View Full Version : Tech / Misc
- Accord H22 AXLES?
- Dry Sump
- What hydro tranny is = to cable YS1 LSD
- vafc
- d15b shiftlink
- vtec problems HELP PLEASE!!!!
- car dying
- "I NEED HELP"
- b16 valve adjustment
- Need help! 00si 75k miles boost or N/A
- new tranny, need help
- What oil are you running?
- BURNT VALVES running open header??????
- car troubles...axle
- 4 wire O2; identify each wire? Help!
- Install diagram?
- Where to find Tuner/aftermarket bin files?
- Do all B series hydo trannies use the same synchros???
- San Diego Help! Camshaft?
- carbon buildup on piston dome, can it be removed?
- problem with lower rad hose leaking
- fpr?
- need help with tranmission
- Hondata Question
- Tuning
- can't find thread about adjusting screw inside IACV.....please HELP! (H22a)
- overheating issue
- knew way to fix a squeaky alternator belt
- temp guage not working right.
- DOHC VTEC - Oil Control Orifice - wtf does it do?
- big problem need help
- F/S honda spec scanner
- Redoing Head; any good resource links?
- does mugen cooling setup work?
- supercharge or turbo?
- Which ARP head studs for a D16a6
- City-Speed B18C5 Heads....
- who rebuilds cusco's
- HELP CAR WINT TURN OVER!!!
- NEED HELP!! ITR wing on a 99 SI???
- Honda/McClaren?
- Pacesetter ... any good?
- Engine hoist rental (maybe stand too)
- Identify this LSD: KAAZ?
- need a favor
- ACL Bearings Cross Compatability
- Timing belt replacement
- cold start problem
- what is this Relay?......Civic 96
- Looking for cable and hydro gear ratio's for B18 & B16
- Using stock 94 Integra seat brackets, rails, and sliders for Bride seats?
- ngk v-power vs. bkr7e
- Different Colored Wires in OBD conversion..
- Question about Eagle rods....
- tuning help
- coolant recycling
- Super Charger VS. Turbo Charger
- Couple Qu's about the EGT and Fan switchs
- 2000 Civic Si Huge Power Loss
- Custom Clutch
- GSR Tranny Problem
- wrx fuel injectors in h22
- B16 & B18 Q
- Anyone experienced these wideband sensors
- Custom exhaust sizing?
- What is this black crud on Cylinder Head?
- What Do These Have in Common?
- shipping weight of B16 bottom end...
- ARP Rod Bolts and Bearings?
- bosch platnum plugs????
- Car losing power?
- Will a b17tranny fit a b20 block?
- thanks but.. OBD 1 VS. OBD 2 injectors
- Proven HP gain from Air Intake?
- car takes for ever to start...running out of ideas
- h22a big problem please help
- Want to turbo my snowmobile
- Rings?
- combustion chamber volume, on b16????????????????????????
- hondata s200 help!
- 3 bar map question
- taillight
- New rebuild burning oil, 2 spark plugs different colors then other 2.
- MSD 2 Step for a msd sci 6300
- few questions about knock sensors ECU´s and harness
- ALIGNMENT QUESTIONS
- Adjusting idle
- REPLACING HOSES PLEASE HELP
- will a gsr 96+ obd2 oil pump fit a 95 obdI gsr block
- F20B Pistons & Rods
- Removing Cruise Control
- what is a missing link........where does it go
- phoenix AZ smog
- Data logging and meters…
- Direct Port Nitrous HELP
- REASONS FOR A DROP IN VACCUM AT IDLE?? ALREADY SEARCHED. PLEASE HELPPPPPPPPP
- Motec Wideband
- need electrical help.....
- Which is Better: Block Guard or Girdle?!?!?
- Car won't move!! Please Help!!
- Ecu chipping!!!
- Prostreet tuning
- D - series OBD 1 vs. OBD 2 injectors
- is this a good desoldering/soldering station?
- MSD Ignition w/ Engine Management
- magnaflow test-pipe o2 sensor question
- timing belt covers. Im one of the few who beleives honda put them there for a reason so please respo
- cam timing y8....need a QUICK answer plz!!
- ----->Brakes FAILED....almost hit a child!!!!
- power steering
- oil leak
- ceramic HEADers??
- clutch problem??
- Integra Rear Caliper part question...
- Help - Eng. Block Heater
- A/C compressor problem/question
- looking for ideal oil pressure?
- d15b7 block with y8 head swap....help please
- d vs b series vtec solenoid
- I'm running out of ideas
- Illumination for tach and guage cluster?
- oil press. gauge ques.
- ignition wire order, 96 accord exr
- Will 96 Ls axles Fit On 95 GSR tranny?!?!?
- LSD?? how do i know? if i have it ?
- Axle Help?
- Oxygen sensor- NTK to bosch cross.
- B16B CARB legal?
- LMAS obd1 gsr lmas Vs. itr lmas
- GSR Swap with wicked bad gas mileage...whats wrong? IDEAS?
- Threw a code.....
- Shift Points
- password powerchamber intake for meh gsr?
- D series fix up
- tape on o2 sensor wiring
- Running One oversized piston?
- what's up with HT???
- mini me swap parts....
- B20 Vtec Turbo Problem
- kinda dumb question on WBo2 bung placement
- header install
- HELP ME! CRX smells of GAS???
- help plz! GSR head on b16A3 HUGE problem...
- Transmission question........
- Liquid Filled Fuel Pressure Gauge... Just Drill and Tap Fuel Rail?
- B&M FP Gauge Problems... dont understand
- OBD2 B18b head on OBD0 b18a block (any problems with sensors transferring over)?
- Great exhaust read!!
- 00 si tranny fit jdm b16a?
- What Size Socket for AEBS Headstuds?
- can I use a 92 o2 sensor to replace my worn 2000 cat o2 sensor
- rod bearing cap. help will gsr fit on ls
- 9 code on zc engine help
- Will a 92-95 rear lower tie bar fit a 00 civic si?
- help with rear alignment
- ABOUT MY GAS PROBLEM
- Tucking wires on Gen3 integra
- Oil filter thread size on a D16z6
- Running Rich
- what causes high HC (PPM) on emission levels?
- b16A2 PnP
- car runs best when 85% warmed up.. ???
- Quesetion About Hondata and Other Systems
- torquing down nuts and bolts
- Crank Pulley is wobbly..
- how accurate is the wideband connected to tailpipe? (dyno'd today)
- H22 civic NOx help
- the threads in the block were the oil jet bolts go are shriped what can i do
- So a put a fuel pressure guage in...
- Where to get 4 pin connector for hondata?
- How much to torque HKS 3mm headgasket?
- Has anyone ever...?
- Master Seal Kit
- B16A & B18A same bore?
- Check out the Uberdata p28 setup for datalogging
- b18b specs needed
- JDM Y21 tranny..add ITR LSD and Ls 5th gear.Possible?
- accord electrical problems!!!!
- how to install my pivot digial tacho lamp???
- '92 trans or cv?
- Why do you need vacum canister?
- Auto to manual conversion in my 94 LS!
- OBD2B distributor conversion to OBD1 dizzy almost finished but ran into problem
- **** messy soldering job: does it work? *************
- GE head gasket for ls vtec
- 95 si 30/40 proportioning valve ok to use for teg front & rear disc swap?
- A/C gets warm when rpm's are low. what's the problem. the compressor?
- boring b18c5
- catalytic converter o2 sensor problem
- Vacuum hose vs. breather
- Code 22 what to look for
- Help >> oil pump discussion
- block guard
- De-socketing an ECU
- MSD BTM Wiring diagram for 94 Accord.
- b18c/built head fuel pressure setting!?
- Cell?... please help I am losing my mind...
- Clutch/flywheel differences
- B17 in EK Major problem help...
- Problems connecting Autometer A/F gauge to AEM UEGO
- help please...
- Need your Opinions on FPRs
- b17 headgasket ?
- 94-97 Integra ABS REMOVAL, help!
- JDM B16 into USDM Si question
- DPFI fuel injectors???
- Electrical + Harness Help:
- HELP check engine light on 92 eg from b18b1 swap dealing with TPS
- 99-00 civic ex obd2(b) engine harness on a 98 obd(a) civic?
- Anyone using SPEC clutch setup ?
- Hondata Playback Question
- bad tranny.....??ls diff and gsr diff interchangeable..
- Is cleaning up an intake manifold even worth it?
- difference in two moroso oil pans?
- gsr vs rs brake booster and master cylinder
- idot shop guys put slotted rotors in wrong direction?
- Ecu questions....pr3-pw0 automatic.... for use with sohc mini me vtec
- Oil leaking into sparkplugs.. Help please
- What head gasket to use? LS VTEC 81.5mm
- Quaife gear kit for the P20 B16 gear box
- Help w/ Hondata S200 install onto a 00' Accord F23 manual tranny w/ boost.
- manual TO auto p28, possible?
- P61 Chipped into a 93Si
- Help me diagnosis my problems.. (valve & axle related)
- 'void if removed' plug on my b16 block.. wtf?
- Info on JG cams in LS? Pics? how to tell? Website?
- changing to a thinner head gasket
- HELP!!!! CHECK ENGINE PROBLEM CANT FIGURE OUT
- civic HB 96 doors
- Darton MIDs VS regular sleeves
- Question about aftermarket ZC pistons...
- Hondata ECU Code ?
- Y cant you used B18c or B16a headgasket on ls/vtec?
- no start has spark and fuel
- scape in head above valve, normal? 1 pic inside
- weird transmission or clutch problem in 92 teg please help
- Which head to I have?
- hondata gurus
- brake problem, pedal drops to floor
- crx si disc brake to civic
- anyone have an LS with a gsr tranny?
- H22 Tranny Talk
- Can u wire up an obd2 dizzy to work on obd1 motor i have the clips
- hondas plug tube seals, on back order!
- What to rebuild my b18b
- I have oil presure....
- Please someone help!!
- leading edge syn oil
- ls tranny
