View Full Version : Tech / Misc
- Need Help
- adjusting valves
- Idle drops low when pressing brake pedal, could it be the brake booster?
- Head work
- ignition timming help
- Rattle problem, exhaust related, searched already, please read!!!!
- Exhaust Manifold Stud Question
- rev limiters? who makes em?
- Help PLEASE!! Dizzy problems???
- removing rod/piston pins
- fpr helpful?
- Good price for 404's and TI VS/Retainer kit?
- screeching noise!! help
- Valve clearance question?
- Electrical vs Mechanical gauges
- EK Hatch with h22a swap suspension help can any one suggest coilovers for killer'app
- i need help on how to connect the vtec
- b16 clutch
- overclocking stock B16 injectors
- INJECTORS: Pintle vs Ball / Disc style - Pros/Cons?
- Mini me in a 91 civic DX hatch back questions wiring
- Help with S-AFC
- compression test on a zc sohc vtec...results!
- ls/vtec fan switch
- Will Obd 2 sensor fit on obd 1 car?
- problem with idle car dies and have to rev it to keep it going at stoplights
- JG Intake Manifold?
- b18a w/gsr or type r pistons?
- 1st gen b16a coil compatibility
- Timing belt/water pump Replacement?
- 95 integra with 750-2000rpm idle speed!!! Help, frustrating!!
- d16z6 oil control orifice pn#
- Need Help??? Wastegate??
- white smoke help!
- B20, z10 block girdle question
- stainless steel brake line advantages
- Black Smoke Problem. TPS? MAP?
- ECU Code 9 CYP Sensor
- dh-racing
- Injector size
- ECU Code 20 -> Car dies out
- Coolant bubbles cause rich condition?
- Another help question concerning MPG ... 320mi a tank to 200mi ....
- Tips for me and questions for you... Aftermarket fuel cell on a DC2
- Tuning tips anyone?
- calculating IMEP?
- Problems with 92 Si...intermittent starting problems...
- tps sensor question, need help
- What should i do first to give my car a lil go?
- spoon sw388
- Dead Bottom End?
- Is it hard to adjust a VAFC apexi controller?
- Seized LCA Strut bushing/bolt how to remove ???
- camber problem
- how to compute psi? (compression tests)
- help!!! vtec not working and i cant figure out why!!!!
- VTEC controller - can I tune it?
- snapped temp needle off of cluster, any place for replacement?
- Need to know where I can buy RS*R ex mag GT II...
- bad oil problem help me
- calculating fuel correction
- Oil change?
- Honda coolant, Type 1 and Type 2
- Car Scraping Problem
- Need some quick sway bar help
- cam gear adjustment advance/retard
- GSR VTEC vs Prelude VTEC
- igniter?
- i got fuel/spark car tries to turn over but just doesnt!
- 2000 DC2 ITR air intake resonator
- prelude o2 sensor/voltage problem
- where do i take the tranny off to swap the clutch?
- I need a verification on the colors/signal of the 02 sensor wires
- VSS / vehical speed sensor, Anyone know the voltage it pulses out?
- Air/Fuel Gauges, Useless or Helpful
- motor swap
- Can I install squirters in an ls block to get a GSR-like block
- how to check igniter and coil in a distributor (did search)
- Identifying a B17a crank
- how do you clean intake filter?
- S-T swaybar question???? for daily driving?
- Is it to much presssure (C&R Radiator Cap)
- LS cable Synchros
- vss question with b-series swap
- Just did the head.. what could be wrong
- helpppp stupid o2 keep throwing a code
- how to ID injectors?
- Wheels Shake.....need help
- Should I be concerned with my A/F ratio/timming?
- HELP: Dealer problems
- engine cutting out
- Help Please!! Broke off Front Passenger rear Mount bolt
- HELP!!! Stripped Allen Head Bolt and Loctite
- few ?????'s
- my skunk2's are crap!!!!
- HEY i have an oil leak drippin on a belt!
- car cranks but wont start no fuel and no spark
- Will springs from a 2000 ex fit a '98 GSR?
- help me finish my swap and get rid of check engine light....
- help b16 not running
- diy a/f meter
- Ferrea Valves
- PT7 oil filters
- Books or publications for Bseries specific motors?
- Bad cam bearings in VTEC head?
- *** Urgent: Help with Progress rear swaybar install ***
- what is the difference between obd1 and 2 inj clips?
- For those with Tokico, or Koni shocks...
- squeeking at cold start up??
- CAR WONT START, 94 hatch with GSR motor
- will a h22 distributor fit a b16a1
- Injector harness adapters.
- b16 2nd gen tranny notchy
- STR Throttlebody/Skunk2 manifold Problem
- stock honda fuel maps
- question about air fuel gauges
- Datalogger to Record Sensor Inputs?
- What is this thing?
- Will aftermarket Cams make my H22 rev like a B18C1?
- pro shifted transmisions ??????
- wiring question...
- Oil Catch can Question?
- Need Help Engine Break In (please read)
- rebuilding engine q's
- Where can I get my cams regrinded?
- setting timming
- No resistance in clutch pedal....
- h23 or b20a rods in b18a
- 88 crx hf w\b16 converting back to D16A6...need help...
- DOHC ZC "Appears Rich"
- power steering parts
- okay my gf's car broke anyone can help? oil pan has hole in it?
- OBD2b engine harneess plug into OBD1 shock towers?
- '98 CTR (EK9) Brake rotor size??
- TECH SCHOOL
- '04 Civic Sedan - Strange tapping/slight squeak 5:38 PM 1/8/2004 Reply Edit
- 00 em1 ecu into 01 type r
- difference between b16b and b16a2 (99 si)
- cam gear bolt backed out?
- Installation of original camshafts Integra Type R on Civic SI (B16A2)
- Burning Oil
- Tranny grinds, WAIT!!! not anymore??
- Vaccume Dizzy
- Is it probable, to calculate RPM from speed, if you stay in the same gear?
- What makes a good intake?
- 84mm 12:1 je in sleeved b16?
- How should i go about cleaning this up myself(valves,IM,ports)?
- b16/itr intake manifold bolt pattern same as ls/b20?
- adjusting my cam gears help
- 2000 h22 injectors,will they work with 0bd1 setup?
- cam questions
- cam caps
- Carsound cat o2 bung sensor question
- is there a power steering relocation kit?
- JG cams
- fuel pump location?
- just to be safe about injector instal
- No Spark
- Fluid for JDM GSR Tranny
- header/exhaust problem with my 94gsr
- Look! my B20B VTEC dyno results.
- resistor help!
- Smog Check
- Tranny opinions
- can i swap my p2e with a p28??
- CEL CODES
- Removing a crx alternator from top, can i do it?
- turbo set up
- newbie.. need some ques answered
- HELP!!! arp rod bolts are they 8mm or 9mm i need b16
- Last minute questions...engine swap
- alarm kill start question
- Cusco Radiator cap type A or B?
- Need Immobilizer taken out. So my swap will run on OBD2B.
- Woodruff keys with str pro cam gears?
- getting code 22's on deceleration
- JG Edelbrock or SKUNK2 Intake Manifold
- B16 cable tranny
- Use water temp gauge for intake temp
- JG ENGINE DYNAMICS
- CRV Gear Ratios
- rev limit with built ls motor?
- check engine light
- VELOX PG-5S
- Cometic Head Gaskets.....
- Rebuilding a Brake Master Cyclinder ?
- ignition problem OR exhaust problem?? please help troubleshoot!!
- apexi n1 coilovers
- Is "5276.HO" a stock B16A2 rod?
- Does anyone know the the AEM FPR outlet size?
- ???-96 Civic Converter Question-???
- crappy start up on b16
- Analog Values from RPM and Map sensor. HW Datalogger completed, now doing software conversions
- Any help with adding a PCV system on a B20 bottom end.......
- compression ratio question
- O2 sensor problems
- how to prevent leaning out
- Hondata
- Violent Steering Wheel Twitch
- no name vs brand name strut/tie bars...any difference?
- are my injectors high or low impedence?
- Plugging oil squirters, what thread pitch?
- LOW Temp Reading
- Golden eagle cam gears
- Need advice on a LSVtech!!!!
- Here's a little something for all the "tuners" out there!
- 91 LS swap into 94 civic ex
- Intake manifold
- itb's and hondata
- how much power loss w/ 2.25" piping and stock muffler?
- N/A b18b build up?
- Throttle is really snappy. TPS? Don't know.
- d15b7 question
- Need to know if I need a part for J1 tranny?
- Can someone verify these ROTOR SIZES?
- B16B and Civic hatchback questions.
- ys1 with Quaife or b16 s1 w/ lsd and ls 5th
- basics
- question about nos pressure
- help with msd
- surging idle HELP!
- 11.4CR on a b18c5 inc jun3's + a 25shot of gas??
- good ls non vtec cams?
- Civic Fog Lights
- welding 2.0" > 2.5"
- head work on ls motor?
- injector clips,wiring. HELP
- good non vtec cams?
- HELP! H22a4 and Oil Control Jets!
- Auto transmission care
- crank pulley fell off while driving!! Belts went flying!!!!! Help
- best place online to buy oem parts?
- EM racing triangulated trunk floor bar,how are they?????
- lower torque mount compatibility?
- ANyone try a crv radiator in a civic (EG)?
- will a OBD I ecu work w/ an OBD 2 dizzy???
- Where can i get a TB WITH the sensors??
- Apex'i N1 Question
- deck height
- ABS locked and light comes on
- Nippon wheels
- Advance Timming with boost and still pre-ignite?
- Tire size?
- motor has no pcv valve is that posiable
- How important is tire balancing?
- FRONT A/C MOUNT
- altenator question
- P70 ?!?!?!?!? what is a P70 ECU?
- My radiator fan doesnt start but the she is good READ PLEASE ...
