View Full Version : Tech / Misc
- help me here i dont know what to do
- exaust recomendations! help me
- shunk 2 intake manifold ?
- V-tec Problems
- 16*7 rim, what size tire???????
- start up problem
- anyone pls d15b7 block d16z6 head and ecu ....sound good.?
- shifting is hard
- d16a6 cam - d16y8 cam - mini me question
- car wont start... need help
- d15b7 and jdm d15 vtec distributor the same???
- Dyno
- Will Civic / Accord OEM oil filter work on 98 GSR?
- b16 swap, how much?
- crank pulley nut size?
- what is involved
- Quick Fuel Filter ques?????????!!!!
- How does a proportioning valve work?
- Help with clutch install!
- Anyone running Greddy E manange?
- What size is the flywheel bolt for B series?
- Coolant reservoir
- Proportioning valve question...
- Who makes an ob2 to ob1 conversion
- Question about JDM B20B's
- PPL Post Dyno sheets of a N/A B16.
- Car starts, run for while, backfires and then stalls?!?!?!?!?!?!
- tech people i need ur help
- Valve seal?
- few questions on motor building
- Electrical Engineering tech help
- port and polish
- b16a2 in 94LS, i need help!
- head stud install
- TB coolant bypass and idle surge
- detonation at 5500 rpm
- stripping a block
- Opening Tranny
- N/a cam questions, want to make power to 9500 RPM
- Wiseco pistons valve relief?
- Does anyone know about this service that places like Pep Boys use to cleans out your fuel system?
- AEM EMS injector size?
- 82mm and OEM headgasket...
- Stroker B16 Build-up
- ITR vs CTR 5-lug conversions
- Tip on pre-ignition - dohc experience.
- Need help : Mugen airbox + Toda Cams Spec B
- new exhaust
- looking at a `93 Accord...have some questions
- header question
- SKunk Tuning questions
- Warming up bad for your car?
- Short shifter shortens life of tranny?
- i remember the old school... 'cause im a old fool..... j/k...
- żżżżżeg2 disc conversion..... just a quick question.....????ż
- Bouncy ride in my CRX - should I have trimmed the bumpstops??
- got a ticket for my tanabe exhaust.......would like to know a better one that is not as loud
- Accord Service manual....
- fuel pressure problem.
- anyway to check what kind of clutch i have?
- hydro pressure plate in a cable tranny
- Deck plate setups on ALL motor app
- Methanol for All-Motor applications
- can i hook up just a shift light on my car?
- So what did GE do about the sunken sleeves?
- duty cycle at redline (GSR)
- carbon fiber hood repair
- micro polishing and balancing the crank
- Where does this line Go? someone help
- my hatch 0WNED! me tonight...please help
- Common misconception about the B18A1 and the Gen 2 Teg's???
- bypassing clutch
- F-d up oil pump tech,
- 6 speed conversion?
- custom piping
- helppppppp wuts best wires n plus for my civic
- Good Books on Honda Stuff?
- r v-tec solenoids universal
- b16b vs. b18c5
- dings
- has anyone used their plam to datalog a tech edge wide band?
- D16Y8 cam gears suck
- b20vtec injector ?
- H23 in 96 teg (will wiring and computer be OK)?????????
- What are some LIGHT tires (searched)
- smogging jdm engines
- power lock malfunction
- oil pump specs? B16 versus GSR, Type R? any more pressure from the 1.8 pumps?
- b18a1 vs. b18b
- car's misfiring
- Oops! Accidentally touched jumper cables together while jump-starting my car..what's worst that can
- Valve Adjustment...clearances were way low?
- How to get 13" wheels over GSR brake rotors...?
- water pump replacement
- 1997 to 1990 Civic Parts Swap...
- 1 point more compression=about how much hp?
- help me please
- Question about a stainless steal header
- teg vs civic
- Excessive motor vibration - '90 Accord auto
- Help please ! Car wont start
- ITR Exhaust Manifold on Del Sol VTEC
- reusing Act pressure plate
- car shakes side to side help me out !!!!!
- Yay, we got featured on a site
- Shifter rattle... not hitting head shield!!
- can i run my autometer water temp guage from stock sending unit?
- Need someone with TEG helms......please
- removing the head off an LS
- Vafc problems
- DC5R pistons on B18 rods
- VTEC activation Switch ????
- Polish or paint valve cover.
- Wiring Fog Lights
- Is it safe to cover spark plug wires.
- sohc dyno graphs
- Help with Ignition problem
- help me answer this question about b16a2
- cams at TDC, distributor isnt
- opinion needed for head work...
- all motor lsvtec guys what have you spent on your setup
- pcd spacers
- Custom harness bar (need feed back)
- how do you remove PCV?
- LSD with Axle issues
- ITR Swaybar question??????? important buy or not????
- 10 millimeter T for oil gauge
- Aftermarket Retainers & Valve Srings
- .....> lets talk about affects of Boring the B16
- Completing An ITR Head and Need Resource?
- Foamy radiator fluid....oh my...
- Spoon Sports 1800 B16B Stroker Kit
- Throttle body on D16Y8
- Dumb mother fuckers at Honda + Me.....
- camber kit install/shops?
- is there a FAST way of taking off a pinstripe??
- When should my secondaries open?
- What kind of compression would these give me???
- cusco master cylinder brace
- Head gasket Q's
- Skunk2 Short Throw = Notchy crap
- Car temperature question.
- Can I connect a VAFC to these?
- Whats wrong with my car? No more 5th gear VTEC???
- tien upper pillow ball mounts?
- STRUTS??????
- apex ws damper kit
- corrugated tubing
- sound of vtec engagment
- does anyone think this will work? homemade fuse box idea
- installing a VAFC into a pr3 ecu obd0 b16a
- How To Retard My Timing??????
- Where to get flywheel lightened?
- jdm engines sensors
- b18c swap (need Help Please
- alright, im second guessing my setup hit me with some critiques
- Estimated WHP and 1/4mile,sorry im one of those people!!
- Assembly of the bottom end?
- What is the minimum size exhaust I should for my 5 speed 91 LS Teg?
- advanced timing MPG question (Just did it)
- What size drive for hand held ratchets?
- endyn bbs back up
- Identifying REAL JDM Visions *****PLEASE HELP, Pics Included******
- just came from the DYNO
- What are the best bulbs to get? Sylvania Silverstars
- What will ZC motor CRX run?
- Does it make a difference if you have the factury pulley or after market?
- Engine Cut off after touching a harness
- Blown head gasket?
- No timing mark... can i use TDC sensor that ECU reads?
- How can you tell its a real JDM ITR tranny?
- ITR down pipe
- i am having trouble w/ h22 wiring please help....URGENT!!!
- Bad distributor cause change in timing?
- please HELP ME!!
- Adjustable cam gear alignment key?
- a20a(or a20a3) block with b16 head.
- How to calibrate the TPS and idle speed on my 98 ITR
- Cut wiring harness solutions??????????/
- Rus
- LS v-tec B16 head 92 block
- NEED some info and help ...
- HEADERS: wheres the results that they all promised??!!!!
- Question about Dynomax Magnum Glasspack Muffler as resonator
- 1998-01 Integra owners check within
- does a GSR have STRONGER VTEC?
- Civic Stuff for sale Look
- Fuel pump ? - What cars will this work on?
- Integra 90-93 axles, abs vs non-abs
- Honda engine swap question
- Intermediate Drive Shaft Bolts for B16A
- carbon fiber lip install
- modding an second gen civic...81
- B20Z /w B16a head - ALL stock, reliable if only revving to 7kRPM?
- o2 sensor question
- b16a revs only until 7000rpms
- Port/polish head...a hype?
- Injector Resistor HELP
- a6 head on y7, OBD-0 ecu?
- WIRING???????
- Overheated engine
- Black Smoke in Idle!!!!!!!
- turbo LS or NA H22
- Have I exceeded duty cycle on 240cc's?
- Sound of Tanabe racing medallion exhaust?
- Cam identification...
- where can i can low cost factory dealer honda parts?
- Advice on passing inspection
- powertrain death. need diagnostic help!
- adjustments needed for gsr girdle on lsvtec
- Idle problem at cold temps on d16z6
- rear disc brake conversion on EG2.......
- Piston to Valve Contact?
- 1.5L engine question
- VAFC Hack on a JRSC @ 6psi w/440cc Injectors?
- Are all b series tranny cases the same?
- TE-37 question
- Final Drive in S1/J1
- Skunk2 Camber
- 30-1000 AEM EMS in obd1 crx/b16a
- header, traditional vs. crazy intestine style
- my DIY catchcan...
- Need answer within the next 5 minutes..... Block Weight
- Skunk 2 came gears or AEM fuel rail?
- SOHC internals. best?
- the title saysrocker ratio of vtec b series head?
- How long to give clutch to break in???
- titanium engine components?
- i have a ringing sound
- is my car running rich or what is the problem?
- too late for turbo?
- need help exuast stuff.
- stuff for sale
- torque spec for 97 ls connecting rods????
- whats the difference?
- spoon wheel size
- does anybody know?
- cams & Compression ratio
- Honing ?? CTR pistons to be added to B16a2
- need help choosing new engine
- engine squeeling
- Im running WAAAAYY too rich. Stock engine. Poor performance, and rough running need help!
- Type One Racing Battery
- Will an ODB1 Converted car work fine with an ITR Intake Manifold and Throttle Body?
- Why are GSR OBD1 ECU's way more in price than OBD2 ECU?
- Wheel hub removal / replacement
- buy back parts???
- defi wiring ?
- black sensor on itr throttle body?
- H22 to Del Sol Swap query
