View Full Version : Tech / Misc
- vtec issues. please read.
- shop fees
- Curious about manufacturing
- Help! Cold running power hesitation.
- Dpfi to Mpfi with OBD0 harness and OBD1 Ecu
- another dpfi to mpfi proble
- need help proving this obvious fake is a fake "mugen"
- AlAddiN|502 A++++ seller
- quality of zerg industries ECU harnesses on ebay ?
- Where can I Buy California Catalytic Converter?
- Steering rack not centered! NOT the wheel, but the steering rack.
- 92 civic ls/gsr problems
- vtec problem
- need a car seat for office chair
- D15B7 / PM9 Timing Belt & Timing Issue
- P28 help needed
- good one for you involving obd0-obd1/2
- d13 block with p08 head
- A complete list of possible scenarios on why the motor cranks but does not start
- going d16z6 in CRX - convert to OBD1 using stock CRX // rywire harness?
- Need help identifying the following on my EK project.
- J30A1 V6 4 Speed tranny rebuild thread
- ITR cluster in EG(gauge lights not working)
- crx b18 misfire help
- 2004 honda accord V6 replacing engine??
- What the HECK is this weird rattle sound at 2500 RPM???
- DC/EK UCA Compatible?
- follow the arrows
- p2p on mini me
- Transfer of a CA Title
- New From U.k
- Which Wire Harness is needed? +ECU
- 74mm BLOX TB worth keeping?
- GS-R rod knock repairable?
- cicvic fuel pump n a prelude?
- Redoing my head gasket HELP
- Engine block casting numbers ARE traceable
- Ice in Air Compressor's LINE??
- Fuel pressure Help wanted !!
- d16z6 or b18b1 need advice
- CANT FIGURE OUT WHERE THIS VACCUM/HOSE GOES!?? PLEASE HELP. B-Series CHIME IN
- Name That Alternator...! B-series or D-series???
- Windshield washer system
- Difference in Timing Belt B16A, B16A1, B16A2, B16A3
- Theft attempt, chunk of key stuck
- LOST GEARS + WONT COME OUT OF GEAR NOW
- Skunk2 Cam ID (lobe size)
- plastic wheel well question
- help plz
- H22 Swap help *vid inside
- kgparts.com lsv kit
- Rebuilding LS head WHat should I DO?
- Who can verify this is a GSR Harness?
- recommendations for a new air compressor
- Which size fitting from fuel filter to braided line....
- Built up zc dohc engine
- 92 gsr battery problem?
- D16A6 Bearing code question....
- how to preform a leak down test
- advice on a header swap needed!
- 98 ls swap into eg NEED HELP
- jdm gsr swap misfire @ low rpm's
- Fuel system
- need wisdom, building a turbo D
- Car Power Inverter Question
- D16 OEM bearings. some colors discontinued?
- Car Wont Start...
- No start(very strange)
- bottom end gasket question
- cel p0441 evap emission incorrect, purge flow on 96 gsr
- B18c ARP Main bolt torque spec
- new lost motion assembly (LMA) part #
- Not an FI question but need help troubleshooting my GF car
- Running to reach??
- Valve Cover gaskets??
- bwr or datum1?
- HELP: heater isnt working
- 98 Civic stumbles off idle
- No power, bad MPGs, white smoke from exhaustexhaust
- Overheating problem need answers tonight please help !!!
- code 20 after wire tuck? help me please
- EG JDM Console Ideas
- Pics of How to Remove Pins in Honda Wire Harnesses
- broken welded nuts from rust inside ek chassis ?
- rebuilt B16a2 in obd2a 97 EK shell, no crank sensor startup ?
- Piston rings? Or valve seals? Pics, and taken apart, YOUR INPUT?
- bearings
- NEED HELP WITH VTEC
- quick question about wd-40 mixing with oil
- changes at your local honda dealer
- extending harness, advice needed
- Car intermittently shuts off while driving & alarm sounds
- 84mm combustion chamber on 81mm block?
- Help. car starting problem
- T/B install on k series xcessive intake
- GSR/B16 differential
- Hondata Heatshield Gasket?
- YAMADA 15100-P72-A01 oil pump compatibility?
- oil rings
- Apexi Neo - Code 22 Solved.
- Used wrong oil in wife's car
- tips
- B18b with PR3's and stock LS ECU.
- Skunk2 ProSeries manifold and throttle body. What throttle cable/bracket to use.
- GS-R civic.
- If you lived in japan
- rsx cluster in ef hatch problems!
- h22a4 prelude sh
- Oddessy ECU Pinout?
- B Series Coilpacks
- Malfunction in O2 Sensor
- WTF Window Motor/Switch
- Headlight shorting out (S2000)
- arp nuts and washers
- differences between sleeved B18 blocks for 750+whp
- apexi gear boost in DX EG
- make honda sound like subaru
- k20a pinging or rattle under load in 1st or second gear disappears at full throttle
- will short shifter fit my car
- Cooling system overhaul
- integra seats in crx
- vtec solenoid?
- bearing clearances
- CAR WONT START!!! NO FUEL PRESSURE
- Aftermarket Valves
- Engine Rods
- help with this part question experts! lol
- custom headgasket
- Account
- Looking for a good shop in VA
- 94 civic sedan power window problem
- Prelude 4WS Sensors
- No power, loud intake, can't reach rev limiter, cuts out at part throttle...wtf?
- FREE G.E. FUEL RAIL OFFER
- Rear brake pads sit unevenly, need help to find out why.
- ref ticket for catch can, will they smog?
- Enthusiasts hobby shop / DIY place to work on car?
- Crankshaft question..
- Blown Rod bearing in d16a6 91 civic ex what to do?
- Fuel pump problems
- NO HEAT
- Rusty Skunk2 Stage2 Exhaust Cam...
- Intake manifold studs, and bolts - b16
- Bent Valve
- Remote key locks deactivated?
- carb to efi
- Fuel economy 98 EX
- Fuel delivery problem when tuning at Church's
- Weak Spark Mystery on my 667WHP Turbo Hatch
- got an idea for a serious anti theft idea. need electronics person
- super tech rpm installation
- d16y8 vtec solenoid oil leak
- CEL CODE P1509 1996 HONDA CIVIC
- another idle problem
- radar detectors/ jammers
- Moving fuel filter
- G.E. THANKS OUR ARMED FORCES
- B16a2 running rich, fouling plugs, etc.
- Early rev limit
- h23a blue top in eg (iacv help)
- broken lower control arm bolt.
- Red dust of death - timing belt
- Identifying/Measuring Cams. How/Where to do it?
- Attn Electrical Engineering Majors: Resistivity of conductive paint for rear window?
- switching to manual rack subframe question
- e85 injector size
- Looking for Help in Md
- Feedback on recommended service for Honda Pilot, please?
- 97 dx coupe nrg short hub problems
- Random Revving in nuetral
- Compression ratios between b16 head and gsr
- f22 tranny on h22?
- B-series ef not starting
- Loses power at 4k as if on a switch.
- GSR Throttle body size: What size works, how big is too big?
- can you use emanage and make it reliable
- rods dont fit pistons
- keep blowing wheel bearing on passenger side help
- Rag got caught inside timing belt. HELP
- Engine chatter...vid!
- Slim fans?
- h22 sleeving
- what valvesprings/retainers to use with skunk2 PRO1 cams?
- Need help id this rod bolt crower h 514bc a1
- LS dizzy on B16 question answered
- Hi need help with vtec problem on a honda bf225 outboards
- 92 vx failed bar/ref: Wiring to sensors?
- cable tranny
- Could remote starter be causing problems with VTM?
- J35A3 L66 Honda Engine EVAP Emissions
- Breaking-in engine using a engine dyno
- k2b swap possible???
- Violent windshield wipers
- BRIDE seats that are fitted for 240, how do i fit them in a DC2 Integra?
- What type of Civic spoiler is this?
- fuel line bolt? what is it called
- k20z6? Info please
- can u test a tranny out of the car???
- Ls-vtec sputtering/misfiring under full throttle
- B18c failing emissions terribly
- 99 passport misfire
- 92 si prelude gauge cluster out
- 92-95 civic 4dr,my windsheild wont defrost,heat barely works
- CR-V Valve adjustment?
- Seat rails
- hondatech please help me!!
- 4000 RPM Max?
- help with my h23 turbo build
- ring gaps.
- DISTRIBUTOR PROBLEMS (Or what seems to be...)
- Tailight issue.
- 1998 honda civic vti in auto ?!
- My Alternator bolt is stuck
- getting out of the honda game
- PG7
- 4th gen: Power window problem
- tachometer not accurate
- Vtec issue
- swaping from h23 to h22 parts list?
- Civic Goes In Limp Mode
- 1994 civic.. zc block???
- oem itr manifold or aftermarket skunk2/blox v2
- need longer studs on head for intake manifold
- B16 Scratching noise
- Somebody HELP ME !!!
- 94 Integra Tuneup...
- car wont rev past 3500??
- SAFE MODE HELP! LSVTEC
- 2000 Si obd1 p28 code 92? EVAP?
- Airbox assy question
- stock ITR header vs aftermarket..
- Have emissions and want to do a small build. Gsr with sk2 IM and type R ecu
- car leaking oil? Need Help.
- b16a2 ring replacement?
- 3m windo-weld
- engine serial number info wanted
- M8 1.25 stainless steel locking nuts? where can i get some
- injectors compatibility
- Will these ac componets work on...
- G.E. WORLD'S FIRST COMPOSITE B18C ENGINE
- E85 winter storage ???
- Oil Leak issue
- B20 FUEL PRESSURE PROBLEM
- fuel pump wont turn on!!HELP
- Where to buy radio brackets (EK)???
- GSR cluster question...
- Stainless header, should I use stainless hardware?
- low fuel light works randomly
- part identification: b16 intake manifold
- crome serial number
