View Full Version : Tech / Misc
- R/H CP-035...What does forged mean?
- Comptech Exhaust Silencer: Look & Effect?
- Strange Noises and Thuds
- To anyone running a Y8 head...
- Anyone ever try this?
- lsd?
- Piston and valve interference
- is it true???
- honda gurus, 'need a lil help
- When is a fuel pump bad?
- Looking for tuners/speedshops in IN/KY area!!
- I have a starting problem and need some help please.
- what are the specs of skunk2 stage 2 cams?
- fmu+440cc injectors = ???
- Fuel Injection Performance Kits
- what is needed for a B18C1 to rev to 8400rpm like the B18C5
- rethread?
- dyno tuning
- need too know clearence really quick "rods"
- hondata
- Strut bar clearance with skunk2 IM and GSR throttle cable... please look
- lsd for b16a2
- damaged JDM ITR longblock
- anyone ever heard of the brand : Top Speed? (and comments on my exhaust setup)
- ITR valve spring q's.
- putting a b20vtec in a G2 LS integra
- front teg upgrade for ek
- quick radiator hose help PLZ!!!
- quick injector question.....
- vx or hx wheels
- integra coil problem
- Got a D16A1 for a good price..
- '02 Civic Si - Bang for buck mods??????
- ls in crx questions
- directions
- Custom headers from AN-R. Anyone?
- 97 ITR ignition in 00 LS.... HELP
- speedometer not right??help
- aftermarket parts
- Car Wont Start!!! No Idea what it is??
- Dyno's in West chester , PA
- Tie Bars - What is their function?
- b16 vs b18 headgasket
- iring harness question
- 1/4 mile....lsd or 4.7 final drive?
- Fuel Pressure Regulator and Cam gears
- New Flywheel throwin CEL 14 what's up?
- Anyone using this (QTEC)
- Air/Fuel Ratio to V-AFC Settings
- cams-torque vs hp
- removing decals..
- camber kit installation?
- Ericks Racing setup??
- 1991 Accord A/C Problem
- ARP Head stud kit for Mini-me swap?
- Accord Tranny??!!??
- Zeal B2
- code 3, what to do?
- b16 bogging, need help!
- timing problem
- SiR2 B16A into 99 EK. Need some help.
- What to choose what to choose
- ANyone have Integra Type R springs on their 6th Gen Civic?
- Conversion to disc problems
- Sites w/ step by step instructions to install B18C1 in 5th gen. h/b??
- code 7 when coasting in 4th or 5th...any thoughts?
- Is this worth the investment?
- B18C crank
- DYNO tuning with VAFC
- Major bogging
- Are JDM engine swaps legal in California?
- SX fuel pressure regulator
- Hydro VSS compatible on a Cable tranny?
- 2000 Prelude Wheels On A 2000 Civic
- ideling bad when car is warmed up?
- VTEC CODE!!!Pleas help
- What aftermarket rods fit on to OEM honda pistons?
- crv (b20) ecu???
- Popping while on the spray...
- what next? headwork or big bore?
- All motor vs f/i
- Problems/ new discoveries on Y8 Mini-Me swap, need advice!
- which clutch?
- wont tart warm?
- Replacing synchros on JDM Y1 cable tranny.... what synchros? anybody have any?
- zc fouling plugs !!! HELP
- Newbie...... SOHC cam adjustments
- Overheating Issues...
- cams for A 2k1 civic ex
- Fuel/Ignition problems, need EXPERIENCED help
- ? on milling my head...
- CTR camshaft specs - open/close degrees
- car died on the highway
- Not getting a Spark
- dying at idle
- What is wrong with my clutch/transmission??
- Cheap header???
- LS.Vtec what head bolts?
- H22 will not idle
- Gas from 711.
- b20 vtec
- do i have to cahnge the ex manifold gasket?
- stroke and cam duration explaination
- how to: lights.
- oil jet check up
- OEM ECM options for better fuel delivery.
- Timing belt slipped!!
- Excessive vibration with new engine...
- ICU interchangeability?
- code 4 b16 crx
- Final drive gear questions
- Oil leak-exhaust manifold..???
- Code 19, b16 in crx
- stumbles in 1st gear
- Primary 02 sensor...how do I check it?
- cranking compression h22 w/ wiseco 8.8 turbo pistons
- How Do You Guys Mount Your Blocks to Engine Stands?
- spring dimensions
- wiring h22 crx
- GSR engine code
- Apex'i s-itc wiring diagram for ef9, 1st gen b16, pr3?
- Question regarding brake booster/MC
- looking to build a sick b18 to drop into 97 gsr
- Vafc Problem
- Pwr Steering pump rebuild
- anyone ever went throttle by wire?
- OBD what????
- Decided to take the plunge into "sleeperness", good exhaust?
- 92 civic clutch
- Intake manifolds, JG, Skunk2 and Type R
- HELP RUFF ass idle
- ???car wont start ???
- Good Automotive?
- Yay! Girlfriends dad got his firearms licesnce renewed!
- where does the wire that grounds the thermostat end up?
- Camber Question!
- blocked EGR
- alternator
- help reading plugs
- If timing belt breaks...
- Need Urgent Help for Cams Problems..
- Question about factory foglights.
- Adjustable brake proportioning valve Q's
- Stroker vs larger bore: food for thought....
- Converting
- B18B = B18C (Clutch Install)?
- B18c & b16a obd1 dist. same?
- Dope video! prelude smoking a...
- should the rear be higher or lower?
- vafc tuning q's
- LSD or NOT ??
- Who Should tune my spec b's EAST COAST
- Is a VAFC worth it??
- Cel Code
- Centerforce I clutch
- help
- 4000rpm at 72 mph...?
- cel goes away
- medium grind cams and N20
- How to check trouble codes on 97 GSR
- rebuilt caliper question
- pct VS p2t ECUs
- Noise from transmission after clutch install
- 94 Accord AT F22 to H22a MT
- HELP! CEL code 54?!?!
- important throttle cable question?
- Help!!! Engine problems...
- Inefficientcy of gasoline engines
- Water in cylinders..
- bad bad bad situation
- question about head?
- Maintence Light On
- Help! Car wont start
- b18 's
- torque specs for crower rods and main caps
- need info on jdm d15.
- help
- Guage Cluster "zero out" - HOW?
- flushing the radiator
- Fix It Ticket: What does he mean "Heated Springs"?
- Tach jumps and car skips???
- engine wiring harness question
- What is the best motor to put in a 94 Hatch?
- D16Y8 with ZEX cam and ZEX nitrous??????
- OBD2 code 92. i know what it is but?
- Integra Alternator
- icm question
- new replacement B18C5 from honda, oil change question
- how much torque for rods bearings caps on b18a1?
- My 99'
- Low TPS Voltage???
- Direct bolt-up Cats?
- koni specials (reds)
- Pads wearind down unevenly
- LS/VTEC suggested safe redline?
- Cam Gears need to be set to 0 before valve adjustment?
- AWD civic???
- possible rethread of block need advice por favor!!
- care of motor as far as driving or trailer to track for long trips
- Change Timing belt & clutch -- Hoist the engine out?
- One or two layer stock haedgasket ?????
- wanna turbo my b18c6 but its smoking badly
- B20 Headgasket on B18 bottom end???LS/VTEC
- gsr or type r
- I have a b17 motor can I...
- blowby
- Nos system
- B Series Intake Manifolds
- Who has a b16 swap?
- How to fix leaky oil drain plug???
- Suspension Upgrade
- Sprint Extreme Springs
- breaking axels
- anyone been paying attention to JR???
- how do u get the front rotor off an accord?
- starting problems
- SPEC-RM Coilovers....... What do you think?
- Which lug nut for the ARP extended stud???
- A bad bad Day..........
- LSD questions...please read!
- N20 bottle question...
- Hondata or Skunk 2???
- Starter is dead I think
- ALL motor vs. turbo
- ARP head studs for a b17a
- B18c1 to 2.0l...worth it???
- Header
- Engine apart, have question..
- Q's spoon cams in b16a
- rev limiter problem
- Roll Bars on a 93 DX Hatch....
- Running ZEX cam with stock springs?
- Skunk2 Stage 2 cams in my B18C
- What should a 95Ls motor have for cylinder to cylinder compression?
- Why doesnt my JDM GSR engine have a VTEC pressure switch...?
- rebuilding axles
- Rod bearings...
- alignment
- HELP Head gasket again???
- cat question
- LS vtec, what to do about knock sensor?
- ITR oil/water pump in 1st gen b16
- everything but start
- bigger brake booster...
- help...fuel rail
- cigarette light problem
- ls/vtec?
- car dying!
- Valve spring help please.
- Best N20 system?
