brake and alignment q's...
Old Nov 28, 2003 | 12:55 PM
Powered by Honda's Avatar
Default brake and alignment q's...
Alright, I have another question I hope someone can confirm for me. After swapping my front ek knuckles for gsr ones, I've noticed really bad negative camber as in: /-------\ But from most of the archived stuff I've been reading, people have said that swapping to integra knuckles usually results in positive camber. So can anyone confirm which actually happened to them after the swap on their EK's (negative or positive)? Or is it just inconsistent?
Finally, I was wondering how or if you can visually tell if you have bad caster or toe, I'm not well versed on these two concepts, so any info would be awesome, thanks!
Old Nov 28, 2003 | 02:59 PM
dirty_d_cx's Avatar
Default Re: brake and alignment q's... (SoichiroH)
Modified by dirty_d_cx at 7:52 PM 11/28/2003
Old Nov 28, 2003 | 06:17 PM
doublejz's Avatar
for your tow, just get a measuring tape measure the distance on the inside of the front of the tires, and then measure the distance on the inside of the back of the tires. they should be the same if your toe is right.
ek3 noob
Suspension & Brakes
14
May 3, 2012 07:16 AM
sayanything
Suspension & Brakes
Nov 11, 2009 09:54 PM
SleeperGSR
13
Jul 25, 2009 03:58 PM
alex_s817
Apr 17, 2006 07:51 PM
Shmeek
13
Jul 24, 2002 12:40 PM
