the car ?
- do B series JDM engines have a evap purge control solenoid?
- Help! I need the stock suspension back on my car
- Valve seal ? Need help A.S.A.P
- 01 civic EX with ABS and SRS lights going crazy....PLEASE HELP!!!!!!!!!!!!!
- Itr lca install on 95 dc2 ( pics needed)
- p29 fictional
- B18B1 parts list for a refresh/rebuild
- will this ecu work?
- going to 4-114.3 lug
- about to give up!!!
- replacing stock pistons with other stock pistons
- Serious Bogging/misfire.
- Brake Master Cylinder Question Help! Please!
- bogging!!! need help
- illumina's work with these springs?
- Need info on jdm d15b vtech swap
- KAAZ fluid questions
- Need help with buildup
- Need name of Good Shop in Sacramento.
- Universal JIC-Magic Exhausts
- ECU Gurus, look at this PM9 please.
- possible fuel filter?
- Stage 2 Performance in NJ, AEM EMS Tuning
- please help, timing issue.
- Help with TPS voltage issue...
- .9 closed, 4.9 WOT. Is something wrong?
- Does a bad throwout bearing make noise?
- Autometer Electrical Oil Pressure gauge, condensation on lense.
- CEL stays on????
- disable knock sensor for lsvtec (obd1) w chipped p28? (searched......for hours!)
- my b18b eg wont stay on without revvin it
- gsr cams...stock exhaust cam, JG intake cam..worth it?
- possible to recognize a typre r crank?
- dont no where this wire came from?
- Throttle body and Intake manifold for turbo?
- Anyone work at an Acura dealer?
- please help me with my back alignment in my civic 93 hatch
- Surface rust on cylinder walls
- Alternator fuse keeps blowing!!!!
- F.A.S.T. Fuel Injection Systems
- B20 swap, getting code 43
- Options for main caps on a B18C1
- Knoxville hondata users.
- em2 suspension
- non-honda related. So all 95-98 240sx's have LSD's?
- Vacuum question
- **How Do You Bench Bleed a Brake Master Cylinder on a G3 1994 Integra GS-R?**
- sir question.
- ls/type r exhaust interchangeable
- D16y7 motor swapping for B16A1 motor NEED ADVICE!!!
- need a shelf 83mm piston
- Integra idling problem. Possibly fuel problem. Help needed please
- Q's about EVAP system on my b16a2, with PICS!!!
- What LSD fits a 95 LS tranny??? ITR or CTR????
- golden eagle vtec oil plate
- Honda sunroof chatter solved.
- hose clamps on a cvboot
- What codes throw you in limp mode?
- Napa part# for dsm injector Seals?
- Deposits on faceside of exhaust valves
- Just cant shake my idling issues. Help me trouble shoot.
- Mystery header?
- ceramic vs steel exhaust manifolds - which is lighter
- 99 Si harness + 99 GSR ECU
- Will obd2 engine harness plug into obd1 firewall harness
- IACV cleaning
- Built Engine Reliability
- Turbo sys., Exhaust header, ECU, and dual overhead cams. Any Suggestions....
- Torque settings for head?
- Tie Rod bushing question
- Timing marks on b16 and b18 engines.
- 2000 Civic SI (Canadian) help with suspension
- Qs??? about code 20 ...and unknown bolt for ground plate.
- My car is acting crazy?
- Rims & Wheels
- Possible to un-do welds?
- ls head on b20 block
- 4 door gsr and 3 door gsr parking brake cables different length?
- h23/vtec--ECU
- How To Differentiate ITR and B16A Injectors
- wrist/piston pin height modafication?'s
- d17 build up
- Turbo edit
- suspension questions and strut help
- DTM Full Coilovers...For Civic 92-95..wow....
- axle stuck in rotor...what do i do??
- B18c5 Crx Swap
- questino about changing crank/roc bearings
- vtec pressure switch problems
- Hondata chipped.... Please help.
- ok heres wat happened i was driving along and then
- should i try dsm 450cc's? on the dyno.
- Where is the ECT Sensor located?
- white smoke
- car shaking when turning
- Will the VAFC work on my Kseries motor?
